[ Upstream commit 550fd08c2cebad61c548def135f67aba284c6162 ]
After the last patch, We are left in a state in which only drivers calling
ether_setup have IFF_TX_SKB_SHARING set (we assume that drivers touching real
hardware call ether_setup for their net_devices and don't hold any state in
their skbs. There are a handful of drivers that violate this assumption of
course, and need to be fixed up. This patch identifies those drivers, and marks
them as not being able to support the safe transmission of skbs by clearning the
IFF_TX_SKB_SHARING flag in priv_flags
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
CC: Karsten Keil <isdn@linux-pingi.de>
CC: "David S. Miller" <davem@davemloft.net>
CC: Jay Vosburgh <fubar@us.ibm.com>
CC: Andy Gospodarek <andy@greyhouse.net>
CC: Patrick McHardy <kaber@trash.net>
CC: Krzysztof Halasa <khc@pm.waw.pl>
CC: "John W. Linville" <linville@tuxdriver.com>
CC: Greg Kroah-Hartman <gregkh@suse.de>
CC: Marcel Holtmann <marcel@holtmann.org>
CC: Johannes Berg <johannes@sipsolutions.net>
Force dev_alloc_name() to be called from register_netdevice() by
dev_get_valid_name(). That allows to remove multiple explicit
dev_alloc_name() calls.
The possibility to call dev_alloc_name in advance remains.
This also fixes veth creation regresion caused by
84c49d8c3e4abefb0a41a77b25aa37ebe8d6b743
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Fix runtime warning with backtrace from hostap by removing
netif_stop_queue() call before register_netdev. Tested to work fine on
hostap_pci Prism 2.5.
(This removes a warning about calling netif_stop_queue before
register_netdev is called. -- JWL)
Signed-off-by: Meelis Roos <mroos@linux.ee>
In hostap_add_interface() we do:
sprintf(dev->name, "%s%s", prefix, name);
dev->name has IFNAMSIZ (16) characters.
prefix is local->dev->name.
name is "wds%d"
strlen() returns the number of characters in the string not counting the
NULL so if we have a string with 11 characters we get "12345678901wds%d"
which is 16 characters and a NULL so we're past the end of the array.
The patch below fixes a warning message Im seeing with gcc 4.6.0
CC [M] drivers/net/wireless/hostap/hostap_main.o
drivers/net/wireless/hostap/hostap_main.c: In function 'hostap_set_multicast_list_queue':
drivers/net/wireless/hostap/hostap_main.c:744:27: warning: variable 'iface' set but not used
As the hostap driver was converted to use net_device_ops, a mistake was
made in hostap_main.c (commit 5ae4efbcd2611562a8b93596be034e63495706a5).
Originally, the tx_queue_len was set to 0 for every other interface than
HOSTAP_INTERFACE_MASTER, but the new fragment of code sets tx_queue_len to
0 only for HOSTAP_INTERFACE_MASTER. The opposite of the previous
behavior makes the driver to drop all packets in AP mode.
Change the way 0 is assigned to tx_queue_len according to the original
logic.
Signed-off-by: Martin Decky <martin@decky.cz>
Use pre-existing net_device_stats in network_device struct.
So that net/ieee80211.h can be made private to ipw2x00 in a follow-up.
Signed-off-by: Dan Williams <dcbw@redhat.com>
These bits are shared already between ipw2x00 and hostap, and could
probably be shared both more cleanly and with other drivers. This
commit simply relocates the code to lib80211 and adjusts the drivers
appropriately.
This converts pretty much everything to print_mac. There were
a few things that had conflicts which I have just dropped for
now, no harm done.
I've built an allyesconfig with this and looked at the files
that weren't built very carefully, but it's a huge patch.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Documentation/feature-removal-schedule.txt
drivers/net/wan/hdlc_fr.c
drivers/net/wireless/iwlwifi/iwl-4965.c
drivers/net/wireless/iwlwifi/iwl3945-base.c
Don't try to skip any headers in hostap_80211_header_parse(). We never
use that function for interfaces affected by local->monitor_type. Both
the master and the AP interface receive 802.11 frames without any
additional headers.
Signed-off-by: Pavel Roskin <proski@gnu.org>
Rewrite AID calculation in handle_pspoll() to avoid truncating bits.
Make hostap_80211_header_parse() static, don't export it. Avoid
shadowing variables.
If the RTNL is held when we invoke flush_scheduled_work() we could
deadlock. One such case is linkwatch, it is a work struct which tries
to grab the RTNL semaphore.
The most common case are net driver ->stop() methods. The
simplest conversion is to instead use cancel_{delayed_}work_sync()
explicitly on the various work struct the driver uses.
This is an OK transformation because these work structs are doing
things like resetting the chip, restarting link negotiation, and so
forth. And if we're bringing down the device, we're about to turn the
chip off and reset it anways. So if we cancel a pending work event,
that's fine here.
Some drivers were working around this deadlock by using a msleep()
polling loop of some sort, and those cases are converted to instead
use cancel_{delayed_}work_sync() as well.
As detailed at https://bugs.gentoo.org/159646 hostap with hostapd confuses
udev by presenting 2 interfaces with the same MAC address. Also, at the time
of detection, the 'type' attribute is 1, identical to other hostap interfaces.
The AP interface is supposed to have type ARPHRD_IEEE80211 (801), but this is
not set until after registration.
Setting it before register_netdev() is called allows us to avoid this
confusion. We can do this by propogating the HOSTAP_INTERFACE type through
to hostap_setup_dev().
Signed-off-by: Daniel Drake <dsd@gentoo.org>
Since hardware header operations are part of the protocol class
not the device instance, make them into a separate object and
save memory.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
This is nicer than the MAC_FMT stuff.
This patch makes /proc/net per network namespace. It modifies the global
variables proc_net and proc_net_stat to be per network namespace.
The proc_net file helpers are modified to take a network namespace argument,
and all of their callers are fixed to pass &init_net for that argument.
This ensures that all of the /proc/net files are only visible and
usable in the initial network namespace until the code behind them
has been updated to be handle multiple network namespaces.
Making /proc/net per namespace is necessary as at least some files
in /proc/net depend upon the set of network devices which is per
network namespace, and even more files in /proc/net have contents
that are relevant to a single network namespace.
The driver version number has not been updated since the driver was
included in the main kernel tree and there is no plan on updating this
in the future either. At this point, the only correct way to refer to
the version is to use the kernel version. The 0.4.4 version is
confusing since there are external version with higher version number
even though they are not actually any newer than the in-tree version.
Let's get rid of the version number in the kernel tree in order to
avoid this kind of confusion.
Signed-off-by: Jouni Malinen <j@w1.fi>
After 13 years of use, it looks like my email address is finally going
to disappear. While this is likely to drop the amount of incoming spam
greatly ;-), it may also affect more appropriate messages, so let's
update my email address in various places. In addition, Host AP mailing
list is subscribers-only and linux-wireless can also be used for
discussing issues related to this driver which is now shown in
MAINTAINERS.
For the common, open coded 'skb->nh.raw = skb->data' operation, so that we can
later turn skb->nh.raw into a offset, reducing the size of struct sk_buff in
64bit land while possibly keeping it as a pointer on 32bit.
This one touches just the most simple case, next will handle the slightly more
"complex" cases.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
For the places where we need a pointer to the mac header, it is still legal to
touch skb->mac.raw directly if just adding to, subtracting from or setting it
to another layer header.
This one also converts some more cases to skb_reset_mac_header() that my
regex missed as it had no spaces before nor after '=', ugh.
For the common, open coded 'skb->mac.raw = skb->data' operation, so that we can
later turn skb->mac.raw into a offset, reducing the size of struct sk_buff in
"complex" cases.
This lets the network core have the ability to handle suspend/resume
issues, if it wants to.
Thanks to Frederik Deweerdt <frederik.deweerdt@gmail.com> for the arm
driver fixes.
Run this:
#!/bin/sh
for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do
echo "De-casting $f..."
perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f
done
And then go through and reinstate those cases where code is casting pointers
to non-pointers.
And then drop a few hunks which conflicted with outstanding work.
Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Greg KH <greg@kroah.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Paul Fulghum <paulkf@microgate.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Karsten Keil <kkeil@suse.de>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: Ian Kent <raven@themaw.net>
Cc: Steven French <sfrench@us.ibm.com>
Cc: Neil Brown <neilb@cse.unsw.edu.au>
Cc: Jaroslav Kysela <perex@suse.cz>
Cc: Takashi Iwai <tiwai@suse.de>
Fix up for make allyesconfig.
Signed-Off-By: David Howells <dhowells@redhat.com>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
There's a bunch of unused exports in the wireless drivers; that's
bad since unused exports take up quite a bit of space in total;
the patch below removes them.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
This patch contains an attempt to properly build hostap.o without
#include'ing C files.
I wanted to remove the #include "hostap_ioctl.c" from hostap.c and
build hostap_ioctl.c separately, but this doesn't work since hostap.c
has the same name as the module.
After renaming hostap.c this will be possible.
Acked-by: Jouni Malinen <jkmaline@cc.hut.fi>
