Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
No functional changes, update comments to match current file structure
Multiple iwlagn based devices shared the same hw definitions.
Move device hardware related defines from iwl-5000-hw.h to iwl-agn-hw.h
file.
Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
I've also for a long time had a problem with the
temperature calculation code, which I had fixed
by byte-swapping the values, and now it turns out
that was the correct fix after all.
Also, any use of iwl_eeprom_query_addr() that is
for more than a u8 must be cast to little endian,
and some structs as well.
Fix all this. Again, no real impact on platforms
that already are little endian.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Cc: stable@kernel.org
The temperature measurement by uCode for 5150 and 5000 are different
CSR_HW_REV_TYPE_5150: temperature sensor output voltage
CSR_HW_REV_TYPE_5000: temperature in Celsius
temperature related operation for 5150 is measured by temperature sensor
output voltage; additional conversion is required for set and store
the temperature.
To make sure support different HW design; implement _ops method for
temperature related functions (temperature reading and set ct kill
threshold)
SRAM addresses are different for 3945, 4065, and 5000, let's give them
different names.
Also, the RSSI_OFFSET is different for 3945 and 4965, thus they should be
named differently.
Signed-off-by: Samuel Ortiz <samuel.ortiz@intel.com>
Signed-off-by: Abhijeet Kolekar <abhijeet.kolekar@intel.com>
This patch replaces personal emails with hopefully
always valid Intel Linux Wireless, which will be routed
to a current maintainer
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
This moves byte count tables to tx domain removing completely
ambivalent shared data. Changes handling of allocation
byte count tables and keep warm consistent memory
Moves general tx scheduler definitions from iwl-4956-hw.h
to iwl-fh.h
This patch moves rx status/read registers into
iwl_rx_queue structures. This solution is more memory
hungry but is more structured and provides needed RX/TX
separation
This patch drops unreadable usage of IWL_SET/GET_BITS16 in byte count
tables handling
This patch also cleans a bit the byte count table code and adds
WARN_ON traps on invalid values
This patch is pure cleanup, no functional changes.
Cc: Johannes Berg <johannes@sipsolutions.net>
Since calibration framework is not HW specific remove 5000 and 4965 prefix
This patch doesn't provide any functional changes only code renaming
and movement
This patch adds ability to configure initial calibration set. Not all HW
supported by iwlwifi use the same calibration set, XTAL is one example.
Some clean ups are also included in this patch.
Signed-off-by: Zhu Yi <yi.zhu@intel.com>
This patch allows variable number of init calibrations and allows
addition new HW.
This patch also fixes critical bug. Only last calibration result
was applied. On reception of one calibration result all the calibration
was freed.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
This patch asks to allocate the correct amount of sw queues according
to hw ampdu queues number.
Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com>
This patch maps sw and hw queues (for aggregations), so the right
mac80211 queue will be waken when ieee80211_wake_queue is invoked.
This patch udpates the byte count of the frame in the registers of the
scheduler.
This patch also moves two defines in iwl-4965.h to a more appropriate
area in the file.
This patch adds iwl 5000 HW parameters
This patch adds eeprom handlers and values for 5000 HW family
This patch adds initial support for recognizing the iwl 5000 family of NICs
ID
