[ Upstream commit cb88d01b67383a095e3f7caeb4cdade5a6cf0417 ]
We can currently get a "command execute failure 19" error on beacon loss
if the signal is weak:
wlcore: Beacon loss detected. roles:0xff
wlcore: Connection loss work (role_id: 0).
wlcore: ERROR command execute failure 19
WARNING: CPU: 0 PID: 1552 at drivers/net/wireless/ti/wlcore/main.c:803
(wl12xx_queue_recovery_work.part.0 [wlcore])
(wl12xx_cmd_role_start_sta [wlcore])
(wl1271_op_bss_info_changed [wlcore])
(ieee80211_prep_connection [mac80211])
Error 19 is defined as CMD_STATUS_WRONG_NESTING from the wlcore firmware,
and seems to mean that the firmware no longer wants to see the quirk
handling for WLCORE_QUIRK_START_STA_FAILS done.
This quirk got added with commit 18eab430700d ("wlcore: workaround
start_sta problem in wl12xx fw"), and it seems that this already got fixed
in the firmware long time ago back in 2012 as wl18xx never had this quirk
in place to start with.
As we no longer even support firmware that early, to me it seems that it's
safe to just drop WLCORE_QUIRK_START_STA_FAILS to fix the error. Looks
like earlier firmware got disabled back in 2013 with commit 0e284c074ef9
("wl12xx: increase minimum singlerole firmware version required").
If it turns out we still need WLCORE_QUIRK_START_STA_FAILS with any
firmware that the driver works with, we can simply revert this patch and
add extra checks for firmware version used.
With this fix wlcore reconnects properly after a beacon loss.
Cc: Raz Bouganim <r-bouganim@ti.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
Link: https://lore.kernel.org/r/20210115065613.7731-1-tony@atomide.com
Align fields reg_ch_conf_last and reg_ch_conf_pending of
struct wl1271{} to 64bit.
Without this, on 64bit ARM, wlcore_set_pending_regdomain_ch() fails at
the point it calls set_bit(ch_bit_idx, (long*)wl->reg_ch_conf_pending);
Here is the error message while doing iw wlan0 scan or connect:
[ 10.666857] wlcore: IRQ work
[ 10.670046] wlcore: intr: 0x40 (fw_rx_counter = 1, drv_rx_counter = 0, tx_results_counter = 0)
[ 10.678697] wlcore: WL1271_ACX_INTR_DATA
[ 10.682810] Unhandled fault: alignment fault (0x96000021) at 0xffffffc037a817f4
[ 10.690139] Internal error: : 96000021 [#1] PREEMPT SMP
[ 10.695366] Modules linked in:
[ 10.698437] CPU: 3 PID: 894 Comm: irq/60-wl18xx Tainted: G W 4.2.0-rc6-linaro-hikey #2
[ 10.707501] Hardware name: HiKey Development Board (DT)
[ 10.712733] task: ffffffc03a9d1680 ti: ffffffc039e18000 task.ti: ffffffc039e18000
[ 10.720239] PC is at set_bit+0x14/0x30
[ 10.724002] LR is at wlcore_set_pending_regdomain_ch+0x40/0x4c
Signed-off-by: Guodong Xu <guodong.xu@linaro.org>
add option to dynamically configure the fw
which debug traces to open
Signed-off-by: Guy Mishol <guym@ti.com>
Signed-off-by: Eliad Peller <eliad@wizery.com>
The platform_quirk element in the platform data was used
to change the way the IRQ is triggered. When set,
the EDGE_IRQ quirk would change the irqflags used
and treat edge trigger differently from the rest.
Instead of hiding this irq flag setting behind the quirk,
have the board files set the irq_trigger explicitly.
This will allow us to use standard irq DT definitions
later on.
Signed-off-by: Luciano Coelho <luca@coelho.fi>
[Eliad - rebase, add irq_trigger field and pass it,
update board file changes]
Tested-by: Nikita Kiryanov <nikita@compulab.co.il>
Acked-by: Kalle Valo <kvalo@codeaurora.org>
Acked-by: Sekhar Nori <nsekhar@ti.com>
Add dfs region to the reg domain channel update command.
call wlcore_cmd_dfs_master_restart when starting
the ap on a new channel (after csa is done).
Add a new WLVIF_FLAG_BEACON_DISABLED flag to
indicate that dfs_master_restart command
is required.
Add support for CAC start/stop commands, and pass
radar detection events from the fw to mac80211.
Bump fw name (to wl18xx-fw-4.bin) and min fw version
(to 8.9.*.*.11), and align event mailbox accordingly.
Enable ELP authorization in AP mode and enable the use
of the wakeup bit in the ELP register.
Introduce AP role sleep configuration which is disabled
by default. When configured, it allows the AP to sleep
when ELP is authorized for it.
Signed-off-by: Kobi Leibovitch <kobi.lev100@gmail.com>
Signed-off-by: Arik Nemtsov <arik@wizery.com>
Add the ability to mask FW interrupts on RX BA activity, PSM
entry/exit and fast-link notifications. This is used when the host
is suspended in order to decrease redundant wake ups.
Signed-off-by: Ram Amrani <ramrani@ti.com>
sta_rc_update runs in atomic context. thus, a new work
should be scheduled in order to configure the fw
with the required configuration.
The *_bit operations expect unsigned longs.
Instead of casting the pointers, simply define various
bitmaps as unsigned long (instead of u32).
These commands configures the fw to set key,
enter smart config mode, and exit it.
Add relevant hw ops as well.
Split sched scan IEs to band specific and not band specific
blocks. Common IEs blocks may be sent to the FW once per command,
instead of per band.
This allows optimization of size of the command, which may be
required by some drivers (eg. iwlmvm with newer firmware version).
As this changes the mac80211 API, update all drivers to use the
new version correctly, even if they don't (yet) make use of the
split data.
Signed-off-by: David Spinadel <david.spinadel@intel.com>
Reviewed-by: Alexander Bondar <alexander.bondar@intel.com>
12xx chips allow only OFDM rates in AP mode for BT-Coex purposes. This
is no longer required in 18xx chips, starting with FW 8.6.0.0.8.
Update the min allowed FW version in 18xx to support this functionality.
Each hw supports a different iface combinations.
Define the supported combinations in each driver,
and save it in wl->iface_combinations.
Since each driver defines its own combinations now,
it can also define its max supported channels, so
we no longer need to save and set it explicitly
in wlcore.
Update wl18xx interface combinations to allow
multiple APs.
Each hw supports a different max stations (connected to the
same ap). add a new wl->max_ap_stations and use it instead
of the current common AP_MAX_STATIONS.
Upcoming fw versions will have different max links support
(according to the hw). Get ready for it by configuring
wl->num_links per-hw, instead of using the const WL12XX_MAX_LINKS.
However, continue using WLCORE_MAX_LINKS in order to simplify
structs declarations (we use it in multiple bitmaps, and converting
them to dynamic arrays is just cumbersome).
Instead of splitting the fw_status into 2 and using some
complex calculations, read the fw status and let each low-level
driver (wl12xx/wl18xx) convert it into a common struct.
This is required for the upcoming fw api changes, which
break the current logic anyway.
zero rx_filter_enabled array after recovery to avoid
cases were the driver will keep trying to clear a
filter which is not configured in FW.
Such case will cause consecutive recoveries due to
command execution failures.
While on it, convert rx_filter_enabled to bitmap,
to save some memory and make sparse happy (it
doesn't like sizeof(bool array)).
Signed-off-by: Nadim Zubidat <nadimz@ti.com>
FW memory block size and FW log end marker parameters
are added to wl structure and are initialized per
chip architecture.
convert_hwaddr hw operation is added to convert chip
dependent FW internal address.
Copy from FW log is also simplified to copy the entire
memory block as FW logger utility is repsponsible
for parsing of FW log content.
Signed-off-by: Igal Chernobelsky <igalc@ti.com>
Signed-off-by: Luciano Coelho <luciano.coelho@intel.com>
Add new ap_event_mask field, to indicate events that
should be unmasked only when there's an ap interface.
This is done in order to avoid spurious wakeups
when we don't care about the incoming event anyway.
Start a ROC on the AP channel beforing sending the authentication reply
to a connecting STA. This ROC is held up to 1 second via a timer. If the
station is authorized and added by mac80211, the ROC is extended until
the station is fully authorized.
We make sure not to ROC twice when several stations are connecting in
parallel and to only release the ROC when both the pending-reply timer
and the STA-state callbacks do not require it.
Maximum number of supported RX BA sessions depends on chip type.
wl18xx supports 5 RX BA sessions while wl12xx supports 3.
Signed-off-by: Luciano Coelho <coelho@ti.com>
There is no platform-specific set_power method anymore. Power setting
is done in the bus modules (wlcore_sdio and wlcore_spi).
Reviewed-by: Felipe Balbi <balbi@ti.com>
drivers/net/wireless/ti/wl12xx/main.c
drivers/net/wireless/ti/wlcore/wlcore.h
Some of the mmc drivers initiate DMA transfers with buffers passed from
higher layers. This means that the driver shouldn't ever pass non
DMA-able buffers, such as ones that are unaligned, allocated on the
stack or static.
Fix a couple of calls to the mmc layer in which buffers which weren't
necessarily DMA-able were passed.
[Use sizeof(*wl->buffer_32) instead of sizeof(u32) -- Luca]
Signed-off-by: Ido Yariv <ido@wizery.com>
Start using the new hw_queue mechanism in mac80211 and give each AC in
each vif its own hw_queue number. This allows us to stop an AC in a vif
independently from other vifs.
Change the Tx watermark handling functions to count packets per AC in
vif. From now on fast links should not be able to hurt the throughput
of slow links on the same AC but on different vifs.
Change internal queue mgmt functions to operate per vif, to support the
new Tx watermark granularity. Make the global versions of the queue
stop/start functions to use the global mac80211 API for queue mgmt. This
helps in situations where the driver currently doesn't know all the vifs
that reside in mac80211. Recovery is a good example for such a case.
[Moved hw_base_queue addition into the wlcore_tx_get_mac80211_queue()
function; changed WARN_ONs to WARN_ON_ONCEs; simplified for loops;
fixed new checkpatch warnings. -- Luca]
Only allow a PSM STA to congest FW memory when it is the single active
link. Being a single STA doesn't imply a single link - there might be
other links on other roles.
[Changed WARN_ON to WARN_ON_ONCE -- Luca]
Update the 18xx FW status private part to include Tx related link
priorities. Introduce new HW ops to determine link priority per chip
family.
For 18xx the changes are:
- Suspended links are at most low priority and Tx for them is stopped
beyond the suspend threshold.
- Active links now get their thresholds directly from FW
- There's a new "stop" threshold for active links, at which point a link
stops receiving new packets.
Update the min 18xx FW version required to make sure suspended links
bitmap is advertised by the FW.
ACX_PEER_CAP command is just ACX_PEER_HT_CAP, but allows
configuring the peer's support rates as well.
this is needed because we start the station role when
the remote rates are not known yet.
the two commands should be unified in future fw versions,
but for now add a new set_peer_cap per-hw op, that will
use ACX_PEER_CAP for 18xx, and ACX_PEER_HT_CAP for 12xx.
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Luciano Coelho <coelho@ti.com>
Prioritize EDCA by choosing the AC before anything else. Use the
fast/slow link bitmap in FW to improve the scheduling algorithm for
the multi-link scenario.
Set packet thresholds to determine if a given link is high or low
priority according to its speed. A slow link will be given high priority
if the amount of packets queued for it in the FW is lower than the
slow-threshold. Similarly, a fast link will be given high priority if
the number of its packets queued in FW is smaller than the high-threshold.
The improved algorithm:
1. Choose optimal AC according to FW utilization
2. Traversing the VIFs in a round-robin fashion, try to choose a high
priority link. Links are traversed in a round-robin fashion inside a
VIF.
3. If no high priority links are found, choose the first non-empty
(low priority) link found in the round robin.
wlcore allocates two static structs wl1271_band_2ghz & wl1271_band_5ghz
which are used/modified by Reg-Domain e.g. some channel might be marked
as passive at some point. Make sure we don't keep stale settings around
if the HW is unregistered/registered during operation.
[Arik - use Tx-power constant and tweak commit message]
Signed-off-by: Victor Goldenshtein <victorg@ti.com>
all the current firmwares support elp, so
we can safely remove WLCORE_QUIRK_NO_ELP.
The 12xx FW doesn't support non-zero session ids for AP-mode. Introduce
an appropriate quirk to make sure the session id is always zero when
needed.
Previously we were only checking the single-role firmware version.
Now add code to check for the firmware versions separately for each
firmware type.
The firmwares version string contain 5 integers. We used to consider
all the digits (except for the first one, which indicates the chip) as
linearly increasing version numbers. This is not correct, because
some of the integers indicate type of firmware (eg. single-role
vs. multi-role) or the internal project it was created for.
Besides, this varies a bit from chip to chip, so we need to make the
firmware version checks more flexible (eg. allow the lower driver to
ignore some of the integers). Additionally, we need to change the
code so that we only check for a linearly increasing number on the
fields where this actually makes sense.
Move wl12xx-specific chip ID macros to the wl12xx driver and rename
them to 127X and 128X for clarity since both the "1" (2.4GHz) and the
"3" (2.4GHz and 5GHz) variants use the same chip ID.
It's sometimes useful to gather information about the firmware
stability in long test runs, especially to see if problems are
recurring frequently or not. With this commit we count the number of
times a hardware recovery was issued and print it out during recovery
and in the driver_state in debugfs.
18xx chips are capable of staying on 2 channels at the same time.
Introduce a chip-family specific parameter to set the number of channels
in the interface-combinations published by the driver.
We support changing the channel BW when we started the STA role on
a 40Mhz bandwidth. Otherwise a reconnection is required.
Save the started channel width and use it when channel width updates
arrive.
The interface might go down before we got the SCHED_STOPPED
event, so make sure to call ieee80211_sched_scan_stopped()
if the scanned interface is removed.
Replace sched_scanning with sched_vif in order to save
the scanned interface.
In 18xx the calibration process of the PHY Cortex domain
requires to perform an active calibration of the channel
before it can be used for transmission. To fulfill world
wide regulatory restrictions, fw should be always
synchronized/updated with current CRDA configuration.
Add a new "CMD_DFS_CHANNEL_CONFIG" command to update the
fw with current reg-domain, this command passes a bit map
of channels that are allowed to be used for transmission.
The driver shall update the fw during initialization and
after each change in the current reg-domain
configuration. The driver will save the channel number of
incoming beacons during the scan process, as they might
be a result of the passive scan on
"IEEE80211_CHAN_PASSIVE_SCAN" channel and will update the
fw accordingly once the scan is finished, the purpose of
this is to be ready in case of the authentication request
on one of these disabled (uncalibrated) channels.
The new command requires to wait for the fw completion
event "DFS_CHANNELS_CONFIG_COMPLETE_EVENT".
No scan commands (including the sched scan) can be
executed concurrently with the "CMD_DFS_CHANNEL_CONFIG",
wl->mutex ensures that.
[Arik - move reset of reg_ch_conf_last to safe place inside
op_stop_locked]
[Eliad - adjust to new event waiting api]
A new session_id is generated on link allocation.
it is saved in a global array and used later, on tx.
The new fw api adds new bcast/global_session_id
fields to start_role(ap) command, and a new session_id
field to add_peer command. align the driver with it.
The event mailbox in wl18xx has a different
(non-compatible) structure.
Create common functions in wlcore to handle the
events, and call them from the chip-specific
event mailbox parsers.
This way, each driver (wl12xx/wl18xx) extracts
the event mailbox by itself according to its
own structure, and then calls the common
wlcore functions to handle it.
Some fields were added to the channel_switch and
stop_channel_switch commands. Unfortunately,
the new 18xx channel_switch struct is not backward
compatible with the 12xx channel switch struct.
Add a new channel_switch op to wlcore, and update
the driver accordingly.
Some regdomains have more than 23 valid 5ghz channels,
so 18xx's MAX_CHANNELS_5GHZ was increased to 32.
Since now we have different max 5ghz channels values
for wl12xx and wl18xx, add a new wl->max_channels_5ghz
field, and use it for scan channels configuration.
The scan APIs of 12xx and 18xx are totally different.
Use some common functions as much as possible (e.g.
for setting scan channels), but split scan.c into
chip-specific scan.c files, each implementing its
own scan mechanism.
(in other words - move most of the current wlcore's
scan.c into wl12xx, and implement a similar mechanism
in 18xx, according to the new api)
New wlcore ops are introduced in order to call the
chip-specific scan functions.
The template indices used for each scan (regular/scheduled)
are also different between the chips, so set the correct
indices used for each scan type after identifying the chip.
implement the reamin_on_channel() callback by starting
a dev role (already associated with the current vif)
on the requested channel/band.
This channel is usually different from the channel
of the sta role, so pass it to wl12xx_roc() as well,
and notify mac80211 (async) when the fw is ready
on the new channel.
Now, in case of offchannel tx, we should use the dev
role hlid, instead of the sta hlid.
Reviewed-by: Arik Nemtsov <arik@wizery.com>
for some reason, the wl12xx fw is not able to rx/tx
on the first start_sta cmd.
Workaround it by issuing a dummy start_sta + stop_sta
before starting the sta for the final time.
