When operating as station, enter psm before suspending
the device into wowlan state.
Add a new completion event to signal when psm was entered
successfully.
Signed-off-by: Eliad Peller <eliad@wizery.com>
Signed-off-by: Luciano Coelho <coelho@ti.com>
To achieve maximal throughput, it is very important to react to
interrupts as soon as possible. Currently the interrupt handler wakes up
a worker for handling interrupts in process context. A cleaner and more
efficient design would be to request a threaded interrupt handler. This
handler's priority is very high, and can do blocking operations such as
SDIO/SPI transactions.
Some work can be deferred, mostly calls to mac80211 APIs
(ieee80211_rx_ni and ieee80211_tx_status). By deferring such work to a
different worker, we can keep the irq handler thread more I/O
responsive. In addition, on multi-core systems the two threads can be
scheduled on different cores, which will improve overall performance.
The use of WL1271_FLAG_IRQ_PENDING & WL1271_FLAG_IRQ_RUNNING was
changed. For simplicity, always query the FW for more pending
interrupts. Since there are relatively long bursts of interrupts, the
extra FW status read overhead is negligible. In addition, this enables
registering the IRQ handler with the ONESHOT option.
Signed-off-by: Ido Yariv <ido@wizery.com>
Reviewed-by: Luciano Coelho <coelho@ti.com>
Update the PS mode of each link according to a bitmap polled from
fw_status. Manually notify mac80211 about PS mode changes in connected
stations.
mac80211 will only be notified about PS start when the station is in PS
and there is a small number of TX blocks from this link ready in HW.
This is required for waking up the remote station since the TIM is
updated entirely by FW.
When a station enters mac80211-PS-mode, we drop all the skbs in the
low-level TX queues belonging to this sta with STAT_TX_FILTERED
to keep our queues clean.
Signed-off-by: Arik Nemtsov <arik@wizery.com>
All files name prefix removed due to the fact that wl12xx driver supports
wl1271 and wl1273.
Also the definition in Kconfig and header files changed respectively.
Signed-off-by: Shahar Levi <shahar_levi@ti.com>
Signed-off-by: Luciano Coelho <luciano.coelho@nokia.com>
Now that all 1271 files are split, we can add wl1251_ prefix to the files.
Signed-off-by: Kalle Valo <kalle.valo@nokia.com>
Reviewed-by: Vidhya Govindan <vidhya.govindan@nokia.com>
Reviewed-by: Luciano Coelho <luciano.coelho@nokia.com>
Rework cmd and acx interfaces, it was just too confusing earlier. Now
all commands need to contain all the needed headers, either just cmd
headers or both cmd and acx headers. This accomplish to remove the
extra copy done for each command. The interfaces are now properly
documented as well.
Also try to make all commands safe for DMA transfers. I might have missed
some, but most of them should be fixed now.
And this is not all! As a free bonus you will also get some cosmetic
cleanups and code reorganisation. Order today!
wl12xx is a driver for TI wl1251 802.11 chipset designed for embedded
devices, supporting both SDIO and SPI busses. Currently the driver
supports only SPI. Adding support 1253 (the 5 GHz version) should be
relatively easy. More information here:
http://focus.ti.com/general/docs/wtbu/wtbuproductcontent.tsp?contentId=4711&navigationId=12494&templateId=6123
(Collapsed original sequence of pre-merge patches into single commit for
initial merge. -- JWL)
Signed-off-by: Bob Copeland <me@bobcopeland.com>
