path: root/drivers/net/wireless/rt2x00/rt2x00config.c
2008-05-28rt2x00: Reset antenna RSSI after switchIvo van Doorn
When the antenna configuration has changed we should reset the antenna RSSI value. Otherwise the value will be influenced by the previous configuration quality which in turn will affect the antenna diversity. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-25rt2x00: Fix in_atomic() usageIvo van Doorn
rt73usb and rt2500usb used in_atomic to determine if a configuration step should be rescheduled or not. Since in_atomic() is not a valid method to determine if sleeping is allowed we should fix the way this is handled by adding a new flag to rt2x00. In addition mark LED class support for the drivers broken since that also uses the broken in_atomic() method but so far no solution exists to have LED triggers work only in scheduled context. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-13rt2x00: Fix basic rate initializationIvo van Doorn
The basic rate which is configured in the register should not match all supported rates, but only the _basic_ rates. Fix this by adding a new flag to the rt2x00_rate structure and whenever the mode is changed, loop over all available rates for that band to get the basic rate mask. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-13rt2x00: Rename config_preamble() to config_erp()Ivo van Doorn
Rename config_preamble() to config_erp() and cleanup argument list by putting it all into a single structure. This will make the function more meaningful and easier to expand later. This second option is mostly intended to make the patch "mac80211: proper short-slot handling" from Johannes Berg easier to apply for rt2x00. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Remove HWMODE_{A,B,G}Ivo van Doorn
rt2500usb initialized the SIFS and EIFS without using the values coming from rt2x000lib. After this is fixed HWMODE_{A,B,G} is now unused and can be removed in favour of the ieee80211_band enumeration which could still be usefull later. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Rate structure overhaulIvo van Doorn
Recent changes to the rate structure registration broke rt2x00, the hw_value was reduced from 32bits to 16bits while rt2x00 used the full 32bits. However the way rt2x00 used the value was inflexible and needed to be changed anyway. This patch creates a array containing information for each rate, the hw_value passed to mac80211 is the index value for that array including a field to indicate if short preamble should be enabled. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29cfg80211 API for channels/bitrates, mac80211 and driver conversionJohannes Berg
This patch creates new cfg80211 wiphy API for channel and bitrate registration and converts mac80211 and drivers to the new API. The old mac80211 API is completely ripped out. All drivers (except ath5k) are updated to the new API, in many cases I expect that optimisations can be done. Along with the regulatory code I've also ripped out the IEEE80211_HW_DEFAULT_REG_DOMAIN_CONFIGURED flag, I believe it to be unnecessary if the hardware simply gives us whatever channels it wants to support and we then enable/disable them as required, which is pretty much required for travelling. Additionally, the patch adds proper "basic" rate handling for STA mode interface, AP mode interface will have to have new API added to allow userspace to set the basic rate set, currently it'll be empty... However, the basic rate handling will need to be moved to the BSS conf stuff. I do expect there to be bugs in this, especially wrt. transmit power handling where I'm basically clueless about how it should work. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Add per-interface structureIvo van Doorn
Rework the interface handling. Delete the interface structure and replace it with a per-interface structure. This changes the way rt2x00 handles the active interface drastically. Copy ieee80211_bss_conf to the this rt2x00_intf structure during the bss_info_changed() callback function. This will allow us to reference it later, and removes the requirement for the device flag SHORT_PREAMBLE flag which is interface specific. Drivers receive the option to give the maximum number of virtual interfaces the device can handle. Virtual interface support: rt2400pci: 1 sta or 1 ap, * monitor interfaces rt2500pci: 1 sta or 1 ap, * monitor interfaces rt2500usb: 1 sta or 1 ap, * monitor interfaces rt61pci: 1 sta or 4 ap, * monitor interfaces rt73usb: 1 sta or 4 ap, * monitor interfaces At the moment none of the drivers support AP and STA interfaces simultaneously, this is a hardware limitation so future support will be very unlikely. Each interface structure receives its dedicated beacon entry, with this we can easily work with beaconing while multiple master mode interfaces are currently active. The configuration handlers for the MAC, BSSID and type are often called together since they all belong to the interface configuration. Merge the 3 configuration calls and cleanup the API between rt2x00lib and the drivers. While we are cleaning up the interface configuration anyway, we might as well clean up the configuration handler as well. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Update copyright noticeIvo van Doorn
2008-02-28rt2x00: Don't switch to antenna with low rssiIvo van Doorn
When rssi_a > rssi_b is true and the current antenna was already antenna A, then rt2x00 incorrectly jumped to antenna B. Also don't configure the antenna when there has been no change in the antenna setup. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-28rt2x00: Add link tuner safe RX toggle statesIvo van Doorn
This adds 2 new states which both are used to toggle the RX. These new states are required for usage inside the link tuner thread, because the normal RX toggling will stop the link tuner thread. While it is possible that the link tuner thread itself is the caller of the RX toggle (when using software antenna diversity). Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28rt2x00: Replace DRV_NAME with KBUILD_MODNAMEIvo van Doorn
DRV_NAME was always set to the KBUILD_MODNAME value, lets clean everything up by removing DRV_NAME and just use KBUILD_MODNAME directly. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28rt2x00: Disable RX when switching antennaIvo van Doorn
Antenna switching will be ignored when RX is enabled during the switch. Make sure we disable the RX during the switch and don't forget to reenable it later. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[PATCH] rt2x00: Fix antenna selection.Mattias Nissler
In the config() handler, make sure that we do configure an antenna if the current active antenna is uninitialized. Furthermore, don't overwrite the active antenna with bogus values if we didn't touch the antenna setup. Signed-off-by: Mattias Nissler <mattias.nissler@gmx.de> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[PATCH] rt2x00: Implement SW diversityIvo van Doorn
When mac80211 indicates that the default antenna setup should be used _and_ that this default setup is SW_DIVERSITY. This requires sampling and storing the RSSI per antenna and check once every 2 seconds to determine if the RSSI has changed significantly. Once this is the case we should sample the other antenna for a short period and evaluate if we need to swap antenna or not. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[PATCH] rt2x00: Correctly translate mac80211 antenna setup to rt2x00Ivo van Doorn
mac80211 has 3 values for the antenna setup: 0 - default 1 - use antenna 1 2 - use antenna 2 This means that rt2x00 should store the default value from the EEPROM somwhere and use that when mac80211 indicates that the antenna setup is 0. This also implies that rt2x00 should no longer write the hw->config.antenna_sel_* values based on the EEPROM input. This also adds the basis in rt2x00lib for correct software diversity handling. By default rt2x00lib will now configure antenna B instead of hardware diversity. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[PATCH] rt2x00: Reorganize configuration handlerIvo van Doorn
Reorganize configuration handling by creating a extra structure which contains precalculated values based on the mac80211 values which are usefull for all individual drivers. This also fixes the preamble configuration problem, up untill now preamble was never configured since by default the rate->val value was used when changing the mode. Now rate->val will only be used to set the basic rate mask. The preamble configuration will now be done correctly through the erp_ie_changed callback function. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] rt2x00: Move TSF sync values into rt2x00configIvo van Doorn
All drivers use the same values for TSF sync, this will move the value determination into rt2x00config.c, and the definition for the values to rt2x00reg.h Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] rt2x00: Remove duplicate code in MAC & BSSID handlingIvo van Doorn
The various drivers contained duplicate code to handle the MAC and BSSID initialization correctly. This moves the address copy to little endian variables to rt2x00config. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] rt2x00: Reorganize rt2x00dev->flagsIvo van Doorn
The rt2x00dev->flags has become a chaos over time, this will reorganize the flags by renaming, deleting, adding and properly implement the flags. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] mac80211: revamp interface and filter configurationJohannes Berg
Drivers are currently supposed to keep track of monitor interfaces if they allow so-called "hard" monitor, and they are also supposed to keep track of multicast etc. This patch changes that, replaces the set_multicast_list() callback with a new configure_filter() callback that takes filter flags (FIF_*) instead of interface flags (IFF_*). For a driver, this means it should open the filter as much as necessary to get all frames requested by the filter flags. Accordingly, the filter flags are named "positively", e.g. FIF_ALLMULTI. Multicast filtering is a bit special in that drivers that have no multicast address filters need to allow multicast frames through when either the FIF_ALLMULTI flag is set or when the mc_count value is positive. At the same time, drivers are no longer notified about monitor interfaces at all, this means they now need to implement the start() and stop() callbacks and the new change_filter_flags() callback. Also, the start()/stop() ordering changed, start() is now called *before* any add_interface() as it really should be, and stop() after any remove_interface(). The patch also changes the behaviour of setting the bssid to multicast for scanning when IEEE80211_HW_NO_PROBE_FILTERING is set; the IEEE80211_HW_NO_PROBE_FILTERING flag is removed and the filter flag FIF_BCN_PRBRESP_PROMISC introduced. This is a lot more efficient for hardware like b43 that supports it and other hardware can still set the BSSID to all-ones. Driver modifications by Johannes Berg (b43 & iwlwifi), Michael Wu (rtl8187, adm8211, and p54), Larry Finger (b43legacy), and Ivo van Doorn (rt2x00). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[RT2x00]: add driver for Ralink wireless hardwareIvo van Doorn
