_agn driver should perform both sensitivity and chain noise calib.
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
After driver split, set_l0s config is no longer needed, remove it
After driver split, no need to use function pointer for those event and
register dump function.
define of firmware filenames use extra macro to build the files name.
Signed-off-by: Jay Sternberg <jay.e.sternberg@intel.com>
drivers/net/wireless/rtlwifi/efuse.c
drivers/net/wireless/rtlwifi/rtl8192c/fw_common.c
net/bluetooth/mgmt.c
The ISR (interrupt service routine) ops are now
no longer necessary since they are the same for
all devices this driver now handles.
Again, a 4965 specific code path that we no
longer need in iwlagn.
Only 4965 had a bootstrap microcode image, so
the agn driver can completely ignore that and
we can remove some code from it.
All agn devices behave the same, so there's no
need to go through function pointers for any
of the ucode loading functionality.
At least EEPROM version 0x11A has the wrong
number of chains programmed into it for some
reason, so we need to override in the driver.
git://git.kernel.org/pub/scm/linux/kernel/git/iwlwifi/iwlwifi-2.6
Since the driver split, there's no need for
function pointers any more for aggregation
queue setup and teardown as all devices now
share the same code. Simplify this.
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
Remove check_plcp_health and check_ack_health ops methods, they are
unneeded after iwlegacy driver split. Merge check health code into to
iwl-rx.c and make functions static.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Acked-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
New iwlwifi-5000 microcode requires driver support for API version 5.
Signed-off-by: Don Fry <donald.h.fry@intel.com>
Multiple devices use almost the same .cfg with minor differences.
Use macro and remove the duplication. By doing this, reduce
the chance for mistake while modify .cfg parameters
For WiFi/WiMAX combo devices, if WiMAX own the RF, WiFi driver
try to access RF and fail. This is the W/A to To avoid WiFi keep
reloading firmware and try to access RF again.
This patch replace monitor/recover timer by watchdog based on time
stamp. New code allow to discover hangs more precisely.
Timeout values are currently doubled monitoring period values of
previous timer. This have to be tuned based of firmware timing
capabilities.
Tested on 3945, 4965, 5300, 6300.
The valid tx/rx antenna information is part of EEPROM, so use it
to configure the device.
For few cases, the EEPROM did not reflect the correct antenna, but
it is too late to modify the EEPROM, so overwrite with .cfg parameters
EEPROM contain the SKU information for the device, use it.
Set the default led mode for different devices.
For the newer devices such as 6000g2a, 6000g2b and newer,
the default led mode is On/Off instead of blinking.
The led_mode still can be control through module parameter
0: system default
1: On/Off
2: blinking
There were two type of isr supported by iwlwifi devices.
legacy isr - only used by legacy devices (3945 & 4965)
ict isr - used by all new generation of iwlwifi devices
Move all the isr related functions into ops, the ict type of isr
supports only needed for newer devices.
In order to simplify the flow, and make new
enhancements easier, separate out the RXON
processing for modern AGN (5000 and newer)
from RXON processing for the older 3945 and
4965 devices. Avoid changing these old ones
to avoid regressions and move their code to
a new file (iwl-legacy.c). 4965 gets the
commit_rxon that used to be common for all
AGN devices, but with removed PAN support.
The new RXON processing is more central and
does more work in committing, so that it is
easier to follow.
To make it more evident what is split out
for legacy, split the necessary operations
for that into a new struct iwl_legacy_ops.
Those parts that still exist in the new AGN
code don't need to be parametrized.
In the future, 4965 and modern AGN devices will
need to have different mac80211 callbacks since
they have different capabilities. Prepare for
that by making the mac80211 operations a device
config.
Since all devices share the same operation here,
there's no need to call it indirectly.
The set_pwr_src operation is only ever used from
within the same sub-driver that it is declared
in, so it can just be called directly instead of
being an operation. Also, it is never called to
set the power source to V_aux, so change the two
functions accordingly (but keep the V_aux code
for documentation purposes in a comment).
This operation is only ever called from set_hw_params,
which is also already based on the config/ops, so that
there's no need to have a separate set_ct_kill op and
we can just call the right ct_threshold function.
All drivers share the same implementation, so
there's no need to call this via a function
pointer nor to export it.
move paramater definitions to a device paramater structure only
leaving the device name, which antennas are used and what firmware
file to use in the iwl_cfg structure. this will not completely
remove the redundancies but greatly reduce them for devices that
only vary by name or antennas. the parameters that are more
likely to change within a given device family are left in iwl_cfg.
also separate bt param structure added to help reduce more.
Tx command response sent to host by uCode after completed
the transmission attempt. The status parameter indicates
whether the transmission was successful, or else why if failed.
Here we keep the counters to help understand the different failure
cases.
Include bt_status_read function pointer for 5150 device
iwlwifi occasionally needs to find the virtual
interface pointer to give it to mac80211, but right
now it only keeps one. Move it into the context so
that we can keep one pointer each.
The broadcast station ID is per context, so
add a variable for the ID in the context and
use it everywhere we previously hardcoded it.
In order to support multiple interfaces, we must move
a lot of data into per-context structures so we can
use the contexts the device offers. To start with,
this makes a lot of code context-aware, more changes
will move more things into the context structure.
drivers/net/wireless/iwlwifi/iwl-core.c
drivers/net/wireless/iwlwifi/iwl-core.h
A few cases in iwlwifi driver function ieee80211_frequency_to_channel()
is called to get channel number from center frequency. This is not needed
since the channel number is already saved in hw_value field of struct
ieee80211_channel in function iwlcore_init_geos(). So replace those function
calls with hw_value field of struct ieee80211_channel.
Signed-off-by: Shanyu Zhao <shanyu.zhao@intel.com>
"Thermal Throttling" is an advance feature which only available for
newer _agn devices. Move from iwl-core to iwl-agn for better code
organization.
For 5000 series of devices, use long monitor timer to check
stuck tx queues.
This modification apply to all the 5000 series including 5300 and others.
Cc: stable@kernel.org [2.6.35]
Reported-by: drago01 <drago01@gmail.com>
For 5000 and 6000g2b series of devices, use long monitor timer to check
stuck tx queues.
.6000g2b series device, it is WiFi/BT combo device, there are some cases,
tx queues are not move for a period of time because the WiFi/BT coex.
.5000 series device, it is being reported firmware got reload more
often than necessary, so extend the timer to avoid un-necessary reload.
Change the name for monitor timer, also adding define for long monitor
timer; long monitor timer can be used for the type of devices require longer
time to determine the uCode is stuck on tx and needed reload.
Currently the driver will try to protect all frames,
which leads to a lot of odd things like sending an
RTS with a zeroed RA before multicast frames, which
is clearly bogus.
In order to fix all of this, we need to take a step
back and see what we need to achieve:
* we need RTS/CTS protection if requested by
the AP for the BSS, mac80211 tells us this
* in that case, CTS-to-self should only be
enabled when mac80211 tells us
* additionally, as a hardware workaround, on
some devices we have to protect aggregated
frames with RTS
To achieve the first two items, set up the RXON
accordingly and set the protection required flag
in the transmit command when mac80211 requests
protection for the frame.
To achieve the last item, set the rate-control
RTS-requested flag for all stations that we have
aggregation sessions with, and set the protection
required flag when sending aggregated frames (on
those devices where this is required).
Since otherwise bugs can occur, do not allow the
user to override the RTS-for-aggregation setting
from sysfs any more.
Finally, also clean up the way all these flags get
set in the driver and move everything into the
device-specific functions.
For WiFi/BT combo devices, add bluetooth statistics counter
read function to debugfs.
If its WiFi/BT combo device, the statistics notification sent by
uCode will include the additional BT related statistics counters.
Adding new data structure to support the new layout.
Code clean up to change name from having 5000 as part of name which easy
to confuse and think it is for 5000 series devices to more
generic _agn name since it is being used by multiple _agn devices.
No functional changes.
Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
"Flush" request can come from two different sources, it can either from
mac80211, or from device when the operation is needed. Here
adding the support for device issue "flush" request.
When receive tx complete with status is TX_STATUS_FAIL_RFKILL_FLUSH,
issue REPLY_TXFIFO_FLUSH command to uCode to flush out all the tx frames
in queues.
In this condition, since mac80211 has no knowledge of "flush" operation,
driver need to stop all the tx queues and wait for the operation
completed before wake up the queues for frames transmission.
Adding flush callback support in the driver. Two type of flush can be
issued by mac80211:
1. drop = true: frame drop is ok, issue REPLY_TXFIFO_FLUSH host command
to uCode to drop all the frames in tx fifo queues; then return the
control back to mac80211
2. drop = false: wait for either all the frames in tx fifo queues been
transmitted, or timeout; then return the control back to mac80211
If the flush request coming from mac80211, mac80211 will make sure there
are no additional frames push down to driver before flush operation is
completed.
The rate table in the bcast LQ is computed only when the station is
allocated, and chooses the lowest rate for the band. Because of when this
occurs, this is the 2.4 GHz band and uses the 0x420a (CCK, 1 Mbps) rate. In 5 GHz
beaconing mode, this rate will prevent beacons from being sent and any other
packets from being received.
We can fix this by re-initializing the bcast station's LQ command when the
channel is changed.
Signed-off-by: Daniel Halperin <dhalperi@cs.washington.edu>
Different devices have different calibration requirement,
some need DC calibration and some don't; make it a cfg parameter
for easy management.
agn and 3945 has different statistics_notif data structure; since 3945
has it statistics_notif data structure inside the _3945 portion of
iwl_priv, it make sense to move the agn statistics_notif into _agn
portion.
