Allow drivers to support NL80211_SCAN_FLAG_RANDOM_ADDR with software
based scanning and generate a random MAC address for them for every
scan request with the flag.
John W. Linville says:
pull request: wireless-next 2014-07-03
Please pull this first batch of wireless updates intended for the
3.17 stream...
For the mac80211 bits, Johannes says:
"The biggest thing here is probably Arik's TDLS rework, beyond that we
have smaller improvements and features like David's scanning IE thing,
Luca's queue work, some CSA work, etc. Also your PID rate control
removal, of course."
For the iwlwifi bits, Emmanuel says:
"I have here a whole bunch of various things. Andy contributes
better debug prints for dvm specific flows and a module parameter to
completely disable power save for dvm. Andrei is sharing the premises
of his work on CSA - more to come. Eran and Liad keep on working
on the new devices. I have the regular amount of BT Coex stuff and
I continue to work on the firmware error report system adding more
debug capabilities. More to come on that subject too."
On top of that, there are some cleanups to the new rsi driver, some
continuing improvements to the rtl818x drivers, and the usual bundles
of updates to ath9k, b43, mwifiex, wil6210, and a few other bits here
and there.
When no beaconing is needed, first stop beacon queue (disable beaconing
globally) to avoid possible sending of not prepared beacon on short
period after clearing beacon and before stop of BCN queue.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
This patch is needed for further changes to keep global variables
consistent when changing beaconing on diffrent vif's.
There is a risk that the variable will be used without being initialized.
This was largely found by using a static code analysis program called cppcheck.
Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se>
On USB we can not get atomically TKIP key. We have to disable support
for TKIP acceleration on USB hardware to avoid bug as showed bellow.
[ 860.827243] BUG: scheduling while atomic: hostapd/3397/0x00000002
<snip>
[ 860.827280] Call Trace:
[ 860.827282] [<ffffffff81682ea6>] dump_stack+0x4d/0x66
[ 860.827284] [<ffffffff8167eb9b>] __schedule_bug+0x47/0x55
[ 860.827285] [<ffffffff81685bb3>] __schedule+0x733/0x7b0
[ 860.827287] [<ffffffff81685c59>] schedule+0x29/0x70
[ 860.827289] [<ffffffff81684f8a>] schedule_timeout+0x15a/0x2b0
[ 860.827291] [<ffffffff8105ac50>] ? ftrace_raw_event_tick_stop+0xc0/0xc0
[ 860.827294] [<ffffffff810c13c2>] ? __module_text_address+0x12/0x70
[ 860.827296] [<ffffffff81686823>] wait_for_completion_timeout+0xb3/0x140
[ 860.827298] [<ffffffff81080fc0>] ? wake_up_state+0x20/0x20
[ 860.827301] [<ffffffff814d5b3d>] usb_start_wait_urb+0x7d/0x150
[ 860.827303] [<ffffffff814d5cd5>] usb_control_msg+0xc5/0x110
[ 860.827305] [<ffffffffa02fb0c6>] rt2x00usb_vendor_request+0xc6/0x160 [rt2x00usb]
[ 860.827307] [<ffffffffa02fb215>] rt2x00usb_vendor_req_buff_lock+0x75/0x150 [rt2x00usb]
[ 860.827309] [<ffffffffa02fb393>] rt2x00usb_vendor_request_buff+0xa3/0xe0 [rt2x00usb]
[ 860.827311] [<ffffffffa023d1a3>] rt2x00usb_register_multiread+0x33/0x40 [rt2800usb]
[ 860.827314] [<ffffffffa05805f9>] rt2800_get_tkip_seq+0x39/0x50 [rt2800lib]
[ 860.827321] [<ffffffffa0480f88>] ieee80211_get_key+0x218/0x2a0 [mac80211]
[ 860.827322] [<ffffffff815cc68c>] ? __nlmsg_put+0x6c/0x80
[ 860.827329] [<ffffffffa051b02e>] nl80211_get_key+0x22e/0x360 [cfg80211]
Cc: stable@vger.kernel.org
Reported-and-tested-by: Peter Wu <lekensteyn@gmail.com>
Reported-and-tested-by: Pontus Fuchs <pontus.fuchs@gmail.com>
drivers/net/ethernet/altera/altera_sgdma.c
net/netlink/af_netlink.c
net/sched/cls_api.c
net/sched/sch_api.c
The netlink conflict dealt with moving to netlink_capable() and
netlink_ns_capable() in the 'net' tree vs. supporting 'tc' operations
in non-init namespaces. These were simple transformations from
netlink_capable to netlink_ns_capable.
The Altera driver conflict was simply code removal overlapping some
void pointer cast cleanups in net-next.
When disable beaconing we clear register with beacon and newer set it
back, what make we stop send beacons infinitely.
This will allow the low level driver to make decision based
on the vif such as queues etc...
Since the vif might be NULL, we can't add it to the tracing
functions.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
[fix staging rtl8821ae driver]
Several files refer to an old address for the Free Software Foundation
in the file header comment. Resolve by replacing the address with
the URL <http://www.gnu.org/licenses/> so that we do not have to keep
updating the header comments anytime the address changes.
CC: linux-wireless@vger.kernel.org
CC: Ivo van Doorn <IvDoorn@gmail.com>
CC: Gertjan van Wingerde <gwingerde@gmail.com>
CC: Helmut Schaa <helmut.schaa@googlemail.com>
Acked-by: Gertjan van Wingerde <gwingerde@gmail.com>
Since:
commit 36323f817af0376c78612cfdab714b0feb05fea5
Author: Thomas Huehn <thomas@net.t-labs.tu-berlin.de>
Date: Mon Jul 23 21:33:42 2012 +0200
mac80211: move TX station pointer and restructure TX
we do not pass sta pointer to rt2x00queue_create_tx_descriptor_ht(),
hence we do not correctly set station WCID and AMPDU density parameters.
Cc: stable@vger.kernel.org # 3.7+
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
drivers/net/wireless/iwlwifi/pcie/drv.c
Fix random kernel panic with below messages when remove dongle.
[ 2212.355447] BUG: unable to handle kernel NULL pointer dereference at 0000000000000250
[ 2212.355527] IP: [<ffffffffa02667f2>] rt2x00usb_kick_tx_entry+0x12/0x160 [rt2x00usb]
[ 2212.355599] PGD 0
[ 2212.355626] Oops: 0000 [#1] SMP
[ 2212.355664] Modules linked in: rt2800usb rt2x00usb rt2800lib crc_ccitt rt2x00lib mac80211 cfg80211 tun arc4 fuse rfcomm bnep snd_hda_codec_realtek snd_hda_intel snd_hda_codec btusb uvcvideo bluetooth snd_hwdep x86_pkg_temp_thermal snd_seq coretemp aesni_intel aes_x86_64 snd_seq_device glue_helper snd_pcm ablk_helper videobuf2_vmalloc sdhci_pci videobuf2_memops videobuf2_core sdhci videodev mmc_core serio_raw snd_page_alloc microcode i2c_i801 snd_timer hid_multitouch thinkpad_acpi lpc_ich mfd_core snd tpm_tis wmi tpm tpm_bios soundcore acpi_cpufreq i915 i2c_algo_bit drm_kms_helper drm i2c_core video [last unloaded: cfg80211]
[ 2212.356224] CPU: 0 PID: 34 Comm: khubd Not tainted 3.12.0-rc3-wl+ #3
[ 2212.356268] Hardware name: LENOVO 3444CUU/3444CUU, BIOS G6ET93WW (2.53 ) 02/04/2013
[ 2212.356319] task: ffff880212f687c0 ti: ffff880212f66000 task.ti: ffff880212f66000
[ 2212.356392] RIP: 0010:[<ffffffffa02667f2>] [<ffffffffa02667f2>] rt2x00usb_kick_tx_entry+0x12/0x160 [rt2x00usb]
[ 2212.356481] RSP: 0018:ffff880212f67750 EFLAGS: 00010202
[ 2212.356519] RAX: 000000000000000c RBX: 000000000000000c RCX: 0000000000000293
[ 2212.356568] RDX: ffff8801f4dc219a RSI: 0000000000000000 RDI: 0000000000000240
[ 2212.356617] RBP: ffff880212f67778 R08: ffffffffa02667e0 R09: 0000000000000002
[ 2212.356665] R10: 0001f95254ab4b40 R11: ffff880212f675be R12: ffff8801f4dc2150
[ 2212.356712] R13: 0000000000000000 R14: ffffffffa02667e0 R15: 000000000000000d
[ 2212.356761] FS: 0000000000000000(0000) GS:ffff88021e200000(0000) knlGS:0000000000000000
[ 2212.356813] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 2212.356852] CR2: 0000000000000250 CR3: 0000000001a0c000 CR4: 00000000001407f0
[ 2212.356899] Stack:
[ 2212.356917] 000000000000000c ffff8801f4dc2150 0000000000000000 ffffffffa02667e0
[ 2212.356980] 000000000000000d ffff880212f677b8 ffffffffa03a31ad ffff8801f4dc219a
[ 2212.357038] ffff8801f4dc2150 0000000000000000 ffff8800b93217a0 ffff8801f49bc800
[ 2212.357099] Call Trace:
[ 2212.357122] [<ffffffffa02667e0>] ? rt2x00usb_interrupt_txdone+0x90/0x90 [rt2x00usb]
[ 2212.357174] [<ffffffffa03a31ad>] rt2x00queue_for_each_entry+0xed/0x170 [rt2x00lib]
[ 2212.357244] [<ffffffffa026701c>] rt2x00usb_kick_queue+0x5c/0x60 [rt2x00usb]
[ 2212.357314] [<ffffffffa03a3682>] rt2x00queue_flush_queue+0x62/0xa0 [rt2x00lib]
[ 2212.357386] [<ffffffffa03a2930>] rt2x00mac_flush+0x30/0x70 [rt2x00lib]
[ 2212.357470] [<ffffffffa04edded>] ieee80211_flush_queues+0xbd/0x140 [mac80211]
[ 2212.357555] [<ffffffffa0502e52>] ieee80211_set_disassoc+0x2d2/0x3d0 [mac80211]
[ 2212.357645] [<ffffffffa0506da3>] ieee80211_mgd_deauth+0x1d3/0x240 [mac80211]
[ 2212.357718] [<ffffffff8108b17c>] ? try_to_wake_up+0xec/0x290
[ 2212.357788] [<ffffffffa04dbd18>] ieee80211_deauth+0x18/0x20 [mac80211]
[ 2212.357872] [<ffffffffa0418ddc>] cfg80211_mlme_deauth+0x9c/0x140 [cfg80211]
[ 2212.357913] [<ffffffffa041907c>] cfg80211_mlme_down+0x5c/0x60 [cfg80211]
[ 2212.357962] [<ffffffffa041cd18>] cfg80211_disconnect+0x188/0x1a0 [cfg80211]
[ 2212.358014] [<ffffffffa04013bc>] ? __cfg80211_stop_sched_scan+0x1c/0x130 [cfg80211]
[ 2212.358067] [<ffffffffa03f8954>] cfg80211_leave+0xc4/0xe0 [cfg80211]
[ 2212.358124] [<ffffffffa03f8d1b>] cfg80211_netdev_notifier_call+0x3ab/0x5e0 [cfg80211]
[ 2212.358177] [<ffffffff815140f8>] ? inetdev_event+0x38/0x510
[ 2212.358217] [<ffffffff81085a94>] ? __wake_up+0x44/0x50
[ 2212.358254] [<ffffffff8155995c>] notifier_call_chain+0x4c/0x70
[ 2212.358293] [<ffffffff81081156>] raw_notifier_call_chain+0x16/0x20
[ 2212.358361] [<ffffffff814b6dd5>] call_netdevice_notifiers_info+0x35/0x60
[ 2212.358429] [<ffffffff814b6ec9>] __dev_close_many+0x49/0xd0
[ 2212.358487] [<ffffffff814b7028>] dev_close_many+0x88/0x100
[ 2212.358546] [<ffffffff814b8150>] rollback_registered_many+0xb0/0x220
[ 2212.358612] [<ffffffff814b8319>] unregister_netdevice_many+0x19/0x60
[ 2212.358694] [<ffffffffa04d8eb2>] ieee80211_remove_interfaces+0x112/0x190 [mac80211]
[ 2212.358791] [<ffffffffa04c585f>] ieee80211_unregister_hw+0x4f/0x100 [mac80211]
[ 2212.361994] [<ffffffffa03a1221>] rt2x00lib_remove_dev+0x161/0x1a0 [rt2x00lib]
[ 2212.365240] [<ffffffffa0266e2e>] rt2x00usb_disconnect+0x2e/0x70 [rt2x00usb]
[ 2212.368470] [<ffffffff81419ce4>] usb_unbind_interface+0x64/0x1c0
[ 2212.371734] [<ffffffff813b446f>] __device_release_driver+0x7f/0xf0
[ 2212.374999] [<ffffffff813b4503>] device_release_driver+0x23/0x30
[ 2212.378131] [<ffffffff813b3c98>] bus_remove_device+0x108/0x180
[ 2212.381358] [<ffffffff813b0565>] device_del+0x135/0x1d0
[ 2212.384454] [<ffffffff81417760>] usb_disable_device+0xb0/0x270
[ 2212.387451] [<ffffffff8140d9cd>] usb_disconnect+0xad/0x1d0
[ 2212.390294] [<ffffffff8140f6cd>] hub_thread+0x63d/0x1660
[ 2212.393034] [<ffffffff8107c860>] ? wake_up_atomic_t+0x30/0x30
[ 2212.395728] [<ffffffff8140f090>] ? hub_port_debounce+0x130/0x130
[ 2212.398412] [<ffffffff8107baa0>] kthread+0xc0/0xd0
[ 2212.401058] [<ffffffff8107b9e0>] ? insert_kthread_work+0x40/0x40
[ 2212.403639] [<ffffffff8155de3c>] ret_from_fork+0x7c/0xb0
[ 2212.406193] [<ffffffff8107b9e0>] ? insert_kthread_work+0x40/0x40
[ 2212.408732] Code: 24 58 08 00 00 bf 80 00 00 00 e8 3a c3 e0 e0 5b 41 5c 5d c3 0f 1f 44 00 00 0f 1f 44 00 00 55 48 89 e5 41 57 41 56 41 55 41 54 53 <48> 8b 47 10 48 89 fb 4c 8b 6f 28 4c 8b 20 49 8b 04 24 4c 8b 30
[ 2212.414671] RIP [<ffffffffa02667f2>] rt2x00usb_kick_tx_entry+0x12/0x160 [rt2x00usb]
[ 2212.417646] RSP <ffff880212f67750>
[ 2212.420547] CR2: 0000000000000250
[ 2212.441024] ---[ end trace 5442918f33832bce ]---
Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl>
Acked-by: Helmut Schaa <helmut.schaa@googlemail.com>
Use the appropriate helper functions instead of
directly accessing the rt2x00dev->cap_flags field
to check device capability flags.
This improves readability of the code a bit.
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Reduce object space ~2% using more current logging styles.
Neaten and simplify logging macros.
Use wiphy_<level> where appropriate.
Coalesce formats.
Convert ERROR/WARNING/INFO macros to rt2x00_<level>
Convert EEPROM to rt2x00_eeprom_dbg
Convert PROBE_ERROR to rt2x00_probe_err
Convert DEBUG to rt2x00_dbg
$ size drivers/net/wireless/rt2x00/built-in.o*
245639 71696 69584 386919 5e767 drivers/net/wireless/rt2x00/built-in.o.new
240609 70096 68944 379649 5cb01 drivers/net/wireless/rt2x00/built-in.o.new.nodyndbg
240609 70096 68944 379649 5cb01 drivers/net/wireless/rt2x00/built-in.o.new.no_rt2x00_debug
249198 70096 70352 389646 5f20e drivers/net/wireless/rt2x00/built-in.o.old
249198 70096 70352 389646 5f20e drivers/net/wireless/rt2x00/built-in.o.old.nodyndbg
244222 70096 69712 384030 5dc1e drivers/net/wireless/rt2x00/built-in.o.old.no_rt2x00_debug
There are a number of situations in which mac80211 only
really needs to flush queues for one virtual interface,
and in fact during this frames might be transmitted on
other virtual interfaces. Calculate and pass a queue
bitmap to the driver so it knows which queues to flush.
Tested-by: Xose Vazquez Perez <xose.vazquez@gmail.com>
During hardware restart, all interfaces are iterated even
though they haven't been re-added to the driver, document
this behaviour. The same also happens during resume, which
is even more confusing since all of the interfaces were
previously removed from the driver. Make this optional so
drivers relying on the current behaviour can still use it,
but to let drivers that don't want this behaviour disable
it.
Also convert all API users, keeping the old semantics
except in hwsim, where the new normal ones are desired.
Mac80211 has formal infrastructure to specify which interface combinations
are supported. Make use of this facility in favor of open coding it
ourselves.
So far we only have to specify we can support multiple AP interfaces,
no other combinations are supported.
Inspired by an earlier patch from Paul Fertser.
Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com>
Cc: Paul Fertser <fercerpav@gmail.com>
All drivers set this value to 1, so there is no need (currently) to let
drivers set this.
Therefor, remove the field; we can always add it back when it is needed.
Remove the control.sta pointer from ieee80211_tx_info to free up
sufficient space in the TX skb control buffer for the upcoming
Transmit Power Control (TPC).
Instead, the pointer is now on the stack in a new control struct
that is passed as a function parameter to the drivers' tx method.
Signed-off-by: Thomas Huehn <thomas@net.t-labs.tu-berlin.de>
Signed-off-by: Alina Friedrichsen <x-alina@gmx.net>
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
[reworded commit message]
Similar like other drivers, do not configure group keys to the hardware
(on Ad-Hoc mode) to make IBSS RSN work.
Remove spinlock as atomic_t can be used instead. Note we use only 16
lower bits, upper bits are changed but we impilcilty cast to u16.
This fix possible deadlock on IBSS mode reproted by lockdep:
[ INFO: inconsistent lock state ]
3.4.0-wl+ #4 Not tainted
inconsistent {IN-SOFTIRQ-W} -> {SOFTIRQ-ON-W} usage.
kworker/u:2/30374 [HC0[0]:SC0[0]:HE1:SE1] takes:
(&(&intf->seqlock)->rlock){+.?...}, at: [<f9979a20>] rt2x00queue_create_tx_descriptor+0x380/0x490 [rt2x00lib]
{IN-SOFTIRQ-W} state was registered at:
[<c04978ab>] __lock_acquire+0x47b/0x1050
[<c0498504>] lock_acquire+0x84/0xf0
[<c0835733>] _raw_spin_lock+0x33/0x40
[<f9979f2a>] rt2x00queue_write_tx_frame+0x1a/0x300 [rt2x00lib]
[<f997834f>] rt2x00mac_tx+0x7f/0x380 [rt2x00lib]
[<f98fe363>] __ieee80211_tx+0x1b3/0x300 [mac80211]
[<f98ffdf5>] ieee80211_tx+0x105/0x130 [mac80211]
[<f99000dd>] ieee80211_xmit+0xad/0x100 [mac80211]
[<f9900519>] ieee80211_subif_start_xmit+0x2d9/0x930 [mac80211]
[<c0782e87>] dev_hard_start_xmit+0x307/0x660
[<c079bb71>] sch_direct_xmit+0xa1/0x1e0
[<c0784bb3>] dev_queue_xmit+0x183/0x730
[<c078c27a>] neigh_resolve_output+0xfa/0x1e0
[<c07b436a>] ip_finish_output+0x24a/0x460
[<c07b4897>] ip_output+0xb7/0x100
[<c07b2d60>] ip_local_out+0x20/0x60
[<c07e01ff>] igmpv3_sendpack+0x4f/0x60
[<c07e108f>] igmp_ifc_timer_expire+0x29f/0x330
[<c04520fc>] run_timer_softirq+0x15c/0x2f0
[<c0449e3e>] __do_softirq+0xae/0x1e0
irq event stamp: 18380437
hardirqs last enabled at (18380437): [<c0526027>] __slab_alloc.clone.3+0x67/0x5f0
hardirqs last disabled at (18380436): [<c0525ff3>] __slab_alloc.clone.3+0x33/0x5f0
softirqs last enabled at (18377616): [<c0449eb3>] __do_softirq+0x123/0x1e0
softirqs last disabled at (18377611): [<c041278d>] do_softirq+0x9d/0xe0
Possible unsafe locking scenario:
CPU0
lock(&(&intf->seqlock)->rlock);
<Interrupt>
*** DEADLOCK ***
4 locks held by kworker/u:2/30374:
#0: (wiphy_name(local->hw.wiphy)){++++.+}, at: [<c045cf99>] process_one_work+0x109/0x3f0
#1: ((&sdata->work)){+.+.+.}, at: [<c045cf99>] process_one_work+0x109/0x3f0
#2: (&ifibss->mtx){+.+.+.}, at: [<f98f005b>] ieee80211_ibss_work+0x1b/0x470 [mac80211]
#3: (&intf->beacon_skb_mutex){+.+...}, at: [<f997a644>] rt2x00queue_update_beacon+0x24/0x50 [rt2x00lib]
stack backtrace:
Pid: 30374, comm: kworker/u:2 Not tainted 3.4.0-wl+ #4
Call Trace:
[<c04962a6>] print_usage_bug+0x1f6/0x220
[<c0496a12>] mark_lock+0x2c2/0x300
[<c0495ff0>] ? check_usage_forwards+0xc0/0xc0
[<c04978ec>] __lock_acquire+0x4bc/0x1050
[<c0527890>] ? __kmalloc_track_caller+0x1c0/0x1d0
[<c0777fb6>] ? copy_skb_header+0x26/0x90
[<f9979a20>] ? rt2x00queue_create_tx_descriptor+0x380/0x490 [rt2x00lib]
[<f997a5cf>] rt2x00queue_update_beacon_locked+0x5f/0xb0 [rt2x00lib]
[<f997a64d>] rt2x00queue_update_beacon+0x2d/0x50 [rt2x00lib]
[<f9977e3a>] rt2x00mac_bss_info_changed+0x1ca/0x200 [rt2x00lib]
[<f9977c70>] ? rt2x00mac_remove_interface+0x70/0x70 [rt2x00lib]
[<f98e4dd0>] ieee80211_bss_info_change_notify+0xe0/0x1d0 [mac80211]
[<f98ef7b8>] __ieee80211_sta_join_ibss+0x3b8/0x610 [mac80211]
[<c0496ab4>] ? mark_held_locks+0x64/0xc0
[<c0440012>] ? virt_efi_query_capsule_caps+0x12/0x50
[<f98efb09>] ieee80211_sta_join_ibss+0xf9/0x140 [mac80211]
[<f98f0456>] ieee80211_ibss_work+0x416/0x470 [mac80211]
[<c0496d8b>] ? trace_hardirqs_on+0xb/0x10
[<c077683b>] ? skb_dequeue+0x4b/0x70
[<f98f207f>] ieee80211_iface_work+0x13f/0x230 [mac80211]
[<c045cf99>] ? process_one_work+0x109/0x3f0
[<c045d015>] process_one_work+0x185/0x3f0
[<f98f1f40>] ? ieee80211_teardown_sdata+0xa0/0xa0 [mac80211]
[<c045ed86>] worker_thread+0x116/0x270
[<c045ec70>] ? manage_workers+0x1e0/0x1e0
[<c0462f64>] kthread+0x84/0x90
[<c0462ee0>] ? __init_kthread_worker+0x60/0x60
[<c083d382>] kernel_thread_helper+0x6/0x10
This is workaround H/W or F/W bug, see in code comments. Without the fix
ping can receive duplicated ICMP frames while associated with legacy AP.
Reported-by: Walter Goldens <goldenstranger@yahoo.com>
Is possible that we stop queue and then do not wake up it again,
especially when packets are transmitted fast. That can be easily
reproduced with modified tx queue entry_num to some small value e.g. 16.
If mac80211 already hold local->queue_stop_reason_lock, then we can wait
on that lock in both rt2x00queue_pause_queue() and
rt2x00queue_unpause_queue(). After drooping ->queue_stop_reason_lock
is possible that __ieee80211_wake_queue() will be performed before
__ieee80211_stop_queue(), hence we stop queue and newer wake up it
again.
Another race condition is possible when between rt2x00queue_threshold()
check and rt2x00queue_pause_queue() we will process all pending tx
buffers on different cpu. This might happen if for example interrupt
will be triggered on cpu performing rt2x00mac_tx().
To prevent race conditions serialize pause/unpause by queue->tx_lock.
ieee80211_free_txskb should be used when dropping a frame in the device
rx path such that mac80211 knows about this frame being dropped.
Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com>
Acked-by: Ivo van Doorn <IvDoorn@gmail.com>
tx params should be configured per interface.
add ieee80211_vif param to the conf_tx callback,
and change all the drivers that use this callback.
The following spatch was used:
@rule1@
struct ieee80211_ops ops;
identifier conf_tx_op;
ops.conf_tx = conf_tx_op;
@rule2@
identifier rule1.conf_tx_op;
identifier hw, queue, params;
conf_tx_op (
- struct ieee80211_hw *hw,
+ struct ieee80211_hw *hw, struct ieee80211_vif *vif,
u16 queue,
const struct ieee80211_tx_queue_params *params) {...}
Signed-off-by: Eliad Peller <eliad@wizery.com>
When a WCID was already assigned to a STA the key configuration
functions need to use the same WCID for configuring the keys. Hence, add
the WCID to the crypo configuration structure.
Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com>
This implements a basic sta_add and sta_remove callback. Introduce a new
structure rt2x00_sta and ask mac80211 to allocate it as private part of
its ieee80211_sta. rt2x00_sta only contains the WCID for now.
The sta_add callback allows the driver to assign a WCID to a station
that is currently being added. The same wcid is also passed to the
sta_remove callback one mac80211 removes this STA.
This will be used by a later patch. No functional changes.
We may call rt2x00queue_pause_queue(queue) with queue == NULL. Bug
was introduced by commit 62fe778412b36791b7897cfa139342906fbbf07b
"rt2x00: Fix stuck queue in tx failure case" .
Cc: stable@kernel.org # 3.0+
Implementing this callback function will cause mac80211 refrain from
going to powersave state when there are still untransmitted TX frames
in the queues.
This would exactly mimic the behaviour of the legacy vendor driver which
also doesn't go in powersave mode if there are still TX frames that are not
transmitted.
This should make powersaving and rt2x00 a better couple.
Implement the get_antenna and set_antenna callback functions, which will
allow clients to control the antenna for all non-11n hardware (Antenna handling
in rt2800 is still a bit magical, so we can't use the set_antenna for those drivers
yet).
To best support the set_antenna callback some modifications are needed in the
diversity handling. We should never look at the default antenna settings to determine
if software diversity is enabled. Instead we should set the diversity flag when
possible, which will allow the link_tuner to automatically pick up the tuning.
With the get_ringparam callback function we can export ring parameters
to ethtool through the mac80211 interface.
The number of flags defined for the rt2x00dev->flags field,
has been growing over the years. Currently we are approaching
the maximum number of bits which are available in the field.
A secondary problem, is that one part of the field are initialized only
during boot, because the driver requirements are initialized or device
requirements are loaded from the EEPROM. In both cases, the flags are
fixed and will not change during device operation. The other flags are
the device state, and will change frequently. So far this resulted in the fact
that for some flags, the atomic bit accessors are used, while for the others
the non-atomic variants are used.
By splitting the flags up into a "flags" and "cap_flags" we can put all flags
which are fixed inside "cap_flags". This field can then be read non-atomically.
In the "flags" field we keep the device state, which is going to be read atomically.
This adds more room for more flags in the future, and sanitizes the field access methods.
Since commit 0b7fde54f94979edc67bbf86b5adba702ebfefe8 "rt2x00: Protect
queue control with mutex" rt2x00 used rt2x00queue_pause_queue for
stopping a tx queue in mac80211. But in case of a failure in the tx
path rt2x00 still called ieee80211_stop_queue which stopped the queue
but prevented rt2x00queue_unpause_queue to wake the queue up again
resulting in a stuck tx queue.
Fix this by also using rt2x00queue_pause_queue in case of tx failures.
In the spirit of optimizing the code to get the queue structure of TX queues,
also optimize the code to get beacon queues. We can simply use the bcn queue
field of the rt2x00_dev structure instead of using the rt2x00queue_get_queue
function.
The ATIM queue is considered to be a TX queue by the drivers that support
the queue. Therefore include support for the ATIM queue to the
rt2x00queue_get_tx_queue function so that the drivers that support the ATIM
queue can also use that function.
Add the support in such a way that drivers that do not support the ATIM
queue are not penalized in their efficiency.
rt2x00queue_write_tx_frame is unlikely to fail. Tell the compiler.
In some cases (tx path for example) we don't need to check for non-tx
queues in rt2x00queue_get_queue. Hence, introduce a new method
rt2x00queue_get_tx_queue that is only valid for tx queues and use it in
places where only tx queues are valid.
Furthermore, this new method is quite short and as such can be inlined
to avoid the function call overhead.
This only converts the txdone functions of drivers that don't use an ATIM
queue and the generic tx path.
The return value of the tx operation is commonly
misused by drivers, leading to errors. All drivers
will drop frames if they fail to TX the frame, and
they must also properly manage the queues (if they
didn't, mac80211 would already warn).
Removing the ability for drivers to return a BUSY
value also allows significant cleanups of the TX
TX handling code in mac80211.
Note that this also fixes a bug in ath9k_htc, the
old "return -1" there was wrong.
Tested-by: Sedat Dilek <sedat.dilek@googlemail.com> [ath5k]
Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> [rt2x00]
Acked-by: Larry Finger <Larry.Finger@lwfinger.net> [b43, rtl8187, rtlwifi]
Acked-by: Luciano Coelho <coelho@ti.com> [wl12xx]
Only devices that don't have RTS/CTS offload need to check for
IEEE80211_TX_RC_USE_RTS_CTS and IEEE80211_TX_RC_USE_CTS_PROTECT.
By swapping both conditions we keep the same number of needed conditionals
for devices without RTS/CTS offload but save one conditional on devices
with RTS/CTS offload.
Currently there are two places that trigger a beacon update on PCI
devices. The bss_info_changed callback and the periodic update
triggered by the TBTT or PRETBTT interrupt.
Since the next TBTT or PRETBTT interrupt will periodically fetch an
updated beacon remove the update_beacon call in the bss_info_changed
callback for PCI devices.
In the worst case it will take one beacon interval longer to fetch
the new beacon then before. For devices that have a PRETBTT interrupt
there should be no change at all.
This patch allows to dynamically remove beaconing interfaces without
shutting beaconing down on all interfaces.
The only place to start and stop beaconing are now the start- and
stop_queue callbacks. Hence, we can remove some register writes during
interface bring up (config_intf) and only write the correct sync mode
to the register there.
When multiple beaconing interfaces are present we should enable
beaconing as soon as mac80211 enables beaconing on at least one of
them. The beacon queue gets stopped when the last beaconing
interface was stopped by mac80211. Therefore, introduce another
interface counter to keep track ot the number of enabled beaconing
interfaces and start or stop the beacon queue accordingly.
To allow single interfaces to stop beaconing, add a new driver
callback clear_beacon to clear a single interface's beacon without
affecting the other interfaces. Don't overload the clear_entry callback
for clearing beacons as that would introduce additional overhead
(check for each TX queue) into the clear_entry callback which is used
on the drivers TX/RX hotpaths.
Furthermore, the write beacon callback doesn't need to enable beaconing
anymore but since beaconing should be disabled while a new beacon is
written or cleared we still disable beacon generation and enable it
afterwards again in the driver specific callbacks. However, beacon
related interrupts should not be disabled/enabled here, that's solely
done from the start- and stop queue callbacks. It would be nice to stop
the beacon queue just before the beacon update and enable it afterwards
in rt2x00queue itself instead of the current implementation that relies
on the driver doing the right thing. However, since start- and
stop_queue are mutex protected we cannot use them for atomic beacon
updates.
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
Documentation/trace/events.txt: Remove obsolete sched_signal_send.
writeback: fix global_dirty_limits comment runtime -> real-time
ppc: fix comment typo singal -> signal
drivers: fix comment typo diable -> disable.
m68k: fix comment typo diable -> disable.
wireless: comment typo fix diable -> disable.
media: comment typo fix diable -> disable.
remove doc for obsolete dynamic-printk kernel-parameter
remove extraneous 'is' from Documentation/iostats.txt
Fix spelling milisec -> ms in snd_ps3 module parameter description
Fix spelling mistakes in comments
Revert conflicting V4L changes
i7core_edac: fix typos in comments
mm/rmap.c: fix comment
sound, ca0106: Fix assignment to 'channel'.
hrtimer: fix a typo in comment
init/Kconfig: fix typo
anon_inodes: fix wrong function name in comment
fix comment typos concerning "consistent"
poll: fix a typo in comment
Fix up trivial conflicts in:
- drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c)
- fs/ext4/ext4.h
Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
The comment doesn't match the code anymore. Fix that.
Since the last user of intf->lock is gone we can safely remove it.
Instead of protecting delayed_flags with a spinlock use atomic bitops to
make the code more readable.
Fix some pointer errors in the various calls to memcpy, memset and memmove.
Although none of these errors are fatal (the expression used now results in
the same pointer value) it is better to use the proper expression.
All errors are having to deal with arrays.
