path: root/drivers/net/wireless/zd1201.c
2007-10-18[PATCH] zd1201: avoid null ptr access of skb->devJohn W. Linville
skb->dev is not set until eth_type_trans is called... Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-04-25[SK_BUFF]: Introduce skb_copy_from_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying from linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2007-04-25[ETH]: Make eth_type_trans set skb->dev like the other *_type_transArnaldo Carvalho de Melo
One less thing for drivers writers to worry about. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-01usb: zd1201 free urb cleanupMariusz Kozlowski
- usb_free_urb() cleanup Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-16[PATCH] zd1201: Possible NULL dereferenceEric Sesterhenn
If we enter the if(!zd) and set free to 1, we dereference zd in the exit code. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-27Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (48 commits) [PATCH] bonding: update version number [PATCH] git-netdev-all: pc300_tty build fix [PATCH] Make PC300 WAN driver compile again [PATCH] Modularize generic HDLC [PATCH] more s2io __iomem annotations [PATCH] restore __iomem annotations in e1000 [PATCH] 64bit bugs in s2io [PATCH] bonding: Fix primary selection error at enslavement time [PATCH] bonding: Don't mangle LACPDUs [PATCH] bonding: Validate probe replies in ARP monitor [PATCH] bonding: Don't release slaves when master is admin down [PATCH] bonding: Add priv_flag to avoid event mishandling [PATCH] bonding: Handle large hard_header_len [PATCH] bonding: Remove unneeded NULL test [PATCH] bonding: Format fix in seq_printf call [PATCH] bonding: Convert delay value from s16 to int [PATCH] bonding: Allow bonding to enslave a 10 Gig adapter Delete unused drivers/net/gt64240eth.h [PATCH] skge: fiber support [PATCH] fix possible NULL ptr deref in forcedeth ...
2006-09-27USB: Dealias -110 code (more complete)Pete Zaitcev
The purpose of this patch is to split off the case when a device does not reply on the lower level (which is reported by HC hardware), and a case when the device accepted the request, but does not reply at upper level. This redefinition allows to diagnose issues easier, without asking the user if the -110 happened "immediately". The usbmon splits such cases already thanks to its timestamp, but it's not always available. I adjusted all drivers which I found affected (by searching for "urb"). Out of tree drivers may suffer a little bit, but I do not expect much breakage. At worst they may print a few messages. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-25[PATCH] WE-21 for zd1201Jean Tourrilhes
Signed-off-by: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-07-27[PATCH] zd1201: workaround interference problemPavel Machek
zd1201 has nasty tendency to emit magicall anti-wifi cloud when it is inserted into slot, but not used. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-06-05[PATCH] wireless: move zd1201 where it belongsPavel Machek
zd1201 is wifi adapter, yet it is hiding in drivers/usb/net where noone can find it. This moves Kconfig/Makefile zd1201 to the right place. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: John W. Linville <linville@tuxdriver.com>
