commit 6a953dc4dbd1c7057fb765a24f37a5e953c85fb0 upstream.
A new warning in clang points out when macro expansion might result in a
GNU C statement expression. There is an instance of this in the mwifiex
driver:
drivers/net/wireless/marvell/mwifiex/cmdevt.c:217:34: warning: '}' and
')' tokens terminating statement expression appear in different macro
expansion contexts [-Wcompound-token-split-by-macro]
host_cmd->seq_num = cpu_to_le16(HostCmd_SET_SEQ_NO_BSS_INFO
drivers/net/wireless/marvell/mwifiex/fw.h:519:46: note: expanded from
macro 'HostCmd_SET_SEQ_NO_BSS_INFO'
(((type) & 0x000f) << 12); }
This does not appear to be a real issue. Removing the braces and
replacing them with parentheses will fix the warning and not change the
meaning of the code.
Fixes: 5e6e3a92b9a4 ("wireless: mwifiex: initial commit for Marvell mwifiex driver")
Link: https://github.com/ClangBuiltLinux/linux/issues/1146
Reported-by: Andy Lavr <andy.lavr@gmail.com>
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
Reviewed-by: Nick Desaulniers <ndesaulniers@google.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
Link: https://lore.kernel.org/r/20200901070834.1015754-1-natechancellor@gmail.com
Signed-off-by: Anders Roxell <anders.roxell@linaro.org>
main_proc_lock and int_lock (in mwifiex_adapter) are the only spinlocks
used in hardirq contexts. The rest are only in task or softirq contexts.
Convert every other lock from *_irq{save,restore}() variants to _bh()
variants.
This is a mechanical transformation of all spinlock usage in mwifiex
using the following:
Step 1:
I ran this nasty sed script:
sed -i -E '/spin_lock_irqsave|spin_unlock_irqrestore/ {
/main_proc_lock|int_lock/! {
s:(spin_(un|)lock)_irq(save|restore):\1_bh: ;
# Join broken lines.
:a /;$/! {
N;
s/\s*\n\s*//;
ba
/,.*\);$/ s:,.*\):\):
}' drivers/net/wireless/marvell/mwifiex/*
Step 2:
Manually delete the flags / ra_list_flags args from:
mwifiex_send_single_packet()
mwifiex_11n_aggregate_pkt()
mwifiex_send_processed_packet()
which are now unused.
Step 3:
Apply this semantic patch (coccinelle) to remove the unused 'flags'
variables:
// <smpl>
type T;
identifier i;
extern T i;
- T i;
... when != i
// </smpl>
(Usage is something like this:
make coccicheck COCCI=./patch.cocci MODE=patch M=drivers/net/wireless/marvell/mwifiex/
although this skips *.h files for some reasons, so I had to massage
stuff.)
Testing: I've played with a variety of stress tests, including download
stress tests on the same APs which caught regressions with commit
5188d5453bc9 ("mwifiex: restructure rx_reorder_tbl_lock usage"). I've
primarily tested on Marvell 8997 / PCIe, although I've given 8897 / SDIO
a quick spin as well.
Signed-off-by: Brian Norris <briannorris@chromium.org>
Firmware can send invalid command response, the processing of
which can attempt to modify unexpected context and cause issues.
To fix this, driver should check that the command response ID is
same as the one it downloaded, and ignore processing of invalid
response.
Signed-off-by: Swati Kushwaha <swatiuma@marvell.com>
Signed-off-by: Ganapathi Bhat <gbhat@marvell.com>
In case dev_alloc_skb fails, the fix returns -ENOMEM to avoid
NULL pointer dereference.
Signed-off-by: Kangjie Lu <kjlu@umn.edu>
Driver is using boolean variables to maintain vairous status
information of adapter. These status variables are accessed by
multiple threads and there is a possibility of a race. To avoid
this, convert these variables to a set of bitops flags, to be
operated atomically.
Below variables of mwifiex_adapter are converted to bitop flags:
surprise_removed
is_cmd_timedout
is_suspended
is_hs_configured
hs_enabling
Nothing that is defined in 11ac.h is referenced in cmdevt.c.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
High bits of antenna number are reserved in hardware spec,
using low 4 bits represent supported antenna.
Signed-off-by: Cathy Luo <cluo@marvell.com>
Signed-off-by: Xinming Hu <huxm@marvell.com>
This patch extend device_dump debugfs function to make it
works for usb interface.
For command timeouts, USB firmware will automatically emit
firmware dump events, so we don't implement device_dump().
For user-initiated dumps, we trigger it by issue firmware
dump event command to firmware, as there is no command
response, do not start 10s timer.
In preparation for unconditionally passing the struct timer_list pointer to
all timer callbacks, switch to using the new timer_setup() and from_timer()
to pass the timer pointer explicitly.
Cc: Kalle Valo <kvalo@codeaurora.org>
Cc: Amitkumar Karwar <amitkarwar@gmail.com>
Cc: Nishant Sarmukadam <nishants@marvell.com>
Cc: Ganapathi Bhat <gbhat@marvell.com>
Cc: Xinming Hu <huxm@marvell.com>
Cc: Arvind Yadav <arvind.yadav.cs@gmail.com>
Cc: Johannes Berg <johannes.berg@intel.com>
Cc: Andrew Zaborowski <andrew.zaborowski@intel.com>
Cc: libertas-dev@lists.infradead.org
Cc: linux-wireless@vger.kernel.org
Cc: netdev@vger.kernel.org
Use put_unaligned_le32 rather than using byte ordering function and
memcpy which makes code clear.
Also, add the header file where it is declared.
Done using Coccinelle and semantic patch used is :
@ rule1 @
identifier tmp; expression ptr,x; type T;
- tmp = cpu_to_le32(x);
<+... when != tmp
- memcpy(ptr, (T)&tmp, ...);
+ put_unaligned_le32(x,ptr);
@ depends on rule1 @
type j; identifier tmp;
- j tmp;
...when != tmp
Signed-off-by: Himanshu Jha <himanshujha199640@gmail.com>
It has some scary comments about "only being called" from the timeout
handler, so let's help keep it that way.
It's always called with 'true' -- we only determine it 'false' locally
within this function. So drop the parameter.
Also, this should be 'bool' (since we use true/false), not 'u32'.
It doesn't fail.
There were many places that my previous spatch didn't find,
as pointed out by yuan linyu in various patches.
The following spatch found many more and also removes the
now unnecessary casts:
identifier p, p2;
expression len;
expression skb;
type t, t2;
-p = skb_put(skb, len);
+p = skb_put_zero(skb, len);
-p = (t)skb_put(skb, len);
... when != p
p2 = (t2)p;
-memset(p2, 0, len);
-memset(p, 0, len);
type t, t2;
identifier p, p2;
expression skb;
t *p;
-p = skb_put(skb, sizeof(t));
+p = skb_put_zero(skb, sizeof(t));
-p = (t *)skb_put(skb, sizeof(t));
... when != p
p2 = (t2)p;
-memset(p2, 0, sizeof(*p));
-memset(p, 0, sizeof(*p));
expression skb, len;
-memset(skb_put(skb, len), 0, len);
+skb_put_zero(skb, len);
Apply it to the tree (with one manual fixup to keep the
comment in vxlan.c, which spatch removed.)
Usb tx aggregation feature will utilize 4-bytes bus interface header,
otherwise it will be set to zero in default case.
mwifiex_exec_next_cmd() seems to have a classic TOCTOU race, where we
drop the list lock in between retrieving the next command and deleting
it from the list. This potentially leaves room for someone else to also
retrieve / steal this node from the list (e.g.,
mwifiex_cancel_all_pending_cmd()).
Let's keep holding the lock while we do our 'ps_state' sanity checks.
There should be no harm in continuing to hold this lock for a bit more.
Noticed only by code inspection.
Just like in the previous patch ("mwifiex: Don't release
tx_ba_stream_tbl_lock while iterating"), in
mwifiex_cancel_all_pending_cmd() we were itearting over a list protected
by a spinlock. Again, it is not safe to release the spinlock while
iterating. Don't do it.
Luckily in this case there should be no need to release the spinlock.
This is evidenced by:
1. The only function called while the spinlock was released was
mwifiex_recycle_cmd_node()
2. Aside from atomic functions (which are safe to call), the only
function called by mwifiex_recycle_cmd_node() was
mwifiex_insert_cmd_to_free_q().
3. It can be seen in mwifiex_cancel_pending_scan_cmd() that it's OK to
call mwifiex_insert_cmd_to_free_q() while holding a different
spinlock (scan_pending_q_lock), so in general holding a spinlock
should be OK.
4. It doesn't appear that mwifiex_insert_cmd_to_free_q() has any
interaction with the cmd_pending_q_lock
No known bugs are fixed with this change, but as with other similar
changes this could fix random list corruption.
Signed-off-by: Douglas Anderson <dianders@chromium.org>
Using the accessor function e.g. get_unaligned_le32 instead of
le32_to_cpu to avoid the unaligned access. This is for the
architectures that don't handle the unaligned memory access
Signed-off-by: Devidas Puranik <devidas@marvell.com>
We may get SLEEP event from firmware even if TXDone interrupt
for last Tx packet is still pending. In this case, we may
end up accessing PCIe memory for handling TXDone after power
save handshake is completed. This causes kernel crash with
external abort.
This patch will only allow downloading sleep confirm
when no tx done interrupt is pending in the hardware.
Signed-off-by: Shengzhen Li <szli@marvell.com>
Tested-by: Xinming Hu <huxm@marvell.com>
Signed-off-by: Amitkumar Karwar <akarwar@marvell.com>
Reviewed-by: Brian Norris <briannorris@chromium.org>
By default normal mode is chosen when driver is loaded. This
patch adds a provision to choose manufacturing mode via module
parameters.
Below command loads driver in manufacturing mode
insmod mwifiex.ko mfg_mode=1.
Tested-by: chunfan chen <jeffc@marvell.com>
It's been observed that firmware sends RADAR detected event without
specifying bss_num/bss_type. Also, the event body is empty.
Currently the event is being ignored by driver.
This patch checks on which interface 11H is active, accordingly fills
bss_num/bss_type and handles the event. Condition
"if (le32_to_cpu(rdr_event->passed))" which always fails is also removed.
This patch creates common function mwifiex_cancel_scan to remove
duplication of code.
after factoring out mwifiex_cancel_pending_scan_cmd
the function is not called outside of cmdevt file
moved function to head of file to avoid forward declaration,
also moved mwifiex_recycle_cmd_node since they are very similar
Signed-off-by: Andreas Fenkart <afenkart@gmail.com>
Releasing the scan_pending lock in mwifiex_check_next_scan_command
introduces a short window where pending scan commands can be removed
or added before removing them all in mwifiex_cancel_pending_scan_cmd.
I think this is safe, since the worst thing to happen is that a
pending scan cmd is removed by the command handler. Adding new scan
commands is not possible while one is pending, see scan_processing flag.
Since all commands are removed from the queue anyway, we don't care if
some commands are removed by a different code path earlier, the final
state remains the same.
I assume, that the critical section needed for the check has been
extended over clearing the pending scan queue out of convenience. The
lock was already held and releasing it and grab it again was just
more work. It doesn't seem to be necessary because of concurrency.
During system suspend, there is a kernel WARNING issued if there
is a pending command present. By marking the wait queue disabled
after calling the command completion routine fixes it.
Signed-off-by: Vishal Thanki <vishalthanki@gmail.com>
This patch adds code to report wakeup reason to cfg80211
when system is resumed.
Signed-off-by: chunfan chen <jeffc@marvell.com>
It's better to use world if region code from EEPROM is
unidentied instead of forcing it to FCC
Part of reorganising wireless drivers directory and Kconfig.
