path: root/drivers/net/wireless
2016-03-23rtl8192cu: Add new device IDsColibri_T30_LinuxImageV2.6Beta1_20160331Colibri_T20_LinuxImageV2.6Beta1_20160331Apalis_T30_LinuxImageV2.6Beta1_20160331Larry Finger
The latest vendor (non-mac80211) driver of 9/22/2011 shows some new device IDs for rtl8192cu. In addition, some typos in the table are fixed and one duplicate is removed. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> (cherry picked from commit 6cddafab54e9a17b2efefe982547865955a5ff3a)
2013-01-11driver: bcm4329: initialize SSID variable properlyMursalin Akon
initialize SSID variable properly to ensure no memory overrun. Bug 1204024 Change-Id: I2485c13edcf6a0feeae3cd4b2e9e98910a771dd2 Signed-off-by: Mursalin Akon <makon@nvidia.com> Reviewed-on: http://git-master/r/190684 Reviewed-by: Matthew Pedro <mapedro@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit
2013-01-09driver: bcmdhd: do not allow hang thread after cleanupMursalin Akon
do not allow scheduling hang thread after cleanup is done. Bug 1210849 Bug 1205910 Bug 1163014 Change-Id: Idc5f9fd6a3d210843f1168e57ceef107599d5789 Signed-off-by: Mursalin Akon <makon@nvidia.com> Reviewed-on: http://git-master/r/189721 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Matthew Pedro <mapedro@nvidia.com> Reviewed-by: Allen Martin <amartin@nvidia.com>
2012-10-04bcmdhd: use the wiphy from private data structure (i.e., wl_priv)Mursalin Akon
problem: The macro wiphy_from_scan retrieves wiphy from wl_priv->escan_info.wiphy which is in turn set by a 'scan' initiated from kernel space (like scheduled scan) or from user space (like iwlist command). Without a scan, a 'connect' crashes in function wl_inform_single_bss, with NULL pointer access, as the variable wiphy (in turn, wl->escan_info.wiphy) is not initialized properly. solution: wireless_device data structures maintained for both STA and P2P mode point to the same wiphy (see, wl_cfgp2p_register_ndev in wl_cfgp2p.c). So, irrespective of whatever wireless_device is in use, a scan will always set wl_priv->escan_info.wiphy to the same wiphy. There is no point in getting wiphy using wl_priv->escan_info.wiphy, rather use the wiphy referred by all wireless_device structures. Bug 1029792 Bug 1029733 Change-Id: I6d744950d3a053642ffa998b3c3f3ba60c0cb687 Signed-off-by: Mursalin Akon <makon@nvidia.com> Reviewed-on: http://git-master/r/141629 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Matthew Pedro <mapedro@nvidia.com> GVS: Gerrit_Virtual_Submit
2012-10-04bcmdhd: do not turn off mmc at probeMursalin Akon
Do not turn off mmc at probe if watchdog thread is in use. Bug 1029792 Bug 1029733 Change-Id: Ia2e303daa27688c96e7fa5941e01cf821166c498 Signed-off-by: Mursalin Akon <makon@nvidia.com> Reviewed-on: http://git-master/r/141628 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Matthew Pedro <mapedro@nvidia.com> GVS: Gerrit_Virtual_Submit
2012-10-04net: wireless: bcmdhd: cleanup Kconfig/MakeMursalin Akon
cleanup bcmdhd driver Kconfig and Makefile Bug 1029792 Bug 1029733 Change-Id: Ic947644d2159a52fab7aea1621e12e51d8ee6332 Signed-off-by: Mursalin Akon <makon@nvidia.com> Reviewed-on: http://git-master/r/141627 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Matthew Pedro <mapedro@nvidia.com> GVS: Gerrit_Virtual_Submit
2012-08-09net: wireless: bcmdhd: Update to 5.90.195.75Narayan Reddy
Bug 1023045 Change-Id: Id6e43c852a90cbd5445daf38279ed690712c3332 Signed-off-by: Narayan Reddy <narayanr@nvidia.com> Reviewed-on: http://git-master/r/117637 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Rakesh Kumar <krakesh@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-07-30net: wireless: bcmdhd: power off card when not in useOm Prakash Singh
Power off the card when wifi is off and power up only when wifi is turned on Bug 1011349 Change-Id: I26a8188d932516c0490dec858acd9e8ea2c5adf8 Signed-off-by: Om Prakash Singh <omp@nvidia.com> Reviewed-on: http://git-master/r/118097 Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Tested-by: Bharat Nihalani <bnihalani@nvidia.com> Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2012-07-17net: wireless: bcmdhd: disable WLC_E_TXFAIL event.Narayan Reddy
In suspend mode WLC_E_TXFAIL event is causing autowake when the device is connected to an AP, so discarding the WLC_E_TXFAIL event initialization as per BRCM team suggestion. Bug 1014610 Change-Id: I297dab7ee589f458bba3e26be090665a36c78502 Signed-off-by: Narayan Reddy <narayanr@nvidia.com> Reviewed-on: http://git-master/r/115633 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Rakesh Goyal <rgoyal@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-07-11net: wireless: WFD specific changesJun (Gab-Joo) Lim
WFD specific changes integrated from broadcom patch Bug 1001418 Bug 997838 Change-Id: I0632307bf5fb959def4ee12687430a14ab9e068e Signed-off-by: Narayan Reddy <narayanr@nvidia.com> Reviewed-on: http://git-master/r/111032 Reviewed-by: Automatic_Commit_Validation_User Tested-by: Rakesh Goyal <rgoyal@nvidia.com> Reviewed-by: Rakesh Kumar <krakesh@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-07-03net: wireless: bcmdhd: do not register for allMursalin Akon
Do not register bcmdhd driver for all sdio devices. Bug 1006828 Change-Id: I49e2d2bc7fbda4414392d8a28a0feefb1c8031ec Signed-off-by: Mursalin Akon <makon@nvidia.com> Reviewed-on: http://git-master/r/113045 Reviewed-by: Simone Willett <swillett@nvidia.com> Tested-by: Simone Willett <swillett@nvidia.com>
2012-07-01net: wireless: bcmdhd: move barrier to after setting the suspended flag.Sang-Hun Lee
Reviewed-on: http://mcrd1-5.corpnet.asus/code-review/master/47846 Tested-by: Kirt Hsieh <Kirt_Hsieh@asus.com> Reviewed-by: Kirt Hsieh <Kirt_Hsieh@asus.com> Reviewed-by: Vincent Yue <Vincent_Yue@asus.com> Bug 984811 Signed-off-by: Roger Hsieh <rhsieh@nvidia.com> Change-Id: I708dadddf3f3eac9f8bacc72e3aef94247a87e70 Reviewed-on: http://git-master/r/106352 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Sang-Hun Lee <sanlee@nvidia.com> Tested-by: Sang-Hun Lee <sanlee@nvidia.com> Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
2012-06-22net: wireless: bcmdhd: Enable 5 GHz supportNitin Bindal
Update wiphy (wireless hardware description) to support 5 GHz scan. Bug 1000888 Change-Id: I1a7a99f97f69dd8f1790f81ee0fb21e209e8d10e Signed-off-by: Nitin Bindal <nbindal@nvidia.com> Reviewed-on: http://git-master/r/109556 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Rakesh Kumar <krakesh@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-06-15net: wireless: bcmdhd: fix Makefile and KconfigOm Prakash Singh
Bug 999876 Change-Id: I83a139e6c0dd42cf095fa2ac1376732075a15434
2012-06-15net: wireless: bcmdhd: Fix P2P driver crash for MFG firmwareLeslie Yu
Signed-off-by: Dmitry Shmidt <dimitrysh@google.com>
2012-06-15net: wireless: bcmdhd: Make responce waiting uninterruptibleDmitry Shmidt
2012-06-15net: wireless: bcmdhd: Fix WPS PBC overlap failureNeeraj Kumar Garg
2012-06-15net: wireless: bcmdhd: Ignore signal_pending() while waiting in IOCTLDmitry Shmidt
2012-06-15net: wireless: bcmdhd: Check return value from dhd_dev_init_ioctl()Dmitry Shmidt
2012-06-15net: wireless: bcmdhd: Fix WARN_ON(!res->pub.channel)Dmitry Shmidt
2012-06-15net: wireless: bcmdhd: Change singal pending return value from -110 to -4Dmitry Shmidt
- ETIMEDOUT is interpreted as FW is not responding, so return EINTR instead Signed-off-by: Dmitry Shmidt <dimitrysh@google.com>
2012-06-15net: wireless: bcmdhd: Fix filtering setting in case of P2PDmitry Shmidt
2012-06-15net: wireless: bcmdhd: Avoid turning radio UP twice on startDmitry Shmidt
2012-06-15net: wireless: bcmdhd: Set MMC_PM_KEEP_POWER flag on suspendDmitry Shmidt
2012-06-15net: wireless: bcmdhd: Update to Version 5.90.195.61Dmitry Shmidt
- Deauth frame from p2p GO to client doesn't go from firmware if we do del_virtual_iface immediately. Putting a delay after sending deauth frame to allowed FW to send out deauth frame. - IF_DEL operation was timing out due to wrong status check. Fixed it and added few debug prints. - Sending Provision Discovery directly to GO instead of doing an internal scan. Also put the internal scan count to 3 to have better timings for GO-NEG. - Increase beacon timeout only for concurrent mode. For STA only operation, use the default beacon timeout value (4). - If scan abort is due to timeout, aborting the scan in FW is not required. Moreover, as this scan_timeout call is coming in timer interrupt context, all blocking calls such as fw scan abort will result in kernel panic : don’t call abort in Firmware. - Add p2p_cancel_listen routine. Fix p2p_listen_complete related kernel crash seen while turning off WiFi. Signed-off-by: Dmitry Shmidt <dimitrysh@google.com>
2012-06-15net: wireless: bcmdhd: Turn OFF wlan power if interface UP failsDmitry Shmidt
2012-06-15net: wireless: bcmdhd: Allow 80211_HT capabilityDmitry Shmidt
2012-06-15net: wireless: bcmdhd: Fix improper band handlingDmitry Shmidt
2012-06-15net: wireless: bcmdhd: Update to version 5.90.195.53Dmitry Shmidt
- Add retry to wl_cfg80211_mgmt_tx() for P2P - Change singal pending return value from -512 to -110 - Minor cleaning Signed-off-by: Dmitry Shmidt <dimitrysh@google.com>
2012-06-15net: wireless: bcmdhd: Move FW hang processign to work queueDmitry Shmidt
2012-06-15net: wireless: bcmdhd: Fix FW hang recoveryDmitry Shmidt
- Reduce IOCTL responce timeout to 2 sec (from 20) - Fix pending status in case of timeout - Pass error code from dhd_is_associated() call - Call cfg80211_disconnected() if no timeout detected Signed-off-by: Dmitry Shmidt <dimitrysh@google.com>
2012-06-15net: wireless: bcmdhd: Fix frame sequence lag issueAndrey Smolnikov
2012-06-15net: wireless: bcmdhd: Fix crash in dhd_preinit_ioctls() band setDmitry Shmidt
2012-06-15net: wireless: bcmdhd: Add CONFIG_DHD_ENABLE_P2P Kconfig optionDmitry Shmidt
2012-06-15net: wireless: bcmdhd: Turn off DHD_USE_EARLYSUSPEND optionDmitry Shmidt
2012-06-15net: wireless: bcmdhd: Update to Version 5.90.195.46Dmitry Shmidt
- Fix WEXT compilation - Start SoftAP in G-band only - Fix IF_DEL timeout due to wrong status check - Fix P2P to pass certification - Enable arpoe in concurrent mode by default - Fail to start sched scan in P2P GO Signed-off-by: Dmitry Shmidt <dimitrysh@google.com>
2012-06-15net: wireless: bcmdhd: Add 'wlan_ctrl_wake' wakelockDmitry Shmidt
2012-06-15net: wireless: bcmdhd: Set probe_resp.timestamp value to scan resultsDmitry Shmidt
2012-06-15net: wireless: bcmdhd: Add constant mDNS filterDmitry Shmidt
2012-06-15net: wireless: bcmdhd: Add WL_CFG80211_STA_EVENT config optionDmitry Shmidt
2012-06-15net: wireless: bcmdhd: Update to Version 5.90.195.35Dmitry Shmidt
- Add SoftAP auto-channel support - P2P fixes Signed-off-by: Dmitry Shmidt <dimitrysh@google.com>
2012-06-15net: wireless: bcmdhd: Fix mac setting from platform hookDmitry Shmidt
2012-06-15net: wireless: bcmdhd: Fix crash on timeout in wl_notify_escan_completeDmitry Shmidt
2012-06-15net: wireless: bcmdhd: Add sched-scan config optionDmitry Shmidt
2012-06-15net: wireless: bcmdhd: Allow Improved suspend/resume processing on 2.6.39Dmitry Shmidt
2012-06-15net: wireless: bcmdhd: Always turn Off wlan power on interface downDmitry Shmidt
2012-06-15net: wireless: bcmdhd: Add SETSUSPENDMODE commandDmitry Shmidt
2012-06-15net: wireless: bcmdhd: Minor cleaningDmitry Shmidt
2012-06-15net: wireless: bcmdhd: Add SET_RANDOM_MAC_SOFTAP optionDmitry Shmidt
2012-06-15net: wireless: bcmdhd: Update to Version 5.90.195.30Dmitry Shmidt
- Fix STA features if P2P FW is in use - Move ENABLE_P2P_INTERFACE to Makefile - Minor fixes in PNO scan Signed-off-by: Dmitry Shmidt <dimitrysh@google.com>
