Fix spelling error across the driver.
Modified only comments and prints.
Signed-off-by: Sara Sharon <sara.sharon@intel.com>
Reviewed-by: Johannes Berg <johannes.berg@intel.com>
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Newer devices have more PAPD channel groups.
Signed-off-by: Eran Harary <eran.harary@intel.com>
CMD_SYNC is really 0 which is confusing:
if (cmd.flags & CMD_SYNC) is always false.
Fix this by simply removing its definition.
All messages should have a trailing newline, add all the
missing ones. Also make all messages constants, replacing
the single one that pointlessly used a variable.
The number of the PAPD group was increased in new devices.
Since we might now get empty entries on older devices, don't
warn if an entry is empty.
Signed-off-by: Ariej Marjieh <ariej.marjieh@intel.com>
Happy new year!
Remove calibration per-channel data as it's no longer used.
Signed-off-by: David Spinadel <david.spinadel@intel.com>
Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
This can happen during development but can cause problems,
WARN (once) and go on.
Reviewed-by: Guy Cohen <guy.cohen@intel.com>
If all the pieces of iwlwifi are built into the kernel
then there's no need for it to export its symbols to
other modules, so prevent that.
7000.c was released as GPL only by mistake: it should be
dual licensed - GPL / BSD.
The file that contains the license in the kernel is COPYING
and not LICENSE.GPL.
The PIC was supposed to be a small signature appended to the
PhyDB data, but the signature isn't really static and thus
attempting to check it just causes the warnings spuriously
so remove them.
Signed-off-by: Dor Shaish <dor.shaish@intel.com>
The new MVM (multi-virtual MAC) firmware driver
requires NVM (non-volatile memory) parsing code
and some PHY information database code. Add this
separately.
The ucode16 option is still very much work in
progress, so there's no need to ask any users
about it. Remove the option and code for now,
we'll put it back when it's actually working.
Each modules will hold a pointer to struct device instead.
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
Implement mapping of channel to TX power channel group,
for sending channel specific data before add context.
Add iwl_phy_db structure and API.
