Extend channel to frequency mapping for 802.11j Japan 4.9GHz band, according to
IEEE802.11 section 17.3.8.3.2 and Annex J. Because there are now overlapping
channel numbers in the 2GHz and 5GHz band we can't map from channel to
frequency without knowing the band. This is no problem as in most contexts we
know the band. In places where we don't know the band (and WEXT compatibility)
we assume the 2GHz band for channels below 14.
This patch does not implement all channel to frequency mappings defined in
802.11, it's just an extension for 802.11j 20MHz channels. 5MHz and 10MHz
channels as well as 802.11y channels have been omitted.
The following drivers have been updated to reflect the API changes:
iwl-3945, iwl-agn, iwmc3200wifi, libertas, mwl8k, rt2x00, wl1251, wl12xx.
The drivers have been compile-tested only.
Signed-off-by: Bruno Randolf <br1@einfach.org>
Signed-off-by: Brian Prodoehl <bprodoehl@gmail.com>
Acked-by: Luciano Coelho <coelho@ti.com>
drivers/net/wireless/iwlwifi/iwl-1000.c
drivers/net/wireless/iwlwifi/iwl-6000.c
drivers/net/wireless/iwlwifi/iwl-core.h
Allow userspace to specify that a given key
is default only for unicast and/or multicast
transmissions. Only WEP keys are for both,
WPA/RSN keys set here are GTKs for multicast
only. For more future flexibility, allow to
specify all combiations.
Wireless extensions can only set both so use
nl80211; WEP keys (connect keys) must be set
as default for both (but 802.1X WEP is still
possible).
The code wants to check if there's a channel and it is not disabled,
but it used to check if channel is not NULL and accessed the channel
struct if this check failed.
Signed-off-by: Sven Neumann <s.neumann@raumfeld.com>
Acked-by: Dan Williams <dcbw@redhat.com>
Using static const generally increases object text and decreases data size.
It also generally decreases overall object size.
3650 56 704 4410 113a drivers/net/wireless/libertas/rx.o.new
3695 56 704 4455 1167 drivers/net/wireless/libertas/rx.o.old
27328 964 5240 33532 82fc drivers/net/wireless/libertas/cfg.o.new
27328 964 5240 33532 82fc drivers/net/wireless/libertas/cfg.o.old
Remove duplicated #include('s) in
drivers/net/wireless/libertas/cfg.c
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
There are currently no provisions in place to ensure that the scanning
task has been stopped when the interface is stopped or removed.
This can result in a WARNING at net/wireless/core.c:643 and other badness
when you remove the module while a scan is happening.
Terminate the scanning task during interface stop.
Signed-off-by: Daniel Drake <dsd@laptop.org>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
Documentation/feature-removal-schedule.txt
drivers/net/wireless/ipw2x00/ipw2200.c
This adds API to allow adding per-station GTKs,
updates mac80211 to support it, and also allows
drivers to remove a key from hwaccel again when
this may be necessary due to multiple GTKs.
arch/arm/mach-omap2/board-omap3pandora.c
drivers/net/wireless/ath/ath5k/base.c
CHECK drivers/net/wireless/libertas/cfg.c
drivers/net/wireless/libertas/cfg.c:493:19: warning: cast to restricted __le16
CHECK drivers/net/wireless/libertas/mesh.c
drivers/net/wireless/libertas/mesh.c:577:16: warning: incorrect type in assignment (different base types)
drivers/net/wireless/libertas/mesh.c:577:16: expected restricted __le32 [addressable] [assigned] [usertype] id
drivers/net/wireless/libertas/mesh.c:577:16: got bool
drivers/net/wireless/libertas/if_sdio.c
i386 allmodconfig:
drivers/net/wireless/libertas/cfg.c: In function 'lbs_scan_worker':
drivers/net/wireless/libertas/cfg.c:722: error: 'TASK_NORMAL' undeclared (first use in this function)
drivers/net/wireless/libertas/cfg.c:722: error: (Each undeclared identifier is reported only once
drivers/net/wireless/libertas/cfg.c:722: error: for each function it appears in.)
drivers/net/wireless/libertas/cfg.c: In function 'lbs_cfg_connect':
drivers/net/wireless/libertas/cfg.c:1267: error: 'TASK_INTERRUPTIBLE' undeclared (first use in this function)
drivers/net/wireless/libertas/cfg.c:1267: error: implicit declaration of function 'signal_pending'
drivers/net/wireless/libertas/cfg.c:1267: error: implicit declaration of function 'schedule_timeout'
So wait.h has a dependency on sched.h, but doesn't include sched.h. This
patch doesn't fix that.
Cc: Dan Williams <dcbw@redhat.com>
Cc: "John W. Linville" <linville@tuxdriver.com>
Bring back the comment about FW v5 status codes from the pre-cfg80211
driver, and let through status codes that aren't remapped by the
firmware.
Signed-off-by: Dan Williams <dcbw@redhat.com>
Make it a bit easier to debug scan results in the future.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (30 commits)
ctcm: rename READ/WRITE defines to avoid redefinitions
claw: rename READ/WRITE defines to avoid redefinitions
phylib: available for any speed ethernet
can: add limit for nframes and clean up signed/unsigned variables
pkt_sched: Check .walk and .leaf class handlers
pkt_sched: Fix sch_sfq vs tc_modify_qdisc oops
caif-spi: Bugfix SPI_DATA_POS settings were inverted.
caif: Bugfix - Increase default headroom size for control channel.
net: make netpoll_rx return bool for !CONFIG_NETPOLL
Bluetooth: Use 3-DH5 payload size for default ERTM max PDU size
Bluetooth: Fix incorrect setting of remote_tx_win for L2CAP ERTM
Bluetooth: Change default L2CAP ERTM retransmit timeout
Bluetooth: Fix endianness issue with L2CAP MPS configuration
net: Use NET_XMIT_SUCCESS where possible.
isdn: mISDN: call pci_disable_device() if pci_probe() failed
isdn: avm: call pci_disable_device() if pci_probe() failed
usbnet: rx_submit() should return an error code.
pkt_sched: Add some basic qdisc class ops verification. Was: [PATCH] sfq: add dummy bind/unbind handles
pkt_sched: sch_sfq: Add dummy unbind_tcf and put handles. Was: [PATCH] sfq: add dummy bind/unbind handles
i386 allmodconfig:
CC [M] drivers/net/wireless/libertas/cfg.o
/home/greearb/git/wireless-testing/drivers/net/wireless/libertas/cfg.c: In function ‘lbs_scan_worker’:
/home/greearb/git/wireless-testing/drivers/net/wireless/libertas/cfg.c:722: error: ‘TASK_NORMAL’ undeclared (first use in this function)
/home/greearb/git/wireless-testing/drivers/net/wireless/libertas/cfg.c:722: error: (Each undeclared identifier is reported only once
/home/greearb/git/wireless-testing/drivers/net/wireless/libertas/cfg.c:722: error: for each function it appears in.)
/home/greearb/git/wireless-testing/drivers/net/wireless/libertas/cfg.c: In function ‘lbs_cfg_connect’:
/home/greearb/git/wireless-testing/drivers/net/wireless/libertas/cfg.c:1267: error: ‘TASK_INTERRUPTIBLE’ undeclared (first use in this function)
/home/greearb/git/wireless-testing/drivers/net/wireless/libertas/cfg.c:1267: error: implicit declaration of function ‘signal_pending’
/home/greearb/git/wireless-testing/drivers/net/wireless/libertas/cfg.c:1267: error: implicit declaration of function ‘schedule_timeout’
Reported-by: Ben Greear <greearb@candelatech.com>
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
Fix this leftover TODO from the cfg80211 conversion by doing a scan
if cfg80211 didn't pass in the BSSID for us. Since the scan code
uses so much of the cfg80211_scan_request structure to build up the
firmware command, we just fake one when the scan request is triggered
internally. But we need to make sure that internal 'fake' cfg82011
scan request does not get back to cfg82011 via cfg80211_scan_done().
Some APs get pissy if you don't send the firmware the extended rates
in the association request's rates TLV. Found this on a Linksys
WRT54G v2; it denies association with status code 18 unless you
add the extended rates too. The old driver did this, but it got
lost in the cfg80211 conversion.
Let's actually check the right field in the command response; and
if there aren't any reported BSSes, exit early with success.
Convert to a full direct command; previous code rolled a direct
command by hand but left the original indirect command code intact
but disabled.
command by handle but left the original indirect command code
lying around.
Added 11d support for libertas driver using cfg80211. This is based on Holger
Shurig's initial work to add cfg80211 support libertas.
(https://patchwork.kernel.org/patch/64286/)
Please let us know, if there are any improvements comments.
Code is added to send 11d enable command to firmware while
initialisation and pass 11d specific information to firmware
when notifier handler is called by cfg80211.
Signed-off-by: Amitkumar Karwar <akarwar@marvell.com>
Signed-off-by: Kiran Divekar <dkiran@marvell.com>
In following scenarios WARN_ON() in cfg80211 code was triggered.
a) Driver unload or card removal.
b) Disconnect from infra network
c) Adhoc start/join
d) Adhoc stop
Added following fixes to avoid WARN_ON() in cfg80211 code.
a) Ensured that cfg80211_disconnected() function defined in cfg80211
code will be called only in infra mode.
b) Solved timing issue by moving cfg80211_disconnected() call inside
lbs_cfg_disconnect().
c) Updated "wdev->ssid" in driver code after Adhoc join/start
d) Removed unnecessory cfg80211_disconnected() call in lbs_remove_card.
Holger Schurig's patch (https://patchwork.kernel.org/patch/64286/)
is rebased to latest wireless-testing tree.
(Includes patches from me originally posted as "libertas: fix build
error due to undefined symbol" and "libertas: unmangle capability
value". -- JWL)
Tested-by: Amitkumar Karwar <akarwar@marvell.com>
drivers/net/wireless/ath/ar9170/main.c
Currently (all tested with hwsim) you can do stupid
things like setting up an AP on a certain channel,
then adding another virtual interface and making
that associate on another channel -- this will make
the beaconing to move channel but obviously without
the necessary IEs data update.
In order to improve this situation, first make the
configuration APIs (cfg80211 and nl80211) aware of
multi-channel operation -- we'll eventually need
that in the future anyway. There's one userland API
change and one API addition. The API change is that
now SET_WIPHY must be called with virtual interface
index rather than only wiphy index in order to take
effect for that interface -- luckily all current
users (hostapd) do that. For monitor interfaces, the
old setting is preserved, but monitors are always
slaved to other devices anyway so no guarantees.
The second userland API change is the introduction
of a per virtual interface SET_CHANNEL command, that
hostapd should use going forward to make it easier
to understand what's going on (it can automatically
detect a kernel with this command).
Other than mac80211, no existing cfg80211 drivers
are affected by this change because they only allow
a single virtual interface.
mac80211, however, now needs to be aware that the
channel settings are per interface now, and needs
to disallow (for now) real multi-channel operation,
which is another important part of this patch.
One of the immediate benefits is that you can now
start hostapd to operate on a hardware that already
has a connection on another virtual interface, as
long as you specify the same channel.
Note that two things are left unhandled (this is an
improvement -- not a complete fix):
* different HT/no-HT modes
currently you could start an HT AP and then
connect to a non-HT network on the same channel
which would configure the hardware for no HT;
that can be fixed fairly easily
* CSA
An AP we're connected to on a virtual interface
might indicate switching channels, and in that
case we would follow it, regardless of how many
other interfaces are operating; this requires
more effort to fix but is pretty rare after all
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (37 commits)
smc91c92_cs: fix the problem of "Unable to find hardware address"
r8169: clean up my printk uglyness
net: Hook up cxgb4 to Kconfig and Makefile
cxgb4: Add main driver file and driver Makefile
cxgb4: Add remaining driver headers and L2T management
cxgb4: Add packet queues and packet DMA code
cxgb4: Add HW and FW support code
cxgb4: Add register, message, and FW definitions
netlabel: Fix several rcu_dereference() calls used without RCU read locks
bonding: fix potential deadlock in bond_uninit()
net: check the length of the socket address passed to connect(2)
stmmac: add documentation for the driver.
stmmac: fix kconfig for crc32 build error
be2net: fix bug in vlan rx path for big endian architecture
be2net: fix flashing on big endian architectures
be2net: fix a bug in flashing the redboot section
bonding: bond_xmit_roundrobin() fix
drivers/net: Add missing unlock
net: gianfar - align BD ring size console messages
net: gianfar - initialize per-queue statistics
The libertas driver calls wiphy_unregister() without a prior
wiphy_register() when a devices fails initialization. Fix this by
introducing a private flag.
[ 9.310000] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[ 9.330000] [<c0311310>] (wiphy_unregister+0xfc/0x19c) from [<bf00c9ec>] (lbs_cfg_free+0x70/0x9c [libertas])
[ 9.330000] [<bf00c9ec>] (lbs_cfg_free+0x70/0x9c [libertas]) from [<bf014fdc>] (lbs_remove_card+0x180/0x210 [libertas])
[ 9.330000] [<bf014fdc>] (lbs_remove_card+0x180/0x210 [libertas]) from [<bf035394>] (if_sdio_probe+0xdc4/0xef4 [libertas_sdio])
[ 9.330000] [<bf035394>] (if_sdio_probe+0xdc4/0xef4 [libertas_sdio]) from [<c0230d14>] (sdio_bus_probe+0xd4/0xf0)
[ 9.330000] [<c0230d14>] (sdio_bus_probe+0xd4/0xf0) from [<c01a6034>] (driver_probe_device+0xa4/0x174)
[ 9.330000] [<c01a6034>] (driver_probe_device+0xa4/0x174) from [<c01a6164>] (__driver_attach+0x60/0x84)
[ 9.330000] [<c01a6164>] (__driver_attach+0x60/0x84) from [<c01a5854>] (bus_for_each_dev+0x4c/0x8c)
[ 9.330000] [<c01a5854>] (bus_for_each_dev+0x4c/0x8c) from [<c01a50e4>] (bus_add_driver+0xa0/0x228)
[ 9.330000] [<c01a50e4>] (bus_add_driver+0xa0/0x228) from [<c01a6470>] (driver_register+0xc0/0x150)
[ 9.330000] [<c01a6470>] (driver_register+0xc0/0x150) from [<bf03a06c>] (if_sdio_init_module+0x6c/0x108 [libertas_sdio])
[ 9.330000] [<bf03a06c>] (if_sdio_init_module+0x6c/0x108 [libertas_sdio]) from [<c00263ac>] (do_one_initcall+0x5c/0x1bc)
[ 9.330000] [<c00263ac>] (do_one_initcall+0x5c/0x1bc) from [<c0069f80>] (sys_init_module+0xc0/0x1f0)
[ 9.330000] [<c0069f80>] (sys_init_module+0xc0/0x1f0) from [<c0026f00>] (ret_fast_syscall+0x0/0x30)
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: John W. Linville <linville@tuxdriver.com>
Cc: Holger Schurig <hs4233@mail.mn-solutions.de>
Cc: Bing Zhao <bzhao@marvell.com>
Cc: libertas-dev@lists.infradead.org
Cc: linux-wireless@vger.kernel.org
Cc: netdev@vger.kernel.org
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de>
