path: root/drivers/net/wireless/hostap/hostap_cs.c
2008-08-31pcmcia: remove unused argument to pcmcia_parse_tuple()Dominik Brodowski
Since we're just parsing the tuple being passed to this function, we don't need any device-specific information. Also, remove the call to pcmcia_validate_cis() from pcmciamtd.c, since it is already called by the PCMCIA core. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-23pcmcia: deprecate CS_SUCCESSDominik Brodowski
Instead of using own error or success codes, the PCMCIA code should rely on the generic return values. Therefore, replace all occurrences of CS_SUCCESS with 0. CC: netdev@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-23pcmcia: pcmcia_config_loop() improvement by passing vccDominik Brodowski
By passing the current Vcc setting to the pcmcia_config_loop callback function, we can remove pcmcia_get_configuration_info() calls from many drivers. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-23pcmcia: pcmcia_config_loop() default CIS entry handlingDominik Brodowski
Many drivers use the default CIS entry within their pcmcia_config_loop() callback function. Therefore, factor the default CIS entry handling out. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-23pcmcia: pcmcia_config_loop() ConfigIndex unificationDominik Brodowski
Almost all drivers set p_dev->conf.ConfigIndex to cfg->index in the pcmcia_config_loop() callback function. Therefore, factor it out. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-23pcmcia: use pcmcia_loop_config in net pcmcia driversDominik Brodowski
Use the config loop helper in (some) net pcmcia drivers. CC: netdev@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-07-07hostap_cs: correct poor NULL checks in suspend/resume routinesJohn W. Linville
This corrects this kernel.org bug: http://bugzilla.kernel.org/show_bug.cgi?id=9701 Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-30hostap: fix sparse warningsPavel Roskin
Rewrite AID calculation in handle_pspoll() to avoid truncating bits. Make hostap_80211_header_parse() static, don't export it. Avoid shadowing variables. Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-20hostap_cs: add ID for Conceptronic CON11CProPavel Roskin
Reported by Santiago Garcia Mantinan <hostap@manty.net> Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-31Add another Prism2 card to hostapMarcin Juszkiewicz
Card reported by Ångström user: http://bugs.openembedded.net/show_bug.cgi?id=3236 Socket 1: product info: "Wireless LAN", "11Mbps PC Card", "Version 01.02", "" manfid: 0x0156, 0x0002 function: 6 (network) Signed-off-by: Marcin Juszkiewicz <openembedded@haerwu.biz> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28hostap_cs: don't match revisions in presense of the MAC chip namePavel Roskin
If the third PCMCIA ID string specifies the MAC chip, the fourth ID string doesn't need to be matched. Even if it's different, it will be compatible with the driver. This ensures that other different revisions of the card will be supported. Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] Add Linksys card to HostAP driverMarcin Juszkiewicz
Socket 1: product info: "The Linksys Group, Inc.", "Wireless Network CF Card", "ISL37300P", "RevA" manfid: 0x0274, 0x3301 Signed-off-by: Marcin Juszkiewicz <openembedded@haerwu.biz> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] hostap_cs: Add device ID for Telekom T-Sinus 111cardStefan Lippers-Hollmann
This adds the PCMCIA device ID for the Deutsche Telekom T-Sinus 111card to hostap_cs. $ /sbin/lspcmcia -v [...] Socket 0 Device 0: [hostap_cs] (bus ID: 0.0) Configuration: state: on Product Name: T-Sinus 111card 2.0.0 Identification: manf_id: 0x01bf card_id: 0x3301 function: 6 (network) prod_id(1): "T-Sinus" (0x8c389dc1) prod_id(2): "111card" (0x6a23ac17) prod_id(3): --- (---) prod_id(4): "2.0.0" (0x92b9effb) Signed-off-by: Stefan Lippers-Hollmann <s.l-h@gmx.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] dev->priv to netdev_priv(dev), for drivers/net/wirelessYoann Padioleau
Replacing accesses to dev->priv to netdev_priv(dev). The replacment is safe when netdev_priv is used to access a private structure that is right next to the net_device structure in memory. Cf http://groups.google.com/group/comp.os.linux.development.system/browse_thread/thread/de19321bcd94dbb8/0d74a4adcd6177bd This is the case when the net_device structure was allocated with a call to alloc_netdev or one of its derivative. Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: mcgrof@gmail.com Cc: linux-wireless@vger.kernel.org Cc: akpm@linux-foundation.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-07-08[PATCH] hostap: Remove driver version numberJouni Malinen
The driver version number has not been updated since the driver was included in the main kernel tree and there is no plan on updating this in the future either. At this point, the only correct way to refer to the version is to use the kernel version. The 0.4.4 version is confusing since there are external version with higher version number even though they are not actually any newer than the in-tree version. Let's get rid of the version number in the kernel tree in order to avoid this kind of confusion. Signed-off-by: Jouni Malinen <j@w1.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-04-28[PATCH] hostap_cs: support ADLINK 345 CFMarcin Juszkiewicz
Add ADLINK 345 CF card into hostap_cs product info: "ADLINK 345 CF" manfid 0xd601, 0x0005 Signed-off-by: Marcin Juszkiewicz <openembedded@hrw.one.pl> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-04-28[PATCH] Update my email address from jkmaline@cc.hut.fi to j@w1.fiJouni Malinen
After 13 years of use, it looks like my email address is finally going to disappear. While this is likely to drop the amount of incoming spam greatly ;-), it may also affect more appropriate messages, so let's update my email address in various places. In addition, Host AP mailing list is subscribers-only and linux-wireless can also be used for discussing issues related to this driver which is now shown in MAINTAINERS. Signed-off-by: Jouni Malinen <j@w1.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-04-28[PATCH] hostap: Add D-Link DWL-650 Rev. P1 product idJouni Malinen
It looks like some of the PC Card manfid/product strings were lost when Host AP driver was converted to use PCMCIA_DEVICE_* helpers. This patch adds back D-Link DWL-650 Rev. P1 using the same product ID string match as the pcmcia-cs/cardmgr configuration used before. Signed-off-by: Jouni Malinen <jkmaline@cc.hut.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-12-07Merge branch 'upstream' of ↵Jeff Garzik
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 into upstream Conflicts: drivers/net/wireless/zd1211rw/zd_mac.h net/ieee80211/softmac/ieee80211softmac_assoc.c
2006-12-05[PATCH] hostap: replace kmalloc+memset with kzallocYan Burman
Replace kmalloc+memset with kzalloc Signed-off-by: Yan Burman <burman.yan@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-12-04[PATCH] pcmcia: conf.ConfigBase and conf.Present consolidationDominik Brodowski
struct pcmcia_device *p_dev->conf.ConfigBase and .Present are set in almost all PCMICA driver right at the beginning, using the same calls but slightly different implementations. Unfiy this in the PCMCIA core. Includes a small bugfix ("drivers/net/pcmcia/xirc2ps_cs.c: remove unused label") from and Signed-off-by Adrian Bunk <bunk@stusta.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-12-04[PATCH] pcmcia: remove manf_id and card_id indirectionDominik Brodowski
As we read out the manufactor and card_id from the PCMCIA device in the PCMCIA core, and device drivers can access those reliably in struct pcmcia_device's fields manf_id and card_id, remove additional (and partly broken) manf_id and card_id detection logic from PCMCIA device drivers. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-10-25[PATCH] pcmcia: add more IDs to hostap_cs.cDominik Brodowski
As a replacement for the broad manufactor/card ID match we commented out because of conflicts with pcnet_cs, add two product ID matches. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-09-11[PATCH] hostap_cs: added support for Proxim Harmony PCI W-Lan cardChristian Steineck
hostap_cs driver - added support for Proxim Harmony PCI W-Lan Card (uses pd6729 based pcmcia2pci bridge) Signed-off-by: Christian Steineck <memphis@machzwo.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-06-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: Remove obsolete #include <linux/config.h> remove obsolete swsusp_encrypt arch/arm26/Kconfig typos Documentation/IPMI typos Kconfig: Typos in net/sched/Kconfig v9fs: do not include linux/version.h Documentation/DocBook/mtdnand.tmpl: typo fixes typo fixes: specfic -> specific typo fixes in Documentation/networking/pktgen.txt typo fixes: occuring -> occurring typo fixes: infomation -> information typo fixes: disadvantadge -> disadvantage typo fixes: aquire -> acquire typo fixes: mecanism -> mechanism typo fixes: bandwith -> bandwidth fix a typo in the RTC_CLASS help text smb is no longer maintained Manually merged trivial conflict in arch/um/kernel/vmlinux.lds.S
2006-06-30[PATCH] pcmcia: hostap_cs.c - 0xc00f,0x0000 conflicts with pcnet_csKomuro
Comment out the ID 0xc00f,0x0000 in hostap_cs.c, as it conflicts with the pcnet_cs driver. Signed-off-by: komurojun-mbn@nifty.com Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-05-22[PATCH] hostap: new pcmcia IDsMarcin Juszkiewicz
Add two Prism cards to hostap_cs driver. product info: "Pretec", "CompactWLAN Card 802.11b", "2.5" manfid: 0x0156, 0x0002 product info: "U.S. Robotics", "IEEE 802.11b PC-CARD", "Version 01.02", "" manfid: 0x0156, 0x0002 Signed-off-by: Marcin Juszkiewicz <openembedded@hrw.one.pl> Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-03-31[PATCH] pcmcia: convert DEV_OK to pcmcia_dev_presentDominik Brodowski
Instead of the DEV_OK macro, drivers should use pcmcia_dev_present(). Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: use bitfield instead of p_state and stateDominik Brodowski
Instead of the two status values struct pcmcia_device->p_state and state, use descriptive bitfields. Most value-checking in drivers was invalid, as the core now only calls the ->remove() (a.k.a. detach) function in case the attachement _and_ configuration was successful. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: add return value to _config() functionsDominik Brodowski
Most of the driver initialization isn't done in the .probe function, but in the internal _config() functions. Make them return a value, so that .probe can properly report whether the probing of the device succeeded or not. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: remove dev_link_t and client_handle_t indirectionDominik Brodowski
dev_link_t * and client_handle_t both mean struct pcmcai_device * by now. Therefore, remove all such indirections. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: embed dev_link_t into struct pcmcia_deviceDominik Brodowski
Embed dev_link_t into struct pcmcia_device(), as they basically address the same entity. The actual contents of dev_link_t will be cleaned up step by step. This patch includes a bugfix from and signed-off-by Andrew Morton. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: remove unneeded Vcc pseudo settingDominik Brodowski
As we do not allow setting Vcc in the pcmcia core, and Vpp1 and Vpp2 can only be set to the same value, a lot of code can be streamlined. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: default suspend and resume handlingDominik Brodowski
In all but one case, the suspend and resume functions of PCMCIA drivers contain mostly of calls to pcmcia_release_configuration() and pcmcia_request_configuration(). Therefore, move this code out of the drivers and into the core. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-31[PATCH] pcmcia: add pcmcia_disable_deviceDominik Brodowski
pcmcia_disable_device(struct pcmcia_device *p_dev) performs the necessary cleanups upon device or driver removal: it calls the appropriate pcmcia_release_* functions, and can replace (most) of the current drivers' _release() functions. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-03-23[PATCH] hostap: Fix double free in prism2_config() error pathEugene Teo
The Coverity checker (CID: 930) spotted this double free on error path (allocation failure). Do not free these here since generic error path will take care of this. Signed-off-by: Eugene Teo <eugene.teo@eugeneteo.net> Signed-off-by: Jouni Malinen <jkmaline@cc.hut.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-03-01[PATCH] pcmcia: avoid binding hostap_cs to Orinoco cardsPavel Roskin
Don't just use cards with PCMCIA ID 0x0156, 0x0002. Make sure that the vendor string is "Intersil" or "INTERSIL" Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-06[PATCH] pcmcia: unify attach, EVENT_CARD_INSERTION handlers into one probe ↵Dominik Brodowski
callback Unify the EVENT_CARD_INSERTION and "attach" callbacks to one unified probe() callback. As all in-kernel drivers are changed to this new callback, there will be no temporary backwards-compatibility. Inside a probe() function, each driver _must_ set struct pcmcia_device *p_dev->instance and instance->handle correctly. With these patches, the basic driver interface for 16-bit PCMCIA drivers now has the classic four callbacks known also from other buses: int (*probe) (struct pcmcia_device *dev); void (*remove) (struct pcmcia_device *dev); int (*suspend) (struct pcmcia_device *dev); int (*resume) (struct pcmcia_device *dev); Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-06[PATCH] pcmcia: remove dev_list from driversDominik Brodowski
The linked list of devices managed by each PCMCIA driver is, in very most cases, unused. Therefore, remove it from many drivers. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-06[PATCH] pcmcia: unify detach, REMOVAL_EVENT handlers into one remove callbackDominik Brodowski
Unify the "detach" and REMOVAL_EVENT handlers to one "remove" function. Old functionality is preserved, for the moment. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-01-05[PATCH] pcmcia: new suspend coreDominik Brodowski
Move the suspend and resume methods out of the event handler, and into special functions. Also use these functions for pre- and post-reset, as almost all drivers already do, and the remaining ones can easily be converted. Bugfix to include/pcmcia/ds.c Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2005-10-03[PATCH] hostap: Do not free local->hw_priv before unregistering netdevJouni Malinen
local->hw_priv was being freed and set to NULL just before calling prism2_free_local_data(). However, this may expose a race condition in which something ends up trying to use hw_priv during shutdown. I haven't noticed this happening, but better be safe than sorry, so let's postpone hw_priv freeing to happen only after prism2_free_local_data() has returned. Signed-off-by: Jouni Malinen <jkmaline@cc.hut.fi> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-03[PATCH] hostap: Remove hw specific dev_open/close handlersJouni Malinen
Host AP driver used hardware model specific dev_open/close handlers that were called on dev_open/close if the hardware driver had registered the handler. These were only used for hostap_cs and only for tracking whether any of the netdevs were UP. This information is already available from local->num_dev_open, so there is not need for the special open/close handler. Let's get rid of these handlers. In addition to cleaning up the code, this fixes a module refcounting issue for hostap_cs where ejecting the card while any of the netdevs were open did not decrement refcount properly. Signed-off-by: Jouni Malinen <jkmaline@cc.hut.fi> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-31[PATCH] hostap: Fix null pointer dereference in prism2_pccard_card_present()Jouni Malinen
local->hw_priv was initialized only after the interrupt handler was registered. This could trigger a NULL pointer dereference in prism2_pccard_card_present() that assumed that local->hw_priv is always set (and it should have been). Fix this by setting local->hw_priv before registering the interrupt handler. Signed-off-by: Jouni Malinen <jkmaline@cc.hut.fi> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-28[PATCH] hostap: Fix null pointer dereference in prism2_pccard_card_present()Kalle Valo
With my Buffalo WLI-CF-S11G PC Card kernel oopses every time in prism2_interrupt() when I try load the hostap module. local->hw_priv is null during the first call to prism2_interrupt(). It feels like interrupts are enabled too early, or something. This patch fixes the symptom, but not the cause. Signed-off-by: Kalle Valo <Kalle.Valo@iki.fi> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-28[PATCH] hostap: Fix hash values for product stringsJouni Malinen
hostap_cs: 0.4.1-kernel (Jouni Malinen <jkmaline@cc.hut.fi>) pcmcia: hostap_cs: invalid hash for product string "BUFFALO": is 0x1b01a57b, should be 0x2decece3 pcmcia: see Documentation/pcmcia/devicetable.txt for details pcmcia: hostap_cs: invalid hash for product string "WLI-CF-S11G": is 0xefd5102a, should be 0x82067c18 pcmcia: see Documentation/pcmcia/devicetable.txt for details This patch fixes them. Signed-off-by: Kalle Valo <Kalle.Valo@iki.fi> Signed-off-by: Jouni Malinen <jkmaline@cc.hut.fi> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-14[PATCH] hostap: Use void *hw_priv instead of #ifdef in local dataJouni Malinen
Replace hardware model specific #ifdef's in struct local_info with void *hw_priv that is pointing to cs/pci/plx specific data structure. This removes unneeded #ifdef's and as such, is a step towards making it possible to share objects for hostap_hw.c and hostap_download.c with cs/pci/plx drivers without having to compile and link the same code separately for each one. Signed-off-by: Jouni Malinen <jkmaline@cc.hut.fi> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-11[PATCH] hostap updateRichard Purdie
Add the device ID of the Buffalo AirStation WLI-CF-S11G Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-07-31[wireless hostap] trim trailing whitespaceJeff Garzik
