path: root/drivers/net/wireless/rt2x00/rt2500usb.h
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-11rt2x00: Update copyright statements.Gertjan van Wingerde
As mentioned on the linux-wireless mailing list, the current copyright statements in the rt2x00 are meaningless, as the rt2x00 project is not even a formal legal entity. Therefore it is better to replace the existing copyright statements with copyright statements for the people that actually wrote the code. Note: Updated to the best of my knowledge with respect to who contributed considerable amounts of code. Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Acked-by: Ivo van Doorn <IvDoorn@gmail.com> CC: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-24rt2x00: Comment spellcheckingLuis Correia
Fix a bunch of spelling errors in the rt2x00 drivers Signed-off-by: Luis Correia <luis.f.correia@gmail.com> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27rt2x00: Remove check for rf word 0Ivo van Doorn
The only way rf_write() can be called with word 0 is when the user sends the wrong word index through debugfs. However the values which are send through debugfs are validated using the RF_BASE and RF_SIZE macro values, the most logical solution is to increase RF_BASE with 4 and decrease RF_SIZE with 4 (RF_SIZE has always been 1 word too big) Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29rt2x00: Update copyright year to 2009Ivo van Doorn
2009-01-29rt2x00: Add RFKILL support to rt2500usb and rt73usbIvo van Doorn
Some very rare Ralink USB hardware exists which features the RFKILL switch on the USB stick. This patch adds the EEPROM check function to see if RFKILL is supported and the polling function to rt2500usb and rt73usb in order to support RFKILL for that hardware. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-12-05rt2x00: Implement HW encryption (rt2500usb)Ivo van Doorn
rt2500usb supports hardware encryption. rt2500usb supports up to 4 shared and pairwise keys. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-10rt2x00: Remove debugfs CSR access wrappersIvo van Doorn
Move calculation of CSR register offset into rt2x00debug.c and remove the wrapper functions from each individual driver. (Except rt2500usb, which still needs to wrap for the different value type argument). Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-22rt2x00: Gather channel information in structureIvo van Doorn
Channel information which is read from EEPROM should be read into an array containing per-channel information. This removes the requirement of multiple arrays and makes the channel handling a bit cleaner and easier to expand. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-08rt2x00: Fix register commentsIvo van Doorn
Fix some register documentation in the register header files. This allows better parsing by userspace scripts which in turn helps debugging. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-14rt2x00: Remove unused definesIvo van Doorn
MAX_RX_SSI and MAX_NOISE are no longer used, it is better to remove them entirely. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-21rt2x00: Fix queue related oops in case of deselected mac80211 multi-queue ↵Gertjan van Wingerde
feature. With the integration of the mac80211 multiqueue patches it has become possible that the mac80211 layer modifies the number of TX queues that is stored inside the ieee80211_hw structure, especially when multi-queue is not selected. The rt2x00 drivers are not well suited to handle that situation, as they allocate the queue structures before mac80211 has modified the number of queues it is going to use, and also expect the number of allocated queues to match the hardware implementation. Hence, ensure that rt2x00 maintains by itself the number of queues that the hardware supports, and, at the same time, making is not dependent on the preservation of contents inside a mac80211 structure. Signed-off-by: Gertjan van Wingerde <gwingerde@kpnplanet.nl> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Rename dscape -> mac80211Ivo van Doorn
The dscape stack was renamed to mac80211 a long time ago, we are long overdue with fixing all comments to reflect this. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Remove HWMODE_{A,B,G}Ivo van Doorn
rt2500usb initialized the SIFS and EIFS without using the values coming from rt2x000lib. After this is fixed HWMODE_{A,B,G} is now unused and can be removed in favour of the ieee80211_band enumeration which could still be usefull later. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Add per-interface structureIvo van Doorn
Rework the interface handling. Delete the interface structure and replace it with a per-interface structure. This changes the way rt2x00 handles the active interface drastically. Copy ieee80211_bss_conf to the this rt2x00_intf structure during the bss_info_changed() callback function. This will allow us to reference it later, and removes the requirement for the device flag SHORT_PREAMBLE flag which is interface specific. Drivers receive the option to give the maximum number of virtual interfaces the device can handle. Virtual interface support: rt2400pci: 1 sta or 1 ap, * monitor interfaces rt2500pci: 1 sta or 1 ap, * monitor interfaces rt2500usb: 1 sta or 1 ap, * monitor interfaces rt61pci: 1 sta or 4 ap, * monitor interfaces rt73usb: 1 sta or 4 ap, * monitor interfaces At the moment none of the drivers support AP and STA interfaces simultaneously, this is a hardware limitation so future support will be very unlikely. Each interface structure receives its dedicated beacon entry, with this we can easily work with beaconing while multiple master mode interfaces are currently active. The configuration handlers for the MAC, BSSID and type are often called together since they all belong to the interface configuration. Merge the 3 configuration calls and cleanup the API between rt2x00lib and the drivers. While we are cleaning up the interface configuration anyway, we might as well clean up the configuration handler as well. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Update copyright noticeIvo van Doorn
2008-01-28rt2x00: Remove data_desc structureIvo van Doorn
Coverty indicated that data_desc with a single element array is bad coding style. This removes the structure and forces everybody to use __le32. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[PATCH] rt2x00: Cleanup if-statementsIvo van Doorn
Cleanup if-statements for simple 1/0 register field values. This also fixes a endian bug in rt2500usb when working with the PHY_CSR2 initialization. As well as a bug in the enabling of the LED in rt73usb. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[RT2x00]: add driver for Ralink wireless hardwareIvo van Doorn
