commit 8d1331b37d5b656a7a8e561f8e9d7661dd00c910 upstream.
During initialization each driver reads the default TX power
for each individual channel. However mac80211 only accepts the
maximum value (which is also handled as default value).
As a result, the TX power of the device was being limited to
the default value, which is often quite low compared to the
real maximum acceptable value.
This patch allows each driver to set the maximum value on a
per-channel basis which is forwarded to mac80211. The default
value will be preserved for now, in case we want to update
mac80211 to differentiate between the maximum and default txpower.
This fixes bug complaining about limited TX power values like:
https://bugzilla.kernel.org/show_bug.cgi?id=16358
Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com>
Acked-by: Helmut Schaa <helmut.schaa@googlemail.com>
Using the set_tim callback without managing the DTIM count and the
broad- and multicast buffering in hw, fw or the driver results in wrong
DTIM count values being sent out in beacons. Since all PCI drivers
fetch new beacons periodically and hence get an updated TIM we can just
remove the set_tim callback from these.
The rt2x00 USB drivers don't update the beacon periodically and thus
rely on the set_tim callback to get a correct TIM for beacon
transmission. USB devices still suffer from the DTIM count being wrong
under some circumstances but removing the set_tim callback from these
would cause more harm then good.
Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com>
Use threaded interrupts for all rt2x00 PCI devices.
This has several generic advantages:
- Reduce the time we spend in hard irq context
- Use non-atmic mac80211 functions for rx/tx
Furthermore implementing broad- and multicast buffering will be
much easier in process context while maintaining low latency and
updating the beacon just before transmission (pre tbtt interrupt)
can also be done in process context.
While scanning the link tuner must be disabled. Otherwise
it will interfere with receiving all beacons for each channel
due to changing sensitivity levels.
Rename CONFIG_DISABLE_LINK_TUNING to DRIVER_SUPPORT_LINK_TUNING
Link tuning support is not only based on EEPROM decisions, but
also if the device actually supports it.
Currently only rt2500usb doesn't support link tuning because
of hardware problems. But rt2800usb is also suspected of having
problems with link tuning.
Fix rt61pci beacon updates in the same way as rt2800pci. rt61pci didn't
update the beacon template after each beacon interval, resulting in the
DTIM count being incorrect (if DTIM period > 1). Fix this by calling
rt2x00lib_beacondone after the current beacon was sent out.
Now that the write_tx_data functions are merged, also merge the relevant
parts of the txdone handling into common code, rather than {usb,pci}
specific code.
Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com>
Now that rt2x00pci_write_tx_data and rt2x00usb_write_tx_data are similar
we can merge them in a single function in rt2x00queue.c.
Similar to rt2800pci, remove the check for duplicate
register reading, and instead limit the for-loop to
the maximum number of TX entries inside a queue.
Acked-by: Gertjan van Wingerde <gwingerde@gmail.com>
Explicitly enable the usage of fallback rates for
the transmission of frames with rt61pci and rt73usb hardware.
Note that for txdone reporting, only rt61pci is capable of
reporting the fallback rates, for USB it is not possible
to determine the number of retries. However the device will
use the fallback rates, so it might still help in the performance.
Instead of fiddling with the skb->data pointer and thereby risking
out of bounds accesses, properly reserve the space needed in an
skb for descriptors.
Acked-by: Ivo van Doorn <IvDoorn@gmail.com>
Not all the devices require a TX descriptor to be written (i.e. rt2800
device don't require them). Push down the creation of the TX descriptor
to the device drivers so that they can decide for themselves whether
a TX descriptor is to be created.
(Based on a patch created by Ondrej Zary)
In some circumstances the Ralink devices do not properly go to sleep
or wake up, with timeouts occurring.
Fix this by retrying telling the device that it has to wake up or
sleep.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
The handling of tx descriptors for beacons can be simplified by updating
write_tx_desc implementations of each driver to write directly to the
queue entry descriptor instead of to a provided memory area.
This is also a preparation for further clean ups where descriptors are
properly reserved in the skb instead of fiddling with the skb data
pointer.
Where possible, write the tx descriptor words from start to end, to
follow a logical ordering of words.
Where this is not possible (in rt2400pci, rt2500pci and rt61pci) add
a comment as to why word 0 needs to be written last.
The buffer address descriptor word is not part of the TXINFO structure
needed for beacons. The current writing of that word for beacons is
therefore an out-of-bounds write.
Fix this by only writing the buffer address descriptor word for TX
queues.
drivers/net/wireless/ath/ar9170/main.c
Preparation to fix rt2800 beaconing.
All of the driver's kick_tx_queue callback functions treat the TX queue
for beacons in a special manner.
Clean this up by integrating the kicking of the beacon queue into the
write_beacon callback function, and let the generic code no longer call
the kick_tx_queue callback function when updating the beacon.
We should simply follow what the hardware told us it has done.
drivers/net/wireless/libertas_tf/cmd.c
drivers/net/wireless/libertas_tf/main.c
And use it consistently in the chipset drivers.
Preparation for further clean ups.
Documentation/feature-removal-schedule.txt
drivers/net/wireless/ath/ath5k/phy.c
drivers/net/wireless/wl12xx/wl1271_main.c
This is needed to wake up the device automatically for receiving beacons,
and is required for proper powersave handling.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Documentation/filesystems/proc.txt
arch/arm/mach-u300/include/mach/debug-macro.S
drivers/net/qlge/qlge_ethtool.c
drivers/net/qlge/qlge_main.c
drivers/net/typhoon.c
drivers/net/wireless/iwlwifi/iwl-core.h
drivers/net/wireless/rt2x00/rt2800pci.c
The recent rt2800 devices are no longer really identified by their PCI
ID's, but rather by the contents of their CSR0 register. Also for the
other chipsets is the contents of this CSR0 register important.
Change the chipset determination logic to be more aligned with the rt2800
model.
Preparation for the support of rt3070 / rt3090 based devices.
Don't set the RT chipset for a device from within the generic PCI/SOC code,
but rather from the individual drivers, so that individual drivers have
more control over what RT chipset is set.
Preparation for chip handling updates for rt2800 devices.
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
In particular, several occurances of funny versions of 'success',
'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address',
'beginning', 'desirable', 'separate' and 'necessary' are fixed.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Joe Perches <joe@perches.com>
Cc: Junio C Hamano <gitster@pobox.com>
get_tx_stats() will be removed from mac80211.
Compile-tested only.
Signed-off-by: Kalle Valo <kalle.valo@iki.fi>
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section
in every case.
Let each of them take a struct rt2x00_dev pointer as argument instead of
a mixture of struct rt2x00_chip and struct rt2x00_dev pointers.
Preparation for further clean ups in the rt2x00 chip handling, especially
for rt2800 devices.
We've had many reports of rt61pci failures with powersaving enabled.
Therefore, as a stop-gap measure, disable powersaving of the rt61pci
until we have found a proper solution.
Also disable powersaving on rt2800pci as it most probably will show
the same problem.
Cc: stable@kernel.org
Set the value of extra_tx_headroom in a central place, rather than in each
of the drivers. This is preparatory for taking alignment space into account
in the TX headroom requested by rt2x00.
Clean up the use of whitespace in the initialization of the rt2x00_ops
structures. This is preparatory for a later patch that adds members
to that structure, which require different whitespace alignment.
Some drivers (rt2800* most notably) cannot set the RF and RT chipset in
the correct order to have the information logging in rt2x00_set_chip
be correct.
Fix this by decoupling the setting of the chipset information from the
logging of the chipset information so that drivers can determine
themselves when all information is set.
fix some typos and punctuation in comments
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com>
As mentioned on the linux-wireless mailing list, the current copyright
statements in the rt2x00 are meaningless, as the rt2x00 project is
not even a formal legal entity. Therefore it is better to replace
the existing copyright statements with copyright statements for the
people that actually wrote the code.
Note: Updated to the best of my knowledge with respect to who
contributed considerable amounts of code.
CC: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
The calculated values for the ACK timeout and ACK
consume time are different then the values as
used by the Legacy drivers.
After testing from James Ledwith it appeared that
the calculated values caused a high amount of TX
failures, and the values from the Legacy drivers
were the most optimal to prevent TX failure due to
excessive retries.
The symptoms of this problem:
- Rate control module always falls back to 1Mbs
- Low throughput when bitrate was fixed
Possible side-effects (not confirmed but highly likely)
- Problems with DHCP
- Broken connections due to lack of probe response
This should fix at least:
Kernel bugzilla reports: [13362], [13009], [9273]
Fedora bugzilla reports: [443203]
but possible some additional bugs as well.
When beacon is being updated to refresh TIM (AP mode), beacon frames are
de-synchronizing (i.e. two neighbor beacon frames - before and after
update - are being transmitted with a wrong time interval).
That is because xxx_write_beacon should disable beacon generation only
while beacon data are being uploaded to the device, but it should not
disable the beacon clock.
Signed-off-by: Igor Perminov <igor.perminov@inbox.ru>
This patch implements FIF_PSPOLL filter flag support in rt2x00 drivers,
which has been introduced in mac80211 (see
http://marc.info/?l=linux-wireless&m=124897986330807&w=2).
Unloading rt61pci can leave the device in such state that reloading
rt61pci would fail to reinitialize it. Bogus data would be read from
the EEPROM and the RF version won't be recognized.
It appears that unloading rt61pci with power saving enabled would have
such effect. To initialize the device properly, SOFT_RESET_CSR should
be set to the same value as rt61pci_config_ps() uses to wake up the
device.
Signed-off-by: Pavel Roskin <proski@gnu.org>
Fix a bunch of spelling errors in the rt2x00 drivers
Signed-off-by: Luis Correia <luis.f.correia@gmail.com>
Implement set_tim callback for all rt2x00 drivers, this makes the
device wake up powersaving stations properly while in AP mode.
The only way to update the beacon is by simply calling mac80211 and
requesting the new beacon. This means the set_tim() event is mostly the
same as a beacon_done() event which was already defined in rt2x00lib.
Signed-off-by: Stefan Steuerwald <salsasepp@googlemail.com>
Remove the input_polldev from rt2x00 and replace it with
the rfkill interface offered by the wiphy structure. This
simplifies the entire rfkill handling in rt2x00 and allows
us to remove the CONFIG_RT2X00_LIB_RFKILL option and always
enables rfkill capabilities.
This removes the last usage of beacon_int inside the iee80211_config
structure from rt2x00. The attempt is a bit hackish, and subject to
change in the future when the entire rt2x00_dev structure is
cleaned up and restructured.
IEEE80211_CONF_CHANGE_BEACON_INTERVAL was deprecated a month ago,
it is about time to remove all usage from the rt2x00 drivers and
use the correct beacon interval configuration through the bss_info
structure.
