commit a8b9774571d46506a0774b1ced3493b1245cf893 upstream.
Commit 5d5cd85ff441 ("rsi: Fix failure to load firmware after memory
leak fix and fix the leak") also added a check on the allocation of
DMA-accessible memory that may directly return. In that case the
already allocated firmware data is leaked. Make sure the data is
always freed correctly. Detected by Coverity CID 1316519.
Fixes: 5d5cd85ff441 ("rsi: Fix failure to load firmware after memory leak fix and fix the leak")
Signed-off-by: Christian Engelmayer <cengelma@gmx.at>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
commit 5d5cd85ff441534a52f23f821d0a7c644d3b6cce upstream.
Fixes commit eae79b4f3e82 ("rsi: fix memory leak in rsi_load_ta_instructions()")
which stopped the driver from functioning.
Firmware data has been allocated using vmalloc(), resulting in memory
that cannot be used for DMA. Hence the firmware was first copied to a
buffer allocated with kmalloc() in the original code. This patch reverts
the commit and only calls "kfree()" to release the buffer after sending
the data. This fixes the memory leak without breaking the driver.
Add a comment to the kmemdup() calls to explain why this is done, and abort
if memory allocation fails.
Tested on a Topic Miami-Florida board which contains the rsi SDIO chip.
Also added the same kfree() call to the USB glue driver. This was not
tested on actual hardware though, as I only have the SDIO version.
Fixes: eae79b4f3e82 ("rsi: fix memory leak in rsi_load_ta_instructions()")
Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl>
Memory allocated by kmemdup() in rsi_load_ta_instructions() is leaked.
But duplication of firmware data here is useless,
so the patch removes kmemdup() at all.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
The patch fixes a couple of issues:
- absence of deallocation of rsi_dev->rx_usb_urb[0] in the driver;
- potential NULL pointer dereference because of lack of checks for memory
allocation success in rsi_init_usb_interface().
By the way, it makes rsi_probe() returning error code instead of 1
and fixes comments regarding returning values.
Fixed a warning related to incorrect return type and removed an
unnecessary semi colon.
Signed-off-by: Jahnavi Meher <jahnavi.meher@gmail.com>
Fixed a potential buffer overflow in 'rsi_rates' and a sparse warning
related to difference in endianness in rsi_91x_mgmt.c.
Added code required for 40MHz.
Added support for host based bgscan. The h/w queues are blocked
while bgscan is being performed and after coming to the connected
channel, the queues are unblocked.
Adding support for 5GHz.
Send the QoS null packet via mgmt queue.
Added some debug messages.
The number of packets being dequeued from s/w queues was fixed -
changed it to a dynamic calculation based on txop. There are also
some fixes to the dequeuing algorithm.
Changed the SDIO interrupt variables and some clean ups.
Use SGI if configured while sending data packets at a fixed rate.
rsi_program_bb_rf().
Lower level debug messages for some frames and changed confirm
received for rsi_program_bb_rf() to a valid case.
Changed rate handling.
Made required changes to rsi_set_channel() and rsi_program_bb_rf()
functions.
Changed the radio caps frame and added the required fields.
Added macros for the endpoints and set the default value of endpoint
to 2.4GHz and 20MHz.
Filling in band from common->band.
Changed the function header to match the function name.
Changed the queue numbers to macros, and corrected the mappings.
Fix rsi_module_init() to propagate sdio_register_driver() errors.
module_usb_driver eliminates the boilerplate and makes the code simpler,
in addition to the fact currently rsi_module_init() ignores usb_deregister() error.
Pull networking updates from David Miller:
1) Seccomp BPF filters can now be JIT'd, from Alexei Starovoitov.
2) Multiqueue support in xen-netback and xen-netfront, from Andrew J
Benniston.
3) Allow tweaking of aggregation settings in cdc_ncm driver, from Bjørn
Mork.
4) BPF now has a "random" opcode, from Chema Gonzalez.
5) Add more BPF documentation and improve test framework, from Daniel
Borkmann.
6) Support TCP fastopen over ipv6, from Daniel Lee.
7) Add software TSO helper functions and use them to support software
TSO in mvneta and mv643xx_eth drivers. From Ezequiel Garcia.
8) Support software TSO in fec driver too, from Nimrod Andy.
9) Add Broadcom SYSTEMPORT driver, from Florian Fainelli.
10) Handle broadcasts more gracefully over macvlan when there are large
numbers of interfaces configured, from Herbert Xu.
11) Allow more control over fwmark used for non-socket based responses,
from Lorenzo Colitti.
12) Do TCP congestion window limiting based upon measurements, from Neal
Cardwell.
13) Support busy polling in SCTP, from Neal Horman.
14) Allow RSS key to be configured via ethtool, from Venkata Duvvuru.
15) Bridge promisc mode handling improvements from Vlad Yasevich.
16) Don't use inetpeer entries to implement ID generation any more, it
performs poorly, from Eric Dumazet.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1522 commits)
rtnetlink: fix userspace API breakage for iproute2 < v3.9.0
tcp: fixing TLP's FIN recovery
net: fec: Add software TSO support
net: fec: Add Scatter/gather support
net: fec: Increase buffer descriptor entry number
net: fec: Factorize feature setting
net: fec: Enable IP header hardware checksum
net: fec: Factorize the .xmit transmit function
bridge: fix compile error when compiling without IPv6 support
bridge: fix smatch warning / potential null pointer dereference
via-rhine: fix full-duplex with autoneg disable
bnx2x: Enlarge the dorq threshold for VFs
bnx2x: Check for UNDI in uncommon branch
bnx2x: Fix 1G-baseT link
bnx2x: Fix link for KR with swapped polarity lane
sctp: Fix sk_ack_backlog wrap-around problem
net/core: Add VF link state control policy
net/fsl: xgmac_mdio is dependent on OF_MDIO
net/fsl: Make xgmac_mdio read error message useful
net_sched: drr: warn when qdisc is not work conserving
Since the rsi_create_kthread interface does not include any format
string arguments, make sure that the resulting thread name can never
accidentally process the name as a format string.
Signed-off-by: Jahnavi Meher <jahnavi.meher@redpinesignals.com>
Timing mode identifier has same role and can take the place
of speed mode. This change removes all related speed mode.
Signed-off-by: Seungwon Jeon <tgih.jun@samsung.com>
Tested-by: Jaehoon Chung <jh80.chung@samsung.com>
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Signed-off-by: Chris Ball <chris@printf.net>
Fix a potential memory leak in the error path of function
rsi_send_auto_rate_request(). In case memory allocation for array
'selected_rates' fails, the error path exits and leaves the previously
allocated skb in place. Detected by Coverity: CID 1195575.
Fix a potential memory leak in function rsi_set_channel() that is used to
program channel changes. The channel check block for the frequency bands
directly exits the function in case of an error, thus leaving an already
allocated skb unreferenced. Move the checks above allocating the skb.
Detected by Coverity: CID 1195576.
drivers/net/wireless/rsi/rsi_91x_core.c: In function ‘rsi_core_determine_hal_queue’:
drivers/net/wireless/rsi/rsi_91x_core.c:91: warning: ‘ii’ may be used uninitialized in this function
Signed-off-by: Fariya Fatima <fariyaf@gmail.com>
There is a missing set of curly braces here so the debug output says
"Probe confirm received" unintentionally.
Emit a prefix for the rsi_dbg messages.
Fix the format and argument mismatch and add
__printf(2, 3) to try to avoid more.
This is to address reports of this:
In file included from drivers/net/wireless/rsi/rsi_mgmt.h:22:0,
from drivers/net/wireless/rsi/rsi_91x_core.c:17:
drivers/net/wireless/rsi/rsi_91x_core.c: In function 'rsi_dbg':
drivers/net/wireless/rsi/rsi_main.h:44:20: error: function 'rsi_dbg' can never be inlined because it uses variable argument lists
static inline void rsi_dbg(u32 zone, const char *fmt, ...)
This patch adds the Redpine Signals' 91x wireless driver.
