path: root/drivers/net/wireless/rt2x00/Kconfig
2015-11-18rt2x00: move under ralink vendor directoryKalle Valo
Part of reorganising wireless drivers directory and Kconfig. Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
2015-08-20rt2x00: use DECLARE_EWMAJohannes Berg
Instead of using the out-of-line EWMA calculation, use DECLARE_EWMA() to create static inlines. On x86/64 this results in code that's one byte larger (for me), but reduces struct link_ant and struct link size by the two unsigned long values that store the parameters each. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-07kconfig: use bool instead of boolean for type definition attributesChristoph Jaeger
Support for keyword 'boolean' will be dropped later on. No functional change. Reference: http://lkml.kernel.org/r/cover.1418003065.git.cj@linux.com Signed-off-by: Christoph Jaeger <cj@linux.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-10-18rt2x00: rt2800pci: move SoC specific code into a separate moduleGabor Juhos
The PCI and SoC specific drivers are using separate code now so it is not reasonable to use the same module for both drivers anymore. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-10-18rt2x00: rt2800pci: move RX control handler functions to the rt2800mmio moduleGabor Juhos
Move the functions into a separate module, in order to make those usable from other modules. Also move the RX descriptor related defines from rt2800pci.h into rt2800mmio.h Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-10-18rt2x00: rt2800pci: move TX descriptor functions to the rt2800mmio moduleGabor Juhos
Move the functions into a separate module, in order to make those usable from other modules. Also move the TX descriptor related defines from rt2800pci.h into rt2800mmio.h. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-10-18rt2x00: create a new module for rt2800 MMIO codeGabor Juhos
Create a new module for common code which can be used for rt2800 device with memory mapped I/O. It is an empty module for now, but it will be populated by subsequent patches. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-10-10rt2x00: use generic EWMA functions for average RSSI calculationsGabor Juhos
Remove the local MOVING_AVERAGE implementation, and use the generic EWMA functions instead. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-07-25Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
2013-07-22rt2x00: rt2800usb: add USB device ID for Linksys AE3000Gabor Juhos
The Linksys AE3000 device is based on the RT3573 chipset. The support for this chipset is available already, and the AE3000 device works with the driver. Only managed mode works correctly at the moment, for AP mode additional changes are needed in the driver. Also add a new RT2800USB_RT3573 Kconfig option and only enable support for RT3573 based devices if that is enabled. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Acked-by: Stanislaw Gruszka <stf_xl@wp.pl> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-07-18rt2x00: RT2X00 should depend on HAS_DMAGeert Uytterhoeven
If NO_DMA=y: drivers/built-in.o: In function `rt2x00queue_unmap_skb': drivers/net/wireless/rt2x00/rt2x00queue.c:129: undefined reference to `dma_unmap_single' drivers/net/wireless/rt2x00/rt2x00queue.c:133: undefined reference to `dma_unmap_single' drivers/built-in.o: In function `rt2x00queue_map_txskb': drivers/net/wireless/rt2x00/rt2x00queue.c:112: undefined reference to `dma_map_single' drivers/net/wireless/rt2x00/rt2x00queue.c:115: undefined reference to `dma_mapping_error' drivers/built-in.o: In function `rt2x00queue_alloc_rxskb': drivers/net/wireless/rt2x00/rt2x00queue.c:93: undefined reference to `dma_map_single' drivers/net/wireless/rt2x00/rt2x00queue.c:95: undefined reference to `dma_mapping_error' Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: linux-wireless@vger.kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-04-10Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless Conflicts: drivers/net/wireless/rt2x00/rt2x00pci.c
2013-04-03rt2x00: rt2x00pci: fix build error on Ralink RT3x5x SoCsGabor Juhos
The rt2800pci driver supports the built-in wireless MAC of the Ralink RT3x5x SoCs. However building the driver for these SoCs leads to the following error: LD init/built-in.o drivers/built-in.o: In function `rt2800pci_rxdone_tasklet': <...>/drivers/net/wireless/rt2x00/rt2800pci.c:1012: undefined reference to `rt2x00pci_rxdone' drivers/built-in.o:(.rodata+0x4780): undefined reference to `rt2x00pci_initialize' drivers/built-in.o:(.rodata+0x4784): undefined reference to `rt2x00pci_uninitialize' drivers/built-in.o:(.rodata+0x47bc): undefined reference to `rt2x00pci_flush_queue' drivers/built-in.o:(.rodata+0x4818): undefined reference to `rt2x00pci_regbusy_read' make[5]: *** [vmlinux] Error 1 The missing functions are provided by the rt2x00pci module. This module is only selected by the rt2800pci driver if PCI support is enabled in the kernel, because some parts of the rt2x00pci code depends on PCI support. PCI support is not available on the RT3x5x SoCs because those have no PCI host controller at all. Move the non PCI specific code from rt2x00pci into a separate module. This makes it possible to use that code even if PCI support is disabled. The affected functions are used by all of the rt2x00 PCI drivers so select the new module for those drivers. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-03-18rt2800: 5592: add KconfigStanislaw Gruszka
Enable support to 5592 chip. Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl> Tested-by: Wanlong Gao <gaowanlong@cn.fujitsu.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-03-13rt2x00: fix rt2x00 to work with the new ralink SoC config symbolsJohn Crispin
Since v3.9-rc1 the kernel has basic support for Ralink WiSoC. The config symbols are named slightly different than before. Fix the rt2x00 to match the new symbols. The commit causing this breakage is: commit ae2b5bb6570481b50a7175c64176b82da0a81836 Author: John Crispin <blogic@openwrt.org> Date: Sun Jan 20 22:05:30 2013 +0100 MIPS: ralink: adds Kbuild files Signed-off-by: John Crispin <blogic@openwrt.org> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-01-22drivers/net/wireless/rt2x00: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: Ivo van Doorn <IvDoorn@gmail.com> CC: Gertjan van Wingerde <gwingerde@gmail.com> CC: Helmut Schaa <helmut.schaa@googlemail.com> Acked-by: John W. Linville <linville@tuxdriver.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Acked-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-20rt2x00 : RT3290 chip support v4Woody Hung
This patch support the new chipset rt3290 wifi implementation in rt2x00. It initailize the related mac, bbp and rf register in startup phase. And this patch modify the efuse read/write method for the different efuse data offset of rt3290. Signed-off-by: Woody Hung <Woody.Hung@mediatek.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-02-22rt2x00:Fix typoJohn Li
Signed-off-by: John Li <chen-yang.li@mediatek.com> Acked-by: Helmut Schaa <helmut.schaa@googlemail.com> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Acked-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-06-01rt2x00: Enabled rt35xx device support by default.Gertjan van Wingerde
Now that support for these devices has been added we can enable them by default and remove the Kconfig not on support for these devices to be non-functional. Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-27wireless: Default to 'n' for 2 new added devices in Kconfig.Tao Ma
We make oldconfig every time when a new kernel arrives, but if we don't have such a device(I guess this is the most common case for a new device), the default value should be 'n' so that the kernel size we build doesn't grow up too much quickly. For anyone who has the device, it is OK for them to turn it on by themselves. Cc: "John W. Linville" <linville@tuxdriver.com> Cc: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-05rt2x00: Initial support for RT5370 USB devices.Gertjan van Wingerde
Add necessary RF chipset define and basic support for these devices. Tested-by: Juan Carlos Garza <juancarlosgarza@gmail.com> Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-19rt2x00: Merge rt2x00ht.c contents in other files.Gertjan van Wingerde
The two functions that are in rt2x00ht.c can be much better placed closer to the places where the call-sites of these functions are (one in rt2x00config.c and one in rt2x00queue.c) allowing us to make these functions static. Also, conditional compilations doesn't seem to be necessary anymore as 802.11n support is quite common nowadays. This makes the code a bit easier readable and searchable. Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-19rt2x00: Enable support for RT53xx PCI devices by default.Gertjan van Wingerde
Code seems to be feature-complete, so no reason to not enable these devices by default. Also, remove the sentence about the support for these devices being non-functional. Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-19rt2x00: RT33xx device support is no longer experimental.Gertjan van Wingerde
The rt33xx devices support for both PCI and USB devices has been in the tree for a couple of months now, and seems to be functional and not in a worse shape than the support for rt28xx and rt30xx devices. No longer mark it as experimental and enable the support for these devices by default. Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-21rt2x00: Add support for RT5390 chipRA-Shiang Tu
Add new RT5390 chip support Signed-off-by: Shiang Tu <shiang_tu@ralinktech.com> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
2010-11-17rt2x00: Remove unneccessary internal Kconfig symbols.Gertjan van Wingerde
CONFIG_RT2800PCI_PCI and CONFIG_RT2800PCI_SOC are strictly not needed as we can check the dependent symbols directly in the rest of Kconfig and the code, so clean up the Kconfig namespace a bit. Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-17rt2x00: Remove RT30XX Kconfig variables.Gertjan van Wingerde
Enabling of RT30xx devices via Kconfig variables was introduced when these devices weren't properly supported yet. Now that that they are properly supported and functional, we can remove these Kconfig variables for RT30xx devices and simply enable them whenever rt2800pci and/or rt2800usb is enabled. Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Acked-by: Helmut Schaa <helmut.schaa@googlemail.com> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-17rt2x00: Clean up Kconfig for RT2800 devices.Gertjan van Wingerde
General clean up of the Kconfig part for RT28XX devices. Also remove the indications of non functional support for rt27xx/rt28xx/rt30xx devices, as this is no longer true. They just work fine. Finally, remove the experimental indications for rt27xx/rt28xx/rt30xx devices as that is no longer true. Keep the experimental indications for rt33xx/rt35xx devices, though. Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Acked-by: Helmut Schaa <helmut.schaa@googlemail.com> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-17rt2x00: Add initial support for RT3370/RT3390 devices.Gertjan van Wingerde
Modified from Eddy's patch by adding the RT3370 USB support as well. Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Cc: Eddy Tsai <Eddy_Tsai@ralinktech.com> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-12led-class: always implement blinkingJohannes Berg
Currently, blinking LEDs can be awkward because it is not guaranteed that all LEDs implement blinking. The trigger that wants it to blink then needs to implement its own timer solution. Rather than require that, add led_blink_set() API that triggers can use. This function will attempt to use hw blinking, but if that fails implements a timer for it. To stop blinking again, brightness_set() also needs to be wrapped into API that will stop the software blink. As a result of this, the timer trigger becomes a very trivial one, and hopefully we can finally see triggers using blinking as well because it's always easy to use. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Acked-by: Richard Purdie <rpurdie@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-04rt2x00: Enable RT30xx by default.Gertjan van Wingerde
Now that RT30xx support is at the same level as RT28xx support we can enable these devices by default. Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-02-15rt2x00: rt2800 - Make rt30xx and rt35xx chipsets configurable.Gertjan van Wingerde
Support for rt30xx- and rt35xx-based devices is currently not functional in rt2800pci and rt2800usb. In order to not confuse users we shouldn't claim the PCI and USB device ID's for these devices. However, to allow for testing it is good to still have them available, although disabled by default. Make support for these device configuration options that default to off. For rt2800usb a 3rd class of devices is added, which are the unknown devices. For these devices it is known that they are either based on rt28xx, rt30xx or rt35xx, but it is not known on what chipset exactly. These devices are disabled by default as well, until it can be established on what chipset exactly they are based. Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-28rt2x00: convert RT2800PCI_PCI and RT2800PCI_SOC Kconfig symbols to booleans.Gertjan van Wingerde
There is no need for Kconfig symbols RT2800PCI_PCI and RT2800PCI_SOC to be tristates, as they are only used to check whether RT2800 PCI or SOC support is to be compiled in. Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Acked-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-06rt2800: add rt2800lib (part one)Bartlomiej Zolnierkiewicz
Code unification. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Acked-by: Ivo van Doorn <IvDoorn@gmail.com> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-04rt2800pci: make Kconfig help entry more helpfulBartlomiej Zolnierkiewicz
Document known issues with the driver to aid distribution makers, users and developers in making informed decisions instead of wasting their time needlessly. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-04rt2800usb: make Kconfig help entry more helpfulBartlomiej Zolnierkiewicz
2009-10-30wireless: remove WLAN_80211 and WLAN_PRE80211 from KconfigJohn W. Linville
With the WLAN_PRE80211 drivers moved to drivers/staging, this distinction becomes unnecessary. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-27rt2x00: Implement support for rt2800pciIvo van Doorn
Add support for the rt2860/rt3090 chipsets from Ralink. Includes various patches from a lot of people who helped getting this driver into the current shape. Signed-off-by: Alban Browaeys <prahal@yahoo.com> Signed-off-by: Benoit PAPILLAULT <benoit.papillault@free.fr> Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Luis Correia <luis.f.correia@gmail.com> Signed-off-by: Mattias Nissler <mattias.nissler@gmx.de> Signed-off-by: Mark Asselstine <asselsm@gmail.com> Signed-off-by: Xose Vazquez Perez <xose.vazquez@gmail.com> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-27rt2x00: Add rt2x00soc bus moduleIvo van Doorn
Add new library module for SoC drivers. This is needed to fully support the platform driver part of rt2800pci. Based on original patch from Felix. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-04rt2x00: move experimental on kconfig only to rt2800usbLuis R. Rodriguez
These drivers have been around for a while, if there are issues they should be reported. rt2800usb is still a bit flaky though. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Acked-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10rt2x00: use wiphy rfkill interfaceIvo van Doorn
Remove the input_polldev from rt2x00 and replace it with the rfkill interface offered by the wiphy structure. This simplifies the entire rfkill handling in rt2x00 and allows us to remove the CONFIG_RT2X00_LIB_RFKILL option and always enables rfkill capabilities. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-15Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: Documentation/feature-removal-schedule.txt drivers/scsi/fcoe/fcoe.c net/core/drop_monitor.c net/core/net-traces.c
2009-06-12trivial: Kconfig: .ko is normally not included in module namesPavel Machek
.ko is normally not included in Kconfig help, make it consistent. Signed-off-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-05-06rt2x00: Implement support for rt2800usbIvo van Doorn
Add support for the rt2800usb chipset. Current problems: * Cannot scan 11n AP's * No TX during first minute after association * Broken Hardware encryption Includes various patches from Mattias, Felix, Xose and Axel. Signed-off-by: Mattias Nissler <mattias.nissler@gmx.de> Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Xose Vazquez Perez <xose.vazquez@gmail.com> Signed-off-by: Axel Kollhofer <rain_maker@root-forum.org> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-06rt2x00: Implement support for 802.11nIvo van Doorn
Extend rt2x00lib capabilities to support 802.11n, it still lacks aggregation support, but that can be added in the future. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29rt2x00: Replace RFKILL with INPUTIvo van Doorn
As discussed on linux-wireless rt2x00 does not offer a true RFKILL key, for that reason RFKILL support should be entirely removed. The key which is attached to the hardware should be treated as normal input device instead. Implement input_poll_dev support to poll the device frequently. When the key status has changed report it as a SW event. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-12-05rt2x00: Implement HW encryption (rt2500usb)Ivo van Doorn
rt2500usb supports hardware encryption. rt2500usb supports up to 4 shared and pairwise keys. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-29rt2x00: Fix build error when mac80211=M rt2x00=YIvo van Doorn
Make menuconfig RT2X00 a tristate instead of boolean, otherwise we do not correctly inherit the mac80211 value on which RT2X00 depends, and makes it possible to compile rt2x00 into the kernel while mac80211 is a module. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-30rt2x00: Fix build errors due to modularized rfkill or leds and built-in rt2x00.Gertjan van Wingerde
Fix by disabling rt2x00 rfkill support when rt2x00 is built-in and rfkill has been modularized, and a similar scheme for the relationship between leds_class and rt2x00.. Also, give a warning to the end-user when rfkill-/leds-support is disabled this way, so that the end-user has at least some clues on what is going on. Proper fixing required some general updates of the Kconfig-structure for the rt2x00 driver, whereby internal configuration symbols had to be moved to after the user-visible configuration symbols. Signed-off-by: Gertjan van Wingerde <gwingerde@kpnplanet.nl> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
