It still holds a pointer to iwl_priv. But hopefully this will disappear at some point.
Also add the multiple inclusion protection to iwl-trans.h that was forgotten.
Move iwl-trans structures to iwl-trans.h
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
Since iwlagn_setup_deferred_work is always called, fold it into
iwl_setup_deferred_work. BT related works are setup by the new
bt_setup_deferred_work lib_ops.
Signed-off-by: Wey-Yi Guy <wey-yi.guy@intel.com>
Since iwlagn_rx_handler_setup is always called, fold it into
iwl_rx_handler_setup. BT related handlers are setup by the new
bt_rx_handler_setup lib_ops.
Not needed since the driver split.
Signed-off-by: Don Fry <donald.h.fry@intel.com>
Define bitmap for calibration
Another clean up work after driver split
After driver split, no need to make the code so complex
Not needed since the driver split. Move single use routines to
calling location and keep static where possible.
No need to do double level indirect call after driver split
no functional changes
Not needed since the driver split. Eliminate redundant routine.
This removes the for priv->trans.ops->...
Now, there are only two functions to send a host command:
* send_cmd that receives a iwl_host_cmd
* send_cmd_pdu that builds the iwl_host_cmd itself and received flags
The flags CMD_ASYNC / CMD_SYNC / CMD_WANT_SKB are not changed by the API
functions.
Kill the unused flags CMD_SIZE_NORMAL / CMD_NO_SKB on the way.
All "agn" devices use the same hcmd functions, no need to call indirectly.
remove hcmd_ops
drivers/net/wireless/iwlwifi/iwl-tx.c
Currently (3.0-rc2), modinfo iwlagn shows:
firmware: iwlwifi-5150-IWL5150_UCODE_API_MAX.ucode
firmware: iwlwifi-5000-IWL5000_UCODE_API_MAX.ucode
firmware: iwlwifi-6000g2b-IWL6000G2_UCODE_API_MAX.ucode
firmware: iwlwifi-6000g2a-IWL6000G2_UCODE_API_MAX.ucode
firmware: iwlwifi-6050-IWL6050_UCODE_API_MAX.ucode
firmware: iwlwifi-6000-IWL6000_UCODE_API_MAX.ucode
firmware: iwlwifi-100-IWL100_UCODE_API_MAX.ucode
firmware: iwlwifi-1000-IWL1000_UCODE_API_MAX.ucode
firmware: iwlwifi-105-IWL105_UCODE_API_MAX.ucode
firmware: iwlwifi-2030-IWL2030_UCODE_API_MAX.ucode
firmware: iwlwifi-2000-IWL2000_UCODE_API_MAX.ucode
which is obviously wrong, the user should not see the *_UCODE_API_MAX
macros but the actual ucode API versions here.
The problem are the
#define *_MODULE_FIRMWARE(api) *_FW_PRE #api ".ucode"
which do not expand api correctly (because this is a macro itself).
Fixed by using __stringify() from linux/stringify.h.
Further information about macro stringification can be found here:
http://gcc.gnu.org/onlinedocs/cpp/Stringification.html
Signed-off-by: Evgeni Golov <sargentd@die-welt.net>
Same operation needed by multiple devices, move to single function.
After driver split, no need to make indirect call to txfifo flush function
We use priv->mutex to avoid race conditions between iwl_chswitch_done()
and iwlagn_mac_channel_switch(), when marking channel switch in
progress. But iwl_chswitch_done() can be called in atomic context
from iwl_rx_csa() or with mutex already taken from iwlagn_commit_rxon().
These bugs were introduced by:
commit 79d07325502e73508f917475bc1617b60979dd94
Author: Wey-Yi Guy <wey-yi.w.guy@intel.com>
Date: Thu May 6 08:54:11 2010 -0700
iwlwifi: support channel switch offload in driver
To fix remove mutex from iwl_chswitch_done() and use atomic bitops for
marking channel switch pending.
Also remove iwl2030_hw_channel_switch() since 2000 series adapters are
2.4GHz only devices.
Cc: stable@kernel.org # 2.6.36+
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Acked-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
All agn devices use the same tx power function, remove the ops
For 6150 devices, modify the supported PCI subsystem ID.
All of these functions no longer need to be
accessed indirectly since they're shared in
all AGN devices.
In a subsequent patch, I want to make commands use
multiple TBs in a TFD. This is a simple change to
prepare the data structures for this, with as of
now still just a single TB supported.
All AGN devices need the bytecount table, so
remove the indirection and make the functions
static again.
After driver split, no need for debugfs callback, remove those
All agn devices use the same eeprom semaphore and calib version routines.
Delete the indirection and move the semaphore routines to where they are
used and make static.
All agn devices use the same module parameter structure. Delete the
indirection and access the structure diretly.
After driver split, no need to use ieee80211_ops, remove it
Thermal throttling functions are available for all _agn devices, call the
functions directly.
All _agn devices support continuous uCode trace, remove checking
After driver split, no need to call led functions through callback
There's no need to keep both normal and BT statistics
versions around all the time in memory when we only
use a subset of both. So keep only the subsets that
we need in memory, depending on the debug config).
Also, in doing so, we can remove all the calls to
iwl_bt_statistics() in the driver as we'll just
access the copied statistics now.
Finally, also remove this call from the one place
where it might still be needed and automatically
detect what kind of statistics the device is sending
based on their size. This way, we don't need to keep
track of which devices do what any more, which is
good since this is subject to change based on the
ucode version (as some ucode even for non-BT devices
will in fact use BT statistics).
Warn upon encountering a statistics command from the
ucode that isn't known, so we will find such issues
earlier in the future.
Tested-by: Don Fry <donald.h.fry@intel.com>
_agn driver should perform both sensitivity and chain noise calib.
After driver split, set_l0s config is no longer needed, remove it
After driver split, no need to use function pointer for those event and
register dump function.
define of firmware filenames use extra macro to build the files name.
Signed-off-by: Jay Sternberg <jay.e.sternberg@intel.com>
The ISR (interrupt service routine) ops are now
no longer necessary since they are the same for
all devices this driver now handles.
Again, a 4965 specific code path that we no
longer need in iwlagn.
Only 4965 had a bootstrap microcode image, so
the agn driver can completely ignore that and
we can remove some code from it.
All agn devices behave the same, so there's no
need to go through function pointers for any
of the ucode loading functionality.
Since the driver split, there's no need for
function pointers any more for aggregation
queue setup and teardown as all devices now
share the same code. Simplify this.
6035 series of devices should use the same uCode as 6030 series,
change it.
Remove check_plcp_health and check_ack_health ops methods, they are
unneeded after iwlegacy driver split. Merge check health code into to
iwl-rx.c and make functions static.
drivers/bluetooth/ath3k.c
drivers/bluetooth/btusb.c
