path: root/drivers/net/wireless/iwlwifi/iwl-agn-rs.h
2011-04-08iwlagn: no 3945 define neededWey-Yi Guy
Remove 3945 define Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2011-04-07iwlagn: change Copyright to 2011Wey-Yi Guy
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-07iwlagn: clean up some 3945/4965 remnantsJohannes Berg
When the driver was split, a bunch of definitions for the 3945 and 4965 devices stayed around, but they're now useless so remove (some of) them. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-01-31iwl3945: do not use agn specific IWL_RATE_COUNTStanislaw Gruszka
Only use IWL_RATE_COUNT_3945 in 3945 code. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Acked-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-07iwlwifi: remove agn rates info thereJohannes Berg
Code and data related to agn bitrates can be part of the agn module rather than being in the core module. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-09-11iwlwifi: fix default LQ table in 5.2 bandTomas Winkler
The default LQ is filled decreasingly using iwl_get_prev_ieee_rate from a starting rate. Since the starting rate is already the lowest one for a specific band it should be actually filled evenly with the starting rate: 1M and 6M for 5.2GHZ and 2.4GH respectively. The bug is that for for A or G-only it decreases to CCK rates which are not supported. iwl_get_prev_ieee_rate function is just not band aware. This affects broadcast station which lq table is not updated by rs algorithm G-only scenario is not treated by this patch iwl_get_prev_ieee_rate is removed completely as it is not used in other contexts Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-08-25iwlagn: let bluetooth traffic load impact rate scaleJohannes Berg
Depending on the amount of bluetooth traffic, using the shared antenna (antenna B) will have adverse impact on both bluetooth and wireless traffic. Add controls to improve the situation by making rate scaling depend on the BT load. When there's high bluetooth traffic load, there's little point in trying to aggregate as BT traffic would disrupt the aggregated frames all the time, so simply don't start sessions then. When BT traffic returns to lower levels, the rate scaling will come here again automatically when wifi traffic is high enough, and then it will be able to successfully enable aggregation. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-19iwlwifi: implement new mac80211 station add/remove callsReinette Chatre
mac80211 recently implemented two new callbacks that are used to request station add/remove from the driver. The benefot from these new callbacks are that they enable the driver to sleep while performing this work. This is a big patch since a few things need to be coordinated in this move. First we need to decouple station management from rate scaling, which caused a lot of code to be moved and/or deleted. Next we needed to tie in with mac80211's station management callback and let it direct our station management as well as trigger the rate scaling initialization. Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
2010-03-09iwlwifi: remove priv->active_rate_basicJohannes Berg
This variable is assigned a default value, but then assigned zero as soon as mac80211 calls a change channel (which will happen right after the hw is started) and after that it never changes again. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
2010-01-29iwlwifi: fix typo in IWL_CCK_RATES_MASKJohannes Berg
Due to a typo, the variable contains OFDM rates as well. The only user doesn't care, so this change doesn't really do anything but fix up my confusion. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2010-01-19iwlwifi: update copyright year to 2010Reinette Chatre
Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-27iwlwifi: move rate scaling structures to header fileReinette Chatre
Move to header file so they can be included and used in other parts of the driver. Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-31iwlwifi: remove 60 Mbps from sband bitrates tableDaniel C Halperin
ieee80211_supported_band is supposed to only contain legacy rates in the bitrates table (HT rates go in the ieee80211_sta_ht_cap substruct). Make iwlwifi driver obey this restriction by removing the 60 Mbps rate. Also, clean up a few pieces of other code that formerly relied on 60 Mbps being in sband->bitrates. Signed-off-by: Daniel C Halperin <daniel.c.halperin@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-11iwlagn: improve rate scale table searchMohamed Abbas
iwlagn rate scaling will periodically search other rate scale tables to switch to the best table regarding performance. In the past the number of search tables were 3. Every time the rate scale algorithm goes through these available tables in will stay in current table for some time before start searching again. Recent driver support more feature and antenna, so we have more tables to search. This patch make sure we go through all available tables. Signed-off-by: Mohamed Abbas <mohamed.abbas@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22iwlwifi: Display decoded rate/mcs informationWey-Yi Guy
This patch adding MCS information in rate_scale_table, it help for debugging rate scaling algorithm, easy to understand what is the current rate scale table and matching modulation, plus the last mcs used for tx. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22iwlwifi: adding MIMO3 support in rate scalingWey-Yi Guy
Separated the MIMO tpt matrix into MIMO2 and MIMO3, adding MIMO3 support in rate scaling algorithm. If the device support 3x3, then utilize all three antenna (A/B/C) for tx to improve throughput. Adding rs_switch_to_mimo3() function to allow switch to mimo3 modulation mode from other modes(legacy/siso/mimo2). Adding rs_move_mimo3_to_other() function to allow switch from mimo3 modulation mode to either siso or mimo2; also support toggle between SGI and NGI. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-16iwlwifi: HT performance improvement changesWey-Yi Guy
During rate scaling, checking for 0 retry count before decrement the count by 1, this can avoid the retry count to become 255 (0xff), which will cause the rate to drop faster than what we expect during good condition (receive 0 retry packet). also change the algorithm to make the rate not drop faster than what we like. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29iwlwifi: update copyright year to 2009Reinette Chatre
2009-01-29iwl3945: Use iwl-agn-rs.h rates definitions.Samuel Ortiz
A lot of rate relates definition are shared between iwl-3945-rs.h and iwl-agn-rs.h. Let's just use the agn version, and add the 3945 specific constants there. Signed-off-by: Samuel Ortiz <samuel.ortiz@intel.com> Signed-off-by: Abhijeet Kolekar <abhijeet.kolekar@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-12-12iwlwifi: change email contact informationWinkler, Tomas
This patch replaces personal emails with hopefully always valid Intel Linux Wireless, which will be routed to a current maintainer Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-10iwlwifi: trivial removal of some 4965 remaining from iwl-agn-rs.hWinkler, Tomas
This patch removes 4965 prefix from comments and one function in iwl-agn-rs.h Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31iwlwifi: run through spell checkerTomas Winkler
2008-10-31iwlwifi: take a valid antenna upon rate scale initTomas Winkler
This patch selects a valid antennae upon rate scale init. This solves a SYSASSERT complaining that the driver is setting a non valid antenna in the LQ CMD. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-11iwlwifi: Added support for 3 antennasGuy Cohen
Added support for 3 antennas for Legacy, SISO and MIMO2. MIMO3 is still not supported yet. Signed-off-by: Guy Cohen <guy.cohen@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-04iwlwifi: kill iwl4965_fill_rs_infoTomas Winkler
iwl4965_fill_rs_info was used in sysfs. This info is already present in iwl-agn-rs debugfs. Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-04iwlwifi: rename iwl-4695-rs to iwl-agn-rsTomas Winkler
This patch renames iwl-4965-rs to iwl-agn-rs as it provides rate scale capability for all AGN capable iwlwifi drivers. Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
