commit 2ae1b8b35faba31a59b153cbad07f9c15de99740 upstream.
We occasionally see list corruption using libertas.
While we haven't been able to diagnose this precisely, we have spotted
a possible cause: cmdpendingq is generally modified with driver_lock
held. However, there are a couple of points where this is not the case.
Fix up those operations to execute under the lock, it seems like
the correct thing to do and will hopefully improve the situation.
Signed-off-by: Paul Fox <pgf@laptop.org>
Signed-off-by: Daniel Drake <dsd@laptop.org>
Acked-by: Dan Williams <dcbw@redhat.com>
After m68k's task_thread_info() doesn't refer to current,
it's possible to remove sched.h from interrupt.h and not break m68k!
Many thanks to Heiko Carstens for allowing this.
Firmware V4 on CF8381 reports region code shifted by 1 byte to left.
The following patch checks for this and handles it properly.
Signed-off-by: Dan Williams <dcbw@redhat.com>
And fix up setting authentication suite for v9+ firmware too.
Easier to read and more conformant with kernel style.
CMD_MESH_CONFIG command ID and a couple of structure members in TxPD,
RxPD have been changed in firmware version 10.x.y.z and newer.
Signed-off-by: Kiran Divekar <dkiran@marvell.com>
Signed-off-by: Bing Zhao <bzhao@marvell.com>
Fix misspelling of firmware.
Signed-off-by: Nick Andrew <nick@nick-andrew.net>
Based on a patch from Shailendra Govardhan <shailen@marvell.com>.
This patch allows implementation of more specific wake-on-lan rules than those
of ethtool.
Please note that only firmware 5.110.22.p20 and above supports this feature.
This patch only implements the driver/firmware interface, not the
userspace/driver interface.
Signed-off-by: Anna Neal <anna@cozybit.com>
Signed-off-by: Javier Cardona <javier@cozybit.com>
Convert all the drivers using net/ieee80211.h to use linux/ieee80211.h.
Contains a bugfix in libertas where the SSID parsing could overrun the
buffer when the AP sends invalid information.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Acked-by: Dan Williams <dcbw@redhat.com> [airo, libertas]
Acked-by: Pavel Roskin <proski@gnu.org> [orinoco]
Acked-by: David Kilroy <kilroyd@googlemail.com> [orinoco]
Also change escape_ssid to print_ssid to match print_mac semantics.
drivers/net/wireless/p54/p54common.c
Johannes Berg detected this two sparse warnings:
drivers/net/wireless/libertas/cmd.c:609:16: warning: cast to restricted __le16
drivers/net/wireless/libertas/cmd.c:611:16: warning: cast to restricted __le16
... but cmd.minlevel is "s8", so we can access it directly and hope
for the sign-extension-code in the compiler to convert that to the
"s16" type.
Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de>
This converts pretty much everything to print_mac. There were
a few things that had conflicts which I have just dropped for
now, no harm done.
I've built an allyesconfig with this and looked at the files
that weren't built very carefully, but it's a huge patch.
Below patch removes the following warning during compilation.
drivers/net/wireless/libertas/cmd.c:826: warning: unused variable 'old_channel'
Signed-off-by : Manish Katiyar <mkatiyar@gmail.com>
This patch addresses comments from Dan Williams about the patch
committed as "libertas: Improvements on automatic tx power control via
SIOCSIWTXPOW."
And support setting both long and short retries independently.
The generic reset command is unused. Each interface type needs to
handle the reset command differently since after reset, the firmware is
dead and interface-specific mechanisms must be used to reinitialize the
card.
iwconfig txpower can now be used to set tx power to fixed or auto. If set to
auto the default firmware settings are used.
The command CMD_802_11_PA_CFG is only sent to older firmware, as Dan Williams
noted the command was no longer supported in firmware V9+.
with fixes for v9 and later firmware too.
and return errors for operations like join & scan that aren't possible
when the radio is turned off.
and remove DISASSOCIATE because it's not in any of the specs and has
never been used.
And while we're at it, grab min/max TX power from the firmware and use
that to validate incoming TX power requests from WEXT.
Add locking and non-locking versions of if_usb_prog_firmware to support
programming firmware after and before driver bring-up respectively. Add more
suitable error codes for firmware programming process. Add capability checks
for persistent features before attempting to use them.
Based on patches from Brajesh Dave and Priyank Singh.
Signed-off-by: Brian Cavagnolo <brian@cozybit.com>
drivers/net/tg3.c
drivers/net/wireless/rt2x00/rt2x00dev.c
net/mac80211/ieee80211_i.h
This fixes an issus that made "iwconfig eth1 power on" non-working.
When we get a "PS sleep" event, we have to confirm this to the firmware.
The confirm happens with a command, but this command is special: the
firmware won't send us a response. if_cs_host_to_card() is setting
priv->dnld_sent anyway, so this variable stayed at DNLD_DATA_SENT and
was never cleared back.
Now I put the special knowledge that the CMD_802_11_PS_MODE with
CMD_SUBCMD_SLEEP_CONFIRMED doesn't need to need a response by directly
clearing the dnld_sent state in lbs_send_confirmsleep().
Implemented rate adaptation support via 'iwconfig rate' API. It is now
possible to specify a bit-rate value and append 'auto'. That will configure
rate adaptation to use all bit-rates equal or lower than than selected value.
Made lbs_cmd_802_11_rate_adapt_rateset a direct command.
... because lbs_pr_XXX prefixes all messages with "libertas: "
[PATCH, take 2] libertas: reduce command retry time
In the normal case, an unsuccessful command would be retried for 10*5 seconds,
or 10*10 seconds in the worst case. This patch reduces this to 3*3 seconds,
or 3*10 seconds in the worst case.
I also reduced the time it takes to start a new command downloaded.
This patch is based on a patch from Shailendra Govardhan and Brian Cavagnolo.
It extends the MESH_CONFIG command to configure non-volatile parameters on
libertas devices that support them (e.g. OLPC Active Antenna).
This patch only implements the driver/firmware interface.
See http://dev.laptop.org/ticket/6823 for minimal testing results and known
issues.
We weren't properly handling multicast on the mesh interface. Fix that,
which involves setting up the hardware to use the union of dev->mc_list
for both eth%d and msh%d devices.
This means we can't do it directly from ->set_multicast_list() because
we'd need to lock the other device to read its list, and we can't do
that because it might deadlock. So punt the actual work to keventd.
Also, invoke the same when taking an interface down; for some reason the
core calls ->set_multicast_list while IFF_UP is still set in dev->flags
when we're taking it down, so its addresses don't get removed then.
We also convert MAC_MULTICAST_ADR to a direct command while we're at it,
removing one more entry from the big switch statement in the deprecated
lbs_prepare_and_send_command() function.
Using the deprecated lbs_prepare_and_send_command() function for a
command which it doesn't understand is an error; complain loudly about
it even when we're not debugging.
The mesh stats bug, where we converted MESH_ACCESS to a direct command
but accidentally missed one user which was still trying to do it through
lbs_prepare_and_send_command(), would have been caught a lot quicker if
we'd done this sooner. Such bugs aren't entirely unlikely in future too,
as we convert more code to stop using this function.
lbs_get_data_rate() gets called, but no-one uses it's result.
Some command structs contain reserved or unused fields, which the driver
send uninitialized down to the card.
This patch (co-developed by Dan Williams and Holger Schurig) uses a kfifo
object for events and a swapping buffer scheme for the command response to
preserve the zero-copy semantics of the CF driver and keep memory usage low.
The main thread should only ever touch the buffer indexed by priv->resp_idx,
while the interface code is free to write to the second buffer, then swap
priv->resp_idx under the driver spinlock. The firmware specs only permit
one in-flight command, so there will only ever be one command response to
process at a time.
... as it has nothing to do with pure association
Besides code moving, I did the following changes:
* made some functions static
* removed some unneeded #include's
* made patch checkpatch.pl clean
Confirm sleep event: they come very regularly, eventually several times per
second. Therefore we want to send the config command as fast as possible.
The old code pre-set the command in priv->lbs_ps_confirm_sleep. However, the
byte sequence to be sent to the hardware is the same for all interfaces. So
this patch make this an extern structure, initialized at module load time.
Config wake event: normal conversion to a direct command. However, I don't know
how to trigger a "HOST AWAKE" event from the firmware, so this part is
untested.
* directly call lbs_cmd_with_response()
* only overwrite priv->current_addr once the firmware call succeeded
This patch tries to make dmesg logs between different runs easier
to compare by
* removing the jiffies (use CONFIG_PRINTK_TIME if you need
timing)
* remove the line numbers, they change with each applied patch
It also changes the deprecated __FUNCTION__ to __func__ to make
checkpatch.pl happy.
This has nowhere been used. Note: in the firmware manual this was
documented as CMD_802_11_PA_CFG. If we ever need it, we can/should
re-implement it as a direct command.
This removes many unused function parameters as well as some not-implemented
functions, e.g. CMD_802_11_GET_STATS. The silly lbs_set_cmd_ctrl_node()
function is now also gone.
* firmware for the CF card supports power saving
* the driver currenly only accept "iwconfig ethX power on|off", so
I fixed what the range wext ioctl reports.
* initialize value/flags in lbs_get_power()
* get rid of unused parameter psmode in lbs_ps_confirm_sleep()
* some minor debug output tweaks
Now uses __lbs_cmd() to get the "log" (it's actually more a snapshot of
various counters, not a sequential log). Besides the "mechanical" convertion
the patch add the following logical changes:
* Removes the priv->logmsg variable, it was only used in one place anyway,
also don't blindly get the counters when associating. Getting the
counters then the user asks via WEXT for them is good enought.
* don't set wstats.discard.fragment with log.rxfrag, because the latter is
a counter for successfully received packets, not for fragmented packets.
The old code incorrectly used lbs_cmd_with_response() and now uses
lbs_cmd_async().
While there I noticed that there is no real useful return values for
asynchronous command functions, so I made the function "void".
This uses a static lbs_cmd_async_callback function, which is a
noop. Just setting the callback argument to __lbs_cmd_async()
to NULL won't work, because then the cmdnode wouldn't be
released.
This also makes __lbs_cmd_async() a static method, which is
now only used by lbs_cmd() and lbs_cmd_async().
Neither CMD_802_11_PAIRWISE_TSC nor CMD_802_11_GROUP_TSC is used or
documented. It might have something to do with TKIP sequence counters,
but that's just an educated guess. Remove all occurences of them.
CMD_CODE_DNLD is also neither used nor documented.
The CMD_MAC_CONTROL can be used for other things than just filtering
packets, e.g. to enable and disable WMM. This uses the same term mac_control
for the define, the function and the shadow value in struct lbs_private.
