In commit b0302ab, the rtlwifi family of drivers was converted to use
asynchronous firmware loading. Unfortumately, the implementation was
racy, and the ieee80211 routines could be started before rtl_init_core()
was called to setup the data.
This patch fixes the bug noted in https://bugzilla.kernel.org/show_bug.cgi?id=43187.
Reported-by: Joshua Roys <Joshua.Roys@gtri.gatech.edu>
Tested-by: Neptune Ning <frostyplanet@gmail.com>
Cc: Stable <stable@vger.kernel.org> [3.3]
Under some circumstances, a PCI-based driver reports the following OOPs:
Mar 19 08:14:35 kvothe kernel: [ 6584.626011] Oops: 0000 [#1] SMP
--snip--
Mar 19 08:14:35 kvothe kernel: [ 6584.626011] Pid: 19627, comm: rmmod
Not tainted 3.2.9-2.fc16.x86_64 #1 LENOVO 05962RU/05962RU
Mar 19 08:14:35 kvothe kernel: [ 6584.626011] RIP:
0010:[<ffffffffa0418d39>] [<ffffffffa0418d39>]
rtl92ce_get_desc+0x19/0xd0 [rtl8192ce]
--snip--
Mar 19 08:14:35 kvothe kernel: [ 6584.626011] Process rmmod (pid:
19627, threadinfo ffff880050262000, task ffff8801156d5cc0)
Mar 19 08:14:35 kvothe kernel: [ 6584.626011] Stack:
Mar 19 08:14:35 kvothe kernel: [ 6584.626011] 0000000000000002
ffff8801176c2540 ffff880050263ca8 ffffffffa03348e7
Mar 19 08:14:35 kvothe kernel: [ 6584.626011] 0000000000000282
0000000180150014 ffff880050263fd8 ffff8801176c2810
Mar 19 08:14:35 kvothe kernel: [ 6584.626011] ffff880050263bc8
ffffffff810550e2 00000000000002c0 ffff8801176c0d40
Mar 19 08:14:35 kvothe kernel: [ 6584.626011] Call Trace:
Mar 19 08:14:35 kvothe kernel: [ 6584.626011] [<ffffffffa03348e7>]
_rtl_pci_rx_interrupt+0x187/0x650 [rtlwifi]
--snip--
Mar 19 08:14:35 kvothe kernel: [ 6584.626011] Code: ff 09 d0 89 07 48
83 c4 08 5b 5d c3 66 0f 1f 44 00 00 55 48 89 e5 53 48 83 ec 08 66 66
66 66 90 40 84 f6 89 d3 74 13 84 d2 75 57 <8b> 07 48 83 c4 08 5b 5d c1
e8 1f c3 0f 1f 00 84 d2 74 ed 80 fa
[<ffffffffa0418d39>] rtl92ce_get_desc+0x19/0xd0 [rtl8192ce]
Mar 19 08:14:35 kvothe kernel: [ 6584.626011] RSP <ffff880050263b58>
Mar 19 08:14:35 kvothe kernel: [ 6584.626011] CR2: 00000000000006e0
Mar 19 08:14:35 kvothe kernel: [ 6584.646491] ---[ end trace
8636c766dcfbe0e6 ]---
This oops is due to interrupts not being disabled in this particular path.
Reported-by: Dave Airlie <airlied@gmail.com>
Tested-by: Dave Airlie <airlied@gmail.com>
In https://bugzilla.kernel.org/show_bug.cgi?id=42976, a system with driver
rtl8192se used as an AP suffers from "Out of SW-IOMMU space" errors. These
are caused by the DMA buffers used for beacons never being unmapped.
This bug was also reported at
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/961618
Reported-and-Tested-by: Da Xue <da@lessconfused.com>
Fixes problem where caller would think routine succeeded when it failed
leading to divide by zero panic.
(This also reverts an earlier attempt, commit 42bc0c97 "rtlwifi: Return
correct failure code on error". -- JWL)
Signed-off-by: Simon Graham <simon.graham@virtualcomputer.com>
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
Callers of rtl_pci_init expect zero to be returned on error. Returning
the error code leads to, amongst other things, divide by zero panics
attempting to use the ring size that is set to zero.
Handle previous allocation failures when freeing device memory
Memory allocated by ieee80211_alloc_hw() will get orphaned
if any subsequent initializations fail.
Also don't pci_set_drvdata(pdev, NULL) until just before disabling
the PCI device. Functions called by rtl_deinit_core(hw) may eventually need
the context (when its actually implemented).
Cc: Larry Finger <Larry.Finger@lwfinger.net>
Cc: Chaoming Li <chaoming_li@realsil.com.cn>
Cc: John W. Linville <linville@tuxdriver.com>
Cc: linux-wireless@vger.kernel.org
Cc: netdev@vger.kernel.org
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
the return value from _rtl_pci_switch_clk_req is not used by any of its callers.
Signed-off-by: Devendra.Naga <devendra.aaru@gmail.com>
This patch addresses a kernel bugzilla report and two recent mail threads.
The kernel bugzilla report is https://bugzilla.kernel.org/show_bug.cgi?id=42632,
which reports a udev timeout on boot.
The first mail thread, which was on LKML (http://lkml.indiana.edu/hypermail/
linux/kernel/1112.3/00965.html) was for a WARNING that occurs after a
suspend/resume cycle for rtl8192cu.
The scond mail thread (http://marc.info/?l=linux-wireless&m=132655490826766&w=2)
concerned changes in udev that break drivers that delay while firmware is loaded
on modprobe.
This patch converts all rtlwifi-based drivers to use the asynchronous firmware
loading mechanism. Drivers rtl8192ce, rtl8192cu and rtl8192de share a common
callback routine. Driver rtl8192se needs different handling of the firmware,
thus it has its own code.
Although the rtlwifi family of devices contains 11 copies of the pr_fmt
macro, the macro is not defined for all routines that need it. By moving
the macro to wifi.h, a single copy is available for all routines.
In https://bugzilla.redhat.com/show_bug.cgi?id=771656, a kernel bug was
triggered due to a failed skb allocation that was not checked. This event
lead to an audit of all memory allocations in the complete rtlwifi family
of drivers. This patch fixes the rest.
Consolidate printks to avoid possible message interleaving
and reduce the object size.
Remove unnecessary RT_ASSERT parentheses.
Align arguments.
Coalesce formats.
Remove unnecessary __func__ use as the macro uses it.
$ size drivers/net/wireless/rtlwifi/built-in.o*
588901 55333 127216 771450 bc57a drivers/net/wireless/rtlwifi/built-in.o.new
590002 55333 127560 772895 bcb1f drivers/net/wireless/rtlwifi/built-in.o.old
Remove unnecessary RT_TRACE parentheses.
Miscellaneous typo and grammar fixes.
Add missing newlines to formats.
Remove duplicate KERN_DEBUG prefixes.
Coalesce formats.
Align arguments.
594841 55333 129680 779854 be64e drivers/net/wireless/rtlwifi/built-in.o.new
607022 55333 138720 801075 c3933 drivers/net/wireless/rtlwifi/built-in.o.old
DaveM said:
Please, this kind of stuff rots forever and not using bool properly
drives me crazy.
Joe Perches <joe@perches.com> gave me the spatch script:
bool b;
-b = 0
+b = false
bool b;
-b = 1
+b = true
I merely installed coccinelle, read the documentation and took credit.
Leaving leisure power save mode can take some time, so it's better to
perform that action in process context with interrupts enabled. This
patch changes lps_leave tasklet to work.
Reported-by: Philipp Dreimann <philipp@dreimann.net>
Tested-by: Larry Finger <Larry.Finger@lwfinger.net>
Cc: Mike McCormack <mikem@ring3k.org>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
The recent discussion regarding an incorrect return of IRQ_HANDLED
from rt2800pci caused me to look at this PCI interrupt routine. I
discovered that changes were needed.
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux
drivers/net/wireless/iwlegacy/iwl-debugfs.c
drivers/net/wireless/iwlegacy/iwl-rx.c
drivers/net/wireless/iwlegacy/iwl-scan.c
drivers/net/wireless/iwlegacy/iwl-tx.c
include/net/bluetooth/bluetooth.h
The interrupt routine for PCI devices has a special exit that
executes the same instructions as does the normal exit.
These were getting the macros from an implicit module.h
include via device.h, but we are planning to clean that up.
drivers/net: Add export.h to wireless/brcm80211/brcmfmac/bcmsdh.c
This relatively recently added file uses EXPORT_SYMBOL and hence
needs export.h included so that it is compatible with the module.h
split up work.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1745 commits)
dp83640: free packet queues on remove
dp83640: use proper function to free transmit time stamping packets
ipv6: Do not use routes from locally generated RAs
|PATCH net-next] tg3: add tx_dropped counter
be2net: don't create multiple RX/TX rings in multi channel mode
be2net: don't create multiple TXQs in BE2
be2net: refactor VF setup/teardown code into be_vf_setup/clear()
be2net: add vlan/rx-mode/flow-control config to be_setup()
net_sched: cls_flow: use skb_header_pointer()
ipv4: avoid useless call of the function check_peer_pmtu
TCP: remove TCP_DEBUG
net: Fix driver name for mdio-gpio.c
ipv4: tcp: fix TOS value in ACK messages sent from TIME_WAIT
rtnetlink: Add missing manual netlink notification in dev_change_net_namespaces
ipv4: fix ipsec forward performance regression
jme: fix irq storm after suspend/resume
route: fix ICMP redirect validation
net: hold sock reference while processing tx timestamps
tcp: md5: add more const attributes
Add ethtool -g support to virtio_net
Fix up conflicts in:
- drivers/net/Kconfig:
The split-up generated a trivial conflict with removal of a
stale reference to Documentation/networking/net-modules.txt.
Remove it from the new location instead.
- fs/sysfs/dir.c:
Fairly nasty conflicts with the sysfs rb-tree usage, conflicting
with Eric Biederman's changes for tagged directories.
Fast-forward merge with Linus to be able to merge patches
based on more recent version of the tree.
Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com>
The PCIe driver used raw reads and writes on the PCIe hardware.
As all of these are only affecting the configuration space, all of
then can be converted to pci_{read,write}_config_XX calls.
This driver uses information from the self member of the pci_bus struct to
get information regarding the bridge to which the PCIe device is attached.
Unfortunately, this member is not established on all architectures, which
leads to a kernel oops.
Skipping the entire block that uses the self member to determine the bridge
vendor will only affect RTL8192DE devices as that driver sets the ASPM support
flag differently when the bridge vendor is Intel. If the self member is
available, there is no functional change.
This patch fixes Bugzilla No. 40212.
Reported-by: Hubert Liao <liao.hubertt@gmail.com>
Cc: Stable <stable@kernel.org> [back to 2.6.38]
This should be unnecessary if synchronize_irq is used.
Signed-off-by: Mike McCormack <mikem@ring3k.org>
Use PCI_VENDOR_ID_* from pci_ids.h instead of creating #define locally.
Signed-off-by: Jon Mason <jdmason@kudzu.us>
The PCIE capability offset is saved during PCI bus walking. It will
remove an unnecessary search in the PCI configuration space if this
value is referenced instead of reacquiring it.
Also, remove unnecessary and unused #defines for PCI.
drivers/net/wireless/iwlwifi/iwl-tx.c
offchan_deley should be offchan_delay
r8192e_pci
There are two devices with PCI ID 0x10ec:0x8192, namely RTL8192E and
RTL8192SE. The method of distinguishing them is by the revision ID
at offset 0x8 of the PCI configuration space. If the value is 0x10,
then the device uses rtl8192se for a driver.
Once we realize a bad packet was received, don't
waste time unmapping it, freeing it, then allocation
a new skb and mapping it, just resubmit the existing
skb.
drivers/net/wireless/iwlwifi/iwl-agn-rxon.c
drivers/net/wireless/rtlwifi/pci.c
In the case we fail to allocate a new skb, the old skb should
be resubmitted unmodified.
Fixes bug introduced in a9e12869758430424804.
Should pass along packet if there's no CRC and no hardware error.
Ownership of an rx buffer should only be given to the hardware
after all other changes are written, otherwise there's
a potential race.
This removes the need to use IRQ safe spinlocks in many places.
_rtl_pci_rx_interrupt uses rtlpci->rx_ring[rx_queue_idx].idx a
few times, so store it in a separate variable.
Although a previous fix handles the kernel panics that result from
failure to allocate a new RX buffer, memory fragmentation can be
reduced if the amsdu_8k capability is disabled as new buffers need only
be of O(0), not O(2).
To handle amsdu_8k capability, the PCI routine of this driver must
allocate receive buffers of order 2. Under heavy load, this causes
fragmentation of memory. The present code releases the current buffer
before checking to see if a new one is availble. Recovery from
allocation failures is not possible, which results in kernel panics.
The fix is to reorder the code to check that a new buffer can be
allocated before the old one is released. If not possible, the
received frame is dropped and the old one is reused. Without this
change, it is impossible to transfer a 2 GB file without a kernel panic.
Cc: Stable <stable@vger.kernel.org> [2.6.{37,38,39}]
When this driver was initially submitted, the system would crash unless
ASPM was disabled. This problem has been fixed.
This patch also adds a printk that outputs the name of the firmware
file that is used.
Signed-off-by: Chaoming_Li <chaoming_li@realsil.com.cn>
Fix most sparse warnings in rtlwifi, rtl8192ce and rtl8192cu drivers.
rtl8192cu for addition of rtl8192se and rtl8192de
Change rtl8192ce routines phy and trx for addition of RTL8192SE and RTL8192DE.
In addition, make necessary modifications to rtl8192cu. This patch also
removes the temporary patches needed to enable intermediate steps to build
without error.
Convert usb routines for addition of RTL8192SE and RTL8192DE code
