path: root/drivers/net/wireless/libertas
2012-04-05simple_open: automatically convert to simple_open()Stephen Boyd
Many users of debugfs copy the implementation of default_open() when they want to support a custom read/write function op. This leads to a proliferation of the default_open() implementation across the entire tree. Now that the common implementation has been consolidated into libfs we can replace all the users of this function with simple_open(). This replacement was done with the following semantic patch: <smpl> @ open @ identifier open_f != simple_open; identifier i, f; @@ -int open_f(struct inode *i, struct file *f) -{ ( -if (i->i_private) -f->private_data = i->i_private; | -f->private_data = i->i_private; ) -return 0; -} @ has_open depends on open @ identifier fops; identifier open.open_f; @@ struct file_operations fops = { ... -.open = open_f, +.open = simple_open, ... }; </smpl> [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-16Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem Conflicts: drivers/net/wireless/ath/ath9k/hw.c
2012-03-15libertas: remove dump_survey implementationDaniel Drake
libertas provides a dump_survey implementation based on reading of a RSSI value. However, this RSSI value is calculated based on the last received beacon from the associated AP - it is not a good way of surveying a channel in general, and even causes an error if the card is not associated to a network. As this is not appropriate as a survey, remove it. This fixes an issue where something in userspace is repeatedly calling site-survey during boot, resulting in many repeated errors as the RSSI value cannot be read before associating. Signed-off-by: Daniel Drake <dsd@laptop.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-31drivers/net: Remove unnecessary k.alloc/v.alloc OOM messagesJoe Perches
alloc failures use dump_stack so emitting an additional out-of-memory message is an unnecessary duplication. Remove the allocation failure messages. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-08Merge branch 'for-linus2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs * 'for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (165 commits) reiserfs: Properly display mount options in /proc/mounts vfs: prevent remount read-only if pending removes vfs: count unlinked inodes vfs: protect remounting superblock read-only vfs: keep list of mounts for each superblock vfs: switch ->show_options() to struct dentry * vfs: switch ->show_path() to struct dentry * vfs: switch ->show_devname() to struct dentry * vfs: switch ->show_stats to struct dentry * switch security_path_chmod() to struct path * vfs: prefer ->dentry->d_sb to ->mnt->mnt_sb vfs: trim includes a bit switch mnt_namespace ->root to struct mount vfs: take /proc/*/mounts and friends to fs/proc_namespace.c vfs: opencode mntget() mnt_set_mountpoint() vfs: spread struct mount - remaining argument of next_mnt() vfs: move fsnotify junk to struct mount vfs: move mnt_devname vfs: move mnt_list to struct mount vfs: switch pnode.h macros to struct mount * ...
2012-01-07Merge branch 'driver-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core * 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (73 commits) arm: fix up some samsung merge sysdev conversion problems firmware: Fix an oops on reading fw_priv->fw in sysfs loading file Drivers:hv: Fix a bug in vmbus_driver_unregister() driver core: remove __must_check from device_create_file debugfs: add missing #ifdef HAS_IOMEM arm: time.h: remove device.h #include driver-core: remove sysdev.h usage. clockevents: remove sysdev.h arm: convert sysdev_class to a regular subsystem arm: leds: convert sysdev_class to a regular subsystem kobject: remove kset_find_obj_hinted() m86k: gpio - convert sysdev_class to a regular subsystem mips: txx9_sram - convert sysdev_class to a regular subsystem mips: 7segled - convert sysdev_class to a regular subsystem sh: dma - convert sysdev_class to a regular subsystem sh: intc - convert sysdev_class to a regular subsystem power: suspend - convert sysdev_class to a regular subsystem power: qe_ic - convert sysdev_class to a regular subsystem power: cmm - convert sysdev_class to a regular subsystem s390: time - convert sysdev_class to a regular subsystem ... Fix up conflicts with 'struct sysdev' removal from various platform drivers that got changed: - arch/arm/mach-exynos/cpu.c - arch/arm/mach-exynos/irq-eint.c - arch/arm/mach-s3c64xx/common.c - arch/arm/mach-s3c64xx/cpu.c - arch/arm/mach-s5p64x0/cpu.c - arch/arm/mach-s5pv210/common.c - arch/arm/plat-samsung/include/plat/cpu.h - arch/powerpc/kernel/sysfs.c and fix up cpu_is_hotpluggable() as per Greg in include/linux/cpu.h
2012-01-06Merge branch 'driver-core-next' into Linux 3.2Greg Kroah-Hartman
This resolves the conflict in the arch/arm/mach-s3c64xx/s3c6400.c file, and it fixes the build error in the arch/x86/kernel/microcode_core.c file, that the merge did not catch. The microcode_core.c patch was provided by Stephen Rothwell <sfr@canb.auug.org.au> who was invaluable in the merge issues involved with the large sysdev removal process in the driver-core tree. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-03switch debugfs to umode_tAl Viro
2012-01-03Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem Conflicts: drivers/net/wireless/b43/dma.c drivers/net/wireless/brcm80211/brcmfmac/dhd_linux.c
2011-12-21libertas: clean up scan thread handlingAndres Salomon
The libertas scan thread expects priv->scan_req to be non-NULL. In theory, it should always be set. In practice, we've seen the following oops: [ 8363.067444] Unable to handle kernel NULL pointer dereference at virtual address 00000004 [ 8363.067490] pgd = c0004000 [ 8363.078393] [00000004] *pgd=00000000 [ 8363.086711] Internal error: Oops: 17 [#1] PREEMPT [ 8363.091375] Modules linked in: fuse libertas_sdio libertas psmouse mousedev ov7670 mmp_camera joydev videobuf2_core videobuf2_dma_sg videobuf2_memops [last unloaded: scsi_wait_scan] [ 8363.107490] CPU: 0 Not tainted (3.0.0-gf7ccc69 #671) [ 8363.112799] PC is at lbs_scan_worker+0x108/0x5a4 [libertas] [ 8363.118326] LR is at 0x0 [ 8363.120836] pc : [<bf03a854>] lr : [<00000000>] psr: 60000113 [ 8363.120845] sp : ee66bf48 ip : 00000000 fp : 00000000 [ 8363.120845] r10: ee2c2088 r9 : c04e2efc r8 : eef97005 [ 8363.132231] r7 : eee0716f r6 : ee2c02c0 r5 : ee2c2088 r4 : eee07160 [ 8363.137419] r3 : 00000000 r2 : a0000113 r1 : 00000001 r0 : eee07160 [ 8363.143896] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel [ 8363.157630] Control: 10c5387d Table: 2e754019 DAC: 00000015 [ 8363.163334] Process kworker/u:1 (pid: 25, stack limit = 0xee66a2f8) While I've not found a smoking gun, there are two places that raised red flags for me. The first is in _internal_start_scan, when we queue up a scan; we first queue the worker, and then set priv->scan_req. There's theoretically a 50mS delay which should be plenty, but doing things that way just seems racy (and not in the good way). The second is in the scan worker thread itself. Depending on the state of priv->scan_channel, we cancel pending scan runs and then requeue a run in 300mS. We then send the scan command down to the hardware, sleep, and if we get scan results for all the desired channels, we set priv->scan_req to NULL. However, it that's happened in less than 300mS, what happens with the pending scan run? This patch addresses both of those concerns. With the patch applied, we have not seen the oops in the past two weeks. Signed-off-by: Andres Salomon <dilinger@queued.net> Cc: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-12-19net: fix assignment of 0/1 to bool variables.Rusty Russell
DaveM said: Please, this kind of stuff rots forever and not using bool properly drives me crazy. Joe Perches <joe@perches.com> gave me the spatch script: @@ bool b; @@ -b = 0 +b = false @@ bool b; @@ -b = 1 +b = true I merely installed coccinelle, read the documentation and took credit. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-02Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless Conflicts: drivers/net/wireless/iwlwifi/iwl-agn.c drivers/net/wireless/libertas/cfg.c
2011-11-28wireless: Remove redundant spi driver bus initializationLars-Peter Clausen
In ancient times it was necessary to manually initialize the bus field of an spi_driver to spi_bus_type. These days this is done in spi_driver_register(), so we can drop the manual assignment. The patch was generated using the following coccinelle semantic patch: // <smpl> @@ identifier _driver; @@ struct spi_driver _driver = { .driver = { - .bus = &spi_bus_type, }, }; // </smpl> Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Cc: Dan Williams <dcbw@redhat.com> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: Christian Lamparter <chunkeey@googlemail.com> Cc: Luciano Coelho <coelho@ti.com> Cc: libertas-dev@lists.infradead.org Cc: linux-wireless@vger.kernel.org Acked-by: Luciano Coelho <coelho@ti.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-22Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux Conflicts: drivers/net/wireless/iwlegacy/iwl-debugfs.c drivers/net/wireless/iwlegacy/iwl-rx.c drivers/net/wireless/iwlegacy/iwl-scan.c drivers/net/wireless/iwlegacy/iwl-tx.c include/net/bluetooth/bluetooth.h
2011-11-18USB: convert drivers/net/* to use module_usb_driver()Greg Kroah-Hartman
This converts the drivers in drivers/net/* to use the module_usb_driver() macro which makes the code smaller and a bit simpler. Added bonus is that it removes some unneeded kernel log messages about drivers loading and/or unloading. Cc: Wolfgang Grandegger <wg@grandegger.com> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: Oliver Neukum <oliver@neukum.name> Cc: Peter Korsgaard <jacmet@sunsite.dk> Cc: Petko Manolov <petkan@users.sourceforge.net> Cc: Steve Glendinning <steve.glendinning@smsc.com> Cc: Christian Lamparter <chunkeey@googlemail.com> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: Dan Williams <dcbw@redhat.com> Cc: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Cc: Ivo van Doorn <IvDoorn@gmail.com> Cc: Gertjan van Wingerde <gwingerde@gmail.com> Cc: Helmut Schaa <helmut.schaa@googlemail.com> Cc: Herton Ronaldo Krzesinski <herton@canonical.com> Cc: Hin-Tak Leung <htl10@users.sourceforge.net> Cc: Larry Finger <Larry.Finger@lwfinger.net> Cc: Chaoming Li <chaoming_li@realsil.com.cn> Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi> Cc: "David S. Miller" <davem@davemloft.net> Cc: Roel Kluin <roel.kluin@gmail.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Jiri Pirko <jpirko@redhat.com> Cc: Pavel Roskin <proski@gnu.org> Cc: Yoann DI-RUZZA <y.diruzza@lim.eu> Cc: George <george0505@realtek.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-17wireless: use strlcpy routine in .get_drvinfoRick Jones
Convert various seemingly still compiled wireless drivers' .get_drvinfo routines to use the preferred strlcpy() routine. Signed-off-by: Rick Jones <rick.jones2@hp.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-17Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
2011-11-15Net, libertas: Resolve memory leak in if_spi_host_to_card()Jesper Juhl
If we hit the default case in the switch in if_spi_host_to_card() we'll leak the memory we allocated for 'packet'. This patch resolves the leak by freeing the allocated memory in that case. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Acked-by: Dan Williams <dcbw@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-11libertas: release bss references and avoid warning from cfg80211_inform_bssJohn W. Linville
CC [M] drivers/net/wireless/libertas/cfg.o drivers/net/wireless/libertas/cfg.c: In function ‘lbs_ret_scan’: drivers/net/wireless/libertas/cfg.c:636:24: warning: ignoring return value of ‘cfg80211_inform_bss’, declared with attribute warn_unused_result drivers/net/wireless/libertas/cfg.c: In function ‘lbs_join_post’: drivers/net/wireless/libertas/cfg.c:1766:21: warning: ignoring return value of ‘cfg80211_inform_bss’, declared with attribute warn_unused_result Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-11Merge branch 'master' of ↵John W. Linville
2011-11-09wireless: libertas: fix unaligned le64 accessesSteven Miao
use get_unaligned_le64() to get timestamp Signed-off-by: Steven Miao <realmz6@gmail.com> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (47 commits) forcedeth: fix a few sparse warnings (variable shadowing) forcedeth: Improve stats counters forcedeth: remove unneeded stats updates forcedeth: Acknowledge only interrupts that are being processed forcedeth: fix race when unloading module MAINTAINERS/rds: update maintainer wanrouter: Remove kernel_lock annotations usbnet: fix oops in usbnet_start_xmit ixgbe: Fix compile for kernel without CONFIG_PCI_IOV defined etherh: Add MAINTAINERS entry for etherh bonding: comparing a u8 with -1 is always false sky2: fix regression on Yukon Optima netlink: clarify attribute length check documentation netlink: validate NLA_MSECS length i825xx:xscale:8390:freescale: Fix Kconfig dependancies macvlan: receive multicast with local address tg3: Update version to 3.121 tg3: Eliminate timer race with reset_task tg3: Schedule at most one tg3_reset_task run tg3: Obtain PCI function number from device ...
2011-11-02libertas: ensure we clean up a scan request properlyAndres Salomon
Commit 2e30168b ("libertas: terminate scan when stopping interface") adds cleanup code to lbs_eth_stop to call cfg80211_scan_done if there's an outstanding cfg80211_scan_request. However, it assumes that the scan request was allocated via the cfg80211 stack. Libertas has its own internal allocation method, kept track of with priv->internal_scan. This doesn't set scan_req->wiphy, amongst other things, which results in hitting a BUG() when we call cfg80211_scan_done on the request. This provides a function to take care of the low-level scan_req cleanup details. We simply call that to deal with finishing up scan requests. The bug we were hitting was: [ 964.321495] kernel BUG at net/wireless/core.h:87! [ 964.329970] Unable to handle kernel NULL pointer dereference at virtual address 00000000 [ 964.341963] pgd = dcf80000 ... [ 964.849998] 9fe0: 00000000 beb417b8 4018e280 401e822c 60000010 00000004 00000000 00000000 [ 964.865007] [<c003104c>] (__bug+0x1c/0x28) from [<c0384ffc>] (cfg80211_scan_done+0x54/0x6c) [ 964.895324] [<c0384ffc>] (cfg80211_scan_done+0x54/0x6c) from [<bf028bac>] (lbs_eth_stop+0x10c/0x188 [libertas]) [ 964.895324] [<bf028bac>] (lbs_eth_stop+0x10c/0x188 [libertas]) from [<c03002a0>] (__dev_close_many+0x94/0xc4) [ 964.918995] [<c03002a0>] (__dev_close_many+0x94/0xc4) from [<c030037c>] (dev_close_many+0x78/0xe0) Signed-off-by: Andres Salomon <dilinger@queued.net> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-10-31drivers/net: change moduleparam.h to module.h as required.Paul Gortmaker
2011-10-31drivers/net: Add export.h to files using EXPORT_SYMBOL/THIS_MODULEPaul Gortmaker
These were getting the macros from an implicit module.h include via device.h, but we are planning to clean that up. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> drivers/net: Add export.h to wireless/brcm80211/brcmfmac/bcmsdh.c This relatively recently added file uses EXPORT_SYMBOL and hence needs export.h included so that it is compatible with the module.h split up work. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-17Merge branch 'master' of ↵John W. Linville
git://git.infradead.org/users/linville/wireless-next into for-davem
2011-10-14libertas: fix changing interface type when interface is downDaniel Drake
The recent changes to only power the device when the interface up introduced a bug: changing interface type, legal when the interface is down, performs device I/O. Fix this functionality by validating and recording the interface type when the change is requested, but only applying the change if/when the interface is brought up. Signed-off-by: Daniel Drake <dsd@laptop.org> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-10-11Merge branch 'master' of ↵John W. Linville
git://git.infradead.org/users/linville/wireless-next into for-davem Conflicts: Documentation/feature-removal-schedule.txt
2011-10-03libertas: detect TX lockups and reset hardwareDaniel Drake
Recent patches added support for resetting the SD8686 hardware when commands time out, which seems to happen quite frequently soon after resuming the system from a Wake-on-WLAN-triggered resume. At http://dev.laptop.org/ticket/10969 we see the same thing happen with transmits. In this case, the hardware will fail to respond to a frame passed for transmission, and libertas (correctly) will block all further commands and transmissions as the hardware can only deal with one thing at a time. This results in a lockup while the system waits indefinitely for the dead card to respond. Hook up a TX lockup timer to detect this and reset the hardware. Signed-off-by: Daniel Drake <dsd@laptop.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-30Merge branch 'master' of ↵John W. Linville
git://git.infradead.org/users/linville/wireless-next into for-davem Conflicts: drivers/net/wireless/iwlwifi/iwl-pci.c drivers/net/wireless/wl12xx/main.c
2011-09-27libertas: scan behaviour consistency improvementsDaniel Drake
When scanning for the broadcast SSID, there is no need to add the SSID TLV (restoring the behaviour of the driver behaviour in the wext days, confirmed in Marvell specifications). If bssid is unspecified, the current scan code will usually fire off an active scan probing for the specific requested SSID. However, if a scan is ongoing (or has just finished), those scan results will be used instead (even if that scan is totally different, e.g. a passive scan on channel 4 for a different SSID). Fix this inconsistency by always firing off a scan when associating without a bssid. Signed-off-by: Daniel Drake <dsd@laptop.org> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-19Merge branch 'master' of ssh://infradead/~/public_git/wireless-next into ↵John W. Linville
for-davem
2011-09-14libertas: prioritize usb8388_olpc.bin firmware on OLPC machinesAndres Salomon
Normally, the v9 firmware will be loaded if it's available. However, on OLPC XO-1 machines, the olpc-specific firmware supports extra functionality. This makes the libertas driver attempt to load the custom firmware first if the machine is an OLPC machine; if that fails (or it's not an OLPC machine), fall back to attempting to load the other firmwares. usb8388_olpc.bin is currently found in the linux-firmware repository. Signed-off-by: Andres Salomon <dilinger@queued.net> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-29Merge branch 'master' of ↵John W. Linville
2011-08-24libertas: update readme fileAmitkumar Karwar
Since all wext specific code is removed, currently there is no way to configure deep sleep mode. This patch removes deep sleep configuration information in readme file. Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-24libertas: handle mesh networks in lbs_iface_active()Dan Carpenter
There was an extra semicolon so the if condition wasn't used. We checked "priv->dev" twice instead of "priv->mesh_dev". Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-22Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem Conflicts: drivers/staging/ath6kl/miscdrv/ar3kps/ar3kpsparser.c drivers/staging/ath6kl/os/linux/ar6000_drv.c
2011-08-17net: remove use of ndo_set_multicast_list in driversJiri Pirko
replace it by ndo_set_rx_mode Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-09libertas: remove some dead code in if_spi_prog_helper_firmware()Dan Carpenter
We always hit the goto and skip the printk(). The original code does the right thing even though it looks messy. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-09libertas: implement if_sdio runtime power managementDaniel Drake
The SDIO card is now fully powered down when the network interface is brought down. Signed-off-by: Daniel Drake <dsd@laptop.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-09libertas: disable functionality when interface is downDaniel Drake
Modify the driver so that it does not function when the interface is down, in preparation for runtime power management. No commands can be run while the interface is down, so the ndo_dev_stop routine now directly does all necessary work (including asking the device to disconnect from the network and disabling multicast functionality) directly. power_save and power_restore hooks are added meaning that card drivers can take steps to turn the device off when the interface is down. The MAC address can now only be changed when all interfaces are down; the new address will be programmed when an interface gets brought up. This matches mac80211 behaviour. Also, some small cleanups/simplifications were made in the surrounding device handling logic. Signed-off-by: Daniel Drake <dsd@laptop.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-08libertas_usb: program OLPC EC wakeup mask for wake-on-WLANDaniel Drake
OLPC power management code has recently gone upstream. This piece completes the puzzle for libertas_usb, which now programs the OLPC EC for wlan wakeups when they have been requested. Signed-off-by: Daniel Drake <dsd@laptop.org> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-08libertas_usb: use USB interface as parent deviceDaniel Drake
Currently, "udevadm info -a -p /sys/class/net/wlan0" doesn't mention the usb8xxx or libertas driver anywhere. This makes writing udev rules a bit uncomfortable. Using the USB interface as the parent device corrects the hierarchy. Signed-off-by: Daniel Drake <dsd@laptop.org> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-08libertas: link mesh device to wiphyDaniel Drake
The mesh device is now exposed as an interface of the wiphy. This exposes the mesh device to the cfg80211 interface, allowing mesh channel selection to be reimplemented, and available to NetworkManager as it was before. Some header tweaking was needed in order to implement lbs_mesh_activated(). Signed-off-by: Daniel Drake <dsd@laptop.org> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-22Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
2011-07-20libertas: only enable mesh when interface is activeDaniel Drake
Previously, the mesh was running whenever the appropriate hardware and firmware was present. Now we only run the mesh when the interface is running. Also simplifies interface management a little. Signed-off-by: Daniel Drake <dsd@laptop.org> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-20libertas: mesh: misc cleanupDaniel Drake
Remove unused blindlist code. Mark a few items const and static where possible. Involved some code re-ordering, but no code changes. Signed-off-by: Daniel Drake <dsd@laptop.org> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-15Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: net/bluetooth/l2cap_core.c
2011-07-11libertas: fix handling of command timeout, completion and interruptionDaniel Drake
When commands time out, corruption ensues. As lbs_complete_command() is called without locking, the command node is mistakenly freed twice. Also fixed up locking here in a few other places. The nature of command timeout may be that the card didn't even acknowledge receipt of the request. Detect this case and reset dnld_sent so that other commands don't hang forever. When cmdnodes are moved between the free list and the pending list, their list heads should be reinitialized. Fixed this. Sometimes commands are completed without actually submitting them or removing them from cmdpendingq. We must remember to remove them from cmdpendingq in these cases, so handle this in lbs_complete_command(). Harmless signals generated during suspend/resume were interrupting lbs_cmd. Convert to an uninterruptible sleep to avoid this. lbs_thread must be woken up every time there is some new work to do. I found that when 2 commands are queued, ther completion of the first command would not wake up lbs_thread to submit the second. Poke lbs_thread at the end of lbs_complete_command() to fix this. Signed-off-by: Daniel Drake <dsd@laptop.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-11libertas: fix errors in functions accessing module registersOlivier Sobrie
Problems located in the two functions lbs_set_reg() and lbs_get_reg(): - The offset field of struct cmd_ds_reg_access was not filled in - The test on the return code of lbs_cmd_with_response() in function lbs_get_reg() was inverted Signed-off-by: Olivier Sobrie <olivier@sobrie.be> Signed-off-by: John W. Linville <linville@tuxdriver.com>
