path: root/drivers/net/wireless/orinoco_tmd.c
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[PATCH] dev->priv to netdev_priv(dev), for drivers/net/wirelessYoann Padioleau
Replacing accesses to dev->priv to netdev_priv(dev). The replacment is safe when netdev_priv is used to access a private structure that is right next to the net_device structure in memory. Cf http://groups.google.com/group/comp.os.linux.development.system/browse_thread/thread/de19321bcd94dbb8/0d74a4adcd6177bd This is the case when the net_device structure was allocated with a call to alloc_netdev or one of its derivative. Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: mcgrof@gmail.com Cc: linux-wireless@vger.kernel.org Cc: akpm@linux-foundation.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-08-19drivers/net: Remove deprecated use of pci_module_init()Jeff Garzik
From: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-02[PATCH] irq-flags: drivers/net: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-05[PATCH] orinoco: don't put PCI resource data to the network devicePavel Roskin
The resource data in the network device is intended for ISA and other older busses, but not for PCI. Don't put PCI data there. Don't (ab)use the network device for keeping the IRQ number. Retire orinoco_pci_setup_netdev(), and print some minimal information to the kernel log instead, identifying the network device and the driver mostly to identify problems at startup. Scripts should rely on sysfs. Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-04-24[PATCH] orinoco: further comment cleanup in the PCI driversPavel Roskin
2006-04-24[PATCH] orinoco: reduce differences between PCI drivers, create orinoco_pci.hPavel Roskin
Make all Orinoco PCI drivers (orinoco_pci, orinoco_plx, orinoco_tmd and orinoco_nortel) as similar as possible. Use the best implementation of error handling, the best error messages, the best comments. Put common code to orinoco_pci.h. For now, it's suspend and resume functions and function for registering the network device. Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-04-24[PATCH] orinoco: support PCI suspend/resume for Nortel, PLX and TMD adaptorsPavel Roskin
Copy PCI suspend/resume functions from orinoco_pci.c. Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2005-09-23[PATCH] orinoco: Remove inneeded system includes.Pavel Roskin
Signed-off-by: Pavel Roskin <proski@gnu.org> Remove inneeded system includes. Most system includes are not needed. In particular, the hardware backends don't need anything network related. Some includes have been moved from local headers to the C files where they are actually used. Includes that have to be in the local headers are no longer from the C sources. Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
