path: root/drivers/net/wireless/ipw2x00
2010-11-08libipw: fix proc entry removalLinus Torvalds
This bug seems to be due to commit 27ae60f8f7aac ("ipw2x00: replace "ieee80211" with "libipw" where appropriate"), where Pavel did this: - libipw_proc = proc_mkdir(DRV_NAME, init_net.proc_net); + libipw_proc = proc_mkdir("ieee80211", init_net.proc_net); but then the cleanup was kept as remove_proc_entry(DRV_NAME, init_net.proc_net); in both places (both in the failure case and in the unload case). The error string is also total crap, and says "Unable to create " DRV_NAME " proc directory\n"); Even though it doesn't actually create a proc directory named DRV_NAME at all. So that patch looks like total and utter crap to me. The commit message says "Keep /proc/net/ieee80211 under the original name to avoid breaking user interface." but the thing is, it really didn't fix anything but that one create thing. It needs to fix all the other cases too. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Tested-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-08Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: Documentation/feature-removal-schedule.txt drivers/net/wireless/ipw2x00/ipw2200.c
2010-10-05ipw2200: check for allocation failuresDan Carpenter
If kzalloc() fails then return should return with -ENOMEM. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-25Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: drivers/net/wireless/libertas/if_sdio.c
2010-08-24Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-core.c drivers/net/wireless/iwlwifi/iwl-core.h
2010-08-21Merge branch 'master' of ↵David S. Miller
2010-08-17drivers/net: Convert unbounded kzalloc calls to kcallocJoe Perches
These changes may be slightly safer in some instances. There are other kzalloc calls with a multiply, but those calls are typically "small fixed #" * sizeof(some pointer)" and those are not converted. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Acked-by: Luciano Coelho <luciano.coelho@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-17ipw2100: don't sync status queue entriesJohn W. Linville
These are allocated with pci_alloc_consistent, so calling pci_dma_sync_single_for_cpu is incorrect usage of the API. Remove this misuse and consequently avoid the following backtrace: WARNING: at lib/dma-debug.c:902 check_sync+0xce/0x43a() Hardware name: 2373HU6 ipw2100 0000:02:02.0: DMA-API: device driver tries to sync DMA memory it has not allocated [device address=0x0000000034e88008] [size=8 bytes] Modules linked in: microcode ipw2100(+) snd_seq_device ppdev libipw nsc_ircc snd_pcm lib80211 video output irda parport_pc cfg80211 parport thinkpad_acpi e1000 iTCO_wdt crc_ccitt snd_timer iTCO_vendor_support snd i2c_i801 pcspkr rfkill soundcore joydev snd_page_alloc yenta_socket radeon ttm drm_kms_helper drm i2c_algo_bit i2c_core [last unloaded: scsi_wait_scan] Pid: 0, comm: swapper Tainted: G W 2.6.35-wl+ #8 Call Trace: [<c043aa42>] warn_slowpath_common+0x6a/0x7f [<c05d252a>] ? check_sync+0xce/0x43a [<c043aaca>] warn_slowpath_fmt+0x2b/0x2f [<c05d252a>] check_sync+0xce/0x43a [<c046189a>] ? print_lock_contention_bug+0x11/0xb2 [<c05d2b6f>] debug_dma_sync_single_for_cpu+0x47/0x49 [<c06cbd3c>] ? ehci_irq+0x31/0x331 [<f82a224a>] ? ipw2100_irq_tasklet+0x24/0x5e9 [ipw2100] [<f82a224a>] ? ipw2100_irq_tasklet+0x24/0x5e9 [ipw2100] [<f82a221d>] pci_dma_sync_single_for_cpu.clone.1+0x42/0x4b [ipw2100] [<f82a23a2>] ipw2100_irq_tasklet+0x17c/0x5e9 [ipw2100] [<c043fd87>] tasklet_action+0x78/0xcb [<c0440293>] __do_softirq+0xc4/0x183 [<c044038d>] do_softirq+0x3b/0x5f [<c04404d0>] irq_exit+0x3a/0x6d [<c0404423>] do_IRQ+0x8b/0x9f [<c04038b5>] common_interrupt+0x35/0x3c [<c062ecfa>] ? acpi_idle_enter_simple+0xfe/0x13c [<c045007b>] ? exit_itimers+0x2d/0x73 [<c062ecfc>] ? acpi_idle_enter_simple+0x100/0x13c [<c070bf10>] cpuidle_idle_call+0x78/0xdc [<c040251c>] cpu_idle+0x9b/0xb7 [<c07b1dd2>] rest_init+0xa6/0xab [<c0a4b96d>] start_kernel+0x389/0x38e [<c0a4b0c9>] i386_start_kernel+0xc9/0xd0 Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-16Merge branch 'master' of ↵John W. Linville
2010-08-16ipw2100: avoid warning from pointer cast in call to IPW_DEBUG_TXJohn W. Linville
drivers/net/wireless/ipw2x00/ipw2100.c: In function 'ipw2100_tx_send_commands': drivers/net/wireless/ipw2x00/ipw2100.c:3063: warning: cast to pointer from integer of different size This changes the cast and the conversion to match other usage of the same value in calls to IPW_DEBUG_TX. Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-11ipw2100: register pm_qos request before registering pci driverJohn W. Linville
It is necessary to call pm_qos_add_request prior to calling pm_qos_update_request. It was revealed that ipw2100 has been doing this wrong since "pm_qos: Get rid of the allocation in pm_qos_add_request()" (commit 82f682514a5df89ffb3890627eebf0897b7a84ec) added a WARN that results in the following backtrace: WARNING: at kernel/pm_qos_params.c:264 pm_qos_update_request+0x5e/0x70() pm_qos_update_request() called for unknown object Call Trace: [<c1024088>] ? warn_slowpath_common+0x78/0xb0 [<c1041c9e>] ? pm_qos_update_request+0x5e/0x70 [<c1041c9e>] ? pm_qos_update_request+0x5e/0x70 [<c1024153>] ? warn_slowpath_fmt+0x33/0x40 [<c1041c9e>] ? pm_qos_update_request+0x5e/0x70 [<f89fe15f>] ? ipw2100_up+0x3f/0xf10 [ipw2100] [<c11961c9>] ? vsnprintf+0xc9/0x530 [<f89ff36c>] ? ipw2100_net_init+0x2c/0x1c0 [ipw2100] [<c12f542d>] ? register_netdevice+0x7d/0x3c0 [<f89f9b00>] ? ipw2100_irq_tasklet+0x910/0x9a0 [ipw2100] [<c12f579f>] ? register_netdev+0x2f/0x40 [<f89fd471>] ? ipw2100_pci_init_one+0xd21/0x1060 [ipw2100] [<c11a5ebb>] ? local_pci_probe+0xb/0x10 [<c11a6d49>] ? pci_device_probe+0x69/0x90 [<c1224704>] ? driver_probe_device+0x74/0x180 [<c10dd15a>] ? sysfs_create_dir+0x6a/0xb0 [<c1224889>] ? __driver_attach+0x79/0x80 [<c1224810>] ? __driver_attach+0x0/0x80 [<c1223fa2>] ? bus_for_each_dev+0x52/0x80 [<c1224586>] ? driver_attach+0x16/0x20 [<c1224810>] ? __driver_attach+0x0/0x80 [<c122395f>] ? bus_add_driver+0x17f/0x250 [<c11a5ec0>] ? pci_device_shutdown+0x0/0x20 [<c11a6c80>] ? pci_device_remove+0x0/0x40 [<c1224b13>] ? driver_register+0x63/0x120 [<c11a6f96>] ? __pci_register_driver+0x36/0xa0 [<f84f9048>] ? ipw2100_init+0x48/0x67 [ipw2100] [<c1001122>] ? do_one_initcall+0x32/0x170 [<c1087078>] ? __vunmap+0xb8/0xf0 [<f84f9000>] ? ipw2100_init+0x0/0x67 [ipw2100] [<c10510c1>] ? sys_init_module+0x161/0x1000 [<c108f847>] ? sys_close+0x67/0xe0 [<c13647c1>] ? syscall_call+0x7/0xb This patch moves pm_qos_add_request prior to pci_register_driver in ipw2100 in order to avoid this problem. Reported-by: Christoph Fritz <chf.fritz@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-06Merge branch 'master' of ↵David S. Miller
2010-08-04wireless: ipw2100: check result of kzalloc()Christoph Fritz
If kzalloc() fails return with -ENOMEM from ipw2100_net_init() which is called by register_netdev. CC: Dan Carpenter <error27@gmail.com> Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-08-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1443 commits) phy/marvell: add 88ec048 support igb: Program MDICNFG register prior to PHY init e1000e: correct MAC-PHY interconnect register offset for 82579 hso: Add new product ID can: Add driver for esd CAN-USB/2 device l2tp: fix export of header file for userspace can-raw: Fix skb_orphan_try handling Revert "net: remove zap_completion_queue" net: cleanup inclusion phy/marvell: add 88e1121 interface mode support u32: negative offset fix net: Fix a typo from "dev" to "ndev" igb: Use irq_synchronize per vector when using MSI-X ixgbevf: fix null pointer dereference due to filter being set for VLAN 0 e1000e: Fix irq_synchronize in MSI-X case e1000e: register pm_qos request on hardware activation ip_fragment: fix subtracting PPPOE_SES_HLEN from mtu twice net: Add getsockopt support for TCP thin-streams cxgb4: update driver version cxgb4: add new PCI IDs ... Manually fix up conflicts in: - drivers/net/e1000e/netdev.c: due to pm_qos registration infrastructure changes - drivers/net/phy/marvell.c: conflict between adding 88ec048 support and cleaning up the IDs - drivers/net/wireless/ipw2x00/ipw2100.c: trivial ipw2100_pm_qos_req conflict (registration change vs marking it static)
2010-07-27Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/holtmann/bluetooth-next-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-commands.h
2010-07-26lib80211: remove unused host_build_iv optionJohn W. Linville
2010-07-20libipw: correct sparse warnings and mark some variables staticJohn W. Linville
CHECK drivers/net/wireless/ipw2x00/libipw_module.c drivers/net/wireless/ipw2x00/libipw_module.c:65:21: warning: symbol 'libipw_config_ops' was not declared. Should it be static? drivers/net/wireless/ipw2x00/libipw_module.c:66:6: warning: symbol 'libipw_wiphy_privid' was not declared. Should it be static? CHECK drivers/net/wireless/ipw2x00/libipw_wx.c drivers/net/wireless/ipw2x00/libipw_wx.c:415:17: warning: symbol 'ssid' shadows an earlier one drivers/net/wireless/ipw2x00/libipw_wx.c:324:9: originally declared here Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-07-20ipw2100: mark ipw2100_pm_qos_req staticJohn W. Linville
CHECK drivers/net/wireless/ipw2x00/ipw2100.c drivers/net/wireless/ipw2x00/ipw2100.c:177:28: warning: symbol 'ipw2100_pm_qos_req' was not declared. Should it be static? Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-07-19pm_qos: Get rid of the allocation in pm_qos_add_request()James Bottomley
All current users of pm_qos_add_request() have the ability to supply the memory required by the pm_qos routines, so make them do this and eliminate the kmalloc() with pm_qos_add_request(). This has the double benefit of making the call never fail and allowing it to be called from atomic context. Signed-off-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: mark gross <markgross@thegnar.org> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-06-17Merge branch 'master' of ↵David S. Miller
2010-06-16ipw2200: Enable LED by defaultubuntu@tjworld.net
BugLink: http://bugs.launchpad.net/bugs/21367 Enable LED by default and update the MODULE_PARM_DESC. The original reason for defaulting to disabled was documented in 2005 and noted, "The LED code has been reported to hang some systems when running ifconfig and is therefore disabled by default." This no longer appears applicable and users have been requesting this be enabled for several years. Signed-off-by: TJ <ubuntu@tjworld.net> Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: Andy Whitcroft <apw@canonical.com> Acked-by: Stefan Bader <stefan.bader@canonical.com> Signed-off-by: Leann Ogasawara <leann.ogasawara@canonical.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-11Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 Conflicts: drivers/net/wireless/wl12xx/wl1271.h drivers/net/wireless/wl12xx/wl1271_cmd.h
2010-06-03drivers/net/wireless/ipw2x00/ipw2100.c: Remove unnecessary kmalloc castsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-03drivers/net: use __packed annotationEric Dumazet
cleanup patch. Use new __packed annotation in drivers/net/ Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-02drivers/net/wireless/ipw2x00: Use kmemdupJulia Lawall
Use kmemdup when some other buffer is immediately copied into the allocated region. A simplified version of the semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression from,to,size,flag; statement S; @@ - to = \(kmalloc\|kzalloc\)(size,flag); + to = kmemdup(from,size,flag); if (to==NULL || ...) S - memcpy(to, from, size); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1674 commits) qlcnic: adding co maintainer ixgbe: add support for active DA cables ixgbe: dcb, do not tag tc_prio_control frames ixgbe: fix ixgbe_tx_is_paused logic ixgbe: always enable vlan strip/insert when DCB is enabled ixgbe: remove some redundant code in setting FCoE FIP filter ixgbe: fix wrong offset to fc_frame_header in ixgbe_fcoe_ddp ixgbe: fix header len when unsplit packet overflows to data buffer ipv6: Never schedule DAD timer on dead address ipv6: Use POSTDAD state ipv6: Use state_lock to protect ifa state ipv6: Replace inet6_ifaddr->dead with state cxgb4: notify upper drivers if the device is already up when they load cxgb4: keep interrupts available when the ports are brought down cxgb4: fix initial addition of MAC address cnic: Return SPQ credit to bnx2x after ring setup and shutdown. cnic: Convert cnic_local_flags to atomic ops. can: Fix SJA1000 command register writes on SMP systems bridge: fix build for CONFIG_SYSFS disabled ARCNET: Limit com20020 PCI ID matches for SOHARD cards ... Fix up various conflicts with pcmcia tree drivers/net/ {pcmcia/3c589_cs.c, wireless/orinoco/orinoco_cs.c and wireless/orinoco/spectrum_cs.c} and feature removal (Documentation/feature-removal-schedule.txt). Also fix a non-content conflict due to pm_qos_requirement getting renamed in the PM tree (now pm_qos_request) in net/mac80211/scan.c
2010-05-14drivers/net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from drivers/net/ all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. It also does not remove null void functions with return. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' with some cleanups by hand. Compile tested x86 allmodconfig only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-10PM QOS updateMark Gross
This patch changes the string based list management to a handle base implementation to help with the hot path use of pm-qos, it also renames much of the API to use "request" as opposed to "requirement" that was used in the initial implementation. I did this because request more accurately represents what it actually does. Also, I added a string based ABI for users wanting to use a string interface. So if the user writes 0xDDDDDDDD formatted hex it will be accepted by the interface. (someone asked me for it and I don't think it hurts anything.) This patch updates some documentation input I got from Randy. Signed-off-by: markgross <mgross@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-04-15Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: Documentation/feature-removal-schedule.txt drivers/net/wireless/ath/ath5k/phy.c drivers/net/wireless/wl12xx/wl1271_main.c
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-08Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 into merge Conflicts: Documentation/feature-removal-schedule.txt drivers/net/wireless/ath/ath5k/phy.c drivers/net/wireless/iwlwifi/iwl-4965.c drivers/net/wireless/iwlwifi/iwl-agn.c drivers/net/wireless/iwlwifi/iwl-core.c drivers/net/wireless/iwlwifi/iwl-core.h drivers/net/wireless/iwlwifi/iwl-tx.c
2010-03-31wireless/ipw2x00: remove trailing space in messagesFrans Pop
Signed-off-by: Frans Pop <elendil@planet.nl> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-31ipw2200: restart adapter only when abort_scan doesn't workZhu Yi
When a scan watchdog is fired, try to send abort scan command first before restarting the adapter. This avoids reconnection for some users when scan hang is detected. This fixed bug https://bugzilla.kernel.org/show_bug.cgi?id=15419 Reported-by: Maurizio Avogadro <mavoga@gmail.com> Tested-by: Maurizio Avogadro <mavoga@gmail.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-29Merge branch 'master' of ↵David S. Miller
2010-03-23drivers/net: Remove local #define IW_IOCTL, use IW_HANDLERJoe Perches
Use #define IW_HANDLER from wireless.h instead Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-22Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 Conflicts: Documentation/feature-removal-schedule.txt drivers/net/wireless/ath/ath5k/phy.c
2010-03-15ipw2x00: replace "ieee80211" with "libipw" where appropriatePavel Roskin
"ieee80211" was the old name of the common library for ipw2100 and ipw2200. It was renamed to "libipw", but some occurrences of the old name remained. Rename alloc_ieee80211() to alloc_libipw() and free_ieee80211() to free_libipw(). Adjust comments and label names. Change prefixes in diagnostic messages. Keep /proc/net/ieee80211 under the original name to avoid breaking user interface. Move the affected EXPORT_SYMBOL macros to their proper places. Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-10ipw2200: use kmalloc for large local variablesZhu Yi
Fixed below compiler warning: drivers/net/wireless/ipw2x00/ipw2200.c: In function ‘ipw_load_firmware’: drivers/net/wireless/ipw2x00/ipw2200.c:3260: warning: the frame size of 1168 bytes is larger than 1024 bytes Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-10libipw: split ieee->networks into small piecesZhu Yi
The ieee->networks consists of 128 struct libipw_network entries. If we allocate this chunk of memory altogether, it ends up with an order 4 page allocation. High order page allocation is likely to fail on system high load. This patch splits the big chunk memory allocation into small pieces, each is 344 bytes, allocates them with 128 times. The patch fixed bug http://bugzilla.kernel.org/show_bug.cgi?id=14989 Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-07drivers/net/: use DEFINE_PCI_DEVICE_TABLE()Alexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section in every case. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-07Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: kernel/irq/chip.c
2009-12-04ipw2100: fix rebooting hang with driver loadedZhu Yi
Add PCI .shutdown method so that we can disable the device during shutdown or reboot. Without this, the reboot doesn't work well on some platforms. This fixes http://bugzilla.intellinuxwireless.org/show_bug.cgi?id=2124 Tested-by: pablo <pablolm2005@gmail.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-28ipw2x00: convert to seq_fileAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-24Merge branch 'master' of ↵David S. Miller
2009-11-23ipw2200: Set core hw rfkill status when hardware changes stateMatthew Garrett
ipw2200 is able to detect when it's been hard-killed, but doesn't update the core rfkill state or update userspace. Ensure that the state is updated, allowing the rfkill core to notify userspace. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-23ipw2100: Register the wiphy deviceMatthew Garrett
libipw unconditionally calls wiphy_unregister, but it's up to the driver to register it in the first place. ipw2100 fails to do so. Add the necessary glue code, and also ensure that rfkill statuses get set up appropriately. (Augmented for proper wiphy_unregister placement. -- JWL) Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-23libipw: initiate cfg80211 API conversion (v2)John W. Linville
Initiate the conversion of libipw to the new cfg80211 configuration API. For now, leave CONFIG_IPW2200_PROMISCUOUS stuff alone. Eventually migrate it to cfg80211 when the add/del/change_virtual_intf methods are implemented. (v2: Fix unconditional wiphy_unregister in libipw which was causing problems for ipw2100, somewhat based on prior attempted fix by Zhu Yi <yi.zhu@intel.com>. Previously both original version of this patch and Zhu Yi's fix attempt were reverted due to discovery of regressions. -- JWL) Signed-off-by: John W. Linville <linville@tuxdriver.com>
