mac80211 requires that rx path does not run concurrently with
tx status reporting. Add a spinlock which will ensure that.
Signed-off-by: Jakub Kicinski <kubakici@wp.pl>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
tx status reporting. Since rx path is run in driver tasklet,
tx status cannot be reported directly from interrupt context
(there would be no way to lock it out).
Add tasklet for tx and move all possible code from irq handler
there.
Note: tx tasklet is needed because workqueue is queued very
rarely and that kills TCP performance.
Rx is run inside a tasklet so ieee80211_rx() should be used
instead of ieee80211_rx_ni().
Users of older Ralink devices report that received frames
sometimes have zero length. Watch out for that.
Add support for the simplest of MediaTek Wi-Fi devices - MT7601U.
It is a single stream bgn chip with no bells or whistles.
This driver is partially based on Felix's mt76 but IMHO it doesn't
make sense to merge the two right now because MT7601U is a design
somewhere between old Ralink devices and new Mediatek chips. There
wouldn't be all that much code sharing with the devices mt76 supports.
Situation may obviously change when someone decides to extend m76 with
support for the more recent USB dongles.
The driver supports only station mode. I'm hoping to add AP support
when time allows.
This driver sat on GitHub for quite a while and got some testing there:
http://github.com/kuba-moo/mt7601u
