path: root/drivers/net/wireless/wl3501.h
2010-06-03drivers/net: use __packed annotationEric Dumazet
cleanup patch. Use new __packed annotation in drivers/net/ Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-10pcmcia: dev_node removal (drivers with unregister_netdev check)Dominik Brodowski
As a third step, remove any usage of dev_node_t from drivers which only wrote to this typedef/struct, except to determine whether register_netdev() succeeded previously. However, the function calling unregister_netdev() was only ever called by the PCMCIA core if register_netdev() succeeded previously. The lonely exception was easily fixed. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-03-21wl3501: convert to internal net_device_statsStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-10don't use net/ieee80211.hJohannes Berg
Convert all the drivers using net/ieee80211.h to use linux/ieee80211.h. Contains a bugfix in libertas where the SSID parsing could overrun the buffer when the AP sends invalid information. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Dan Williams <dcbw@redhat.com> [airo, libertas] Acked-by: Pavel Roskin <proski@gnu.org> [orinoco] Acked-by: David Kilroy <kilroyd@googlemail.com> [orinoco] Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-03-31[PATCH] pcmcia: embed dev_link_t into struct pcmcia_deviceDominik Brodowski
Embed dev_link_t into struct pcmcia_device(), as they basically address the same entity. The actual contents of dev_link_t will be cleaned up step by step. This patch includes a bugfix from and signed-off-by Andrew Morton. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2005-09-22ieee80211: update orinoco, wl3501 drivers for latest struct namingJames Ketrenos
2005-09-06[PATCH] wl3501_cs : WE-17 supportJean Tourrilhes
wl3501_cs won't compile with WE-19. This patches fixes it. Signed-off-by: Jean Tourrilhes <jt@hpl.hp.com> Acked-by: Arnaldo Carvalho de Melo <acme@conectiva.com.br> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-05-12[NET] ieee80211 subsystemJeff Garzik
Contributors: Host AP contributors James Ketrenos <jketreno@linux.intel.com> Francois Romieu <romieu@fr.zoreil.com> Adrian Bunk <bunk@stusta.de> Matthew Galgoci <mgalgoci@parcelfarce.linux.th eplanet.co.uk>
