This enum is already perfectly aliased to enum nl80211_band, and
the only reason for it is that we get IEEE80211_NUM_BANDS out of
it. There's no really good reason to not declare the number of
bands in nl80211 though, so do that and remove the cfg80211 one.
This array contains list of supported region codes.
It is changed to make it aligned with region code
to country mapping table in driver.
Signed-off-by: Amitkumar Karwar <akarwar@marvell.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
EU is not a valid country in db.txt file. Hence regulatory_hint
returns failure if EEPROM provides region code as 0x30. Let's
use FR for 0x30.
Signed-off-by: Cathy Luo <cluo@marvell.com>
Driver gets country information from EEPROM during
initialization. We will call regulatory_hint to update
current regulatory domain.
As by default world regulatory domain is selected by
cfg80211, country '00' from EEPROM is ignored.
Part of reorganising wireless drivers directory and Kconfig.
