move paramater definitions to a device paramater structure only
leaving the device name, which antennas are used and what firmware
file to use in the iwl_cfg structure. this will not completely
remove the redundancies but greatly reduce them for devices that
only vary by name or antennas. the parameters that are more
likely to change within a given device family are left in iwl_cfg.
also separate bt param structure added to help reduce more.
Signed-off-by: Jay Sternberg <jay.e.sternberg@intel.com>
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
Remove the "\n" from following module parameter description:
- enable wifi/bluetooth co-exist
- led mode: 0=blinking, 1=On(RF On)/Off(RF Off), (default 0)
to be consistence with the rest of iwlagn/iwlcore module parameters format.
Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
Current blinking rate is calculated based on the difference between
current tx/rx byte counts and priv->led_tpt.
priv->led_tpt should not get reset in iwl_leds_init(), this function can be
called by bring interface "up" or "down", or when uCode sysassert occurred.
resetting the led_tpt parameter will introduce incorrect led blinking behavior.
The iwlwifi drivers have LED blinking requirements that
mac80211 cannot fulfill due to the use of just a single
LED instead of different ones for TX, RX, radio etc.
Instead, the single LED blinks according to transfers
and is solid on the rest of the time. As such, having
LED class devices registered that mac80211 triggers are
connected to is pointless as we don't use the triggers
anyway.
Remove all the useless code and add hooks into the
driver itself. At the same time, make the LED code
abstracted so the core code that determines blink rate
etc. can be shared between 3945 and agn in iwlcore.
At the same time, the fact that we removed the use of
the mac80211 LED triggers means we can also remove the
IWLWIFI_LEDS Kconfig symbol since the LED support is
now self-contained.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Today's implementation allow LED to blink based on the traffic
condition. We introduce an additional LED mode that reflects the RF
state.
The supported LED modes after this are:
IWL_LED_BLINK (current/default) - blink rate based on current Tx/Rx
traffic
IWL_LED_RF_STATE (new) -
LED OFF: No power/RF disabled, the LED is emitting no light
LED ON: Powered/RF enabled, the LED is emitting light
in a stable non-flashing state.
In order to provide the flexibility to support different LED
behavior per user/system preference we add "led_mode" iwlcore module
parameter.
Adjust led blink rate to compensate on a MAC Clock difference on every
HW. Led blink rate analysis showed an average deviation of 0% on 3945,
5% on 4965 HW and 20% on 5000 series and up.
Need to compensate on the led on/off time per HW according to the
deviation to achieve the desired led frequency
The calculation is: (100-averageDeviation)/100 * blinkTime
For code efficiency the calculation will be:
compensation = (100 - averageDeviation) * 64 / 100
NewBlinkTime = (compensation * BlinkTime) / 64
Modify LED blink index table to include 1Mbps.
Break down the traffic type and counter for both Tx and Rx.
Enhance the tx_statistics and rx_statistics debugfs function and move
to /sys/kernel/debug/ieee80211/phy0/iwlagn/debug directory to help
better debugging both driver and uCode related problems.
Even with the split into iwlcore/agn/3945 not all symbols
that cross file boundaries are needed in other modules, a
few are only used within iwlcore, for example.
The current command sending in iwlwifi is a bit of a mess:
1) there is a struct, iwl_cmd, that contains both driver
and device data in a single packed structure -- this
is very confusing
2) the on-stack data and the command metadata share a
structure by embedding the latter in the former, which
is also rather confusing because it leads to weird
unions and similarly odd constructs
3) each txq always has enough space for 256 commands,
even if only 32 end up being used
This patch fixes these things:
1) rename iwl_cmd to iwl_device_cmd and keep track of
command metadata and device command separately, in
two arrays in each tx queue
2) remove the 'meta' member from iwl_host_cmd and only
put in the required members
3) allocate the cmd/meta arrays separately instead of
embedding them into the txq structure
For controlling led blinking, counting both tx and rx data traffic; this
will be able to handle traffic in either direction
Led functions are generic for all the devices except 3945, so remove the
reference to 4965
Patch fixes the bug at
http://www.intellinuxwireless.org/bugzilla/show_bug.cgi?id=1903
when SW rfkill is invoked by 'iwconfig txpower off',
the existing connection disassociates and led off command is sent
to the device which returns error as rfkill is 'true'.
Patch fixes this by just avoiding sending the led off/on command when
disassociated. The main purpose of the led_disassociate callback
is to start or stop the blinking.
There are three states in led
1) Always on when radio is on
2) Always off when radio is off
3) blink when associated and if there is some traffic.
In this callback 'allow_blinking' needs to be set false
when associated, as LED will be always on.
Signed-off-by: Abhijeet Kolekar <abhijeet.kolekar@intel.com>
Fixed led device naming for the iwl driver. Due to the
documentation of the led subsystem/class the naming should be
"devicename:colour:function" while not applying sections
should be left blank.
This should lead to e.g. "iwl-phy0::RX" instead of "iwl-phy0:RX".
Signed-off-by: Danny Kukawka <dkukawka@suse.de>
Acked-by: Reinette Chatre <reinette.chatre@intel.com>
Call IWL_DEBUG macro with explicit priv argument.
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
Acked-by: Samuel Ortiz <samuel.ortiz@intel.com>
IWL_ERR doesn't use hidden priv pointer.
Signed-off-by: Zhu Yi <yi.zhu@intel.com>
This adds line feed to printk.
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
This patch removes includes of iwl-helpers.h where not needed
Acked-by: Samuel Ortiz <sameo@linux.intel.com>
This patch replaces personal emails with hopefully
always valid Intel Linux Wireless, which will be routed
to a current maintainer
This patch lets the files using linux/version.h match the files that
#include it.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Having the buffer on the stack and even re-using it for all led devices is bad.
Not being able to resolve the name member of the led device structure to a
meaningful value leads to confusion during ad-hoc debugging and potential
breakage in the future, if we ever decide to access the name member outside of
the registration function. Move the buffer to our private per led device
structures so that it is accessible after registration.
A quick grep didn't yield any occurence of using the led device name parameter
outside of the led device registration function, so currently we should already
be safe for normal operation.
Signed-off-by: Sven Wegener <sven.wegener@stealer.net>
Cc: Richard Purdie <rpurdie@rpsys.net>
Acked-by: Zhu Yi <yi.zhu@intel.com>
This patch sets the led register in disassociation flow according to
rf-kill state : off - in case of rf_kill, on - otherwise.
Signed-off-by: Esti Kummer <ester.kummer@intel.com>
ia64:
drivers/net/wireless/iwlwifi/iwl-led.c: In function `iwl_get_blink_rate':
drivers/net/wireless/iwlwifi/iwl-led.c:271: warning: long long int format, s64 arg (arg 6)
drivers/net/wireless/iwlwifi/iwl-led.c:271: warning: long long int format, u64 arg (arg 7)
We do not know what type the architecture uses to impement u64 and s64,
hence we must cast the variables for printing.
Cc: Tomas Winkler <tomas.winkler@intel.com>
Cc: John W. Linville <linville@tuxdriver.com>
Cc: Zhu Yi <yi.zhu@intel.com>
This is a small fix to change the idx type from int to unsigned.
This patch makes correct usage of the LED blink table.
This patch fixes LED stall. last_blink_time was updated only if LED command
was sent, causing wrong computation of the througput.
Some code cleanup comes with this patch as well
This patch renames iwl-4965.h to iwl-dev.h
This patch moves inline functions into iwl-core.h
This patch initialize all fields in led before registering it
This fixes oops on initialization
This patch renames iwl-4965-io.h back to iw-io.h
it also remove 4965 from all functions it supplies
This patch add LEDS support to 3965 and 4965 drivers. It is based on
led trigger and class. For our drivers we needed to avoid two things.
1- We receive led trigger on/off on each Rx\Tx frame. In our driver
we can not call led command like that. In this driver once driver
receive a start of traffic it call the led command to start blinking
then we count all bytes of Tx and Rx frame, after two second we count the
blink rate of last two second then id blink rate changed we call the led
commands
2- Since we can call led command very often, we make sure we call the
led command after we receive the statistics notification so
we don't need to wake up the ucode id it is in sleep state.
This patch was tested with 4965 and 3945.
Signed-off-by: Mohamed Abbas <mabbas@linux.intel.com>
Signed-off-by: Ian Schram<ischram@telenet.be>
