path: root/drivers/net/wireless/zd1211rw/zd_chip.h
2008-03-06zd1211rw: support for mesh interface and beaconingLuis Carlos Cobo
The previously unused CR_CAM_MODE register is set to MODE_AP_WDS. This makes the driver ack mesh (WDS) frames. It does not affect Infra functionality of the driver. Previously missing beaconing support has been added. This might also help implement a currently missing ah-hoc mode. Support for interrupts from the device have been added, but we are not handling most of them. Mesh interfaces are considered associated as long as the interface is up. Signed-off-by: Luis Carlos Cobo <luisca@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29zd1211rw: Fixed incorrect constant name.Javier Cardona
Trial and error reveals that CR_ZD1211B_TX_PWR_CTL* do not affect the transmission power. Instead these registers seem to control the contention windows limits for different QoS access categories. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28zd1211rw: add copyright noticesDaniel Drake
Requested by Michael Wu. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28zd1211rw: port to mac80211Daniel Drake
This seems to be working smoothly now. Let's not hold back the mac80211 transition any further. This patch ports the existing driver from softmac to mac80211. Many thanks to everyone who helped out with the porting efforts. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] zd1211rw: monitor all packetsUlrich Kunitz
While in monitor mode the zd1211rw received only a limited set of packets. This patch forwards now all packets the device receives. Notify that while monitoring no FCS checks are done; so strange packets might appear in the network sniffer of your choice. ATTENTION: Support for multiple interfaces on a single ZD1211 device is currently broken. So this code works only on the first interface. Here is an example to put the device in monitor mode. iwconfig wlan0 mode monitor ifconfig wlan0 up iwconfig wlan0 channel 10 [dsd@gentoo.org: backport to mainline] Signed-off-by: Ulrich Kunitz <kune@deine-taler.de> Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-07-10[PATCH] zd1211rw: Defer firmware load until first ifupDaniel Drake
While playing with the firmware a while back, I discovered a way to access the device's entire address space before the firmware has been loaded. Previously we were loading the firmware early on (during probe) so that we could read the MAC address from the EEPROM and register a netdevice. Now that we can read the EEPROM without having firmware, we can defer firmware loading until later while still reading the MAC address early on. This has the advantage that zd1211rw can now be built into the kernel -- previously if this was the case, zd1211rw would be loaded before the filesystem is available and firmware loading would fail. Firmware load and other device initialization operations now happen the first time the interface is brought up. Some architectural changes were needed: handling of the is_zd1211b flag was moved into the zd_usb structure, MAC address handling was obviously changed, and a preinit_hw stage was added (the order is now: init, preinit_hw, init_hw). Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-07-08[PATCH] zd1211rw: Add UW2453 RF supportDaniel Drake
This patch adds support for another radio appearing in new devices: the Ubec UW2453. It's more complicated than the other RF's we support, but Ubec publish full tech specs so we're able to understand the vendor code relatively well. Now that we support UW2453, we also support Atheros' new USB chip: the AR5007UG. From the little info we have, this appears to be just a rebranded ZD1211B. This RF code doesn't work very well -- lots more TX/RX errors than the other RFs. However, the vendor driver doesn't do any better, so this is all we can do for now. [kune@deine-taler.de: bug fixes] Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-04-28[PATCH] zd1211rw: rework band edge patchingDaniel Drake
This change allows RF drivers to provide their own 6M band edge patching implementation, while providing a generic implementation shared by most currently supported RF's. The upcoming ZD1211B/AL7230B code will use this to define its own patching function, which is different from the other RF configurations. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-04-10[PATCH] zd1211rw: Fix E2P_PHY_REG patchingDaniel Drake
Due to conflicting/confusing defines in the vendor driver, we were reading E2P_PHY_REG from the wrong location. CR157 patching was slightly incorrect in that the vendor driver only patches in an 8-bit value, whereas we were patching 24 bits. Additionally, CR157 patching was happening on both zd1211 and zd1211b, but this should only happen on zd1211. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: Ulrich Kunitz <kune@deine-taler.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-04-10[PATCH] zd1211rw: Reject AL2230S devicesDaniel Drake
zd1211rw currently detects AL2230S-based devices as AL2230, and hence programs the RF incorrectly. Transmit silently fails on this misconfiguration. After this patch, AL2230S devices are rejected with an error message, to avoid any confusion with an apparent driver bug. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-02-05[PATCH] zd1211rw: Remove addressing abstractionDaniel Drake
Instead of passing our own custom 32-bit addresses around and translating them, this patch makes all our register address constants absolute and removes the translation. There are two ugly parts: - fw_reg_addr() is needed to compute addresses of firmware registers, as this is dynamic based upon firmware - inc_addr() needs a small hack to handle byte vs word addressing However, both of those are only small, and we don't use fw_regs a whole lot anyway. The bonuses here include simplicity and improved driver readability. Also, the fact that registers are now referenced by 16-bit absolute addresses (as opposed to 32-bit pseudo addresses) means that over 2kb compiled code size has been shaved off. Includes some touchups and sparse fixes from Ulrich Kunitz. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-02-05[PATCH] zd1211rw: Consistency for address space constantsDaniel Drake
The zd1211rw address space has confused me once too many times. This patch introduces the following naming notation: Memory space is split into segments (cr, fw, eeprom) and segments may contain components (e.g. boot code inside eeprom). These names are arbitrary and only for the description below: x_START: Absolute address of segment start (previously these were named such as CR_BASE_OFFSET, but they weren't really offsets unless you were considering them as an offset to 0) x_LEN: Segment length x_y_LEN: Length of component y of segment x x_y_OFFSET: Relative address of component y into segment x. The absolute address for this component is (x_START + x_y_OFFSET) I also renamed EEPROM registers to EEPROM data. These 'registers' can't be written to using standard I/O and really represent predefined data from the vendor. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-12-05[PATCH] zd1211rw: Support for multicast addressesUlrich Kunitz
Support for multicast adresses is implemented by supporting the set_multicast_list() function of the network device. Address filtering is supported by a group hash table in the device. This is based on earlier work by Benoit Papillaut. Fixes multicast packet reception and ipv6 connectivity: http://bugzilla.kernel.org/show_bug.cgi?id=7424 http://bugzilla.kernel.org/show_bug.cgi?id=7425 Signed-off-by: Ulrich Kunitz <kune@deine-taler.de> Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-12-02[PATCH] zd1211rw: Use softmac ERP handling functionalityDaniel Drake
This adds zd1211rw driver support for the softmac functionality I added a while back. We now obey changes in basic rates, use short preamble if it is available (but long if the AP says it's not), and send self-CTS in the proper situations. Locking fixed and improved by Ulrich Kunitz. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-12-02[PATCH] zd1211rw: cleanupsUlrich Kunitz
Bit-field constants in zd_chip.h are now defined using a shift expression. The value 0x08 is now (1 << 3). The fix is intended to improve readability. Remove misleading comment in zd_mac.c: The function already returns -EPERM in managed mode (IW_MODE_INFRA). Remove unused code in zd_mac.c: The unused code intended for debugging rx_status values is no longer useful. Added dump_stack() to ZD_ASSERT macro: Output of the stack helps to debug assertions. Keep in mind that the ZD_ASSERT() macro only results in code, if DEBUG is defined. Improved comments for filter_rx() zd_usb.c: Added driver name to module init and exit functions Signed-off-by: Ulrich Kunitz <kune@deine-taler.de> Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-09-25[PATCH] zd1211rw: Add LED supportUlrich Kunitz
This patch includes a big cleanup of the existing unused LED code, and adds support for controlling the LED. The link LED will blink if the device is not associated. The LED switches between 2 seconds on and 1 second off. If the device is associated the LED is switched on. The link LED also indicates packet TX. I do a little bit more led resetting than the vendor driver, but the device works now as expected for single LED and double LED devices. Signed-off-by: Ulrich Kunitz <kune@deine-taler.de> Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-08-14[PATCH] zd1211rw: Firmware version vs bootcode version mismatch handlingDaniel Drake
This is needed for my G220F, otherwise it fails to initialize after the existing firmware upload routine. The vendor driver actually does more than what I have done here: it downloads the firmware + boot code, modifies it, and uploads it again (really messy). I have not copied that part over, as my device can get on its feet without it. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-08-14[PATCH] zd1211rw: Support AL7230B RFDaniel Drake
This patch adds support for another Airoha RF which is present in some ZD1211 adapters. This RF supports 802.11a as well as 802.11b/g, but 802.11a connectivity is not yet supported by this driver. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-08-14[PATCH] zd1211rw: AL2230 ZD1211B vendor syncDaniel Drake
This patch synchronizes our code to some recent vendor driver modifications. A new PHY layout is supported, some values are tweaked, and the AL2230 is now programmed over a new interface which is many times faster. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-08-14[PATCH] zd1211rw: Match vendor driver IFS valuesDaniel Drake
The vendor driver resets the IFS value every time the channel changes, to this one. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-08-02[PATCH] zd1211rw: Packet filter fix for managed (STA) modeUlrich Kunitz
I had problems with my AVM Fritz!Box access point. It appeared that the AP deauthorized me and the softmac didn't reconnect me. This patch handles the problem. Signed-off-by: Ulrich Kunitz <kune@deine-taler.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-08-02[PATCH] zd1211rw: Pass more management frame types up to hostDaniel Drake
We'll be needing these at some point... Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: Ulrich Kunitz <kune@deine-taler.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-07-05[PATCH] ZyDAS ZD1211 USB-WLAN driverDaniel Drake
There are 60+ USB wifi adapters available on the market based on the ZyDAS ZD1211 chip. Unlike the predecessor (ZD1201), ZD1211 does not have a hardware MAC, so most data operations are coordinated by the device driver. The ZD1211 chip sits alongside an RF transceiver which is also controlled by the driver. Our driver currently supports 2 RF types, we know of one other available in a few marketed products which we will be supporting soon. Our driver also supports the newer revision of ZD1211, called ZD1211B. The initialization and RF operations are slightly different for the new revision, but the main difference is 802.11e support. Our driver does not support the QoS features yet, but we think we know how to use them. This driver is based on ZyDAS's own GPL driver available from www.zydas.com.tw. ZyDAS engineers have been responsive and supportive of our efforts, so thumbs up to them. Additionally, the firmware is redistributable and they have provided device specs. This driver has been written primarily by Ulrich Kunitz and myself. Graham Gower, Greg KH, Remco and Bryan Rittmeyer have also contributed. The developers of ieee80211 and softmac have made our lives so much easier- thanks! We maintain a small info-page: http://zd1211.ath.cx/wiki/DriverRewrite If there is enough time for review, we would like to aim for inclusion in 2.6.18. The driver works nicely as a STA, and can connect to both open and encrypted networks (we are using software-based encryption for now). We will work towards supporting more advanced features in the future (ad-hoc, master mode, 802.11a, ...). Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
