path: root/drivers/net/wireless/ti/wl12xx/main.c
2021-07-20wlcore/wl12xx: Fix wl12xx get_mac error if device is in ELPTony Lindgren
[ Upstream commit 11ef6bc846dcdce838f0b00c5f6a562c57e5d43b ] At least on wl12xx, reading the MAC after boot can fail with a warning at drivers/net/wireless/ti/wlcore/sdio.c:78 wl12xx_sdio_raw_read. The failed call comes from wl12xx_get_mac() that wlcore_nvs_cb() calls after request_firmware_work_func(). After the error, no wireless interface is created. Reloading the wl12xx module makes the interface work. Turns out the wlan controller can be in a low-power ELP state after the boot from the bootloader or kexec, and needs to be woken up first. Let's wake the hardware and add a sleep after that similar to wl12xx_pre_boot() is already doing. Note that a similar issue could exist for wl18xx, but I have not seen it so far. And a search for wl18xx_get_mac and wl12xx_sdio_raw_read did not produce similar errors. Cc: Carl Philipp Klemm <philipp@uvos.xyz> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Kalle Valo <kvalo@codeaurora.org> Link: https://lore.kernel.org/r/20210603062814.19464-1-tony@atomide.com Signed-off-by: Sasha Levin <sashal@kernel.org>
2021-03-07wlcore: Fix command execute failure 19 for wl12xxTony Lindgren
[ Upstream commit cb88d01b67383a095e3f7caeb4cdade5a6cf0417 ] We can currently get a "command execute failure 19" error on beacon loss if the signal is weak: wlcore: Beacon loss detected. roles:0xff wlcore: Connection loss work (role_id: 0). ... wlcore: ERROR command execute failure 19 ... WARNING: CPU: 0 PID: 1552 at drivers/net/wireless/ti/wlcore/main.c:803 ... (wl12xx_queue_recovery_work.part.0 [wlcore]) (wl12xx_cmd_role_start_sta [wlcore]) (wl1271_op_bss_info_changed [wlcore]) (ieee80211_prep_connection [mac80211]) Error 19 is defined as CMD_STATUS_WRONG_NESTING from the wlcore firmware, and seems to mean that the firmware no longer wants to see the quirk handling for WLCORE_QUIRK_START_STA_FAILS done. This quirk got added with commit 18eab430700d ("wlcore: workaround start_sta problem in wl12xx fw"), and it seems that this already got fixed in the firmware long time ago back in 2012 as wl18xx never had this quirk in place to start with. As we no longer even support firmware that early, to me it seems that it's safe to just drop WLCORE_QUIRK_START_STA_FAILS to fix the error. Looks like earlier firmware got disabled back in 2013 with commit 0e284c074ef9 ("wl12xx: increase minimum singlerole firmware version required"). If it turns out we still need WLCORE_QUIRK_START_STA_FAILS with any firmware that the driver works with, we can simply revert this patch and add extra checks for firmware version used. With this fix wlcore reconnects properly after a beacon loss. Cc: Raz Bouganim <r-bouganim@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Kalle Valo <kvalo@codeaurora.org> Link: https://lore.kernel.org/r/20210115065613.7731-1-tony@atomide.com Signed-off-by: Sasha Levin <sashal@kernel.org>
2015-03-24wlcore: remove wl12xx_platform_dataEliad Peller
Now that we have wlcore device-tree bindings in place (for both wl12xx and wl18xx), remove the legacy wl12xx_platform_data struct, and move its members into the platform device data (that is passed to wlcore) Davinci 850 is the only platform that still set the platform data in the legacy way (and doesn't have DT bindings), so remove the relevant code/Kconfig option from the board file (as suggested by Sekhar Nori) Since no one currently uses wlcore_spi, simply remove its platform data support (DT bindings will have to be added if someone actually needs it) Signed-off-by: Luciano Coelho <luca@coelho.fi> Signed-off-by: Eliad Peller <eliad@wizery.com> Tested-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Kalle Valo <kvalo@codeaurora.org> Acked-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-03-24wl12xx: use frequency instead of enumerations for pdata clocksLuciano Coelho
Instead of defining an enumeration with the FW specific values for the different clock rates, use the actual frequency instead. Also add a boolean to specify whether the clock is XTAL or not. Change all board files to reflect this. Signed-off-by: Luciano Coelho <luca@coelho.fi> [Eliad - small fixes, update board file changes] Signed-off-by: Eliad Peller <eliad@wizery.com> Tested-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Kalle Valo <kvalo@codeaurora.org> Acked-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-01-09wlcore: enable sleep during AP mode operationKobi L
Enable ELP authorization in AP mode and enable the use of the wakeup bit in the ELP register. Introduce AP role sleep configuration which is disabled by default. When configured, it allows the AP to sleep when ELP is authorized for it. Signed-off-by: Kobi Leibovitch <kobi.lev100@gmail.com> Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
2015-01-09wlcore: add ability to reduce FW interrupts during suspendRam Amrani
Add the ability to mask FW interrupts on RX BA activity, PSM entry/exit and fast-link notifications. This is used when the host is suspended in order to decrease redundant wake ups. Signed-off-by: Ram Amrani <ramrani@ti.com> Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
2014-10-20net: wireless: ti: wl12xx: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-07-15wlcore/wl18xx/wl12xx: convert bitmaps to unsigned longsEliad Peller
The *_bit operations expect unsigned longs. Instead of casting the pointers, simply define various bitmaps as unsigned long (instead of u32). Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2014-02-13wlcore: wl18xx: allow CCK rates for AP modeArik Nemtsov
12xx chips allow only OFDM rates in AP mode for BT-Coex purposes. This is no longer required in 18xx chips, starting with FW 8.6.0.0.8. Update the min allowed FW version in 18xx to support this functionality. Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2014-02-13wlcore/wl12xx/wl18xx: configure iface_combinations per-hwEliad Peller
Each hw supports a different iface combinations. Define the supported combinations in each driver, and save it in wl->iface_combinations. Since each driver defines its own combinations now, it can also define its max supported channels, so we no longer need to save and set it explicitly in wlcore. Update wl18xx interface combinations to allow multiple APs. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2014-02-13wlcore/wl12xx/wl18xx: configure max_stations per-hwEliad Peller
Each hw supports a different max stations (connected to the same ap). add a new wl->max_ap_stations and use it instead of the current common AP_MAX_STATIONS. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2014-02-13wlcore/wl12xx/wl18xx: configure num_links per-hwEliad Peller
Upcoming fw versions will have different max links support (according to the hw). Get ready for it by configuring wl->num_links per-hw, instead of using the const WL12XX_MAX_LINKS. However, continue using WLCORE_MAX_LINKS in order to simplify structs declarations (we use it in multiple bitmaps, and converting them to dynamic arrays is just cumbersome). Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2014-02-13wlcore/wl12xx/wl18xx: simplify fw_status handlingEliad Peller
Instead of splitting the fw_status into 2 and using some complex calculations, read the fw status and let each low-level driver (wl12xx/wl18xx) convert it into a common struct. This is required for the upcoming fw api changes, which break the current logic anyway. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-10-23wlcore/wl18xx/wl12xx: FW log params per chip archIgal Chernobelsky
FW memory block size and FW log end marker parameters are added to wl structure and are initialized per chip architecture. convert_hwaddr hw operation is added to convert chip dependent FW internal address. Copy from FW log is also simplified to copy the entire memory block as FW logger utility is repsponsible for parsing of FW log content. Signed-off-by: Igal Chernobelsky <igalc@ti.com> Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Luciano Coelho <luciano.coelho@intel.com>
2013-10-23wl12xx/wl18xx: update default fw logger's settingsIdo Reis
update the fw logger mode to continuous, and output to dbgpins (uart). Signed-off-by: Ido Reis <idor@ti.com> Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Luciano Coelho <luciano.coelho@intel.com>
2013-10-23wlcore: add ap_event_maskEliad Peller
Add new ap_event_mask field, to indicate events that should be unmasked only when there's an ap interface. This is done in order to avoid spurious wakeups when we don't care about the incoming event anyway. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Luciano Coelho <luciano.coelho@intel.com>
2013-09-26wireless: wl12xx: use dev_get_platdata()Jingoo Han
Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. This is a cosmetic change to make the code simpler and enhance the readability. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-03-25wlcore: set max num of Rx BA sessions per chipIgal Chernobelsky
Maximum number of supported RX BA sessions depends on chip type. wl18xx supports 5 RX BA sessions while wl12xx supports 3. Signed-off-by: Igal Chernobelsky <igalc@ti.com> Signed-off-by: Luciano Coelho <coelho@ti.com>
2013-02-08wlcore: remove if_ops from platform_dataLuciano Coelho
We can't pass pointers from the platform data to the modules, because with DT it cannot be done. Those pointers are not set by the board files anyway. It's the bus modules that set them, so they can be safely removed from the platform data without changing any board files. Create a new structure that the bus modules pass to wlcore. This structure contains the if_ops pointers and a pointer to the actual platform data. Signed-off-by: Luciano Coelho <coelho@ti.com> Reviewed-by: Felipe Balbi <balbi@ti.com>
2013-01-18Merge branch 'wl12xx-next' into for-linvilleLuciano Coelho
Conflicts: drivers/net/wireless/ti/wl12xx/main.c drivers/net/wireless/ti/wlcore/wlcore.h
2012-12-11wlcore: Always pass DMA-able buffers to mmc functionsIdo Yariv
Some of the mmc drivers initiate DMA transfers with buffers passed from higher layers. This means that the driver shouldn't ever pass non DMA-able buffers, such as ones that are unaligned, allocated on the stack or static. Fix a couple of calls to the mmc layer in which buffers which weren't necessarily DMA-able were passed. [Use sizeof(*wl->buffer_32) instead of sizeof(u32) -- Luca] Signed-off-by: Ido Yariv <ido@wizery.com> Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: Luciano Coelho <coelho@ti.com>
2012-12-11wlcore/wl18xx: change priority calculations for linksArik Nemtsov
Update the 18xx FW status private part to include Tx related link priorities. Introduce new HW ops to determine link priority per chip family. For 18xx the changes are: - Suspended links are at most low priority and Tx for them is stopped beyond the suspend threshold. - Active links now get their thresholds directly from FW - There's a new "stop" threshold for active links, at which point a link stops receiving new packets. Update the min 18xx FW version required to make sure suspended links bitmap is advertised by the FW. Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: Luciano Coelho <coelho@ti.com>
2012-12-11wlcore: increase scan dwell times if no activityEyal Shapira
There's a limit on scan dwell times of max 30ms in order to avoid degrading voip traffic which could be going on while scanning. However these dwell times increase the chance of missing out on nearby APs leading to partial scan results. Allow configuration of longer dwell times in case there no active interface (i.e. no STA associated or AP up). [Arik - count started vifs using an in-driver function] [Fixed some new checkpatch warnings regarding comments in the networking subsystem. -- Luca] Signed-off-by: Eyal Shapira <eyal@wizery.com> Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: Luciano Coelho <coelho@ti.com>
2012-12-11wlcore: add ACX_PEER_CAP commandEliad Peller
ACX_PEER_CAP command is just ACX_PEER_HT_CAP, but allows configuring the peer's support rates as well. this is needed because we start the station role when the remote rates are not known yet. the two commands should be unified in future fw versions, but for now add a new set_peer_cap per-hw op, that will use ACX_PEER_CAP for 18xx, and ACX_PEER_HT_CAP for 12xx. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: Luciano Coelho <coelho@ti.com>
2012-12-06wlcore/wl18xx/wl12xx: remove __dev* attributesBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Luciano Coelho <coelho@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-12-05wlcore: improved Tx scheduling algorithmArik Nemtsov
Prioritize EDCA by choosing the AC before anything else. Use the fast/slow link bitmap in FW to improve the scheduling algorithm for the multi-link scenario. Set packet thresholds to determine if a given link is high or low priority according to its speed. A slow link will be given high priority if the amount of packets queued for it in the FW is lower than the slow-threshold. Similarly, a fast link will be given high priority if the number of its packets queued in FW is smaller than the high-threshold. The improved algorithm: 1. Choose optimal AC according to FW utilization 2. Traversing the VIFs in a round-robin fashion, try to choose a high priority link. Links are traversed in a round-robin fashion inside a VIF. 3. If no high priority links are found, choose the first non-empty (low priority) link found in the round robin. Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: Luciano Coelho <coelho@ti.com>
2012-12-04wlcore/wl12xx: make sure session id is always zero for APArik Nemtsov
The 12xx FW doesn't support non-zero session ids for AP-mode. Introduce an appropriate quirk to make sure the session id is always zero when needed. Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: Luciano Coelho <coelho@ti.com>
2012-12-04wlcore/wl12xx/wl18xx: verify multi-role and single-role fw versionsLuciano Coelho
Previously we were only checking the single-role firmware version. Now add code to check for the firmware versions separately for each firmware type. Signed-off-by: Luciano Coelho <coelho@ti.com>
2012-12-04wlcore/wl12xx: remove deprecated FW version checkLuciano Coelho
We don't distinguish between STA and AP firmwares anymore, so the firmware version checking and quirks setting in wl12xx isn't needed anymore. Remove implementation of .identify_fw in wl12xx and deprecated definitions. Don't remove the op entirely from wlcore, because it may be needed for more fine-grained checking later. Signed-off-by: Luciano Coelho <coelho@ti.com>
2012-12-04wlcore/wl12xx: move wl12xx chip ID defines to the lower driverLuciano Coelho
Move wl12xx-specific chip ID macros to the wl12xx driver and rename them to 127X and 128X for clarity since both the "1" (2.4GHz) and the "3" (2.4GHz and 5GHz) variants use the same chip ID. Signed-off-by: Luciano Coelho <coelho@ti.com>
2012-12-04wlcore/wl18xx/wl12xx: add recovery settings to confYair Shapira
add support for recovery settings including bug_on_recovery and no_recovery options. These options can now be set using wl18xx-conf.bin file and wlconf tool. Signed-off-by: Yair Shapira <yair.shapira@ti.com> Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: Luciano Coelho <coelho@ti.com>
2012-12-04wlcore/wl18xx/wl12xx: separate channel count between chipsArik Nemtsov
18xx chips are capable of staying on 2 channels at the same time. Introduce a chip-family specific parameter to set the number of channels in the interface-combinations published by the driver. Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: Luciano Coelho <coelho@ti.com>
2012-11-28wlcore: configure dwell times according to scan typeEliad Peller
Allow configuring different dwell times to the different scan types (regular and scheduled). Add new configuration entry (dwell_time_dfs) to conf_scan_settings, in order to allow setting different values for normal scan and scheduled scan. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: Luciano Coelho <coelho@ti.com>
2012-11-27wlcore: update events enum/struct to new fw apiEliad Peller
The event mailbox in wl18xx has a different (non-compatible) structure. Create common functions in wlcore to handle the events, and call them from the chip-specific event mailbox parsers. This way, each driver (wl12xx/wl18xx) extracts the event mailbox by itself according to its own structure, and then calls the common wlcore functions to handle it. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Luciano Coelho <coelho@ti.com>
2012-11-27wlcore: update channel_switch/stop_channel_switch commandsEliad Peller
Some fields were added to the channel_switch and stop_channel_switch commands. Unfortunately, the new 18xx channel_switch struct is not backward compatible with the 12xx channel switch struct. Add a new channel_switch op to wlcore, and update the driver accordingly. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Luciano Coelho <coelho@ti.com>
2012-11-27wl18xx: increase MAX_CHANNELS_5GHZEliad Peller
Some regdomains have more than 23 valid 5ghz channels, so 18xx's MAX_CHANNELS_5GHZ was increased to 32. Since now we have different max 5ghz channels values for wl12xx and wl18xx, add a new wl->max_channels_5ghz field, and use it for scan channels configuration. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Luciano Coelho <coelho@ti.com>
2012-11-27wlcore: split 18xx and 12xx scan mechanismEliad Peller
The scan APIs of 12xx and 18xx are totally different. Use some common functions as much as possible (e.g. for setting scan channels), but split scan.c into chip-specific scan.c files, each implementing its own scan mechanism. (in other words - move most of the current wlcore's scan.c into wl12xx, and implement a similar mechanism in 18xx, according to the new api) New wlcore ops are introduced in order to call the chip-specific scan functions. The template indices used for each scan (regular/scheduled) are also different between the chips, so set the correct indices used for each scan type after identifying the chip. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Luciano Coelho <coelho@ti.com>
2012-11-27wlcore: workaround start_sta problem in wl12xx fwEliad Peller
for some reason, the wl12xx fw is not able to rx/tx on the first start_sta cmd. Workaround it by issuing a dummy start_sta + stop_sta before starting the sta for the final time. Signed-off-by: Eliad Peller <eliad@wizery.com> Reviewed-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: Luciano Coelho <coelho@ti.com>
2012-09-27wlcore: Refactor probeIdo Yariv
Move most of the device-specific probe functionality into setup(), a new op. By doing this, wlcore_probe will be the first to request a firmware from userspace, making it easier to load the NVS file asynchronously. Signed-off-by: Ido Yariv <ido@wizery.com> Signed-off-by: Luciano Coelho <luca@coelho.fi>
2012-09-27wlcore: Fix unbalanced interrupts enablementIdo Yariv
The interrupt line is enabled by wl12xx_enable_interrupts and wl18xx_enable_interrupts, but it will not be disabled in all failure paths. Fix this. Signed-off-by: Ido Yariv <ido@wizery.com> Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: Luciano Coelho <luca@coelho.fi>
2012-09-27wlcore/wl18xx/wl12xx: allow up to 3 mac addressesArik Nemtsov
Allow 3 native mac addresses on 18xx. On 12xx allow 2 native mac addresses and set the LAA bit to create a third mac address. This enabled operation with a separate group interface. Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: Luciano Coelho <luca@coelho.fi>
2012-09-27wlcore/wl18xx/wl12xx: aggregation buffer size setIgal Chernobelsky
Aggregation buffer size is set separately per 18xx/12xx chip family. For 18xx aggragation buffer is set to 13 pages to utilize all the available tx/rx descriptors for aggregation. [Arik - remove redundant parts from the patch] Signed-off-by: Igal Chernobelsky <igalc@ti.com> Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: Luciano Coelho <luca@coelho.fi>
2012-09-27wl18xx/wl12xx: defines for Tx/Rx descriptors numIgal Chernobelsky
Use defines for number of Tx/Rx descriptors. Signed-off-by: Igal Chernobelsky <igalc@ti.com> Signed-off-by: Luciano Coelho <luca@coelho.fi>
2012-09-27wl12xx: remove duplicated include from main.cWei Yongjun
Remove duplicated include. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Luciano Coelho <luca@coelho.fi>
2012-09-27wl12xx: use module_platform_driverLuciano Coelho
Use a module_platform_driver declaration instead of replicating the init and exit functions in the driver. Based on the patch for wl18xx by Devendra Naga. Signed-off-by: Luciano Coelho <luca@coelho.fi>
2012-07-18wlcore/wl12xx: calibrator fem detect implementationYair Shapira
this completes the calibrator based fem detect logic in driver: driver starts (by calibrator) in plt_mode PLT_FEM_DETECT wlcore inits and starts plt on wl12xx wl12xx fetches fem number from firmware and stores it in wl->fem_manuf wl12xx immediatly returns (doesn't start radio, etc...) wlcore returns the fem_manuf to calibrator using WL1271_TM_ATTR_DATA plt_mode is stopped Signed-off-by: Yair Shapira <yair.shapira@ti.com> Signed-off-by: Luciano Coelho <coelho@ti.com>
2012-07-10wl12xx/wl18xx: use a dynamic PS timeout of 1.5secArik Nemtsov
It seems some parties have bad user experience when smaller values are used. This should have little implications for power consumption, since traffic is bursty in nature. Signed-off-by: Arik Nemtsov <arik@wizery.com>
2012-07-10wl12xx/wlcore: increase FW filename versionLuciano Coelho
We have some API changes and new features in the new firmwares that are not compatible with older drivers. Increase the version of the FW filenames for wl12xx to 5. Additionally, remove the duplicate definitions from wlcore_i.h and remove the MODULE_FIRMWARE macro calls from the SDIO and SPI modules, since they're irrelevant there. Signed-off-by: Luciano Coelho <coelho@ti.com>
2012-07-10wlcore: add probe request templates for sched and one-shot scansYoni Divinsky
The driver configures the firmware template for probe requests during the scan process. If the same template is used for one-shot and sched scans they will override each other when running scans simultaneously. This fix works only on firmwares later than X.3.9.2.112 for single role and X.3.9.2.23 for multi-role. [Some cleaning-up and renaming of the quirk to something smaller -- Luca.] Signed-off-by: Yoni Divinsky <yoni.divinsky@ti.com> Signed-off-by: Luciano Coelho <coelho@ti.com>
2012-07-10wlcore/wl12xx/wl18xx: check min FW versionArik Nemtsov
Refuse to boot if the FW version is too old. The minimum version is set per chip, with the option of setting it per PG in the future. When boot fails because of an old FW, display a helpful message. Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: Luciano Coelho <coelho@ti.com>
