git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
There are few places at the begining of Tx/Rx paths where
tx_info/rx_info is not correctly initialized. This patch
takes care of it.
Signed-off-by: Amitkumar Karwar <akarwar@marvell.com>
Signed-off-by: Avinash Patil <patila@marvell.com>
Signed-off-by: Bing Zhao <bzhao@marvell.com>
This patch updates mwifiex Copyright to 2014.
Signed-off-by: Xinming Hu <huxm@marvell.com>
This patch fixes an issue where AMSDU packets for TDLS link
would flow over infra link. This happened because we were
missing setting TDLS flag in TxPD on AMSDU packets.
New skbs are allocated at the time of AMSDU aggregation. Setting
up in timestamps for such skbs was missing which would result
into wrong queue delays passed to FW. Fix this by setting
timestamp of skbs created for AMSDU aggregation.
For PCIe, aggregate more AMSDU packets till PCIe TXBD is full.
For SDIO, aggregation was disabled for AMSDU packets because
AMSDU aggregated packet size is already 4K or 8K, SDIO Multiport
Aggregation feature didn't use to gain much previously.
Now with increased multiport aggregation buffer, we can enable
it for AMSDU packets.
Actually we are updating snap_type with h_proto (__be16 variable)
in ethernet frame header. Hence endianness conversion is not
required.
Bug 60815 - Interface hangs in mwifiex_usb
https://bugzilla.kernel.org/show_bug.cgi?id=60815
We have 4 bytes of interface header for packets delivered to SDIO
and PCIe, but not for USB interface.
In Tx AMSDU case, currently 4 bytes of garbage data is unnecessarily
appended for USB packets. This sometimes leads to a firmware hang,
because it may not interpret the data packet correctly.
Problem is fixed by removing this redundant headroom for USB.
Cc: <stable@vger.kernel.org> # 3.5+
Tested-by: Dmitry Khromov <icechrome@gmail.com>
It exceeded 80 characters. Split it into two lines.
Fixes multiple locations where a little endian host is assumed during
ser/des of messages sent to/received from the chip.
Signed-off-by: Tobias Waldekranz <tobias@waldekranz.com>
Maintain total outstanding packet count for RA list instead of total
outstanding size as packet count metric seems more reasonable for
checking threshold etc.
Rotate bss prio list, so the bss next to the one served, will come first
in the list of bss' with equal priority. This way we pick bss nodes in a
round robin fashion. Using list rotation instead of a cur ptr simplifies
iteration to calling list_for_each_entry. List rotation is done via
list_move, where the head itself is temporarily removed and then
re-inserted after the bss just served.
Signed-off-by: Andreas Fenkart <andreas.fenkart@streamunlimited.com>
Acked-by: Bing Zhao <bzhao@marvell.com>
After a packet is successfully transmitted, ra list is rotated, so the ra
next to the one transmitted, will be the first in the list. This way we
pick the ra' in a round robin fashion. This significantly simplifies
iteration in mwifiex_wmm_get_highest_priolist_ptr to a call to
List rotation is done via list_move, where the head itself is temporarily
removed and then re-inserted after the item just transferred.
This patch is an enhacement to mwifiex_pcie driver to use
map/unmap PCI memory APIs. This reduces one memcpy each in TX
path and RX path, and enhances throughput.
This patch adds support for multiple TX queues inside mwifiex
driver. Four different queues according to WMM access categories
are defined for each virtual interface. When a packet is
received from netdev for transmission, tx pending count for
particular queue is incremented and if tx pending count has
reached upper water-mark, this queue is stopped instead of
stopping all queues. Similarly when a packet is successfully
transmitted from device, tx pending count is decremented per
queue and if pending count falls below lower water-mark, queue
operations are again resumed. This ensures that not all
tranmission is blocked if traffic with particular TOS value
suddenly increases.
Also wake all queues after association/IBSS_join/uAP_BSS_start
to enable traffic on all queues.
Padding arithmetic will always work for MSDUs provided first MSDU
ends on 4-byte boundary. Fixing it by making sure that all MSDU ends
on 4-byte boundary.
Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com>
Signed-off-by: Kiran Divekar <dkiran@marvell.com>
Since commit: fb3c19bc9687d972b83faf366b38ac807eca8f25, adding
extra padding to AMSDU is redundant since same is being performed at
mwifiex_11n_aggregate_pkt after forming the AMSDU packet. Fixing it
by removing it.
All MSDU subframes, except the first one in AMSDU, were being written
wrongly at the location of first MSDU frame. Fixing that by copying
the MSDU at skb->tail of AMSDU.
This patch supports Avastar 88W8797 chipset with USB interface.
The corresponding firmware image file is located at:
"mrvl/usb8797_uapsta.bin"
Signed-off-by: Frank Huang <frankh@marvell.com>
For files 11n.c, 11n.h, 11n_aggr.c, 11n_rxreorder.c
Current implementation, for retrieving priv from adapter,
uses bss_index. In multi interface environment supporting
different types, bss_index may not be unique.
Use bss_type along with bss_num to retrieve the priv.
bss_index is removed with this change.
This patch supports 88W8766P chipset with a PCIe interface.
"mrvl/pcie8766_uapsta.bin"
Signed-off-by: Ramesh Radhakrishnan <rramesh@marvell.com>
The commit "mwifiex: remove list traversal.."(fcf2176c87..)
wrongly modifies AMSDU aggregation check. Due to this even though
packet size for iperf traffic is already large, we unnecessarily
try to aggregate them which adds some delay. If Tx iperf is started
on UUT for 30 seconds, UUT keeps sending Tx packets for few more
seconds.
That commit is reverted to fix the problem.
Also, MIN_NUM_AMSDU check is moved inside the loop to optimize the
loop.
Padding per MSDU will affect the length of next packet and hence
the exact length of next packet is uncertain here.
Also, aggregation of transmission buffer, while downloading the
data to the card, wont gain much on the AMSDU packets as the AMSDU
packets utilizes the transmission buffer space to the maximum
(adapter->tx_buf_size).
All MSDUs, except the last one in an AMSDU, should end up at 4
bytes boundary. There is need to check if enough skb_tailroom
space exists before padding the skb.
Also re-arranging code for better readablity.
The check of skb list empty before calling skb_peek and skb_dequeue is
redundant. These functions returns NULL if the list is empty.
Instead of counting the number of packets in txq
for particular RA list before AMSDU creation,
maintain a counter which will keep track of the
same.
This will reduce some MIPS while generating AMSDU
traffic as we only have to check the counter instead
of traversing through skb list.
This patch adds tx_pkts_queued to track number of packets being
enqueued & dequeued so that mwifiex_wmm_lists_empty() evaluation
is lightweight.
Signed-off-by: Marc Yang <yangyang@marvell.com>
mwifiex was using its own implementation of converting 802.11n
AMSDU to 802.3s. This patch removes mwifiex specific
implementation and uses existing ieee80211_amsdu_to_8023s
routine.
This patch:
- adds kfree() where necessary
- prevents potential null dereferences
- makes use of kfree_skb()
- replaces -1 for failed kzallocs with -ENOMEM
Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com>
Reviewed-by: Kiran Divekar <dkiran@marvell.com>
Tested-by: Amitkumar Karwar <akarwar@marvell.com>
Skip initialization of local variables with some default values
if the values are not going to be used further down the code path.
Some function parameters become useless after previous
cleanup changes.
This driver adds WiFi support for Marvell 802.11n based chipsets
with SDIO interface. Currently only SD8787 is supported. More
chipsets will be supported later.
drivers/net/wireless/mwifiex/
Signed-off-by: Nishant Sarmukadam <nishants@marvell.com>
