path: root/drivers/net/wireless/iwlwifi/iwl-3945-led.c
2009-07-27iwlwifi: remove command callback return valueJohannes Berg
No existing callbacks use anything other than the return value 1, which means that the caller should free the reply skb, so it seems safer in terms of not introducing memory leaks to simply remove the return value and let the caller always free the skb. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-27iwlwifi: fix up command sendingJohannes Berg
The current command sending in iwlwifi is a bit of a mess: 1) there is a struct, iwl_cmd, that contains both driver and device data in a single packed structure -- this is very confusing 2) the on-stack data and the command metadata share a structure by embedding the latter in the former, which is also rather confusing because it leads to weird unions and similarly odd constructs 3) each txq always has enough space for 256 commands, even if only 32 end up being used This patch fixes these things: 1) rename iwl_cmd to iwl_device_cmd and keep track of command metadata and device command separately, in two arrays in each tx queue 2) remove the 'meta' member from iwl_host_cmd and only put in the required members 3) allocate the cmd/meta arrays separately instead of embedding them into the txq structure Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-04iwl3945/iwlwifi: fix led bug when SW rfkillAbhijeet Kolekar
Patch fixes the bug at http://www.intellinuxwireless.org/bugzilla/show_bug.cgi?id=1903 when SW rfkill is invoked by 'iwconfig txpower off', the existing connection disassociates and led off command is sent to the device which returns error as rfkill is 'true'. Patch fixes this by just avoiding sending the led off/on command when disassociated. The main purpose of the led_disassociate callback is to start or stop the blinking. There are three states in led 1) Always on when radio is on 2) Always off when radio is off 3) blink when associated and if there is some traffic. In this callback 'allow_blinking' needs to be set false when associated, as LED will be always on. Signed-off-by: Abhijeet Kolekar <abhijeet.kolekar@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-22iwl3945: improve 3945 ledsAbhijeet Kolekar
'tpt' is a delta throughput (number of packets) and is corelated to brightness of the LED. We already maintain a delta of packets in rxtxpackets. There is no need to calculate this delta again which was affecting the behaviour of LEDS. Also add two new callback functions for ASSOCIATED/DISASSOCIATED states where LED's will be *on* for associated state and *off* for disassociated state. This fixes http://www.intellinuxwireless.org/bugzilla/show_bug.cgi?id=1771. Signed-off-by: Abhijeet Kolekar <abhijeet.kolekar@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-16iwl3945: use iwl_led structureAbhijeet Kolekar
3945 can now use iwl_led's structure from iwlwifi. Patch also removes CONFIG_IWL3945_LEDS flag from Kconfig as 3945's led support will now be enabled if user selects CONFIG_IWLWIFI_LEDS. Signed-off-by: Abhijeet Kolekar <abhijeet.kolekar@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-09iwlwifi: another led naming fixDanny Kukawka
Fixed led device naming for the iwlwifi (iwl-3945) driver. Due to the documentation of the led subsystem/class the naming should be "devicename:colour:function" while not applying sections should be left blank. This should lead to e.g. "iwl-%s::RX" instead of "iwl-%s:RX". Signed-off-by: Danny Kukawka <dkukawka@suse.de> Acked-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-09iwlwifi: don't use implicit priv in IWL_DEBUGTomas Winkler
Call IWL_DEBUG macro with explicit priv argument. Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Acked-by: Samuel Ortiz <samuel.ortiz@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29iwl3945: Use iwl-hcmd host command routinesSamuel Ortiz
With the previously added tfd related ops, we can now use the iwl-tx.c host command enqueue routine. Since the 3945 host command specific routines are identical to the agn ones, we can just remove them from the 3945 code. Signed-off-by: Samuel Ortiz <samuel.ortiz@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29iwlwifi: update copyright year to 2009Reinette Chatre
2009-01-29iwlwifi: use iwl_cmd instead of iwl3945_cmdWinkler, Tomas
This patch makes use of iwl_cmd instead of iwl3945_cmd and related structures which were just the same. Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29iwlwifi: replace IWL_ERROR with IWL_ERRWinkler, Tomas
IWL_ERR doesn't use hidden priv pointer. Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29iwl3945: replaces iwl3945_priv with iwl_privAbhijeet Kolekar
The patch replaces iwl3945_priv to iwl_priv. It adds 3945 specific data members to iwl_priv. Signed-off-by: Abhijeet Kolekar <abhijeet.kolekar@intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29iwl3945: rename iwl3945_priv variablesAbhijeet Kolekar
The patch renames iwl3945 specific variables in iwl3945_priv structure. iwl3945_priv structure differs with iwl_priv structure with these variables. Goal of this patch is to make transition from iwl3945_priv to iwl_priv smoothly. Signed-off-by: Abhijeet Kolekar <abhijeet.kolekar@intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29iwlwifi: 3945 remove iwl-3945-commands.hTomas Winkler
This patch remove iwl-3945-commands.h eliminating duplicated and moving all definitions to iwl-commands.h Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29iwlwifi: 3945 remove duplicated code from iwl-3945-commands.hTomas Winkler
This patch remove trivial (renames) commands and defines from iwl-3945-commands.h Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29iwlwifi: use iwl-commands.h also in 3945Tomas Winkler
This patch uses iwl-commands.h also for iwl3945 more clean ups are required but this get to stage where it compiles cleanly. Most massive changes are in spectrum and power managment. Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29iwlwifi: 3945 unfold iwl-3945-commands.hTomas Winkler
This patch unfolds includes of iwl-3945-commands.h Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-12-12iwlwifi: change email contact informationWinkler, Tomas
This patch replaces personal emails with hopefully always valid Intel Linux Wireless, which will be routed to a current maintainer Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-23removed unused #include <linux/version.h>'sAdrian Bunk
This patch lets the files using linux/version.h match the files that #include it. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-04iwlwifi: Don't use buffer allocated on the stack for led namesSven Wegener
Having the buffer on the stack and even re-using it for all led devices is bad. Not being able to resolve the name member of the led device structure to a meaningful value leads to confusion during ad-hoc debugging and potential breakage in the future, if we ever decide to access the name member outside of the registration function. Move the buffer to our private per led device structures so that it is accessible after registration. A quick grep didn't yield any occurence of using the led device name parameter outside of the led device registration function, so currently we should already be safe for normal operation. Signed-off-by: Sven Wegener <sven.wegener@stealer.net> Cc: Richard Purdie <rpurdie@rpsys.net> Acked-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-14iwlwifi: Fix LEDs for 3945Abhijeet Kolekar
The patch fixes LEDs problem for 3945. Signed-off-by: Abhijeet Kolekar <abhijeet.kolekar@intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-09iwlwifi: fix oops in iwl3945_led_brightness_setMarcin Slusarz
fix race between: ieee80211_open->ieee80211_led_radio->led_trigger_event->led_set_brightness->iwl3945_led_brightness_set (which assumes that "led->priv" is not NULL) and iwl3945_pci_probe->iwl3945_setup_deferred_work->(...)->iwl3945_bg_alive_start->iwl3945_alive_start->iwl3945_led_register->iwl3945_led_register_led which sets priv field in struct iwl3945_led after led->led_dev.brightness_set = iwl3945_led_brightness_set; (...) led_classdev_register(device, &led->led_dev); http://kerneloops.org/guilty.php?guilty=iwl3945_led_brightness_set&version=2.6.25-release&start=1671168&end=1703935&class=oops Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Zhu Yi <yi.zhu@intel.com> Cc: Reinette Chatre <reinette.chatre@intel.com> Cc: Tomas Winkler <tomas.winkler@intel.com> Cc: linux-wireless@vger.kernel.org Cc: ipw3945-devel@lists.sourceforge.net Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-27iwlwifi: Add led supportMohamed Abbas
This patch add LEDS support to 3965 and 4965 drivers. It is based on led trigger and class. For our drivers we needed to avoid two things. 1- We receive led trigger on/off on each Rx\Tx frame. In our driver we can not call led command like that. In this driver once driver receive a start of traffic it call the led command to start blinking then we count all bytes of Tx and Rx frame, after two second we count the blink rate of last two second then id blink rate changed we call the led commands 2- Since we can call led command very often, we make sure we call the led command after we receive the statistics notification so we don't need to wake up the ucode id it is in sleep state. This patch was tested with 4965 and 3945. Signed-off-by: Mohamed Abbas <mabbas@linux.intel.com> Signed-off-by: Ian Schram<ischram@telenet.be> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
