path: root/drivers/net/wireless/prism54
2008-05-12prism54: fix regression with missing carrier in AP-modeLuis R. Rodriguez
This fixes a regression introduced by commit 7b463ced6 (prism54: set carrier flags correctly) which causes the device to come up without a carrier in AP-mode. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-23prism54: prism54_get_encode() test below 0 on unsigned indexRoel Kluin
previously in this function: u32 index = (dwrq->flags & IW_ENCODE_INDEX) - 1; index is unsigned, so if -1, the original test (below) didn't work. Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-08prism54: set carrier flags correctlyLuis R. Rodriguez
> prism54 should set the carrier flags correctly when it thinks the > link can be used. Agreed, so sure, this is OK but I rather we turn the carrier on or off *before* sending an event, like this. Signed-off-by: Roy Marples <uberlord@gentoo.org> Signed-off-by: Luis R. Rodriguez <mcgrof@winlab.rutgers.edu> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-27prism54: correct thinko in "prism54: Convert stats_sem in a mutex"John W. Linville
mutex_trylock has different return code semantics than down_trylock... Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29prism54: Convert wpa_sem in a mutexMatthias Kaehlcke
The semaphore wpa_sem is used as mutex, convert it to the mutex API Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net> Acked-by: Luis R. Rodriguez <mcgrof@winlab.rutgers.edu> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29prism54: Convert stats_sem in a mutexMatthias Kaehlcke
The semaphore stats_sem is used as mutex, convert it to the mutex API Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net> Acked-by: Luis R. Rodriguez <mcgrof@winlab.rutgers.edu> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29prism54: Convert acl->sem in a mutexMatthias Kaehlcke
The semaphore acl->sem is used as mutex, convert it to the mutex API Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net> Acked-by: Luis R. Rodriguez <mcgrof@winlab.rutgers.edu> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28prism54: remove questionable down_interruptible usageDaniel Walker
Reviewing the semaphore usage I noticed these down_interruptible calls. Most of these aren't returning anything, so a caller can't tell if the operation completed or not. prism54_wpa_bss_ie_get() returns zero, but it's treated as the function failing which doesn't seem correct. Signed-off-by: Daniel Walker <dwalker@mvista.com> Cc: Michael Wu <flamingice@sourmilk.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28prism54 trivial annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28wireless: fix '!x & y' typo'sRoel Kluin
Fix priority mistakes similar to '!x & y' Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28Prism54: Convert mgmt_sem to the mutex APIMatthias Kaehlcke
Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10drivers/net/: all drivers/net/ cleanup with ARRAY_SIZEDenis Cheng
Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[PATCH] dev->priv to netdev_priv(dev), for drivers/net/wirelessYoann Padioleau
Replacing accesses to dev->priv to netdev_priv(dev). The replacment is safe when netdev_priv is used to access a private structure that is right next to the net_device structure in memory. Cf http://groups.google.com/group/comp.os.linux.development.system/browse_thread/thread/de19321bcd94dbb8/0d74a4adcd6177bd This is the case when the net_device structure was allocated with a call to alloc_netdev or one of its derivative. Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: mcgrof@gmail.com Cc: linux-wireless@vger.kernel.org Cc: akpm@linux-foundation.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] drivers/net/wireless/prism54/oid_mgt.c: kmalloc + memset conversion ↵Mariusz Kozlowski
to kzalloc Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Acked-by: Luis R. Rodriguez <mcgrof@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-07-16Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (37 commits) forcedeth bug fix: realtek phy forcedeth bug fix: vitesse phy forcedeth bug fix: cicada phy atl1: reorder atl1_main functions atl1: fix excessively indented code atl1: cleanup atl1_main atl1: header file cleanup atl1: remove irq_sem cdc-subset to support new vendor/product ID 8139cp: implement the missing dev->tx_timeout myri10ge: Remove nonsensical limit in the tx done routine gianfar: kill unused header EP93XX_ETH must select MII macb: Add multicast capability macb: Use generic PHY layer s390: add barriers to qeth driver s390: scatter-gather for inbound traffic in qeth driver eHEA: Introducing support vor DLPAR memory add Fix a potential NULL pointer dereference in free_shared_mem() in drivers/net/s2io.c [PATCH] softmac: Fix ESSID problem ...
2007-07-11PCI: add pci_try_set_mwiRandy Dunlap
As suggested by Andrew, add pci_try_set_mwi(), which does not require return-value checking. - add pci_try_set_mwi() without __must_check - make it return 0 on success, errno if the "try" failed or error - review callers Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-11PCI: remove useless pci driver methodDavid Brownell
Remove pointless and never-called enable_wake() hook from pci_driver and from documentation. Evidently this was introduced in the 2.4.6 kernel, but there's no evidence it was ever called; and it was rarely implemented. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-10[PATCH] use list_for_each_entry() for iteration in Prism 54 driverMatthias Kaehlcke
Use list_for_each_entry() instead of manual iteration and substitute a list_for_each_safe() loop with list_for_each_entry_safe() Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Cc: Christoph Hellwig <hch@lst.de> Acked-by: Luis R. Rodriguez <mcgrof@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-05-29[PATCH] prism54: fix monitor mode oopsBjörn Steinbrink
Manually set the device of a skb for prism54 cards that are in monitor mode as we never call eth_type_trans in that case. Signed-off-by: Björn Steinbrink <B.Steinbrink@gmx.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-05-09Fix "deprecated" typoes.Robert P. J. Day
Fix remaining misspellings of "depreciated" to "deprecated." Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-09Fix misspellings collected by members of KJ list.Robert P. J. Day
Fix the misspellings of "propogate", "writting" and (oh, the shame :-) "kenrel" in the source tree. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-04-25[SK_BUFF]: Introduce skb_copy_to_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying to linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
2007-04-25[SK_BUFF]: Introduce skb_copy_from_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying from linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2007-04-25[SK_BUFF]: Introduce skb_reset_mac_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->mac.raw = skb->data' operation, so that we can later turn skb->mac.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple case, next will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-17Merge branch 'upstream' into upstream-jgarzikJohn W. Linville
Conflicts: net/ieee80211/softmac/ieee80211softmac_module.c net/ieee80211/softmac/ieee80211softmac_wx.c
2007-02-14[PATCH] prism54: correct assignment of DOT1XENABLE in WE-19 codepathsDan Williams
Correct assignment of DOT1XENABLE in WE-19 codepaths. RX_UNENCRYPTED_EAPOL = 1 really means setting DOT1XENABLE _off_, and vice versa. The original WE-19 patch erroneously reversed that. This patch fixes association with unencrypted and WEP networks when using wpa_supplicant. It also adds two missing break statements that, left out, could result in incorrect card configuration. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-02-14[PATCH] misc-wireless: Use ARRAY_SIZE macro when appropriateAhmed S. Darwish
A patch to use ARRAY_SIZE macro already defined in kernel.h for some miscellaneous wireless drivers with no specific maintaners. Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-02-05[PATCH] prism54: add ethtool -i interfaceKai Engert
Add support for "ethtool -i" to prism54 driver. ethtool -i queries the specified device for associated driver information. This helps tools like Fedora's system-config-network to provide GUI management of network devices. I learned how to write this patch by reading the ipw2100 driver code. Signed-off-by: Kai Engert <kengert@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-12-13[PATCH] getting rid of all casts of k[cmz]alloc() callsRobert P. J. Day
Run this: #!/bin/sh for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do echo "De-casting $f..." perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f done And then go through and reinstate those cases where code is casting pointers to non-pointers. And then drop a few hunks which conflicted with outstanding work. Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Greg KH <greg@kroah.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Ian Kent <raven@themaw.net> Cc: Steven French <sfrench@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07Merge branch 'upstream' of ↵Jeff Garzik
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 into upstream Conflicts: drivers/net/wireless/zd1211rw/zd_mac.h net/ieee80211/softmac/ieee80211softmac_assoc.c
2006-12-05[PATCH] prism54: replace kmalloc+memset with kzallocYan Burman
Replace kmalloc+memset with kzalloc Signed-off-by: Yan Burman <burman.yan@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-12-05Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/infiniband/core/iwcm.c drivers/net/chelsio/cxgb2.c drivers/net/wireless/bcm43xx/bcm43xx_main.c drivers/net/wireless/prism54/islpci_eth.c drivers/usb/core/hub.h drivers/usb/input/hid-core.c net/core/netpoll.c Fix up merge failures with Linus's head and fix new compilation failures. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-12-02[PATCH] prism54: correct overly aggressive check of return from pci_set_mwiJohn W. Linville
Failure of pci_set_mwi should not be considered a fatal error. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-12-02[PATCH] wireless: clean-up some "check return code" warningsJohn W. Linville
Clean-up some warnings from missing return code checks, mostly from calling pci_enable_device during a PCI resume. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-12-02[PATCH] prism54: use BUILD_BUG_ONAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-12-02[PATCH] prism54: whitespace cleanupDmitry Torokhov
NET: prism54 - whitespace cleanup Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-12-02[PATCH] prism54: fix potential race in reset schedulingDmitry Torokhov
NET: prism54 - fix potential race in reset scheduling There appears to be a race in reset scheduling logic - thread responsible for reseting the interface should clear "reset pending" flag before restarting the queue, otherwise timeout handler might not schedule another reset even if it is needed. This race is mostly theoretical as far as I can see but a race nonetheless. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-25[PATCH] WE-21 for Prism54Jean Tourrilhes
Signed-off-by: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-09-12Merge branch 'upstream' of ↵Jeff Garzik
2006-09-11[PATCH] Prism54 : add bitrates to scan resultJean Tourrilhes
This patch adds bitrate information to the scan result in the Prism54 driver, like some/most other driver do. Signed-off-by: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-08-19drivers/net: Remove deprecated use of pci_module_init()Jeff Garzik
From: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-07-27[PATCH] prism54: update to WE-19 for WPA supportDan Williams
Add WE-19 capabilities to prism54 fullmac driver so that it supports the necessary Wireless Extensions WPA calls. Convert reporting of WPA/RSN Generic Information Elements to IWEVGENIE rather than pre-WE-19 IWEVCUSTOM as well. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-07-02[PATCH] irq-flags: drivers/net: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Typo fixesAlexey Dobriyan
Fix a lot of typos. Eyeballed by jmc@ in OpenBSD. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
