The driver version number has not been updated since the driver was
included in the main kernel tree and there is no plan on updating this
in the future either. At this point, the only correct way to refer to
the version is to use the kernel version. The 0.4.4 version is
confusing since there are external version with higher version number
even though they are not actually any newer than the in-tree version.
Let's get rid of the version number in the kernel tree in order to
avoid this kind of confusion.
Signed-off-by: Jouni Malinen <j@w1.fi>
After 13 years of use, it looks like my email address is finally going
to disappear. While this is likely to drop the amount of incoming spam
greatly ;-), it may also affect more appropriate messages, so let's
update my email address in various places. In addition, Host AP mailing
list is subscribers-only and linux-wireless can also be used for
discussing issues related to this driver which is now shown in
MAINTAINERS.
For the common, open coded 'skb->nh.raw = skb->data' operation, so that we can
later turn skb->nh.raw into a offset, reducing the size of struct sk_buff in
64bit land while possibly keeping it as a pointer on 32bit.
This one touches just the most simple case, next will handle the slightly more
"complex" cases.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
For the places where we need a pointer to the mac header, it is still legal to
touch skb->mac.raw directly if just adding to, subtracting from or setting it
to another layer header.
This one also converts some more cases to skb_reset_mac_header() that my
regex missed as it had no spaces before nor after '=', ugh.
For the common, open coded 'skb->mac.raw = skb->data' operation, so that we can
later turn skb->mac.raw into a offset, reducing the size of struct sk_buff in
"complex" cases.
This lets the network core have the ability to handle suspend/resume
issues, if it wants to.
Thanks to Frederik Deweerdt <frederik.deweerdt@gmail.com> for the arm
driver fixes.
Run this:
#!/bin/sh
for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do
echo "De-casting $f..."
perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f
done
And then go through and reinstate those cases where code is casting pointers
to non-pointers.
And then drop a few hunks which conflicted with outstanding work.
Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Greg KH <greg@kroah.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Paul Fulghum <paulkf@microgate.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Karsten Keil <kkeil@suse.de>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: Ian Kent <raven@themaw.net>
Cc: Steven French <sfrench@us.ibm.com>
Cc: Neil Brown <neilb@cse.unsw.edu.au>
Cc: Jaroslav Kysela <perex@suse.cz>
Cc: Takashi Iwai <tiwai@suse.de>
Fix up for make allyesconfig.
Signed-Off-By: David Howells <dhowells@redhat.com>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
There's a bunch of unused exports in the wireless drivers; that's
bad since unused exports take up quite a bit of space in total;
the patch below removes them.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
This patch contains an attempt to properly build hostap.o without
#include'ing C files.
I wanted to remove the #include "hostap_ioctl.c" from hostap.c and
build hostap_ioctl.c separately, but this doesn't work since hostap.c
has the same name as the module.
After renaming hostap.c this will be possible.
Acked-by: Jouni Malinen <jkmaline@cc.hut.fi>
