Skip manual device power on in case runtime PM is enabled for
our device.
This eliminates a secondary & redundant SDIO init sequence.
Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
Signed-off-by: Luciano Coelho <coelho@ti.com>
Some platforms don't support the wake_irq, so disable wowlan
in this case, and avoid the "Unbalanced IRQ wake disable"
warning on disable_irq_wake().
Signed-off-by: Eliad Peller <eliad@wizery.com>
If our SDIO function has its runtime PM disabled, don't try to
manipulate its runtime PM status at all. This way we can still
power on cards plugged to mmc hosts that are not MMC_CAP_POWER_OFF_CARD.
Reported-and-tested-by: Tim Yamin <tim@kangatronix.co.uk>
crc7 is used only in wl12xx_spi.
Remove redundant crc7.h includes, and update Kconfig to select CRC7
only if WL12XX_SPI is being selected.
Nops aren't needed. When we actually need
those calls, then we add them with meat
and barbecue sauce.
Signed-off-by: Felipe Balbi <balbi@ti.com>
Those have little value. Remove those to make
the driver less noisy.
That's only needed during init anyway, let's free
some space after we're done probing.
There was a compilation error when PM is not enabled:
CC [M] drivers/net/wireless/wl12xx/main.o
drivers/net/wireless/wl12xx/main.c:3653: error: unknown field 'suspend' specified in initializer
drivers/net/wireless/wl12xx/main.c:3653: warning: initialization from incompatible pointer type
drivers/net/wireless/wl12xx/main.c:3654: error: unknown field 'resume' specified in initializer
drivers/net/wireless/wl12xx/main.c:3654: warning: initialization from incompatible pointer type
Fix this by adding #ifdef's in the appropriate places.
Cc: Eliad Peller <eliad@wizery.com>
Since wowlan requires the ability to stay awake while the host
is suspended, declare support for NL80211_WOW_TRIGGER_ANYTHING
if the MMC_PM_KEEP_POWER capability is being supported.
When WoW is enabled, the interface will stay up and the chip will
be powered on, so we have to flush/cancel any remaining work, and
prevent the irq handler from scheduling a new work until the system
is resumed.
Add 2 new flags:
* WL1271_FLAG_SUSPENDED - the system is (about to be) suspended.
* WL1271_FLAG_PENDING_WORK - there is a pending irq work which
should be scheduled when the system is being resumed.
In order to wake-up the system while getting an irq, we initialize
the device as wakeup device, and calling pm_wakeup_event() upon
getting the interrupt (while the system is about to be suspended)
if a wow trigger was configured, set the MMC_PM_KEEP_POWER flag
on suspend, so our power will be kept while the system is suspended.
We needed to set this flag on each suspend attempt (when we want
to keep power)
set the sdio interrupt as wake_up interrupt, so we will be able
to wake up the suspended system (Wake-On-Wireless)
Some platforms are incapable of triggering on level interrupts. Add a
platform quirks member in the platform data structure, as well as an
edge interrupt quirk which can be set on such platforms.
When the interrupt is requested with IRQF_TRIGGER_RISING, IRQF_ONESHOT
cannot be used, as we might miss interrupts that occur after the FW
status is cleared and before the threaded interrupt handler exits.
Moreover, when IRQF_ONESHOT is not set, iterating more than once in the
threaded interrupt handler introduces a few race conditions between this
handler and the hardirq handler. Currently this is worked around by
limiting the loop to one iteration only. This workaround has an impact
on performance. To remove to this restriction, the race conditions will
need to be addressed.
Signed-off-by: Ido Yariv <ido@wizery.com>
Simplify and clean up the block size alignment code:
1. Set the block size according to the padding field type, as it cannot
exceed the maximum value this field can hold.
2. Move the alignment code into a function instead of duplicating it in
multiple places.
3. In the current implementation, the block_size member can be
misleading because a zero value actually means that there's no need to
align. Declare a block size alignment quirk instead.
On wl128x based devices, when TX packets are aggregated, each packet
size must be aligned to the SDIO block size, and sent using block mode
transfers.
The block size is set to 256 bytes, which is less than the maximum
possible byte transfer. Thus, if two small packets (< 256 bytes) are
aggregated, the aggregation buffer size would be 512, and will be sent
using byte mode transfers. This can have undesired side effects.
Fix this by setting the MMC_QUIRK_BLKSZ_FOR_BYTE_MODE mmc card quirk.
For 127x chips this has no effect, as the block size is set to 512
bytes.
Signed-off-by: Arik Nemtsov <arik@wizery.com>
chips
Choose a different FW for AP-mode wl127x and wl128x chips, base on chip
ID at boot time.
Reviewed-by: Luciano Coelho <coelho@ti.com>
Boot sequence support FREF clock and TCXO clock.
WL128x has two clocks input - TCXO and FREF.
TCXO is the main clock of the device, while FREF is used to sync
between the GPS and the cellular modem.
Auto-detection checks where TCXO is 32.736MHz or 16.368MHz, in that
case the FREF will be used as the WLAN/BT main clock.
[Use clock enumeration as defined in linux/wl12xx.h; remove
unnecessary else block in wl128x_switch_fref; remove unnecessary
change in main.c; remove some unnecessary debug prints and comments;
fix potential use of uninitialized value (pll_config) -- Luca]
Signed-off-by: Shahar Levi <shahar_levi@ti.com>
Add the the set_block_size op in the SDIO and in the SPI modules.
Since it is only used with SDIO, just explicitly set the op to NULL in
spi.c
Definitions to support wl128x:
- New FW file name
- Chip ID
- New PLL Configuration Algorithm macros that will be used at wl128x
boot stage
- Rename NVS macro name: wl127x and wl128x are using the same NVS
file name. However, the ini parameters between them are
different. The driver will validate the correct NVS size in
wl1271_boot_upload_nvs().
[Cleaned up some of the definitions. -- Luca]
The MODULE_AUTHOR() macro in the main module (wl12xx) has been updated
to reflect one of the author's new email address, but the wl12xx_spi
and wl12xx_sdio modules haven't been updated. This patches updates
them.
The interrupt of the wl12xx is a level interrupt in nature, since the
interrupt line is not auto-reset. However, since resetting the interrupt
requires bus transactions, this cannot be done from an interrupt
context. Thus, requesting a level interrupt would require to disable the
irq and re-enable it after the HW is acknowledged. Since we now request
a threaded irq, this can also be done by specifying the IRQF_ONESHOT
flag.
Triggering on an edge can be problematic in some platforms, if the
sampling frequency is not sufficient for detecting very frequent
interrupts. In case an interrupt is missed, the driver will hang as the
interrupt line will stay high until it is acknowledged by the driver,
which will never happen.
Fix this by requesting a level triggered interrupt, with the
IRQF_ONESHOT flag.
To achieve maximal throughput, it is very important to react to
interrupts as soon as possible. Currently the interrupt handler wakes up
a worker for handling interrupts in process context. A cleaner and more
efficient design would be to request a threaded interrupt handler. This
handler's priority is very high, and can do blocking operations such as
SDIO/SPI transactions.
Some work can be deferred, mostly calls to mac80211 APIs
(ieee80211_rx_ni and ieee80211_tx_status). By deferring such work to a
different worker, we can keep the irq handler thread more I/O
responsive. In addition, on multi-core systems the two threads can be
scheduled on different cores, which will improve overall performance.
The use of WL1271_FLAG_IRQ_PENDING & WL1271_FLAG_IRQ_RUNNING was
changed. For simplicity, always query the FW for more pending
interrupts. Since there are relatively long bursts of interrupts, the
extra FW status read overhead is negligible. In addition, this enables
registering the IRQ handler with the ONESHOT option.
The SDIO bus is claimed and released for each SDIO transaction. In
addition to the few CPU cycles it takes to claim and release the bus, it
may also cause undesired side effects such as the MMC host stopping its
internal clocks.
Since only the wl12xx_sdio driver drives this SDIO card, it is safe to
claim the SDIO host once (on power on), and release it only when turning
the power off.
This patch was inspired by Juuso Oikarinen's (juuso.oikarinen@nokia.com)
patch "wl12xx: Change claiming of the (SDIO) bus".
Runtime PM might not always be enabled. Even if it is enabled in the
running kernel, it can still be temporarily disabled, for instance
during suspend. Runtime PM is opportunistic in nature, and should not be
relied on for toggling power.
In case the interface is removed and re-added while runtime PM is
disabled, the FW will fail to boot, as it is mandatory to toggle power
between boots. For instance, this can happen during suspend in case one
of the devices fails to suspend before the MMC host suspends, but after
mac80211 was suspended. The interface will be removed and reactivated
without toggling the power.
Fix this by calling mmc_power_save_host/mmc_power_restore_host in
wl1271_sdio_power_on/off functions. It will toggle the power to the chip
even if runtime PM is disabled. The runtime PM functions should still be
called to make sure runtime PM does not opportunistically power the chip
off (e.g. after resuming from system suspend).
In wl12xx cards AP-mode requires a separate FW file. Add this file to
the module info.
All files name prefix removed due to the fact that wl12xx driver supports
wl1271 and wl1273.
Also the definition in Kconfig and header files changed respectively.
Signed-off-by: Luciano Coelho <luciano.coelho@nokia.com>
