In a subsequent patch, I want to make commands use
multiple TBs in a TFD. This is a simple change to
prepare the data structures for this, with as of
now still just a single TB supported.
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
There are a number of things in the driver that
may result in a BUG(), which is suboptimal since
it's hard to get debugging information out of
the driver in that case and the user experience
is also not good :-)
Almost all BUG_ON instances can be converted to
WARN_ON with a few lines of appropriate error
handling, so do that instead.
Some code was removed, but a variable it used
and that is now unused stayed around, kill it.
After driver split, no more 3945 only station support needed.
Intel WiFi devices 3945 and 4965 now have their own driver in the folder
drivers/net/wireless/iwlegacy
Add support to build these drivers independently of the driver for
AGN devices. Selecting the 3945 builds iwl3945.ko and iwl_legacy.ko,
and selecting the 4965 builds iwl4965.ko and iwl_legacy.ko. iwl-legacy.ko
contains code shared between both devices.
The 3945 is an ABG/BG device, with no support for 802.11n. The 4965 is a 2x3
ABGN device.
Signed-off-by: Meenakshi Venkataraman <meenakshi.venkataraman@intel.com>
Acked-by: Johannes Berg <johannes.berg@intel.com>
This reverts commit aa833c4b1a928b8d3c4fcc2faaa0d6b81ea02b56.
ABGN device.
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
Documentation/trace/events.txt: Remove obsolete sched_signal_send.
writeback: fix global_dirty_limits comment runtime -> real-time
ppc: fix comment typo singal -> signal
drivers: fix comment typo diable -> disable.
m68k: fix comment typo diable -> disable.
wireless: comment typo fix diable -> disable.
media: comment typo fix diable -> disable.
remove doc for obsolete dynamic-printk kernel-parameter
remove extraneous 'is' from Documentation/iostats.txt
Fix spelling milisec -> ms in snd_ps3 module parameter description
Fix spelling mistakes in comments
Revert conflicting V4L changes
i7core_edac: fix typos in comments
mm/rmap.c: fix comment
sound, ca0106: Fix assignment to 'channel'.
hrtimer: fix a typo in comment
init/Kconfig: fix typo
anon_inodes: fix wrong function name in comment
fix comment typos concerning "consistent"
poll: fix a typo in comment
Fix up trivial conflicts in:
- drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c)
- fs/ext4/ext4.h
Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
During reprogram stations, do not send link quality command.
uCode will crash if receive link quality command for invalid station
Instead of unconditionally sending unassoc RXON,
before any assoc RXON, re-send only the AP STA
entry which is required after the BSSID has been
programmed into the device to set up internal
filters in the microcode properly.
This fixes some issues that we correlated with
sending a lot of RXON commands to the device.
"gadget", "through", "command", "maintain", "maintain", "controller", "address",
"between", "initiali[zs]e", "instead", "function", "select", "already",
"equal", "access", "management", "hierarchy", "registration", "interest",
"relative", "memory", "offset", "already",
By duplicating a little bit of code between 3945
and agn, we can move a lot of code into an agn
specific station management file and thus reduce
the amount of code in core that is dead to 3945.
before:
212886 3872 96 216854 34f16 iwlcore.ko
620542 10448 304 631294 9a1fe iwlagn.ko
314013 3264 196 317473 4d821 iwl3945.ko
after:
202857 3872 92 206821 327e5 iwlcore.ko
629102 10448 308 639858 9c372 iwlagn.ko
314240 3264 196 317700 4d904 iwl3945.ko
delta:
-10029 iwlcore.ko
8560 iwlagn.ko
227 iwl3945.ko
so it's a net win even if you have both loaded,
likely because a lot of EXPORT_SYMBOLs go away.
The default LQ is filled decreasingly using
iwl_get_prev_ieee_rate from a starting rate.
Since the starting rate is already the lowest one for
a specific band it should be actually filled evenly with
the starting rate: 1M and 6M for 5.2GHZ and 2.4GH respectively.
The bug is that for for A or G-only it decreases to
CCK rates which are not supported.
iwl_get_prev_ieee_rate function is just not band aware.
This affects broadcast station which lq table
is not updated by rs algorithm
G-only scenario is not treated by this patch
iwl_get_prev_ieee_rate is removed completely as it
is not used in other contexts
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
A lot of HT configuration semantically belongs into
the context, even if right now it will never be
different between contexts. Move it so we're better
prepared for future changes in mac80211.
Sometimes we only pass around station
pointers but need to find the context
they belong to, so store it in there.
Since the default context is initialised to zero,
and the default flags are zero, no more code is
needed to initialise them right now, but another
context can have different default flags.
HW crypto needs to be aware of the context, and there
are different command IDs for the WEP keys per context,
so move the key tracking variables and command IDs into
the context structure.
Each context needs to use a different AP sta
ID, so we need to move that into the context
struct instead of hardcoding it.
The microcode tracks stations per context, so
the driver needs to do that as well for adding,
deleting and restoring them, especially in the
implicit removal case when we send an RXON.
The broadcast station ID is per context, so
add a variable for the ID in the context and
use it everywhere we previously hardcoded it.
In order to support multiple interfaces, we must move
a lot of data into per-context structures so we can
use the contexts the device offers. To start with,
this makes a lot of code context-aware, more changes
will move more things into the context structure.
Currently, mac80211 translates the cfg80211
cipher suite selectors into ALG_* values.
That isn't all too useful, and some drivers
benefit from the distinction between WEP40
and WEP104 as well. Therefore, convert it
all to use the cipher suite selectors.
Acked-by: Gertjan van Wingerde <gwingerde@gmail.com>
spin_is_locked() can return zero on some (UP?)
configurations because locks don't exist, and
that causes an endless amount of warnings. Use
lockdep_assert_held() instead, which has two
advantages:
1) it verifies the current task is holding
the lock or mutex
2) it compiles away completely when lockdep
is not enabled
Cc: stable@kernel.org [2.6.34+, maybe only parts of patch]
Reported-by: Thomas Meyer <thomas@m3y3r.de>
The rate table in the bcast LQ is computed only when the station is
allocated, and chooses the lowest rate for the band. Because of when this
occurs, this is the 2.4 GHz band and uses the 0x420a (CCK, 1 Mbps) rate. In 5 GHz
beaconing mode, this rate will prevent beacons from being sent and any other
packets from being received.
We can fix this by re-initializing the bcast station's LQ command when the
channel is changed.
Signed-off-by: Daniel Halperin <dhalperi@cs.washington.edu>
Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
When station management calls to ucode return
an error we could previously do nothing, but
now that almost all calls are synchronous we
can actually let the error bubble up. Use EIO
as the error as it best indicates a problem
with the device.
Key management can use sync commands
instead of asynchronous ones to have
better error checking.
Also add checks that the commands all
should have the mutex held.
Now that the ampdu_action callback can sleep,
we can use the mutex to properly protect the
aggregation data, and return useful errors if
they should happen.
Also, add some sleep and mutex debugging so
we won't call any of the functions that now
require being able to sleep and/or the mutex
to be held in an invalid context.
Acked-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
net/mac80211/mlme.c
We are seeing some race conditions between incoming station management
requests (station add/remove) and the internal unassoc RXON command that
modifies station table. Modify these flows to require the mutex to be held
and thus serializing them.
This fixes http://bugzilla.intellinuxwireless.org/show_bug.cgi?id=2207
git://git.kernel.org/pub/scm/linux/kernel/git/iwlwifi/iwlwifi-2.6
The intent here is to test that "sta_id_r" is a valid pointer. We do
this same test later on in the function.
Btw iwl_add_bssid_station() is called from two places and "sta_id_r" is
a valid pointer from both callers.
There are a few places where sta_lock is used, but the
station information protected by it is accessed outside
of the lock. Address this in two ways, if the access
won't sleep then just move the access into the lock, if
the access can sleep then copy the needed station
information to the stack to be accessed without risk of
it changing while access in progress.
Additionally, a number of other places access station
station information without holding the sta_lock, fix
those as well.
There are now five places where we need to
look up the station ID, but the sta pointer
may be NULL due to mac80211 passing that to
indicate a certain special state.
Replace all these by a new inline function,
called iwl_sta_id_or_broadcast(), and add
documentation about when to use it.
Remove the check before invoking iwl_set_ht_add_station(),
since neither of the conditions in this check makes sense,
as either we pass in a NULL ht_info (first branch) or in
the IBSS case an ht_info with ht_enabled=false.
This function is now only used for the special
IBSS BSSID station, so rename it to indicate
this. The new name is iwl_add_bssid_station.
4965 code is the only thing that now still
needs iwl_find_station(), so move it there
and make it static. Everything else can
rely on the station data passed by mac80211.
With the station ID being stored in the
station struct, which mac80211 gives us
for TKIP phase 1 key updates, we can also
remove the use of iwl_find_station() in
that code path.
for aggregation callbacks, we can also
those code paths.
Since we now store the station ID in each station
struct, many places need not look at the station
table any more since they can just pull the station
ID out of the struct. Remove iwl_get_sta_id() and
use iwl_sta_id() instead as appropriate.
This reduces the amount of code needed to find the
right station significantly, and works since
mac80211 passes the station only after it has been
fully initialised, ie. even if TX races with
station addition it will only be passed to TX once
the addition is complete.
mac80211 allows us to store private data per
station, so put the station ID there. This
allows us to avoid the station ID lookup when
removing regular stations. To also be able to
avoid the lookup to remove the special IBSS
BSSID station, track its ID in the per-vif
private data.
When station is using an HT channel to communicate to AP and communication
is lost then driver will first be notified that channel is not an HT
channel anymore before AP station is removed. A consequence of that is that
the driver will know that it is not communicating on HT anymore, but the
rate scaling table is still under the impression it is operating in HT. Any
time after driver has been notified channel is not HT anymore there will
thus be a firmware SYSASSERT when the current active LQ command is sent.
A workaround for this issue is to not send a LQ command in the short time between
being notified channel is not HT anymore and rate scaling table being
updated.
This fixes http://bugzilla.intellinuxwireless.org/show_bug.cgi?id=2173
Currently, the broadcast station is managed along
with the interface type, rather than always being
present. That leads to a bug with injection -- it
is currently not possible to inject frames when
the only virtual interface is a monitor, because
in that the required broadcast station is missing.
Additionally, allocating and deallocating the
broadcast station's LQ all the time is wasteful,
and the code to support this is fairly complex.
So this changes completely the way we manage the
broadcast station. Rather than manage it along
with any interface, we now allocate it when we
bring the device up, and remove it again when we
bring the device down. When we bring the device
up, we don't immediately program the broadcast
station into it, instead we just mark it active
and rely on the next restore cycle to upload it
to the device. This works because an unassociated
RXON is always required at least once to set up
device parameters, which implies a reprogramming
of stations into the device.
As we now manage all stations properly, there no
longer is a need for forcing a clearing of them
via iwl_clear_ucode_stations(), which can become
a lot simpler.
Rename iwl_sta_init_lq to iwl_sta_alloc_lq and
move sending it out into the caller.
The "is_ap" argument to iwl_sta_init_lq is never true,
so it and the corresponding code can be removed. However,
it needs to have the station ID because it is also used
for the IBSS BSSID station, and that doesn't have the
broadcast ID.
This function is only needed by 4965, so
it need not be in core code and can be
made static.
Currently iwlwifi will eventually exhaust the station
table when adding the BSSID station for IBSS mode,
unless the interface is set down.
The new mac80211 ibss joined/left notification allows
us to fix that easily by moving the code to add the
IBSS station to the notification, and also adding
code to remove it again when we leave the IBSS.
We'll need that function for IBSS station management,
so pass it the address, which is the only thing it
uses from the station struct.
When adding the broadcast station the link quality command is
generated on demand, sent to device, and disappears. It is thus not
available for later cases when we need to restore stations and need
to send the link quality command afterwards. Now, when first adding the
broadcast station, also generate its link quality command to always be
available for later restoring.
Also fix an issue when adding local stations where the "in progress" state
is never cleared.
Reported-by: Johannes Berg <johannes.berg@intel.com>
This function is called twice in a row, remove the second one.
Signed-off-by: Shanyu Zhao <shanyu.zhao@intel.com>
