5000 series has issue supporting power save idle mode:
commit 9dc2153315650eae220898668b6aa56a25c130be
iwlwifi: always support idle mode for agn devices
For agn devices, always support idle mode which help power
consumption in idle unassociated state.
the above changes cause 5000 become not stable when power management is "on"
http://bugzilla.intellinuxwireless.org/show_bug.cgi?id=2312
Cc: stable@kernel.org #2.6.39, #3.0.0
Reported-by: Devin J Pohly <djpohly+iwl@gmail.com>
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
Remove the "disable otp refresh" work-around, not needed anymore.
The price to pay is the access to the log system. Therefore logs from bus layer
are sent by dev_printk instead of IWL_XXXX.
Rename bus->priv to bus->drv_data to make the separation even clearer.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Since iwlagn_setup_deferred_work is always called, fold it into
iwl_setup_deferred_work. BT related works are setup by the new
bt_setup_deferred_work lib_ops.
Signed-off-by: Wey-Yi Guy <wey-yi.guy@intel.com>
Since iwlagn_rx_handler_setup is always called, fold it into
iwl_rx_handler_setup. BT related handlers are setup by the new
bt_rx_handler_setup lib_ops.
There are still a few functions here and there that should be
put in the transport layer. Mainly the functions that are related to the reclaim flow.
Also create a new file: iwl-trans-int-pcie.h which will include
the non static functions that are shared among the current pcie transport layer.
Not needed since the driver split.
Signed-off-by: Don Fry <donald.h.fry@intel.com>
Modify the comments for iwl_cfg, no functional changes
Another clean up work after driver split
After driver split, no need to make the code so complex
Not needed since the driver split. Move single use routines to
calling location and keep static where possible.
No need to do double level indirect call after driver split
Now, there are only two functions to send a host command:
* send_cmd that receives a iwl_host_cmd
* send_cmd_pdu that builds the iwl_host_cmd itself and received flags
The flags CMD_ASYNC / CMD_SYNC / CMD_WANT_SKB are not changed by the API
functions.
Kill the unused flags CMD_SIZE_NORMAL / CMD_NO_SKB on the way.
Tx stop moves to transport layer.
Tx free functions move to the transport layer. Unify the functions that deal with tx queues and cmd queue.
Since the CMD queue is not fully allocated, but uses the q->n_bd / q->window trick, the release flow of TX queue and CMD queue was different.
iwlagn_txq_free_tfd receives now the index of the TFD to be freed, which allows to unify the release flow for all the queues.
All "agn" devices use the same hcmd functions, no need to call indirectly.
remove hcmd_ops
These functions allocate all the Tx context. Only the simple tx_init is exported as API.
The transport layer is responsible for all the queues, DMA rings etc...
This is the beginning of the separation of all the code that is tighly
related to HW design to the aforementioned transport layer.
Add the parameter to disable stuck queue watchdog timer, different platforms
might have different timing. Provide the option to disable the timer to prevent
un-necessary firmware reload.
Use the rate that mac80211 requested to fill the
uCode TX command for the beacon. Unfortunately,
the uCode is (currently?) ignoring it, but now
at least fill it properly.
Add power_level module parameter to set the default power save level.
Power save level has range from 1 - 5, default power save level is 1.
Add power_save module parameter to enable power management if needed
Default power management is disabled.
Continue to popule the PCI layer and the iwl_bus_ops with the power related
stuff.
Move some PCI functionality to the new iwl_pci.[ch] files:
* the PCI_DEVICE_TABLE
* the pci_driver struct definition
* the PCI probe / remove functions
* the PCI suspend / resume functions
All these functions are now split: the trigger comes from the PCI layer which
calls to the bus generic code located in the other files.
This is the beginning only. There are still a lot of PCI related code needs
to be gathered.
After driver split, no need to make indirect call to txfifo flush function
Instead of having the separated define, use the sku capabilities in EEPROM
Move no_sleep_autoadjust module parameter into iwlagn_mod_params structure
along with all the other iwlagn module parameters
Move led_mode module parameter into iwlagn_mod_params structure
Move bt_coex_active module parameter into iwlagn_mod_params structure
No need to go though multiple levels of indirect call to send RXON command.
Call it directly
After driver split, no need to use function "ops" for post_scan.
For some timing reason, 1000 device having problem to kick-in to aggregation
without sending rxon assoc command. This is a W/A until find the real reason
We use priv->mutex to avoid race conditions between iwl_chswitch_done()
and iwlagn_mac_channel_switch(), when marking channel switch in
progress. But iwl_chswitch_done() can be called in atomic context
from iwl_rx_csa() or with mutex already taken from iwlagn_commit_rxon().
These bugs were introduced by:
commit 79d07325502e73508f917475bc1617b60979dd94
Author: Wey-Yi Guy <wey-yi.w.guy@intel.com>
Date: Thu May 6 08:54:11 2010 -0700
iwlwifi: support channel switch offload in driver
To fix remove mutex from iwl_chswitch_done() and use atomic bitops for
marking channel switch pending.
Also remove iwl2030_hw_channel_switch() since 2000 series adapters are
2.4GHz only devices.
Cc: stable@kernel.org # 2.6.36+
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Acked-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
All agn devices use the same tx power function, remove the ops
All of these functions no longer need to be
accessed indirectly since they're shared in
all AGN devices.
All AGN devices need the bytecount table, so
remove the indirection and make the functions
static again.
There's no need for this, all commands are the right size.
After driver split, no need for debugfs callback, remove those
All agn devices use the same module parameter structure. Delete the
indirection and access the structure diretly.
Move rxon_assoc to static function from ops
If a device error happens while the uCode is
being loaded or initialised, we will attempt
to restart the device (which will likely fail
again, but that's not the issue here). During
this new restart, we turn off the device, but
as the uCode failed to initialise it already
is turned off. As a consequence, grabbing NIC
access will fail and cause excessive messages
and hangs.
To fix this issue, introduce a new status bit
and only attempt to reprogram the device when
it isn't already disabled.
No longer use, remove it
No longer used by _agn devices, remove it
After driver split, no need to use ieee80211_ops, remove it
Thermal throttling functions are available for all _agn devices, call the
functions directly.
All _agn devices support continuous uCode trace, remove checking
