We should prefer `struct pci_device_id` over `DEFINE_PCI_DEVICE_TABLE` to
meet kernel coding style guidelines. This issue was reported by checkpatch.
A simplified version of the semantic patch that makes this change is as
follows (http://coccinelle.lip6.fr/):
// <smpl>
identifier i;
declarer name DEFINE_PCI_DEVICE_TABLE;
initializer z;
- DEFINE_PCI_DEVICE_TABLE(i)
+ const struct pci_device_id i[]
= z;
// </smpl>
[bhelgaas: add semantic patch]
Signed-off-by: Benoit Taine <benoit.taine@lip6.fr>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
After changing local per interface beacon setting restore original
global beaconing state.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
Acked-by: Christian Lamparter <chunkeey@googlemail.com>
Acked-by: Gertjan van Wingerde <gwingerde@gmail.com>
Several files refer to an old address for the Free Software Foundation
in the file header comment. Resolve by replacing the address with
the URL <http://www.gnu.org/licenses/> so that we do not have to keep
updating the header comments anytime the address changes.
CC: linux-wireless@vger.kernel.org
CC: Ivo van Doorn <IvDoorn@gmail.com>
CC: Gertjan van Wingerde <gwingerde@gmail.com>
CC: Helmut Schaa <helmut.schaa@googlemail.com>
Use the appropriate helper functions instead of
directly accessing the rt2x00dev->cap_flags field
to check device capability flags.
This improves readability of the code a bit.
Compile tested only.
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
The current code uses the same index value both
for the channel information array and for the TX
power table. The index starts from 14, however the
index of the TX power table must start from zero.
Fix it, in order to get the correct TX power value
for a given channel.
The changes in rt61pci.c and rt73usb.c are compile
tested only.
Cc: stable@vger.kernel.org
Acked-by: Stanislaw Gruszka <stf_xl@wp.pl>
The extra_tx_headroom field of struct rt2x00_ops
indicates the extra TX headroom size required for
a given device. This data is redundant, the value
can be computed from the desc_size and winfo_size
fields of the TX queues.
Move the extra_tx_headroom field to struct rt2x00_dev,
compute its value in the probe routine and use the
cached value in the rest of the code.
Acked-by: Stanislaw Gruszka <sgruszka@redhat.com>
The generic rt2x00 code has been changed to allow the
drivers toimplement dynamic data_queue initialization.
Remove the static data queue descriptor structures
and implement the queue_init callback instead.
Tested-by: Jakub Kicinski <kubakici@wp.pl>
The TX data queue is initialized already when
the rt61pci_txdone() function is called.
Fetch the number of the queue entries from that
instead of using the entry_num field of the data
queue descriptor.
The two values are the same, and the use of the
rt2x00dev->tx->limit value allows us to get rid
of a superfluous pointer dereference.
Reduce object space ~2% using more current logging styles.
Neaten and simplify logging macros.
Use wiphy_<level> where appropriate.
Coalesce formats.
Convert ERROR/WARNING/INFO macros to rt2x00_<level>
Convert EEPROM to rt2x00_eeprom_dbg
Convert PROBE_ERROR to rt2x00_probe_err
Convert DEBUG to rt2x00_dbg
$ size drivers/net/wireless/rt2x00/built-in.o*
245639 71696 69584 386919 5e767 drivers/net/wireless/rt2x00/built-in.o.new
240609 70096 68944 379649 5cb01 drivers/net/wireless/rt2x00/built-in.o.new.nodyndbg
240609 70096 68944 379649 5cb01 drivers/net/wireless/rt2x00/built-in.o.new.no_rt2x00_debug
249198 70096 70352 389646 5f20e drivers/net/wireless/rt2x00/built-in.o.old
249198 70096 70352 389646 5f20e drivers/net/wireless/rt2x00/built-in.o.old.nodyndbg
244222 70096 69712 384030 5dc1e drivers/net/wireless/rt2x00/built-in.o.old.no_rt2x00_debug
Use the recently introduced rt2x00mmio_* routines
instead of the rt2x00pci_* variants.
The patch contains no functional changes.
Acked-by: Helmut Schaa <helmut.schaa@googlemail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next
drivers/net/wireless/ath/carl9170/debug.c
drivers/net/wireless/ath/carl9170/main.c
net/mac80211/ieee80211_i.h
The rt2800pci driver supports the built-in wireless
MAC of the Ralink RT3x5x SoCs. However building the
driver for these SoCs leads to the following error:
LD init/built-in.o
drivers/built-in.o: In function `rt2800pci_rxdone_tasklet':
<...>/drivers/net/wireless/rt2x00/rt2800pci.c:1012: undefined reference to `rt2x00pci_rxdone'
drivers/built-in.o:(.rodata+0x4780): undefined reference to `rt2x00pci_initialize'
drivers/built-in.o:(.rodata+0x4784): undefined reference to `rt2x00pci_uninitialize'
drivers/built-in.o:(.rodata+0x47bc): undefined reference to `rt2x00pci_flush_queue'
drivers/built-in.o:(.rodata+0x4818): undefined reference to `rt2x00pci_regbusy_read'
make[5]: *** [vmlinux] Error 1
The missing functions are provided by the rt2x00pci
module. This module is only selected by the rt2800pci
driver if PCI support is enabled in the kernel, because
some parts of the rt2x00pci code depends on PCI support.
PCI support is not available on the RT3x5x SoCs because
those have no PCI host controller at all.
Move the non PCI specific code from rt2x00pci into a
separate module. This makes it possible to use that
code even if PCI support is disabled. The affected
functions are used by all of the rt2x00 PCI drivers
so select the new module for those drivers.
Drivers that don't use chanctxes cannot perform VHT association because
they still use a "backward compatibility" pair of {ieee80211_channel,
nl80211_channel_type} in ieee80211_conf and ieee80211_local.
Signed-off-by: Karl Beldan <karl.beldan@rivierawaves.com>
[fix kernel-doc]
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Ivo van Doorn <IvDoorn@gmail.com>
Cc: Gertjan van Wingerde <gwingerde@gmail.com>
Cc: Helmut Schaa <helmut.schaa@googlemail.com>
Cc: users@rt2x00.serialmonkey.com (moderated for non-subscribers)
All drivers set this value to 1, so there is no need (currently) to let
drivers set this.
Therefor, remove the field; we can always add it back when it is needed.
Inspired by an earlier patch from Paul Fertser.
Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com>
Cc: Paul Fertser <fercerpav@gmail.com>
The various rt2x00 drivers use different methods to name the different
GPIO register fields indicating the GPIO pin value and the fields
indicating the direction.
Start using a unified naming scheme for the GPIO register fields:
- <csr>_VAL<x> for fields indicating the GPIO pin value.
- <csr>_DIR<x> for fields indicating the GPIO pin direction.
Acked-by: Ivo Van Doorn <ivdoorn@gmail.com>
We need to program the rfkill switch GPIO pin direction to input at
device initialization time, not only when the interface is brought up.
Doing this only when the interface is brought up could lead to rfkill
detecting the switch is turned on erroneously and inability to create
the interface and bringing it up.
Reported-and-tested-by: Andreas Messer <andi@bastelmap.de>
Cc: <stable@vger.kernel.org>
We can not pass NULL libconf->conf->channel to rt61pci_config() as it
is dereferenced unconditionally in rt61pci_config_lna_gain() subroutine.
Resolves:
https://bugzilla.kernel.org/show_bug.cgi?id=44361
Reported-and-tested-by: <dolohow@gmail.com>
Convert the existing uses of random_ether_addr to
the new eth_random_addr.
Acked-by: Hin-Tak Leung <htl10@users.sourceforge.net>
This patch converts the drivers in drivers/net/wireless/* to use
module_pci_driver() macro which makes the code smaller and a bit simpler.
Cc: "John W. Linville" <linville@tuxdriver.com>
Cc: Jiri Slaby <jirislaby@gmail.com>
Cc: Nick Kossifidis <mickflemm@gmail.com>
Cc: "Luis R. Rodriguez" <mcgrof@qca.qualcomm.com>
Cc: Simon Kelley <simon@thekelleys.org.uk>
Cc: Jouni Malinen <j@w1.fi>
Cc: Lennert Buytenhek <buytenh@wantstofly.org>
Cc: Christian Lamparter <chunkeey@googlemail.com>
Cc: Larry Finger <Larry.Finger@lwfinger.net>
Cc: linux-wireless@vger.kernel.org
Acked-by: Lennert Buytenhek <buytenh@wantstofly.org>
module_param(bool) used to counter-intuitively take an int. In
fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy
trick.
It's time to remove the int/unsigned int option. For this version
it'll simply give a warning, but it'll break next kernel version.
(Thanks to Joe Perches for suggesting coccinelle for 0/1 -> true/false).
Cc: netdev@vger.kernel.org
tx params should be configured per interface.
add ieee80211_vif param to the conf_tx callback,
and change all the drivers that use this callback.
The following spatch was used:
@rule1@
struct ieee80211_ops ops;
identifier conf_tx_op;
ops.conf_tx = conf_tx_op;
@rule2@
identifier rule1.conf_tx_op;
identifier hw, queue, params;
conf_tx_op (
- struct ieee80211_hw *hw,
+ struct ieee80211_hw *hw, struct ieee80211_vif *vif,
u16 queue,
const struct ieee80211_tx_queue_params *params) {...}
Signed-off-by: Eliad Peller <eliad@wizery.com>
TSF can be kept per vif.
Add ieee80211_vif param to set/get/reset_tsf, and move
the debugfs entries to the per-vif directory.
Update all the drivers that implement these callbacks.
When toggle_irq is called for PCI devices to disable device interrupts
it used tasklet_disable to wait for a possibly running tasklet to finish.
However, on SMP systems the tasklet might still be scheduled on another CPU.
Instead, use tasklet_kill to ensure that all scheduled tasklets are finished
before returning from toggle_irq.
Furthermore, it was possible that a tasklet reenabled its interrupt even
though interrupts have been disabled already. Fix this by checking the
DEVICE_STATE_ENABLED_RADIO flag before reenabling single interrupts
during tasklet processing.
While at it also enable/kill the TBTT and PRETBTT tasklets in the
toggle_irq callback and only use tasklet_kill in stop_queue to wait
for a currently scheduled beacon update before returning.
Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com>
Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com>
Implementing this callback function will cause mac80211 refrain from
going to powersave state when there are still untransmitted TX frames
in the queues.
This would exactly mimic the behaviour of the legacy vendor driver which
also doesn't go in powersave mode if there are still TX frames that are not
transmitted.
This should make powersaving and rt2x00 a better couple.
Implement the get_antenna and set_antenna callback functions, which will
allow clients to control the antenna for all non-11n hardware (Antenna handling
in rt2800 is still a bit magical, so we can't use the set_antenna for those drivers
yet).
To best support the set_antenna callback some modifications are needed in the
diversity handling. We should never look at the default antenna settings to determine
if software diversity is enabled. Instead we should set the diversity flag when
possible, which will allow the link_tuner to automatically pick up the tuning.
With the get_ringparam callback function we can export ring parameters
to ethtool through the mac80211 interface.
Both USB and PCI drivers allow a system administrator to dynamically add
USB/PCI IDs to the device table that a driver supports via the
/sys/bus/{usb,pci,pci_express}/drivers/<driver-name>/new_id files.
However, for the rt2x00 drivers using this method currently crashes the
system with a NULL pointer failure.
This is due to the set-up of rt2x00 where the probe functions require a
rt2x00_ops structure in the driver_info field of the probed device. As
this field is empty for the dynamically added devices this fails for
these devices.
Fix this by introducing driver-specific probe wrappers that do nothing
but calling the bus-specific probe functions with the rt2x00_ops structure
as an argument, rather than depending on the driver_info field.
This allows the compiler to perform the necessary bitfield calculations
during compile time instead of run time and thus reduces the number of
instructions to run during each tasklet invocation. This should improve
performance in the RX hotpath.
This comes at the cost of a slight increase in the module size (for
example rt2800pci):
Before:
14133 832 4 14969 3a79 drivers/net/wireless/rt2x00/rt2800pci.ko
After:
14149 832 4 14985 3a89 drivers/net/wireless/rt2x00/rt2800pci.ko
When powersaving is enabled, assocaition times are very high
(for WPA2 networks, the time can easily be around the 3 seconds).
This is caused, because the flushing of the queues takes
too much time. Without the flushing callback mac80211 assumes
a timeout of 100ms while scanning. Limit all flush waiting
loops to the same maximum.
We can apply this maximum by passing the drop status to the
driver, which makes sure the driver performs extra actions
during the waiting for the queue to become empty.
After these changes, association times fall within the
healthy range of ~0.6 seconds with powersaving enabled.
The difference between association time between powersaving
enabled and disabled is now only ~0.1 second (which can also
be due to the measuring method).
The number of flags defined for the rt2x00dev->flags field,
has been growing over the years. Currently we are approaching
the maximum number of bits which are available in the field.
A secondary problem, is that one part of the field are initialized only
during boot, because the driver requirements are initialized or device
requirements are loaded from the EEPROM. In both cases, the flags are
fixed and will not change during device operation. The other flags are
the device state, and will change frequently. So far this resulted in the fact
that for some flags, the atomic bit accessors are used, while for the others
the non-atomic variants are used.
By splitting the flags up into a "flags" and "cap_flags" we can put all flags
which are fixed inside "cap_flags". This field can then be read non-atomically.
In the "flags" field we keep the device state, which is going to be read atomically.
This adds more room for more flags in the future, and sanitizes the field access methods.
Instead of receiving an unlimited number of frames, stop after 16
entries and reschedule the rxdone tasklet. This allows other tasklets
to be run inbetween.
The PCI device irqmask is locked by a spin_lock. Currently
spin_lock_irqsave is used everywhere. To reduce the locking overhead
replace spin_lock_irqsave in hard irq context with spin_lock and in
soft irq context with spin_lock_irq.
"ifs" is only used by no-HT devices. Move it into the plcp substruct and
fill in the value only for no-HT devices.
HT and no-HT rt2x00 devices use a partly different TX descriptor.
Optimize the tx desciptor memory layout by putting the PLCP and HT
substructs into a union and introduce a new driver flag to decide which
TX desciptor format is used by the device.
This saves us the expensive PLCP calculation fOr HT devices and the HT
descriptor setup on no-HT devices.
In some cases (tx path for example) we don't need to check for non-tx
queues in rt2x00queue_get_queue. Hence, introduce a new method
rt2x00queue_get_tx_queue that is only valid for tx queues and use it in
places where only tx queues are valid.
Furthermore, this new method is quite short and as such can be inlined
to avoid the function call overhead.
This only converts the txdone functions of drivers that don't use an ATIM
queue and the generic tx path.
Commit 739fd94 ("rt2x00: Pad beacon to multiple of 32 bits")
added calls to skb_pad() without checking the return value,
which could cause problems if any of those calls does happen
to fail. Add checks to prevent this from happening.
Signed-off-by: Seth Forshee <seth.forshee@canonical.com>
Acked-by: Ivo van Doorn <IvDoorn@gmail.com>
Both rt61pci and rt73usb check the Michael MIC in hardware and strip the
Michael MIC from received frames. This is perfectly allowed by mac80211 as
long as this is properly reported to mac80211.
Both these drivers reported the Michael MIC handling properly to mac80211, but
still contained a FIXME comment on this, which is not needed to be handled, since
mac80211 doesn't really need the Michael MIC in this case.
Remove STATE_RADIO_IRQ_OFF_ISR and STATE_RADIO_IRQ_ON_ISR as they are
not used anymore.
Fix interrupt processing on slow machines by using individual tasklets
for each different device interrupt. This ensures that while a RX or TX
status tasklet is scheduled only the according device interrupt is
masked and other interrupts such as TBTT can still be processed.
Also, this allows us to use tasklet_hi_schedule for TBTT processing
which is required to not send out beacons with a wrong DTIM count (due
to delayed periodic beacon updates). Furthermore, this improves the
latency between the TBTT and sending out buffered multi- and broadcast
traffic.
As a nice bonus, the interrupt handling overhead should be much lower.
Compile-tested only.
This patch allows to dynamically remove beaconing interfaces without
shutting beaconing down on all interfaces.
The only place to start and stop beaconing are now the start- and
stop_queue callbacks. Hence, we can remove some register writes during
interface bring up (config_intf) and only write the correct sync mode
to the register there.
When multiple beaconing interfaces are present we should enable
beaconing as soon as mac80211 enables beaconing on at least one of
them. The beacon queue gets stopped when the last beaconing
interface was stopped by mac80211. Therefore, introduce another
interface counter to keep track ot the number of enabled beaconing
interfaces and start or stop the beacon queue accordingly.
To allow single interfaces to stop beaconing, add a new driver
callback clear_beacon to clear a single interface's beacon without
affecting the other interfaces. Don't overload the clear_entry callback
for clearing beacons as that would introduce additional overhead
(check for each TX queue) into the clear_entry callback which is used
on the drivers TX/RX hotpaths.
Furthermore, the write beacon callback doesn't need to enable beaconing
anymore but since beaconing should be disabled while a new beacon is
written or cleared we still disable beacon generation and enable it
afterwards again in the driver specific callbacks. However, beacon
related interrupts should not be disabled/enabled here, that's solely
done from the start- and stop queue callbacks. It would be nice to stop
the beacon queue just before the beacon update and enable it afterwards
in rt2x00queue itself instead of the current implementation that relies
on the driver doing the right thing. However, since start- and
stop_queue are mutex protected we cannot use them for atomic beacon
updates.
Pad beacon to a multiple of 32 bits in preparation for the change
from memcpy_toio() to __iowrite32_copy() in register_multiwrite().
Signed-off-by: Wolfgang Kufner <wolfgang.kufner@gmail.com>
The Queue names were incorrectly copied from the legacy drivers,
as a result the queue names were inversed to what was expected.
This renames the queues using this mapping:
QID_AC_BK -> QID_AC_VO (priority 0)
QID_AC_BE -> QID_AC_VI (priority 1)
QID_AC_VI -> QID_AC_BE (priority 2)
QID_AC_VO -> QID_AC_BK (priority 3)
Note that this was a naming problem only, which didn't affect
the assignment of frames to their respective queues.
As part of the queue refactoring, change the queue callback
function names to have 3 different actions: start, kick & stop.
We can now also remove the STATE_RADIO_RX_ON/STATE_RADIO_RX_OFF
device_state flags, and replace the usage with using the
start_queue/stop_queue callback functions.
This streamlines the RX queue handling to the
similar approach as all other queues.
As part of the queue refactoring, we now introduce
3 queue commands: start, kick, stop.
- Start: will enable a queue, for TX this will
not mean anything, while for beacons and RX
this will update the registers to enable the queue.
- Kick: This will kick all pending frames to
the hardware. This is needed for the TX queue
to push all frames to the HW after the queue
has been started
- Stop: This will stop the queue in the hardware,
and cancel any pending work (So this doesn't
mean the queue is empty after a stop!).
Move all code from the drivers into the appropriate
functions, and link those calls to the old rt2x00lib
callback functions (we will fix this later when we
refactor the queue control inside rt2x00lib).
Commit 0204464329c17ba6d293e1899f71223599a0e582 "Check for specific changed
flags when updating the erp config" changed the way in which a new beacon
interval gets handled. However, due to a bug in rt2800usb and rt2800pci the
beacon interval was reset during each scan, thus causing problems in AdHoc
mode.
Fix this by not cleaning up the beacon interval when killing the beacon queue
but just prevent the device from sending out beacons.
Reported-by: Wolfgang Kufner <wolfgang.kufner@gmail.com>
As part of the queue refactoring, the rt2x00lib_toggle_rx
can be removed and replaced with the call directly to
the set_device_state callback function.
We can remove the STATE_RADIO_RX_ON_LINK and
STATE_RADIO_RX_OFF_LINK, as it was only used for
special behavior inside rt2x00lib rather then the
drivers.
Implement a basic flush callback function, which simply loops
over all TX queues and waits until all frames have been transmitted
and the status reports have been gathered.
At this moment we don't support dropping any frames during the
flush, but mac80211 will only send 'false' for this argument anyway,
so this is not important at this time.
The tx descriptor values qid, cw_min, cw_max and aifs are directly
accessible through the tx entry struct. So there's no need to copy
them into the tx descriptor and passing them to the indiviual drivers.
Instead we can just get the correct value from the tx entry.
