There's no need for this, all commands are the right size.
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
Move rxon_assoc to static function from ops
There are a number of places where the minimum
slot time is hardcoded to 20 TU, add a new
constant for that and use it everywhere.
For device supporting PAN/P2P, use the PAN
context to implement the remain-on-channel
operation using device offloads so that the
filters in the device will be programmed
correctly -- otherwise we cannot receive
any probe request frames during off-channel
periods.
When the DTIM is not 1, then the slot timing is in
some cases required to be calclulated based on the
DTIM interval instead of the beacon interval, fix
that.
The core module doesn't need to carry around
the code for chain settings that is used for
HT drivers (agn) only.
The different drivers need to do different things
after a scan, so create a post_scan hook to allow
them to do this.
iwl_commit_rxon really should be named
iwlagn_commit_rxon, so rename it.
move paramater definitions to a device paramater structure only
leaving the device name, which antennas are used and what firmware
file to use in the iwl_cfg structure. this will not completely
remove the redundancies but greatly reduce them for devices that
only vary by name or antennas. the parameters that are more
likely to change within a given device family are left in iwl_cfg.
also separate bt param structure added to help reduce more.
Signed-off-by: Jay Sternberg <jay.e.sternberg@intel.com>
The iwl_adjust_beacon_interval function is a bit
of black magic, so add comments to it describing
what it does. Also, in the case when there's no
beacon interval set, program the default into
the device (instead of adjusting, which results
in the max) since using the max in that case
interacts badly with dual-mode/PAN parameters.
Also update the PAN parameters accordingly and
use the same constant as here.
When the PAN context is unused, there's no
need to continually update it in the device.
So track which contexts are active (with the
special case that the WLAN context is always
active ...) and only send their commands to
the device when needed.
When only the PAN side was active, we gave no
time to the WLAN context, which is OK unless
we are scanning, which always happens on the
WLAN context. Fix this.
In order for the microcode to be able to handle
multiple interfaces, we need to give it the PAN
parameters that state how to allocate the time
between the two interfaces. Do this, and update
it wherever necessary.
Some commands will have different command IDs
for different contexts, so we need to store
those IDs in the context structure and use
them instead of hardcoding the commands.
In order to support multiple interfaces, we must move
a lot of data into per-context structures so we can
use the contexts the device offers. To start with,
this makes a lot of code context-aware, more changes
will move more things into the context structure.
Move bt coex functions to iwl-agn-lib.c, so those functions
can be shared by multiple wifi/bt combo devices
Change the define to more generic naming to match _agn devices
since the rssi calculation are common function for 5000 series and up
Currently the driver will try to protect all frames,
which leads to a lot of odd things like sending an
RTS with a zeroed RA before multicast frames, which
is clearly bogus.
In order to fix all of this, we need to take a step
back and see what we need to achieve:
* we need RTS/CTS protection if requested by
the AP for the BSS, mac80211 tells us this
* in that case, CTS-to-self should only be
enabled when mac80211 tells us
* additionally, as a hardware workaround, on
some devices we have to protect aggregated
frames with RTS
To achieve the first two items, set up the RXON
accordingly and set the protection required flag
in the transmit command when mac80211 requests
protection for the frame.
To achieve the last item, set the rate-control
RTS-requested flag for all stations that we have
aggregation sessions with, and set the protection
required flag when sending aggregated frames (on
those devices where this is required).
Since otherwise bugs can occur, do not allow the
user to override the RTS-for-aggregation setting
from sysfs any more.
Finally, also clean up the way all these flags get
set in the driver and move everything into the
device-specific functions.
Cc: stable@kernel.org [2.6.35]
Different devices have different size of phy calibration table; add
new TLV to specify the size. If the TLV is not part of uCode header, the
default table size will be used to make sure the backward
compatibilities.
This bit need to be set for both RTS/CTS or CTS-to-self protection, if
CTS-to-self is used, then uCode will check the RXON_FLG_SELF_CTS_EN
status. Change the name from TX_CMD_FLG_RTS_CTS_MSK to TX_CMD_FLAG_PROT_REQUIRE_MSK
to match the behavior of the bit setting.
Also update comments to reflect which hardware uses which of the TX command
flags.
Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
When building tx command, always set TX_CMD_FLAG_PROT_REQUIRE_MSK
for 5000 series and up.
Without setting this bit the firmware will not examine the RTS/CTS setting
and thus not send traffic with the appropriate protection. RTS/CTS is is
required for HT traffic in a noisy environment where, without this setting,
connections will stall on some hardware as documented in the patch that
initially attempted to address this:
commit 1152dcc28c66a74b5b3f1a3ede0aa6729bfd48e4
Author: Wey-Yi Guy <wey-yi.w.guy@intel.com>
Date: Fri Jan 15 13:42:58 2010 -0800
iwlwifi: Fix throughput stall issue in HT mode for 5000
Similar to 6000 and 1000 series, RTS/CTS is the recommended
protection mechanism for 5000 series in HT mode based on the HW design.
Using RTS/CTS will better protect the inner exchange from interference,
especially in highly-congested environment, it also prevent uCode encounter
TX FIFO underrun and other HT mode related performance issues.
For 3945 and 4965, different flags are used for RTS/CTS or CTS-to-Self
protection.
Chain noise calibration data are cleared after the calibration is done
in iwlagn_gain_computation() and iwl4965_gain_computation(). This cause
the debugfs entries for those data useless. To provide valid debugging
info, clear those data right before starting the calibration instead.
Signed-off-by: Shanyu Zhao <shanyu.zhao@intel.com>
This patch enables all remaining 6000 series Gen2 devices.
To work-around a firmware crash problem, we disable sending
bt coex command for 6000g2b series devices.
Some future hardware will require a different command to
be sent for bluetooth coexist, so make this a virtual
method that can be changed on a per-device basis.
Scan requesting doesn't need to be asynchronous
since all code paths leading up to it can sleep.
Make the scan request a new util operation that
is hw-specific (to account for 3945 vs. agn)
and call it right in place.
This patch moves a lot of code into iwlagn as
it need not be in iwlcore.
Some defines used by all agn devices, but the definitions were in
iwl-4965-hw.h, move those to iwl-agn-hw.h which is the better place for
those.
After re-structure the agn files layout and move all the
agn shared functions out from iwl-5000.c, all those functions and data
structures do not need to be declare "extern" from iwl-5000.c in
iwl-dev.h.
Multiple iwlagn based devices shared the same hw definitions.
Move device hardware related defines from iwl-5000-hw.h to iwl-agn-hw.h
file.
Multiple iwlagn based devices shared the same hcmd related functions.
Move from iwl-5000.c to iwl-agn-hcmd.c file.
