IntType was only set to INT_MEMORY (driver pcmciamtd) or INT_MEMORY_AND_IO
(all other drivers). As this flags seems to relate to ioport access, make
it conditional to the driver having requested IO port access. There are two
drivers which do not request IO ports, but did set INT_MEMORY_AND_IO:
ray_cs and b43. For those, we consistently only set INT_MEMORY in future.
CC: netdev@vger.kernel.org
CC: linux-wireless@vger.kernel.org
CC: linux-ide@vger.kernel.org
CC: linux-usb@vger.kernel.org
CC: laforge@gnumonks.org
CC: linux-mtd@lists.infradead.org
CC: alsa-devel@alsa-project.org
CC: linux-serial@vger.kernel.org
CC: Jiri Kosina <jkosina@suse.cz>
CC: linux-scsi@vger.kernel.org
Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth)
Tested-by: Wolfram Sang <w.sang@pengutronix.de>
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
drivers/net/wireless/ath/ath5k/base.c
net/mac80211/main.c
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
arch/arm/mach-omap2/board-omap3pandora.c
CHECK drivers/net/wireless/libertas/cfg.c
drivers/net/wireless/libertas/cfg.c:493:19: warning: cast to restricted __le16
CHECK drivers/net/wireless/libertas/mesh.c
drivers/net/wireless/libertas/mesh.c:577:16: warning: incorrect type in assignment (different base types)
drivers/net/wireless/libertas/mesh.c:577:16: expected restricted __le32 [addressable] [assigned] [usertype] id
drivers/net/wireless/libertas/mesh.c:577:16: got bool
The default llseek operation is changing from
default_llseek to no_llseek, so all code relying on
the current behaviour needs to make that explicit.
The wireless driver infrastructure and some of the drivers
make use of generated debugfs files, so they cannot
be converted by our script that automatically determines
the right operation.
All these files use debugfs and they typically rely
on simple_read_from_buffer, so the best llseek operation
here is generic_file_llseek.
Cc: "John W. Linville" <linville@tuxdriver.com>
Cc: linux-wireless@vger.kernel.org
Cc: netdev@vger.kernel.org
net/mac80211/main.c
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (26 commits)
pkt_sched: Fix lockdep warning on est_tree_lock in gen_estimator
ipvs: avoid oops for passive FTP
Revert "sky2: don't do GRO on second port"
gro: fix different skb headrooms
bridge: Clear INET control block of SKBs passed into ip_fragment().
3c59x: Remove incorrect locking; correct documented lock hierarchy
ipv4: minor fix about RPF in help of Kconfig
xfrm_user: avoid a warning with some compiler
net/sched/sch_hfsc.c: initialize parent's cl_cfmin properly in init_vf()
pxa168_eth: fix a mdiobus leak
net sched: fix kernel leak in act_police
vhost: stop worker only if created
MAINTAINERS: Add ehea driver as Supported
ath9k_hw: fix parsing of HT40 5 GHz CTLs
ath9k_hw: Fix EEPROM uncompress block reading on AR9003
wireless: register wiphy rfkill w/o holding cfg80211_mutex
netlink: Make NETLINK_USERSOCK work again.
irda: Correctly clean up self->ias_obj on irda_bind() failure.
wireless extensions: fix kernel heap content leak
The commit 886275ce41a9751117367fb387ed171049eb6148 (param: lock
if_sdio's lbs_helper_name and lbs_fw_name against sysfs changes)
introduced new fields into the if_sdio_card structure. It caused
missalignment of the if_sdio_card.buffer field and failure at driver
load time:
~# modprobe libertas_sdio
[ 62.315124] libertas_sdio: Libertas SDIO driver
[ 62.319976] libertas_sdio: Copyright Pierre Ossman
[ 63.020629] DMA misaligned error with device 48
[ 63.025207] mmci-omap-hs mmci-omap-hs.1: unexpected dma status 800
[ 66.005035] libertas: command 0x0003 timed out
[ 66.009826] libertas: Timeout submitting command 0x0003
[ 66.016296] libertas: PREP_CMD: command 0x0003 failed: -110
Adding explicit alignment attribute for the if_sdio_card.buffer field
fixes this problem.
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Acked-by: Dan Williams <dcbw@redhat.com>
drivers/net/wireless/libertas/if_sdio.c
i386 allmodconfig:
drivers/net/wireless/libertas/cfg.c: In function 'lbs_scan_worker':
drivers/net/wireless/libertas/cfg.c:722: error: 'TASK_NORMAL' undeclared (first use in this function)
drivers/net/wireless/libertas/cfg.c:722: error: (Each undeclared identifier is reported only once
drivers/net/wireless/libertas/cfg.c:722: error: for each function it appears in.)
drivers/net/wireless/libertas/cfg.c: In function 'lbs_cfg_connect':
drivers/net/wireless/libertas/cfg.c:1267: error: 'TASK_INTERRUPTIBLE' undeclared (first use in this function)
drivers/net/wireless/libertas/cfg.c:1267: error: implicit declaration of function 'signal_pending'
drivers/net/wireless/libertas/cfg.c:1267: error: implicit declaration of function 'schedule_timeout'
So wait.h has a dependency on sched.h, but doesn't include sched.h. This
patch doesn't fix that.
Cc: Dan Williams <dcbw@redhat.com>
linux-firmware puts libertas firmware in /libertas. Fix the driver to
look there first, but fall back to the old firmware names if the new
ones don't exist. Add preference for newer firmware versions too.
Signed-off-by: Dan Williams <dcbw@redhat.com>
ones don't exist.
SDIO, GSPI, and CS all use 2-stage firmware and the loading
process and logic should be the same. Allow module parameters
to override the automatic firmware choice, otherwise just walk
the bus driver's firmware table and pick out the first firmware
pair that exists for the given model.
Some special care is taken to allow overriding of just the helper
or the main firmware, but let the other of the pair be chosen
automatically.
Look for firmware where the linux-firmware tree actually puts it, but
fall back to original firmware name & location when the new location
doesn't exist.
At the point of the patched code, err has already been tested, so it is
only worthwhile to test it again in the if branches where it is changed.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r disable braces4@
position p1,p2;
statement S1,S2;
if (...) { ... }
if (...) S1@p1 S2@p2
@script:python@
p1 << r.p1;
p2 << r.p2;
if (p1[0].column == p2[0].column):
cocci.print_main("branch",p1)
cocci.print_secs("after",p2)
// </smpl>
Bring back the comment about FW v5 status codes from the pre-cfg80211
driver, and let through status codes that aren't remapped by the
firmware.
Make it a bit easier to debug scan results in the future.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (30 commits)
ctcm: rename READ/WRITE defines to avoid redefinitions
claw: rename READ/WRITE defines to avoid redefinitions
phylib: available for any speed ethernet
can: add limit for nframes and clean up signed/unsigned variables
pkt_sched: Check .walk and .leaf class handlers
pkt_sched: Fix sch_sfq vs tc_modify_qdisc oops
caif-spi: Bugfix SPI_DATA_POS settings were inverted.
caif: Bugfix - Increase default headroom size for control channel.
net: make netpoll_rx return bool for !CONFIG_NETPOLL
Bluetooth: Use 3-DH5 payload size for default ERTM max PDU size
Bluetooth: Fix incorrect setting of remote_tx_win for L2CAP ERTM
Bluetooth: Change default L2CAP ERTM retransmit timeout
Bluetooth: Fix endianness issue with L2CAP MPS configuration
net: Use NET_XMIT_SUCCESS where possible.
isdn: mISDN: call pci_disable_device() if pci_probe() failed
isdn: avm: call pci_disable_device() if pci_probe() failed
usbnet: rx_submit() should return an error code.
pkt_sched: Add some basic qdisc class ops verification. Was: [PATCH] sfq: add dummy bind/unbind handles
pkt_sched: sch_sfq: Add dummy unbind_tcf and put handles. Was: [PATCH] sfq: add dummy bind/unbind handles
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus
* 'params' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (22 commits)
param: don't deref arg in __same_type() checks
param: update drivers/acpi/debug.c to new scheme
param: use module_param in drivers/message/fusion/mptbase.c
ide: use module_param_named rather than module_param_call
param: update drivers/char/ipmi/ipmi_watchdog.c to new scheme
param: lock if_sdio's lbs_helper_name and lbs_fw_name against sysfs changes.
param: lock myri10ge_fw_name against sysfs changes.
param: simple locking for sysfs-writable charp parameters
param: remove unnecessary writable charp
param: add kerneldoc to moduleparam.h
param: locking for kernel parameters
param: make param sections const.
param: use free hook for charp (fix leak of charp parameters)
param: add a free hook to kernel_param_ops.
param: silence .init.text references from param ops
Add param ops struct for hvc_iucv driver.
nfs: update for module_param_named API change
AppArmor: update for module_param_named API change
param: use ops in struct kernel_param, rather than get and set fns directly
param: move the EXPORT_SYMBOL to after the definitions.
i386 allmodconfig:
Since it can be changed via sysfs, we need to make a copy. This most
generic way of doing this is to keep a flag so we know when to free it.
Reviewed-by: Takashi Iwai <tiwai@suse.de>
Cc: John W. Linville <linville@tuxdriver.com>
Cc: libertas-dev@lists.infradead.org
Since the writing to sysfs can free the old one, we need to block that
when we access the charp variables.
Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Jing Huang <huangj@brocade.com>
Cc: James E.J. Bottomley <James.Bottomley@suse.de>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: user-mode-linux-devel@lists.sourceforge.net
Cc: linux-scsi@vger.kernel.org
Cc: linux-usb@vger.kernel.org
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (59 commits)
igbvf.txt: Add igbvf Documentation
igb.txt: Add igb documentation
e100/e1000*/igb*/ixgb*: Add missing read memory barrier
ixgbe: fix build error with FCOE_CONFIG without DCB_CONFIG
netxen: protect tx timeout recovery by rtnl lock
isdn: gigaset: use after free
isdn: gigaset: add missing unlock
solos-pci: Fix race condition in tasklet RX handling
pkt_sched: Fix sch_sfq vs tcf_bind_filter oops
net: disable preemption before call smp_processor_id()
tcp: no md5sig option size check bug
iwlwifi: fix locking assertions
iwlwifi: fix TX tracer
isdn: fix information leak
net: Fix napi_gro_frags vs netpoll path
usbnet: remove noisy and hardly useful printk
rtl8180: avoid potential NULL deref in rtl8180_beacon_work
ath9k: Remove myself from the MAINTAINERS list
libertas: scan before assocation if no BSSID was given
libertas: fix association with some APs by using extended rates
CC [M] drivers/net/wireless/libertas/cfg.o
/home/greearb/git/wireless-testing/drivers/net/wireless/libertas/cfg.c: In function ‘lbs_scan_worker’:
/home/greearb/git/wireless-testing/drivers/net/wireless/libertas/cfg.c:722: error: ‘TASK_NORMAL’ undeclared (first use in this function)
/home/greearb/git/wireless-testing/drivers/net/wireless/libertas/cfg.c:722: error: (Each undeclared identifier is reported only once
/home/greearb/git/wireless-testing/drivers/net/wireless/libertas/cfg.c:722: error: for each function it appears in.)
/home/greearb/git/wireless-testing/drivers/net/wireless/libertas/cfg.c: In function ‘lbs_cfg_connect’:
/home/greearb/git/wireless-testing/drivers/net/wireless/libertas/cfg.c:1267: error: ‘TASK_INTERRUPTIBLE’ undeclared (first use in this function)
/home/greearb/git/wireless-testing/drivers/net/wireless/libertas/cfg.c:1267: error: implicit declaration of function ‘signal_pending’
/home/greearb/git/wireless-testing/drivers/net/wireless/libertas/cfg.c:1267: error: implicit declaration of function ‘schedule_timeout’
Reported-by: Ben Greear <greearb@candelatech.com>
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6:
pcmcia: avoid buffer overflow in pcmcia_setup_isa_irq
pcmcia: do not request windows if you don't need to
pcmcia: insert PCMCIA device resources into resource tree
pcmcia: export resource information to sysfs
pcmcia: use struct resource for PCMCIA devices, part 2
pcmcia: remove memreq_t
pcmcia: move local definitions out of include/pcmcia/cs.h
pcmcia: do not use io_req_t when calling pcmcia_request_io()
pcmcia: do not use io_req_t after call to pcmcia_request_io()
pcmcia: clean up cs.h
pcmcia: use pcmica_{read,write}_config_byte
pcmcia: remove cs_types.h
pcmcia: remove unused flag, simplify headers
pcmcia: remove obsolete CS_EVENT_ definitions
pcmcia: split up central event handler
pcmcia: simplify event callback
pcmcia: remove obsolete ioctl
Conflicts in:
- drivers/staging/comedi/drivers/*
- drivers/staging/wlags49_h2/wl_cs.c
due to dev_info_t and whitespace changes
Fix this leftover TODO from the cfg80211 conversion by doing a scan
if cfg80211 didn't pass in the BSSID for us. Since the scan code
uses so much of the cfg80211_scan_request structure to build up the
firmware command, we just fake one when the scan request is triggered
internally. But we need to make sure that internal 'fake' cfg82011
scan request does not get back to cfg82011 via cfg80211_scan_done().
Some APs get pissy if you don't send the firmware the extended rates
in the association request's rates TLV. Found this on a Linksys
WRT54G v2; it denies association with status code 18 unless you
add the extended rates too. The old driver did this, but it got
lost in the cfg80211 conversion.
Let's actually check the right field in the command response; and
if there aren't any reported BSSes, exit early with success.
Instead of io_req_t, drivers are now requested to fill out
struct pcmcia_device *p_dev->resource[0,1] for up to two ioport
ranges. After a call to pcmcia_request_io(), the ports found there
are reserved, after calling pcmcia_request_configuration(), they may
be used.
CC: Michael Buesch <mb@bu3sch.de>
Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/)
After pcmcia_request_io(), do not make use of the values stored in
io_req_t, but instead use those found in struct pcmcia_device->resource[].
Remove cs_types.h which is no longer needed: Most definitions aren't
used at all, a few can be made away with, and two remaining definitions
(typedefs, unfortunatley) may be moved to more specific places.
Remove last bits of indirect command code.
Other uses were already used direct command paths.
Powersave looks like it got broken at some point but we'll fix that up
when the command submission stuff is more understandable, which this
series helps to do. That said, this patch should not further break
powersave.
Slightly different approach here since there are so many arguments to
the firmware command. Just let the caller fill them in before pushing
the command to the firmware.
For now; it's a pretty easy command to hook up and whenever OLPC
figures out how they want the userspace interface to look (ie,
not iwpriv commands) we can easily add it back in. Since the
cfg80211 conversion it wasn't working anyway.
It hasn't been hooked up to anything in a long time and it's not
even listed in any of the firmware documentation I have (and I
have v5.1, v8, v9, and v10).
These were no longer used but were left around; Transmit Power
Control is done through the lbs_set_tpc_cfg() function.
Convert to a full direct command; previous code rolled a direct
command by hand but left the original indirect command code intact
but disabled.
command by handle but left the original indirect command code
lying around.
git://git.kernel.org/pub/scm/linux/kernel/git/holtmann/bluetooth-next-2.6
drivers/net/wireless/iwlwifi/iwl-commands.h
Negate has precedence over comparison so the original test was always
false. (Neither 0 nor 1 are equal to NL80211_IFTYPE_MONITOR).
