path: root/drivers/net/wireless/rt2x00/rt2x00leds.h
2008-04-01rt2x00: Remove MAC80211_LEDS dependencyIvo van Doorn
Implement triggers inside rt2x00 itself based on input from mac80211. This replaces the method of using the mac80211 trigger events which do not work for USB drivers due to the scheduling requirement. After this patch RT2500USB_LEDS and RT73USB_LEDS no longer need to be tagged as broken since they now support LED handling again without having to check for in_atomic(). Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29rt2x00: Enable LED class support for rt2500usb/rt73usbIvo van Doorn
Add kerneldoc for vendor request functions in rt2x00usb. Add asynchroneous vendor request function in rt2x00usb. With the availability of the asynchroneuous vendor request we can now enable LED class support for rt2500usb and rt73usb. Since LED handling is not important, it doesn't really matter if a register call fails (This solution is better then no LED class support at all). Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
