This allows individual users and deployments to disable mesh support at
runtime, i.e. without having to build and maintain a custom kernel.
Based on a patch by Paul Fox <pgf@laptop.org>.
Signed-off-by: Sascha Silbe <silbe@activitycentral.com>
Using the more descriptive logging styles gives a bit
more information about the device being operated on.
Makes the object trivially smaller too.
$ size drivers/net/wireless/libertas/built-in.o.*
187730 2973 38488 229191 37f47 drivers/net/wireless/libertas/built-in.o.new
188195 2973 38488 229656 38118 drivers/net/wireless/libertas/built-in.o.old
Acked-by: Dan Williams <dcbw@redhat.com>
Use the standard pr_<level> functions eases grep a bit.
Added a few missing terminating newlines to messages.
Coalesced long formats.
As described at http://marc.info/?l=linux-netdev&m=130428493104730&w=2
libertas frequently generates spurious tx timeouts, because the tx
queue is brought down for extended periods during scanning. The net
layer takes a look and incorrectly assumes the queue has been down for
several seconds, and generates a tx_timeout.
One way to fix this is to bump the trans_start counter while scanning
so that the network layer knows that the device is still alive, but
I think the tx_timeout handler is implemented wrongly here and not of
any real use, so I vote to remove it.
As explained at http://marc.info/?l=linux-wireless&m=130430311115755&w=2
the watchdog is primarily meant to deal with lockup on the hardware TX
path (detected by the tx queue being stopped for an extended period of
time), but this is unlikely to happen with libertas. In this case, the tx
queue is stopped only while waiting for lbs_thread to send the queued frame
to the driver, and lbs_thread wakes up the queue immediately after, even
if the frame could not be sent correctly.
So, the only hardware-related possibility that this catches is if
hw_host_to_card hangs - this is something I have never seen. And if it
were to happen, nothing done by lbs_tx_timeout would actually wake up
lbs_thread any quicker than otherwise.
Removing this oddly-behaving spuriously-firing tx_timeout handler should
fix an occasional kernel crash during resume
(http://dev.laptop.org/ticket/10748)
Signed-off-by: Daniel Drake <dsd@laptop.org>
Convert all libertas/ files to use kernel-doc notation instead
of whatever it was (doxygen?).
Add or fix function parameters in several places.
Use expected style for multi-line comments in lots of places.
Remove erroneous /** in multiple places.
To support suspend/resume in if_spi we need two things:
- re-setup fw in lbs_resume(), because if_spi powercycles card;
- don't touch hwaddr on second lbs_update_hw_spec() call for same
reason;
Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
drivers/net/wireless/ath/ath9k/ar9003_eeprom.c
net/llc/af_llc.c
"priv" is stored at the end of the wiphy structure, which is freed
during the call to lbs_cfg_free(). It must not be touched afterwards.
Remove the unnecessary NULL assignment causing this memory corruption.
Certain firmware versions, particularly the 8388 found on the XO-1,
do not support the EHS_REMOVE_WAKEUP command that is used to disable
WOL. Sending this command to the card will return a failure that
would get propagated up the stack and cause suspend to fail.
Instead, fall back to an all-zero wakeup mask.
This fixes http://dev.laptop.org/ticket/9967
Signed-off-by: Deepak Saxena <dsaxena@laptop.org>
[includes fixups by Paul Fox]
There are currently no provisions in place to ensure that the scanning
task has been stopped when the interface is stopped or removed.
This can result in a WARNING at net/wireless/core.c:643 and other badness
when you remove the module while a scan is happening.
Terminate the scanning task during interface stop.
SDIO, GSPI, and CS all use 2-stage firmware and the loading
process and logic should be the same. Allow module parameters
to override the automatic firmware choice, otherwise just walk
the bus driver's firmware table and pick out the first firmware
pair that exists for the given model.
Some special care is taken to allow overriding of just the helper
or the main firmware, but let the other of the pair be chosen
automatically.
Signed-off-by: Dan Williams <dcbw@redhat.com>
Fix this leftover TODO from the cfg80211 conversion by doing a scan
if cfg80211 didn't pass in the BSSID for us. Since the scan code
uses so much of the cfg80211_scan_request structure to build up the
firmware command, we just fake one when the scan request is triggered
internally. But we need to make sure that internal 'fake' cfg82011
scan request does not get back to cfg82011 via cfg80211_scan_done().
Other uses were already used direct command paths.
Powersave looks like it got broken at some point but we'll fix that up
when the command submission stuff is more understandable, which this
series helps to do. That said, this patch should not further break
powersave.
Convert to a full direct command; previous code rolled a direct
command by hand but left the original indirect command code intact
but disabled.
Existing "ethtool -s ethX wol X" command configures hostsleep
parameters, but those are activated only during suspend/resume,
there is no way to configure host sleep without actual suspend.
This patch adds debugfs command to enable/disable host sleep based on
already configured host sleep parameters using wol command.
Signed-off-by: Amitkumar Karwar <akarwar@marvell.com>
Signed-off-by: Kiran Divekar <dkiran@marvell.com>
Added 11d support for libertas driver using cfg80211. This is based on Holger
Shurig's initial work to add cfg80211 support libertas.
(https://patchwork.kernel.org/patch/64286/)
Please let us know, if there are any improvements comments.
Code is added to send 11d enable command to firmware while
initialisation and pass 11d specific information to firmware
when notifier handler is called by cfg80211.
In following scenarios WARN_ON() in cfg80211 code was triggered.
a) Driver unload or card removal.
b) Disconnect from infra network
c) Adhoc start/join
d) Adhoc stop
Added following fixes to avoid WARN_ON() in cfg80211 code.
a) Ensured that cfg80211_disconnected() function defined in cfg80211
code will be called only in infra mode.
b) Solved timing issue by moving cfg80211_disconnected() call inside
lbs_cfg_disconnect().
c) Updated "wdev->ssid" in driver code after Adhoc join/start
d) Removed unnecessory cfg80211_disconnected() call in lbs_remove_card.
Holger Schurig's patch (https://patchwork.kernel.org/patch/64286/)
is rebased to latest wireless-testing tree.
(Includes patches from me originally posted as "libertas: fix build
error due to undefined symbol" and "libertas: unmangle capability
value". -- JWL)
Tested-by: Amitkumar Karwar <akarwar@marvell.com>
In suspend() host sleep is activated using already configured
host sleep parameters through wol command, and in resume() host
sleep is cancelled. Earlier priv->fw_ready flag used to reset and
set in suspend and resume handler respectively. Since after suspend
only host goes into sleep state and firmware is always ready, those
changes in flag state are removed.
Now that core network takes care of trans_start updates, dont do it
in drivers themselves, if possible. Drivers can avoid one cache miss
(on dev->trans_start) in their start_xmit() handler.
Exceptions are NETIF_F_LLTX drivers
drivers/net/stmmac/stmmac_main.c
drivers/net/wireless/wl12xx/wl1271_cmd.c
drivers/net/wireless/wl12xx/wl1271_main.c
drivers/net/wireless/wl12xx/wl1271_spi.c
net/core/ethtool.c
net/mac80211/scan.c
Converts the list and the core manipulating with it to be the same as uc_list.
+uses two functions for adding/removing mc address (normal and "global"
variant) instead of a function parameter.
+removes dev_mcast.c completely.
+exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for
manipulation with lists on a sandbox (used in bonding and 80211 drivers)
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Auto auth mode is enabled by default. If user doesn't specify the
auth mode, while association driver will first try with open mode
and then with shared key mode. If user specifies an auth mode,
auto auth is disabled and driver will not try association with
another auth mode.
Signed-off-by: Bing Zhao <bzhao@marvell.com>
also added missed locking in rndis_wlan.c
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
Retrying commands seldomly works, most often the firmware is in a
weird state anyway and needs the device to reset. So it's better
to report the broken state back to user-space.
Also rename command_timer_fn() into lbs_cmd_timeout_handler(),
which better reflect it's usage.
Signed-off-by: Holger Schurig <holgerschurig@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
Fix the "ignoring return value of '...', declared with attribute
warn_unused_result" compiler warning in several users of the new kfifo
API.
It removes the __must_check attribute from kfifo_in() and
kfifo_in_locked() which must not necessary performed.
Fix the allocation bug in the nozomi driver file, by moving out the
kfifo_alloc from the interrupt handler into the probe function.
Fix the kfifo_out() and kfifo_out_locked() users to handle a unexpected
end of fifo.
Signed-off-by: Stefani Seibold <stefani@seibold.net>
rename kfifo_put... into kfifo_in... to prevent miss use of old non in
kernel-tree drivers
ditto for kfifo_get... -> kfifo_out...
Improve the prototypes of kfifo_in and kfifo_out to make the kerneldoc
annotations more readable.
Add mini "howto porting to the new API" in kfifo.h
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Acked-by: Andi Kleen <ak@linux.intel.com>
change name of __kfifo_* functions to kfifo_*, because the prefix __kfifo
should be reserved for internal functions only.
Move the pointer to the spinlock out of struct kfifo. Most users in
tree do not actually use a spinlock, so the few exceptions now have to
call kfifo_{get,put}_locked, which takes an extra argument to a
spinlock.
This is a new generic kernel FIFO implementation.
The current kernel fifo API is not very widely used, because it has to
many constrains. Only 17 files in the current 2.6.31-rc5 used it.
FIFO's are like list's a very basic thing and a kfifo API which handles
the most use case would save a lot of development time and memory
resources.
I think this are the reasons why kfifo is not in use:
- The API is to simple, important functions are missing
- A fifo can be only allocated dynamically
- There is a requirement of a spinlock whether you need it or not
- There is no support for data records inside a fifo
So I decided to extend the kfifo in a more generic way without blowing up
the API to much. The new API has the following benefits:
- Generic usage: For kernel internal use and/or device driver.
- Provide an API for the most use case.
- Slim API: The whole API provides 25 functions.
- Linux style habit.
- DECLARE_KFIFO, DEFINE_KFIFO and INIT_KFIFO Macros
- Direct copy_to_user from the fifo and copy_from_user into the fifo.
- The kfifo itself is an in place member of the using data structure, this save an
indirection access and does not waste the kernel allocator.
- Lockless access: if only one reader and one writer is active on the fifo,
which is the common use case, no additional locking is necessary.
- Remove spinlock - give the user the freedom of choice what kind of locking to use if
one is required.
- Ability to handle records. Three type of records are supported:
- Variable length records between 0-255 bytes, with a record size
field of 1 bytes.
- Variable length records between 0-65535 bytes, with a record size
field of 2 bytes.
- Fixed size records, which no record size field.
- Preserve memory resource.
- Performance!
- Easy to use!
This patch:
Since most users want to have the kfifo as part of another object,
reorganize the code to allow including struct kfifo in another data
structure. This requires changing the kfifo_alloc and kfifo_init
prototypes so that we pass an existing kfifo pointer into them. This
patch changes the implementation and all existing users.
[akpm@linux-foundation.org: fix warning]
This variable was once set to WLAN_CAPABILITY_SHORT_PREAMBLE and
there's no code that could change the variable to something else.
Therefore it seems this is not necessary :-)
While it's might be technically true that only MESH-enabled firmwares
are also RTAP-enabled, I like to have this decoupled.
mesh_autostart_enabled was nowhere set. Rumor is that this is used in the
OLPC tree, but they never did submit their code upstream.
After removing this code, it turned out that the sync_channel stuff is now
also unused, so get rid of that as well.
This moves mesh initialization, start/stop and rx/tx handling from
into mesh.c.
Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de>
... as priv->curbssparams won't exist once libertas+cfg80211 lands.
Another cfg80211-preparation patch: removes some code/definitions from
main.c and dev.h and put's it into assoc.c/.h, scan.c/.h.
No function change.
Most of the 11d code was protected with an "if (priv->enable11d)" clause.
But there was no code that anywhere that was able to set this
variable to true. So all 11d code was dead for almost a year and no one
complained. That's enought incentive to remove this code.
Besides removing old cruft, we gain back the 11d capability in a common way
when we merge the cfg80211 functionality.
Return status of lbs_prepare_and_send_command and lbs_cmd_with_response
functions is not checked at some places. Those checks are added.
This came in through the patch titled:
libertas: first stab at cfg80211 support
I only noticed it because it breaks compat-wireless :)
Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
Acked-by: Holger Schurig <hs4233@mail.mn-solutions.de>
Add timer based auto deep sleep feature in libertas driver which can be
configured using iwconfig command. This is tested on SD8688, SD8686 cards
with firmware versions 10.38.1.p25, 9.70.4.p0 respectively on 32-bit and 64-bit
platforms. Tests have been done for USB/CS cards to make sure that the patch
won't break USB/CS code. We didn't test the if_spi driver.
