path: root/drivers/net/wireless
2010-11-24iwlagn: fix station powersave accounting for aggregationJohannes Berg
Since aggregation queues are station-specific, the device will not reject packets in them but rather will stop the appropriate aggregation queues when a station goes to sleep. I forgot to account for this in the driver, so if a station went to sleep that had aggregation enabled, traffic would stop indefinitely. Fix this by only accounting frames queued on the normal AC queues for associated station. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-11-24iwlagn: remove powersave warningJohannes Berg
Through races, a packet may be enqueued for transmission to a station while that station is going to sleep, in which case the warning here triggers. Instead of warning, check the condition -- if this packet is not a PS-poll response then we still enqueue it but it will be rejected by the device since the station is marked as asleep. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-11-24iwlwifi: use antenna information in EEPROMWey-Yi Guy
The valid tx/rx antenna information is part of EEPROM, so use it to configure the device. For few cases, the EEPROM did not reflect the correct antenna, but it is too late to modify the EEPROM, so overwrite with .cfg parameters Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-11-24iwlwifi: remove unused defineWey-Yi Guy
was not used, remove it Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2010-11-24ath9k_hw: remove ath9k_hw_stoppcurecvFelix Fietkau
It is no longer used anywhere Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24ath9k_htc: Identify devices using driver_infoRajkumar Manoharan
Categorize AR7010 & AR9287 devices based on driver_info of usb_device_id, instead of PIDs. This avoids per-device cases and minimize code changes for new device addition. Signed-off-by: Rajkumar Manoharan <rmanoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24ath9k_hw: Fix eeprom offset for AR9287 devices (PCI/USB)Rajkumar Manoharan
AR9287 devices (PCI/USB) use different eeprom start location to read nvram. New devices might endup with same devid. So use driver_info to set offset, instead of devid. driver_info is valid for HTC devices alone which is filled in usb_device_id. Signed-off-by: Rajkumar Manoharan <rmanoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24ath9k_htc: Add driver_info in usb device listRajkumar Manoharan
Added driver_info to identify AR7010, R9287 HTC devices. Signed-off-by: Rajkumar Manoharan <rmanoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24ath: Add a driver_info bitmask fieldRajkumar Manoharan
The driver_info stores the device category information which is used to load appropriate device firmware, select firmware offset and eeprom starting location. The driver_info is accessed across ath9k_htc and ath9k_hw. Hence placed under common structure. Signed-off-by: Rajkumar Manoharan <rmanoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24iwlwifi: advance power management supportWey-Yi Guy
For 6000g2b and up, adding advance power management support for better power consumption Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24iwlwifi: power management checking for shadow registerWey-Yi Guy
If shadow register is enable, modify the power management command to inform uCode Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24iwlwifi: consider BT for power managementWey-Yi Guy
Check the BT PSPoll flag when fill PM command to uCode Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24iwlwifi: add more power management flagsWey-Yi Guy
Adding additional power management option available for the device. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24iwlagn: name change for BT config flagWey-Yi Guy
Bit 7 of BT config flag is used to enable/disable PSPoll sync. Make the name to match it. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24ath9k: avoid aggregation for VO trafficLuis R. Rodriguez
This should help with latency issues which can happen when using aggregation. Cc: Matt Smith <matt.smith@atheros.com> Cc: Senthil Balasubramanian <senthilkumar@atheros.com> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24b43: N-PHY: little cleanupsRafał Miłecki
Remove some typos, warnings, initialize some values to follow wl's code path. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24b43: N-PHY: rev2: save and restore PHY regs on RSSI pollRafał Miłecki
2010-11-24b43: N-PHY: fix BPHY initRafał Miłecki
2010-11-24b43: N-PHY: init BPHY when neededRafał Miłecki
2010-11-24b43: N-PHY: fix some typos, conditions, set gain_boostRafał Miłecki
2010-11-24b43: N-PHY: minor fixes to match specsRafał Miłecki
2010-11-24b43: N-PHY: fix values for PHY regs in channel tables of 2055 radioRafał Miłecki
Additional comment by Larry Finger <Larry.Finger@lwfinger.net>: This change deserves a bit more explanation. You might include something like "These tables came from reverse engineering the 5.10.56.46 version of the Broadcom driver. Trace comparisons between b43 and the current Broadcom driver (5.10.120.0) show byte reversals for the PHY register writes." Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-24Merge branch 'master' of ↵John W. Linville
2010-11-23wireless: b43: fix error path in SDIOGuennadi Liakhovetski
Fix unbalanced call to sdio_release_host() on the error path. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-22ath9k_htc: fix eeprom accessFelix Fietkau
wireless-testing commit a05b5d45049d60a06a1b12976150572304a51928 ath9k: add support for reading eeprom from platform data on PCI devices This change moved the initialization of the AH_USE_EEPROM flag from ath9k_hw to ath9k. This needs to be added to ath9k_htc as well Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-22ath9k_hw: fix A-MPDU key search issues on AR9003Felix Fietkau
Under load, a large number of frames can produce decryption errors, even when no key cache update is being done. Performing a key search for every single frame in an A-MPDU improves reliability. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-22zd1211rw: Use constJoe Perches
Mark arrays const that are unmodified after initializations. text data bss dec hex filename 19291 56 4136 23483 5bbb drivers/net/wireless/zd1211rw/zd_chip.o.old 19291 56 4136 23483 5bbb drivers/net/wireless/zd1211rw/zd_chip.o.new Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-22rt2x00: Use static constJoe Perches
Using static const generally increases object text and decreases data size. It also generally decreases overall object size. text data bss dec hex filename 40197 56 8336 48589 bdcd drivers/net/wireless/rt2x00/rt2800lib.o.new 40205 56 8336 48597 bdd5 drivers/net/wireless/rt2x00/rt2800lib.o.old Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-22rndis_wlan: Use static constJoe Perches
Using static const generally increases object text and decreases data size. It also generally decreases overall object size. text data bss dec hex filename 41757 2205 9896 53858 d262 drivers/net/wireless/rndis_wlan.o.old 41653 2205 9880 53738 d1ea drivers/net/wireless/rndis_wlan.o.new Changed functions rndis_set_oid and set_bssid to take const *'s. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-22ray_cs: Use static constJoe Perches
Using static const generally increases object text and decreases data size. It also generally decreases overall object size. text data bss dec hex filename 42607 3581 8536 54724 d5c4 drivers/net/wireless/ray_cs.o.new 42603 3585 8536 54724 d5c4 drivers/net/wireless/ray_cs.o.old Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-22libertas: Use static constJoe Perches
Using static const generally increases object text and decreases data size. It also generally decreases overall object size. text data bss dec hex filename 3650 56 704 4410 113a drivers/net/wireless/libertas/rx.o.new 3695 56 704 4455 1167 drivers/net/wireless/libertas/rx.o.old 27328 964 5240 33532 82fc drivers/net/wireless/libertas/cfg.o.new 27328 964 5240 33532 82fc drivers/net/wireless/libertas/cfg.o.old Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-22iwlwifi: Use static constJoe Perches
Using static const generally increases object text and decreases data size. It also generally decreases overall object size. text data bss dec hex filename 48644 57 12120 60821 ed95 drivers/net/wireless/b43/phy_n.o.new 48661 57 12120 60838 eda6 drivers/net/wireless/b43/phy_n.o.old 37906 86 7904 45896 b348 drivers/net/wireless/iwlwifi/iwl-agn-lib.o.new 37937 86 7904 45927 b367 drivers/net/wireless/iwlwifi/iwl-agn-lib.o.old 37781 523 6752 45056 b000 drivers/net/wireless/iwlwifi/iwl-3945.o.new 37781 523 6752 45056 b000 drivers/net/wireless/iwlwifi/iwl-3945.o.old Changed b43_nphy_write_clip_detection to take a const u16 * Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-22b43: Use static constJoe Perches
Using static const generally increases object text and decreases data size. It also generally decreases overall object size. text data bss dec hex filename 5502 56 1336 6894 1aee drivers/net/wireless/b43/phy_common.o.new 5511 56 1336 6903 1af7 drivers/net/wireless/b43/phy_common.o.old Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-22atmel: Use static constJoe Perches
Using static const generally increases object text and decreases data size. It also generally decreases overall object size. text data bss dec hex filename 42578 720 8528 51826 ca72 drivers/net/wireless/atmel.o.old 42578 720 8528 51826 ca72 drivers/net/wireless/atmel.o.new Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-22carl9170: Use static constJoe Perches
Using static const generally increases object text and decreases data size. It also generally decreases overall object size. text data bss dec hex filename 1897 56 672 2625 a41 drivers/net/wireless/ath/carl9170/cmd.o.new 1897 56 672 2625 a41 drivers/net/wireless/ath/carl9170/cmd.o.old Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-22ath9k: Use static constJoe Perches
Using static const generally increases object text and decreases data size. It also generally decreases overall object size. text data bss dec hex filename 11161 56 2136 13353 3429 drivers/net/wireless/ath/ath9k/ar9003_paprd.o.new 11167 56 2136 13359 342f drivers/net/wireless/ath/ath9k/ar9003_paprd.o.old 15428 56 3056 18540 486c drivers/net/wireless/ath/ath9k/eeprom_4k.o.old 15451 56 3056 18563 4883 drivers/net/wireless/ath/ath9k/eeprom_4k.o.new 14087 56 2560 16703 413f drivers/net/wireless/ath/ath9k/eeprom_9287.o.old 14036 56 2560 16652 410c drivers/net/wireless/ath/ath9k/eeprom_9287.o.new 10041 56 2384 12481 30c1 drivers/net/wireless/ath/ath9k/ani.o.new 10088 56 2384 12528 30f0 drivers/net/wireless/ath/ath9k/ani.o.old 9316 1580 2304 13200 3390 drivers/net/wireless/ath/ath9k/htc_drv_init.o.new 9316 1580 2304 13200 3390 drivers/net/wireless/ath/ath9k/htc_drv_init.o.old 16483 56 3432 19971 4e03 drivers/net/wireless/ath/ath9k/ar9003_phy.o.new 16517 56 3432 20005 4e25 drivers/net/wireless/ath/ath9k/ar9003_phy.o.old 18221 104 2960 21285 5325 drivers/net/wireless/ath/ath9k/rc.o.old 18203 104 2960 21267 5313 drivers/net/wireless/ath/ath9k/rc.o.new 19985 56 4288 24329 5f09 drivers/net/wireless/ath/ath9k/eeprom_def.o.new 20040 56 4288 24384 5f40 drivers/net/wireless/ath/ath9k/eeprom_def.o.old 23997 56 4984 29037 716d drivers/net/wireless/ath/ath9k/ar5008_phy.o.old 23846 56 4984 28886 70d6 drivers/net/wireless/ath/ath9k/ar5008_phy.o.new 24285 56 3184 27525 6b85 drivers/net/wireless/ath/ath9k/ar9003_eeprom.o.old 24101 56 3184 27341 6acd drivers/net/wireless/ath/ath9k/ar9003_eeprom.o.new 6834 56 1032 7922 1ef2 drivers/net/wireless/ath/ath9k/ar9002_phy.o.old 6780 56 1032 7868 1ebc drivers/net/wireless/ath/ath9k/ar9002_phy.o.new 36211 64 8624 44899 af63 drivers/net/wireless/ath/ath9k/hw.o.new 36401 64 8624 45089 b021 drivers/net/wireless/ath/ath9k/hw.o.old 9281 56 1496 10833 2a51 drivers/net/wireless/ath/ath9k/ar9003_calib.o.old 9150 56 1496 10702 29ce drivers/net/wireless/ath/ath9k/ar9003_calib.o.new Use ARRAY_SIZE instead of a magic number. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-22ath5k: Use static constJoe Perches
Using static const generally increases object text and decreases data size. It also generally decreases overall object size. text data bss dec hex filename 11266 56 2464 13786 35da drivers/net/wireless/ath/ath5k/ani.o.old 11181 56 2464 13701 3585 drivers/net/wireless/ath/ath5k/ani.o.new Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-22ar9170: Use constJoe Perches
Mark an array const. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-22carl9170: fix init-self regressionChristian Lamparter
The commit: "carl9170: tx path review" introduced a regression. gcc (with -Winit-self): tx.c:1264: warning: ‘super’ is used uninitialized in this function Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-22libertas: remove duplicated #includeHuang Weiyi
Remove duplicated #include('s) in drivers/net/wireless/libertas/cfg.c Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-22ath9k: fix recursive locking in the tx flush pathFelix Fietkau
Signed-off-by: Felix Fietkau <nbd@openwrt.org> Tested-by: Ben Greear <greearb@candelatech.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-22iwlwifi: fix modular 3945 only buildJohannes Berg
If only 3945 is selected, and is a module, build fails because iwl-legacy.c won't be compiled. Fix this by adding it to the build correctly. This doesn't happen for 4965 because it is a bool option, not tristate, since it's built into the AGN module. Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Tested-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-22b43: rfkill: use HI enabled bit for all devicesRafał Miłecki
Devices which use LO enabled bit are covered by b43legacy Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-22b43: N-PHY: add 2056 radio channels tablesRafał Miłecki
2010-11-22Merge branch 'wireless-next-2.6' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/iwlwifi/iwlwifi-2.6
2010-11-22carl9170: fix virtual interface setup crashChristian Lamparter
This patch fixes a faulty bound check which caused a crash when too many virtual interface were brought up. BUG: unable to handle kernel NULL pointer dereference at 00000004 IP: [<f8125f67>] carl9170_op_add_interface+0x1d7/0x2c0 [carl9170] *pde = 00000000 Oops: 0002 [#1] PREEMPT Modules linked in: carl9170 [...] Pid: 4720, comm: wpa_supplicant Not tainted 2.6.37-rc2-wl+ EIP: 0060:[<f8125f67>] EFLAGS: 00210206 CPU: 0 EIP is at carl9170_op_add_interface+0x1d7/0x2c0 [carl9170] EAX: 00000000 ... Process wpa_supplicant Stack: f4f88f34 fffffff4 .. Call Trace: [<f8f4e666>] ? ieee80211_do_open+0x406/0x5c0 [mac80211] [...] Code: <89> 42 04 ... EIP: [<f8125f67>] carl9170_op_add_interface+0x1d7/0x2c0 [carl9170] CR2: 0000000000000004 Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-22ath9k: fix timeout on stopping rx dmaFelix Fietkau
It seems that using ath9k_hw_stoppcurecv to stop rx dma is not enough. When it's time to stop DMA, the PCU is still busy, so the rx enable bit never clears. Using ath9k_hw_abortpcurecv helps with getting rx stopped much faster, with this change, I cannot reproduce the rx stop related WARN_ON anymore. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Cc: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-22wl12xx: Unset bssid filter, ssid and bssid from firmware on disassocJuuso Oikarinen
On the disassociation event from the mac80211, the wl12xx driver does not clear the chipset configuration related to the AP - i.e. it does not perform a DISCONNECT and then a JOIN with zero SSID and dummy BSSID. Also, it does not unset the BSSID filter. Often this is not a problem, as the above is performed upon entering idle state. But if a scenario arises where a new association is attempted without cycling through idle state, the new association will fail. Fix this by resetting the firmware state on disassociation. Signed-off-by: Juuso Oikarinen <juuso.oikarinen@nokia.com> Reviewed-by: Luciano Coelho <luciano.coelho@nokia.com> Signed-off-by: Luciano Coelho <luciano.coelho@nokia.com>
2010-11-22wl1271: add support for HW TX fragmentationArik Nemtsov
Indicate to mac80211 we support HW fragmentation. Support updates of the fragmentation threshold via the set_frag_threshold callback. Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: Luciano Coelho <luciano.coelho@nokia.com>
2010-11-22Revert "wl1271: Change supported channel order for a more optimal scan"Juuso Oikarinen
This reverts commit fa21c7a9e4be439e217fe72edbd39b643b643791. The reverted patch caused more harm than benefit. Signed-off-by: Juuso Oikarinen <juuso.oikarinen@nokia.com> Reviewed-by: Luciano Coelho <luciano.coelho@nokia.com> Tested-by: Tuomas Katila <ext-tuomas.2.katila@nokia.com> Signed-off-by: Luciano Coelho <luciano.coelho@nokia.com>
