path: root/drivers/net/wireless/libertas/main.c
2009-09-01wireless: convert drivers to netdev_tx_tStephen Hemminger
Mostly just simple conversions: * ray_cs had bogus return of NET_TX_LOCKED but driver was not using NETIF_F_LLTX * hostap and ipw2x00 had some code that returned value from a called function that also had to change to return netdev_tx_t Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-14libertas: name the network device wlan%dDaniel Mack
Devices created by the libertas driver are currently called eth%d. Which is wrong, because the device does not at all have anything to do with Ethernet. And it is also confusing when used on devices with more than one network device. Fix this by calling it wlan%d. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Roel Kluin <roel.kluin@gmail.com> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03libertas: improve function init/shutdown handling for SD8688Bing Zhao
This patch is to incorporate Dan Williams' comments for commit: "libertas: implement function init/shutdown commands for SD8688" 1. remove fn_init_required and fn_shutdown_required variables from lbs_private structure. If required, __lbs_cmd() will be called directly to send function init/shutdown command for SD8688 in if_sdio_probe() or if_sdio_remove() callback. 2. add global variable "user_rmmod" to distinguish between the module removal case and the card removal case. This flag will be checked in if_sdio_remove() against SD8688 card to determine whether or not the function shutdown command needs to be sent. 3. remove "card" from if_sdio_model structure as it cannot store card pointers for multiple cards. Besides, it's no longer needed to store the "card" pointer with changes #1 & #2 above. Signed-off-by: Bing Zhao <bzhao@marvell.com> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-22libertas: implement function init/shutdown commands for SD8688Bing Zhao
SD8688 is a WLAN/Bluetooth combo chip and both functions are supported in a single firmware image. FUNC_INIT and FUNC_SHUTDOWN commands are implemented to utilize the multiple function feature. When SD8688 card is inserted, the firmware image should be downloaded only once through either WLAN function (Libertas driver) or Bluetooth function (Bluetooth driver). This patch adds function init/shutdown for SD8688 WLAN function only. Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22libertas: support mesh for various firmware versionsBing Zhao
CMD_MESH_CONFIG command ID and a couple of structure members in TxPD, RxPD have been changed in firmware version 10.x.y.z and newer. Signed-off-by: Kiran Divekar <dkiran@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-21libertas: convert to net_device_opsStephen Hemminger
2009-03-21libertas: convert to internal net_device_statsStephen Hemminger
2009-03-01Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-tx.c net/8021q/vlan_core.c net/core/dev.c
2009-02-26libertas: fix misuse of netdev_priv() and dev->ml_privKiran Divekar
The mesh and radiotap interfaces need to use the same private data as the main wifi interface. If the main wifi interface uses netdev_priv(), but the other interfaces ->ml_priv, there's no way to figure out where the private data actually is in the WEXT handlers and netdevice callbacks. So make everything use ->ml_priv. Fixes botched netdev_priv() conversion introduced by "netdevice libertas: Fix directly reference of netdev->priv", though admittedly libertas' use of ->priv was somewhat "special". Signed-off-by: Kiran Divekar <dkiran@marvell.com> Acked-by: Dan Williams <dcbw@redhat.com> Tested-by: Chris Ball <cjb@laptop.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29libertas: Update libertas core with GSPI constantsColin McCabe
Add GSPI constants to libertas core. Fix misleading comment in lbs_setup_firmware. Signed-off-by: Colin McCabe <colin@cozybit.com> Signed-off-by: Andrey Yurovsky <andrey@cozybit.com> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-11drivers/net/wireless/libertas: move a dereference below a NULL testJulia Lawall
In each case, if the NULL test is necessary, then the dereference should be moved below the NULL test. I have also taken advantage of the availability of the value of priv->dev in the subsequent calls to netif_stop_queue and netif_carrier_off. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ type T; expression E; identifier i,fld; statement S; @@ - T i = E->fld; + T i; ... when != E when != i if (E == NULL) S + i = E->fld; // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-12libertas: Create sysfs entry for changing the mesh probe response limitAnna Neal
This patch adds the ability to change the number of probe response retries sent by the mesh interface. In dense networks it is recommended to change this value to zero to reduce traffic congestion. Signed-off-by: Anna Neal <anna@cozybit.com> Signed-off-by: Andrey Yurovsky <andrey@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-10don't use net/ieee80211.hJohannes Berg
Convert all the drivers using net/ieee80211.h to use linux/ieee80211.h. Contains a bugfix in libertas where the SSID parsing could overrun the buffer when the AP sends invalid information. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Dan Williams <dcbw@redhat.com> [airo, libertas] Acked-by: Pavel Roskin <proski@gnu.org> [orinoco] Acked-by: David Kilroy <kilroyd@googlemail.com> [orinoco] Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-10netdevice libertas: Fix directly reference of netdev->privWang Chen
We have some reasons to kill netdev->priv: 1. netdev->priv is equal to netdev_priv(). 2. netdev_priv() wraps the calculation of netdev->priv's offset, obviously netdev_priv() is more flexible than netdev->priv. But we cann't kill netdev->priv, because so many drivers reference to it directly. OK, becasue Dave S. Miller said, "every direct netdev->priv usage is a bug", and I want to kill netdev->priv later, I decided to convert all the direct reference of netdev->priv first. Different to readonly reference of netdev->priv, in this driver, netdev->priv was changed. I use netdev->ml_priv to replace netdev->priv. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31wireless: consolidate on a single escape_essid implementationJohn W. Linville
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-11libertas: clear current command on card removalDan Williams
If certain commands were in-flight when the card was pulled or the driver rmmod-ed, cleanup would block on the work queue stopping, but the work queue was in turn blocked on the current command being canceled, which didn't happen. Fix that. Signed-off-by: Dan Williams <dcbw@redhat.com> Cc: stable <stable@kernel.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-29libertas: convert adhoc operations to direct commandsDan Williams
with fixes for v9 and later firmware too. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-29libertas: convert CMD_802_11_RADIO_CONTROL to a direct commandDan Williams
and return errors for operations like join & scan that aren't possible when the radio is turned off. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-29libertas: convert CMD_802_11_DEAUTHENTICATE to a direct commandDan Williams
and remove DISASSOCIATE because it's not in any of the specs and has never been used. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-29libertas: convert CMD_802_11_RF_TX_POWER to a direct commandDan Williams
And while we're at it, grab min/max TX power from the firmware and use that to validate incoming TX power requests from WEXT. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-01libertas: only enable rtap with mesh firmwareDan Williams
Since only mesh-enabled firmware has the CMD_802_11_MONITOR_MODE on which the rtap functionality depends, only expose the rtap functionality when mesh is also available. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-15netdev: Do not use TX lock to protect address lists.David S. Miller
Now that we have a specific lock to protect the network device unicast and multicast lists, remove extraneous grabs of the TX lock in cases where the code only needs address list protection. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-15netdev: Add netdev->addr_list_lock protection.David S. Miller
Add netif_addr_{lock,unlock}{,_bh}() helpers. Use them to protect operations that operate on or read the network device unicast and multicast address lists. Also use them in cases where the code simply wants to block calls into the driver's ->set_rx_mode() and ->set_multicast_list() methods. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-10Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/tg3.c drivers/net/wireless/rt2x00/rt2x00dev.c net/mac80211/ieee80211_i.h
master.kernel.org:/pub/scm/linux/kernel/git/linville/wireless-next-2.6 Conflicts: drivers/net/ps3_gelic_wireless.c drivers/net/wireless/libertas/main.c
2008-06-09libertas: fix sleep confirmationHolger Schurig
This fixes an issus that made "iwconfig eth1 power on" non-working. When we get a "PS sleep" event, we have to confirm this to the firmware. The confirm happens with a command, but this command is special: the firmware won't send us a response. if_cs_host_to_card() is setting priv->dnld_sent anyway, so this variable stayed at DNLD_DATA_SENT and was never cleared back. Now I put the special knowledge that the CMD_802_11_PS_MODE with CMD_SUBCMD_SLEEP_CONFIRMED doesn't need to need a response by directly clearing the dnld_sent state in lbs_send_confirmsleep(). Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-03libertas: rate adaptation configuration via iwconfig.Javier Cardona
Implemented rate adaptation support via 'iwconfig rate' API. It is now possible to specify a bit-rate value and append 'auto'. That will configure rate adaptation to use all bit-rates equal or lower than than selected value. Made lbs_cmd_802_11_rate_adapt_rateset a direct command. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-03libertas: before sleeping, check for a command resultHolger Schurig
If we don't check for a command response early, but rather sleep, then we might sleep despite an already-received command response. This will lead to a command-timeout. Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-03libertas: don't spin_unlock_irq() twiceHolger Schurig
priv->driver_lock has already been unlocked some lines above. This patch fixes the sparse warning: drivers/net/wireless/libertas/main.c:792:6: warning: context problem in 'lbs_thread': '_spin_unlock_irq' expected different context drivers/net/wireless/libertas/main.c:792:6: context 'lock': wanted >= 1, got 0 Signed-of-by: Holger Schurig <hs4233@mail.mn-solutions.de> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-25Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/cpmac.c net/mac80211/mlme.c
2008-05-21libertas: reduce command retry timeHolger Schurig
[PATCH, take 2] libertas: reduce command retry time In the normal case, an unsuccessful command would be retried for 10*5 seconds, or 10*10 seconds in the worst case. This patch reduces this to 3*3 seconds, or 3*10 seconds in the worst case. I also reduced the time it takes to start a new command downloaded. Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-21libertas: Add reset_card() callback to hardware driverDavid Woodhouse
Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-21libertas: sysfs interface for accessing non-volatile configurationJavier Cardona
This will create the following sysfs directories: /sys/class/net/mshX ... |-- boot_options | |-- bootflag | `-- boottime ... |-- mesh_ie | |-- capability | |-- mesh_id | |-- metric_id | `-- protocol_id Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-21libertas: Extend MESH_CONFIG command to access non-volatile configurationJavier Cardona
This patch is based on a patch from Shailendra Govardhan and Brian Cavagnolo. It extends the MESH_CONFIG command to configure non-volatile parameters on libertas devices that support them (e.g. OLPC Active Antenna). This patch only implements the driver/firmware interface. See http://dev.laptop.org/ticket/6823 for minimal testing results and known issues. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-21libertas: fix multicast filtering on eth and msh interfacesDavid Woodhouse
We weren't properly handling multicast on the mesh interface. Fix that, which involves setting up the hardware to use the union of dev->mc_list for both eth%d and msh%d devices. This means we can't do it directly from ->set_multicast_list() because we'd need to lock the other device to read its list, and we can't do that because it might deadlock. So punt the actual work to keventd. Also, invoke the same when taking an interface down; for some reason the core calls ->set_multicast_list while IFF_UP is still set in dev->flags when we're taking it down, so its addresses don't get removed then. We also convert MAC_MULTICAST_ADR to a direct command while we're at it, removing one more entry from the big switch statement in the deprecated lbs_prepare_and_send_command() function. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-16wireless: Create 'device' symlink in sysfsMasakazu Mokuno
Some network interfaces of the wireless drivers lack the 'device' symlink in sysfs. This patch lets the drivers create the links. Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-16libertas: fix command timeout after firmware failureBrian Cavagnolo
This is a fix for OLPC ticket #6586: "SCAN command fails, timer doesn't fire". In fact, the timer was firing; the problem was that the dnld_sent state variable was not being updated after the timer expired, so lbs_execute_next_command was not being called. Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-14libertas: remove lbs_get_data_rate()Holger Schurig
lbs_get_data_rate() gets called, but no-one uses it's result. Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-07libertas: allow removal of card at any timeHolger Schurig
This fixes several problems I had: * when removing the card while the card was scanning or associtating, it could happen that destroy_workqueue() stuck and didn't return. * make sure the command function doesn't run while we remove the list of pending commands * for still unknown reason, I had calls to lbs_stop_card() with priv==NULL Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-07libertas: make some functions voidHolger Schurig
They don't return anything meaningfull and no-one cares about their results. Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-07libertas: debug output tweaks for lbs_threadHolger Schurig
* make debug output match the variable name * always report that lbs_remove_rtap() has has been exited Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-16libertas: convert libertas driver to use an event/cmdresp queueHolger Schurig
This patch (co-developed by Dan Williams and Holger Schurig) uses a kfifo object for events and a swapping buffer scheme for the command response to preserve the zero-copy semantics of the CF driver and keep memory usage low. The main thread should only ever touch the buffer indexed by priv->resp_idx, while the interface code is free to write to the second buffer, then swap priv->resp_idx under the driver spinlock. The firmware specs only permit one in-flight command, so there will only ever be one command response to process at a time. Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-08libertas: move association code from scan.c into assoc.cHolger Schurig
Besides code moving, I did the following changes: * made some functions static * removed some unneeded #include's * made patch checkpatch.pl clean Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-08libertas: move association code from join.c into scan.cHolger Schurig
2008-04-01libertas: don't depend on IEEE80211Holger Schurig
Runtime-wise we only need escape_ssid from the deprecated IEEE80211 subsystem. However, it's easy to provide our own copy. Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-01libertas: convert sleep/wake config direct commandsHolger Schurig
Confirm sleep event: they come very regularly, eventually several times per second. Therefore we want to send the config command as fast as possible. The old code pre-set the command in priv->lbs_ps_confirm_sleep. However, the byte sequence to be sent to the hardware is the same for all interfaces. So this patch make this an extern structure, initialized at module load time. Config wake event: normal conversion to a direct command. However, I don't know how to trigger a "HOST AWAKE" event from the firmware, so this part is untested. Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-01libertas: convert CMD_802_11_MAC_ADDRESS to a direct commandHolger Schurig
* directly call lbs_cmd_with_response() * only overwrite priv->current_addr once the firmware call succeeded Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-27libertas: kill useless #define LBS_MONITOR_OFF 0Holger Schurig
2008-03-25libertas: remove lots of unused stuffHolger Schurig
This removes many unused function parameters as well as some not-implemented functions, e.g. CMD_802_11_GET_STATS. The silly lbs_set_cmd_ctrl_node() function is now also gone. Signed-off-by: Holger Schurig <hs4233@mail.mn-solutions.de> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
