Pull networking update from David Miller:
"A couple weeks of bug fixing in there. The largest chunk is all the
broken crap Amerigo Wang found in the netpoll layer."
1) netpoll and it's users has several serious bugs:
a) uses GFP_KERNEL with locks held
b) interfaces requiring interrupts disabled are called with them
enabled
c) and vice versa
d) VLAN tag demuxing, as per all other RX packet input paths, is not
applied
All from Amerigo Wang.
2) Hopefully cure the ipv4 mapped ipv6 address TCP early demux bugs for
good, from Neal Cardwell.
3) Unlike AF_UNIX, AF_PACKET sockets don't set a default credentials
when the user doesn't specify one explicitly during sendmsg().
Instead we attach an empty (zero) SCM credential block which is
definitely not what we want. Fix from Eric Dumazet.
4) IPv6 illegally invokes netdevice notifiers with RCU lock held, fix
from Ben Hutchings.
5) inet_csk_route_child_sock() checks wrong inet options pointer, fix
from Christoph Paasch.
6) When AF_PACKET is used for transmit, packet loopback doesn't behave
properly when a socket fanout is enabled, from Eric Leblond.
7) On bluetooth l2cap channel create failure, we leak the socket, from
Jaganath Kanakkassery.
8) Fix all the netprio file handling bugs found by Al Viro, from John
Fastabend.
9) Several error return and NULL deref bug fixes in networking drivers
from Julia Lawall.
10) A large smattering of struct padding et al. kernel memory leaks to
userspace found of Mathias Krause.
11) Conntrack expections in netfilter can access an uninitialized timer,
fix from Pablo Neira Ayuso.
12) Several netfilter SIP tracker bug fixes from Patrick McHardy.
13) IPSEC ipv6 routes are not initialized correctly all the time,
resulting in an OOPS in inet_putpeer(). Also from Patrick McHardy.
14) Bridging does rcu_dereference() outside of RCU protected area, from
Stephen Hemminger.
15) Fix routing cache removal performance regression when looking up
output routes that have a local destination. From Zheng Yan.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (87 commits)
af_netlink: force credentials passing [CVE-2012-3520]
ipv4: fix ip header ident selection in __ip_make_skb()
ipv4: Use newinet->inet_opt in inet_csk_route_child_sock()
tcp: fix possible socket refcount problem
net: tcp: move sk_rx_dst_set call after tcp_create_openreq_child()
net/core/dev.c: fix kernel-doc warning
netconsole: remove a redundant netconsole_target_put()
net: ipv6: fix oops in inet_putpeer()
net/stmmac: fix issue of clk_get for Loongson1B.
caif: Do not dereference NULL in chnl_recv_cb()
af_packet: don't emit packet on orig fanout group
drivers/net/irda: fix error return code
drivers/net/wan/dscc4.c: fix error return code
drivers/net/wimax/i2400m/fw.c: fix error return code
smsc75xx: add missing entry to MAINTAINERS
net: qmi_wwan: new devices: UML290 and K5006-Z
net: sh_eth: Add eth support for R8A7779 device
netdev/phy: skip disabled mdio-mux nodes
dt: introduce for_each_available_child_of_node, of_get_next_available_child
net: netprio: fix cgrp create and write priomap race
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull more USB patches from Greg Kroah-Hartman:
"Here are 10 more USB patches for 3.6-rc3. They all fix reported
problems (build problems for one of them, and easily repeatable oopses
for the others.)
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
* tag 'usb-3.6-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb:
gpu/mfd/usb: Fix USB randconfig problems
USB: CDC ACM: Fix NULL pointer dereference
USB: emi62: remove __devinit* from the struct usb_device_id table
USB: winbond: remove __devinit* from the struct usb_device_id table
USB: vt6656: remove __devinit* from the struct usb_device_id table
USB: rtl8187: remove __devinit* from the struct usb_device_id table
USB: p54usb: remove __devinit* from the struct usb_device_id table
USB: spca506: remove __devinit* from the struct usb_device_id table
USB: jl2005bcd: remove __devinit* from the struct usb_device_id table
USB: smsusb: remove __devinit* from the struct usb_device_id table
This structure needs to always stick around, even if CONFIG_HOTPLUG
is disabled, otherwise we can oops when trying to probe a device that
was added after the structure is thrown away.
Thanks to Fengguang Wu and Bjørn Mork for tracking this issue down.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Reported-by: Bjørn Mork <bjorn@mork.no>
Cc: stable <stable@vger.kernel.org>
CC: Herton Ronaldo Krzesinski <herton@canonical.com>
CC: Hin-Tak Leung <htl10@users.sourceforge.net>
CC: Larry Finger <Larry.Finger@lwfinger.net>
CC: "John W. Linville" <linville@tuxdriver.com>
CC: Christian Lamparter <chunkeey@googlemail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
Lockdep found an inconsistent lock state when joining a mesh with
ath5k. The problem is that ath5k takes the lock for its beacon state,
ah->block, with spin_lock_irqsave(), while mesh internally takes the
sync_offset_lock with spin_lock_bh() in mesh_sync_offset_adjust_tbtt(),
which in turn is called under ah->block.
This could deadlock if the beacon tasklet was run on the processor
that held the beacon lock during the do_softirq() in spin_unlock_bh().
We probably shouldn't hold the lock around the callbacks, but the
easiest fix is to switch to spin_lock_bh for ah->block: it doesn't
need interrupts disabled anyway as the data in question is only accessed
in softirq or process context.
Fixes the following lockdep warning:
[ 446.892304] WARNING: at kernel/softirq.c:159 _local_bh_enable_ip+0x38/0xa6()
[ 446.892306] Hardware name: MacBook1,1
[ 446.892309] Modules linked in: tcp_lp fuse sunrpc cpufreq_ondemand acpi_cpufreq mperf ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 nf_conntrack_ipv4 ip6table_filter nf_defrag_ipv4 xt_state nf_conntrack ip6_tables ext2 arc4 btusb bluetooth snd_hda_codec_idt snd_hda_intel carl9170 snd_hda_codec coretemp joydev ath5k snd_hwdep snd_seq isight_firmware ath snd_seq_device snd_pcm applesmc appletouch mac80211 input_polldev snd_timer microcode cfg80211 snd lpc_ich pcspkr i2c_i801 mfd_core soundcore rfkill snd_page_alloc sky2 tpm_infineon virtio_net kvm_intel kvm i915 drm_kms_helper drm i2c_algo_bit i2c_core video
[ 446.892385] Pid: 1892, comm: iw Not tainted 3.6.0-rc1-wl+ #296
[ 446.892387] Call Trace:
[ 446.892394] [<c0432958>] warn_slowpath_common+0x7c/0x91
[ 446.892398] [<c04399d7>] ? _local_bh_enable_ip+0x38/0xa6
[ 446.892403] [<c04399d7>] ? _local_bh_enable_ip+0x38/0xa6
[ 446.892459] [<f7f9ae3b>] ? mesh_sync_offset_adjust_tbtt+0x95/0x99 [mac80211]
[ 446.892464] [<c043298f>] warn_slowpath_null+0x22/0x24
[ 446.892468] [<c04399d7>] _local_bh_enable_ip+0x38/0xa6
[ 446.892473] [<c0439a52>] local_bh_enable_ip+0xd/0xf
[ 446.892479] [<c088004f>] _raw_spin_unlock_bh+0x34/0x37
[ 446.892527] [<f7f9ae3b>] mesh_sync_offset_adjust_tbtt+0x95/0x99 [mac80211]
[ 446.892569] [<f7f7650f>] ieee80211_beacon_get_tim+0x28f/0x4e0 [mac80211]
[ 446.892575] [<c047ceeb>] ? trace_hardirqs_on_caller+0x10e/0x13f
[ 446.892591] [<f7fdc541>] ath5k_beacon_update+0x40/0x26b [ath5k]
[ 446.892597] [<c047ad67>] ? lock_acquired+0x1f5/0x21e
[ 446.892612] [<f7fdf9fb>] ? ath5k_bss_info_changed+0x167/0x1b2 [ath5k]
[ 446.892617] [<c087f9ea>] ? _raw_spin_lock_irqsave+0x78/0x82
[ 446.892632] [<f7fdf9fb>] ? ath5k_bss_info_changed+0x167/0x1b2 [ath5k]
[ 446.892647] [<f7fdfa09>] ath5k_bss_info_changed+0x175/0x1b2 [ath5k]
[ 446.892651] [<c0479dd4>] ? lock_is_held+0x73/0x7b
[ 446.892662] [<c0458fd5>] ? __might_sleep+0xa7/0x17a
[ 446.892698] [<f7f5d8f7>] ieee80211_bss_info_change_notify+0x1ed/0x21a [mac80211]
[ 446.892703] [<c0449875>] ? queue_work+0x24/0x32
[ 446.892718] [<f7fdf894>] ? ath5k_configure_filter+0x163/0x163 [ath5k]
[ 446.892766] [<f7f95fa4>] ieee80211_start_mesh+0xb9/0xbd [mac80211]
[ 446.892806] [<f7f6e610>] ieee80211_join_mesh+0x10c/0x116 [mac80211]
[ 446.892834] [<f7a96b90>] __cfg80211_join_mesh+0x176/0x1b3 [cfg80211]
[ 446.892855] [<f7a96c1c>] cfg80211_join_mesh+0x4f/0x6a [cfg80211]
[ 446.892875] [<f7a89891>] nl80211_join_mesh+0x1de/0x1ed [cfg80211]
[ 446.892908] [<f7a8db99>] ? nl80211_set_wiphy+0x4cf/0x4cf [cfg80211]
[ 446.892919] [<c07cfa36>] genl_rcv_msg+0x1d5/0x1f3
[ 446.892940] [<c07cf861>] ? genl_rcv+0x25/0x25
[ 446.892946] [<c07cf009>] netlink_rcv_skb+0x37/0x78
[ 446.892950] [<c07cf85a>] genl_rcv+0x1e/0x25
[ 446.892955] [<c07cebf3>] netlink_unicast+0xc3/0x12d
[ 446.892959] [<c07cee46>] netlink_sendmsg+0x1e9/0x213
[ 446.892966] [<c079f282>] sock_sendmsg+0x79/0x96
[ 446.892972] [<c04eb90d>] ? might_fault+0x9d/0xa3
[ 446.892978] [<c07a81d8>] ? copy_from_user+0x8/0xa
[ 446.892983] [<c07a852c>] ? verify_iovec+0x43/0x77
[ 446.892987] [<c079f4d8>] __sys_sendmsg+0x180/0x215
[ 446.892993] [<c045f107>] ? sched_clock_cpu+0x134/0x144
[ 446.892997] [<c047992f>] ? trace_hardirqs_off+0xb/0xd
[ 446.893002] [<c047bf88>] ? __lock_acquire+0x46b/0xb6e
[ 446.893006] [<c047992f>] ? trace_hardirqs_off+0xb/0xd
[ 446.893010] [<c045f149>] ? local_clock+0x32/0x49
[ 446.893015] [<c0479ec1>] ? lock_release_holdtime.part.9+0x4b/0x51
[ 446.893020] [<c0479dd4>] ? lock_is_held+0x73/0x7b
[ 446.893025] [<c050d127>] ? fcheck_files+0x97/0xcd
[ 446.893029] [<c050d4df>] ? fget_light+0x2d/0x81
[ 446.893034] [<c07a01f3>] sys_sendmsg+0x3b/0x52
[ 446.893038] [<c07a07b4>] sys_socketcall+0x238/0x2a2
[ 446.893044] [<c0885edf>] sysenter_do_call+0x12/0x38
[ 446.893047] ---[ end trace a9af5998f929270f ]---
[ 447.627222]
[ 447.627232] =================================
[ 447.627237] [ INFO: inconsistent lock state ]
[ 447.627244] 3.6.0-rc1-wl+ #296 Tainted: G W
[ 447.627248] ---------------------------------
[ 447.627253] inconsistent {SOFTIRQ-ON-W} -> {IN-SOFTIRQ-W} usage.
[ 447.627260] swapper/0/0 [HC0[0]:SC1[1]:HE1:SE0] takes:
[ 447.627264] (&(&ah->block)->rlock){+.?...}, at: [<f7fdd2d1>] ath5k_tasklet_beacon+0x91/0xa7 [ath5k]
[ 447.627299] {SOFTIRQ-ON-W} state was registered at:
[ 447.627304] [<c047cdbf>] mark_held_locks+0x59/0x77
[ 447.627316] [<c047ceeb>] trace_hardirqs_on_caller+0x10e/0x13f
[ 447.627324] [<c047cf27>] trace_hardirqs_on+0xb/0xd
[ 447.627332] [<c0439a3d>] _local_bh_enable_ip+0x9e/0xa6
[ 447.627342] [<c0439a52>] local_bh_enable_ip+0xd/0xf
[ 447.627349] [<c088004f>] _raw_spin_unlock_bh+0x34/0x37
[ 447.627359] [<f7f9ae3b>] mesh_sync_offset_adjust_tbtt+0x95/0x99 [mac80211]
[ 447.627451] [<f7f7650f>] ieee80211_beacon_get_tim+0x28f/0x4e0 [mac80211]
[ 447.627526] [<f7fdc541>] ath5k_beacon_update+0x40/0x26b [ath5k]
[ 447.627547] [<f7fdfa09>] ath5k_bss_info_changed+0x175/0x1b2 [ath5k]
[ 447.627569] [<f7f5d8f7>] ieee80211_bss_info_change_notify+0x1ed/0x21a [mac80211]
[ 447.627628] [<f7f95fa4>] ieee80211_start_mesh+0xb9/0xbd [mac80211]
[ 447.627712] [<f7f6e610>] ieee80211_join_mesh+0x10c/0x116 [mac80211]
[ 447.627782] [<f7a96b90>] __cfg80211_join_mesh+0x176/0x1b3 [cfg80211]
[ 447.627816] [<f7a96c1c>] cfg80211_join_mesh+0x4f/0x6a [cfg80211]
[ 447.627845] [<f7a89891>] nl80211_join_mesh+0x1de/0x1ed [cfg80211]
[ 447.627872] [<c07cfa36>] genl_rcv_msg+0x1d5/0x1f3
[ 447.627881] [<c07cf009>] netlink_rcv_skb+0x37/0x78
[ 447.627891] [<c07cf85a>] genl_rcv+0x1e/0x25
[ 447.627898] [<c07cebf3>] netlink_unicast+0xc3/0x12d
[ 447.627907] [<c07cee46>] netlink_sendmsg+0x1e9/0x213
[ 447.627915] [<c079f282>] sock_sendmsg+0x79/0x96
[ 447.627926] [<c079f4d8>] __sys_sendmsg+0x180/0x215
[ 447.627934] [<c07a01f3>] sys_sendmsg+0x3b/0x52
[ 447.627941] [<c07a07b4>] sys_socketcall+0x238/0x2a2
[ 447.627949] [<c0885edf>] sysenter_do_call+0x12/0x38
[ 447.627959] irq event stamp: 1929200
[ 447.627963] hardirqs last enabled at (1929200): [<c043a0e9>] tasklet_hi_action+0x3e/0xbf
[ 447.627972] hardirqs last disabled at (1929199): [<c043a0c0>] tasklet_hi_action+0x15/0xbf
[ 447.627981] softirqs last enabled at (1929196): [<c043999d>] _local_bh_enable+0x12/0x14
[ 447.627989] softirqs last disabled at (1929197): [<c040443b>] do_softirq+0x63/0xb8
[ 447.627999]
[ 447.627999] other info that might help us debug this:
[ 447.628004] Possible unsafe locking scenario:
[ 447.628004]
[ 447.628009] CPU0
[ 447.628012] ----
[ 447.628016] lock(&(&ah->block)->rlock);
[ 447.628023] <Interrupt>
[ 447.628027] lock(&(&ah->block)->rlock);
[ 447.628034]
[ 447.628034] *** DEADLOCK ***
Signed-off-by: Bob Copeland <me@bobcopeland.com>
ath_rx_tasklet() calls ath9k_rx_skb_preprocess() and ath9k_rx_skb_postprocess()
in a loop over the received frames. The decrypt_error flag is
initialized to false
just outside ath_rx_tasklet() loop. ath9k_rx_accept(), called by
ath9k_rx_skb_preprocess(),
only sets decrypt_error to true and never to false.
Then ath_rx_tasklet() calls ath9k_rx_skb_postprocess() and passes
decrypt_error to it.
So, after a decryption error, in ath9k_rx_skb_postprocess(), we can
have a leftover value
from another processed frame. In that case, the frame will not be marked with
RX_FLAG_DECRYPTED even if it is decrypted correctly.
When using CCMP encryption this issue can lead to connection stuck
because of CCMP
PN corruption and a waste of CPU time since mac80211 tries to decrypt an already
deciphered frame with ieee80211_aes_ccm_decrypt.
Fix the issue initializing decrypt_error flag at the begging of the
Signed-off-by: Lorenzo Bianconi <lorenzo.bianconi83@gmail.com>
Cc: <stable@kernel.org>
During suspend, the device will be moved to FULLSLEEP state.
As btcoex is never been stopped, the btcoex timer is running
and tries to access hw on fullsleep state. Fix that.
Cc: stable@vger.kernel.org
Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com>
This return holds the number of bytes transfered (1 byte) or a negative
error code. The type should be int instead of u8.
Acked-by: Pavel Roskin <proski@gnu.org>
Do not leak memory by updating pointer with potentially NULL realloc return value.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
Acked-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
commit b74713d04effbacd3d126ce94cec18742187b6ce
"ath9k: Handle fatal interrupts properly" introduced a race condition, where
IRQs are being left enabled, however the irq handler returns IRQ_HANDLED
while the reset is still queued without addressing the IRQ cause.
This leads to an IRQ storm that prevents the system from even getting to
the reset code.
Fix this by disabling IRQs in the handler without touching intr_ref_cnt.
Cc: Rajkumar Manoharan <rmanohar@qca.qualcomm.com>
Cc: Sujith Manoharan <c_manoha@qca.qualcomm.com>
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Pull networking fixes from David Miller:
1) Missed rcu_assign_pointer() in mac80211 scanning, from Johannes
Berg.
2) Allow devices to limit the number of segments that an individual
TCP TSO packet can use at a time, to deal with device and/or driver
specific limitations. From Ben Hutchings.
3) Fix unexpected hard IPSEC expiration after setting the date. From
Fan Du.
4) Memory leak fix in bxn2x driver, from Jesper Juhl.
5) Fix two memory leaks in libertas driver, from Daniel Drake.
6) Fix deref of out-of-range array index in packet scheduler generic
actions layer. From Hiroaki SHIMODA.
7) Fix TX flow control errors in mlx4 driver, from Yevgeny Petrilin.
8) Fix CRIS eth_v10.c driver build, from Randy Dunlap.
9) Fix wrong SKB freeing in LLC protocol layer, from Sorin Dumitru.
10) The IP output path checks neigh lookup errors incorrectly, it needs
to use IS_ERR(). From Vasiliy Kulikov.
11) An estimator leak leads to deref of freed memory in timer handler,
fix from Hiroaki SHIMODA.
12) TCP early demux in ipv6 needs to use DST cookies in order to
validate the RX route properly. Fix from Eric Dumazet.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (43 commits)
net: ipv6: fix TCP early demux
net: Use PTR_RET rather than if(IS_ERR(.. [1]
net_sched: act: Delete estimator in error path.
ip: fix error handling in ip_finish_output2()
llc: free the right skb
ixp4xx_eth: fix ptp_ixp46x build failure
drivers/atm/iphase.c: fix error return code
tcp_output: fix sparse warning for tcp_wfree
drivers/net/phy/mdio-mux-gpio.c: drop devm_kfree of devm_kzalloc'd data
batman-adv: select an internet gateway if none was chosen
mISDN: Bugfix for layer2 fixed TEI mode
igb: don't break user visible strings over multiple lines in igb_ethtool.c
igb: correct hardware type (i210/i211) check in igb_loopback_test()
igb: Fix for failure to init on some 82576 devices.
cris: fix eth_v10.c build error
cdc-ncm: tag Ericsson WWAN devices (eg F5521gw) with FLAG_WWAN
isdnloop: fix and simplify isdnloop_init()
hyperv: Move wait completion msg code into rndis_filter_halt_device()
net/mlx4_core: Remove port type restrictions
net/mlx4_en: Fixing TX queue stop/wake flow
There's a bug that causes the rate scaling to get stuck
when it has to use single-stream rates with a peer that
can do GF and SGI; the two are incompatible so we can't
use them together, but that causes the algorithm to not
work at all, it always rejects updates.
Disable greenfield for now to prevent that problem.
Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Tested-by: Cesar Eduardo Barros <cesarb@cesarb.net>
We can not pass NULL libconf->conf->channel to rt61pci_config() as it
is dereferenced unconditionally in rt61pci_config_lna_gain() subroutine.
Resolves:
https://bugzilla.kernel.org/show_bug.cgi?id=44361
Reported-and-tested-by: <dolohow@gmail.com>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
AR1111 is same as AR9485. The h/w
difference between them is quite insignificant,
Felix suggests only very few baseband features
may not be available in AR1111. The h/w code for
AR9485 is already present, so AR1111 should
work fine with the addition of its PID/VID.
Cc: stable@vger.kernel.org [2.6.39+]
Cc: Felix Bitterli <felixb@qca.qualcomm.com>
Reported-by: Tim Bentley <Tim.Bentley@Gmail.com>
Signed-off-by: Mohammed Shafi Shajakhan <mohammed@qca.qualcomm.com>
Tested-by: Tim Bentley <Tim.Bentley@Gmail.com>
Pull OLPC platform updates from Andres Salomon:
"These move the OLPC Embedded Controller driver out of
arch/x86/platform and into drivers/platform/olpc.
OLPC machines are now ARM-based (which means lots of x86 and ARM
changes), but are typically pretty self-contained.. so it makes more
sense to go through a separate OLPC tree after getting the appropriate
review/ACKs."
* 'for-linus-3.6' of git://dev.laptop.org/users/dilinger/linux-olpc:
x86: OLPC: move s/r-related EC cmds to EC driver
Platform: OLPC: move global variables into priv struct
Platform: OLPC: move debugfs support from x86 EC driver
x86: OLPC: switch over to using new EC driver on x86
Platform: OLPC: add a suspended flag to the EC driver
Platform: OLPC: turn EC driver into a platform_driver
Platform: OLPC: allow EC cmd to be overridden, and create a workqueue to call it
drivers: OLPC: update various drivers to include olpc-ec.h
Platform: OLPC: add a stub to drivers/platform/ for the OLPC EC driver
brcmsmac cannot call freq_reg_info() during channel changes as it does
not hold cfg80211_lock, and as a result it generates a lockdep warning.
freq_reg_info() is being used to determine whether OFDM is allowed on
the current channel, so we can avoid the errant call by using the new
IEEE80211_CHAN_NO_OFDM for this purpose instead.
Reported-by: Josh Boyer <jwboyer@redhat.com>
Signed-off-by: Seth Forshee <seth.forshee@canonical.com>
The if_sdio_card structure was never being freed, and neither
was the command structure used for association.
Signed-off-by: Daniel Drake <dsd@laptop.org>
This patch is going to fix the resuming failed from S3/S4
for rt3290 chip.
Signed-off-by: Woody Hung <Woody.Hung@mediatek.com>
Cc: Kevin Chou <kevin.chou@mediatek.com>
Signed-off-by: Chen, Chien-Chia <machen@suse.com>
Reviewed-by: Stanislaw Gruszka <sgruszka@redhat.com>
On an OLPC XO-1.5 we have seen the following situation:
- the system starts going into suspend
- no wake params are set, so the mmc layer removes the card
- during remove, we send a command to the card
- that command fails, causing if_sdio's reset method to try and remove
the mmc card in attempt to reset it
- the mmc layer is not happy about being asked to remove a card that
it is already removing, and the kernel crashes
While the MMC layer could possibly be taught to behave better here,
it also seems sensible for libertas not to try and reset a card if
we're in the process of removing it anyway.
Acked-by: Dan Williams <dcbw@redhat.com>
Add some comments by the way
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
Pull second vfs pile from Al Viro:
"The stuff in there: fsfreeze deadlock fixes by Jan (essentially, the
deadlock reproduced by xfstests 068), symlink and hardlink restriction
patches, plus assorted cleanups and fixes.
Note that another fsfreeze deadlock (emergency thaw one) is *not*
dealt with - the series by Fernando conflicts a lot with Jan's, breaks
userland ABI (FIFREEZE semantics gets changed) and trades the deadlock
for massive vfsmount leak; this is going to be handled next cycle.
There probably will be another pull request, but that stuff won't be
in it."
Fix up trivial conflicts due to unrelated changes next to each other in
drivers/{staging/gdm72xx/usb_boot.c, usb/gadget/storage_common.c}
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (54 commits)
delousing target_core_file a bit
Documentation: Correct s_umount state for freeze_fs/unfreeze_fs
fs: Remove old freezing mechanism
ext2: Implement freezing
btrfs: Convert to new freezing mechanism
nilfs2: Convert to new freezing mechanism
ntfs: Convert to new freezing mechanism
fuse: Convert to new freezing mechanism
gfs2: Convert to new freezing mechanism
ocfs2: Convert to new freezing mechanism
xfs: Convert to new freezing code
ext4: Convert to new freezing mechanism
fs: Protect write paths by sb_start_write - sb_end_write
fs: Skip atime update on frozen filesystem
fs: Add freezing handling to mnt_want_write() / mnt_drop_write()
fs: Improve filesystem freezing handling
switch the protection of percpu_counter list to spinlock
nfsd: Push mnt_want_write() outside of i_mutex
btrfs: Push mnt_want_write() outside of i_mutex
fat: Push mnt_want_write() outside of i_mutex
Switch over to using olpc-ec.h in multiple steps, so as not to break builds.
This covers every driver that calls olpc_ec_cmd().
Signed-off-by: Andres Salomon <dilinger@queued.net>
Acked-by: Paul Fox <pgf@laptop.org>
... only needed if it's been in descriptor table
control.vif
info->control.sta and control.vif may only be dereferenced during the
drv_tx call otherwise could lead to use-after-free bugs.
Signed-off-by: Thomas Huehn <thomas@net.t-labs.tu-berlin.de>
Pull trivial tree from Jiri Kosina:
"Trivial updates all over the place as usual."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (29 commits)
Fix typo in include/linux/clk.h .
pci: hotplug: Fix typo in pci
iommu: Fix typo in iommu
video: Fix typo in drivers/video
Documentation: Add newline at end-of-file to files lacking one
arm,unicore32: Remove obsolete "select MISC_DEVICES"
module.c: spelling s/postition/position/g
cpufreq: Fix typo in cpufreq driver
trivial: typo in comment in mksysmap
mach-omap2: Fix typo in debug message and comment
scsi: aha152x: Fix sparse warning and make printing pointer address more portable.
Change email address for Steve Glendinning
Btrfs: fix typo in convert_extent_bit
via: Remove bogus if check
netprio_cgroup.c: fix comment typo
backlight: fix memory leak on obscure error path
Documentation: asus-laptop.txt references an obsolete Kconfig item
Documentation: ManagementStyle: fixed typo
mm/vmscan: cleanup comment error in balance_pgdat
mm: cleanup on the comments of zone_reclaim_stat
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem
Signed-off-by: Duan Jiong <djduanjiong@gmail.com>
In some rare cases, the CMD_ROC completion may take over 1 second.
The timeout had earlier been increased to 1000ms (from 750ms), but it
is still not enoug. Increase it to 1500ms.
Signed-off-by: Luciano Coelho <coelho@ti.com>
We need to wait for the command completion event when we send the
CMD_ROLE_STOP event otherwise we may try to send CMD_ROLE_START too
soon and get out-of-sync with the firmware.
In some cases, the firmware may not send the event, so we wait for the
event or for the timeout, whichever comes first.
This patch is based on an earlier version by Eliad.
Cc: Eliad Peller <eliad@wizery.com>
Use this opportunity to consolidate the check for MIMO support into a
separate function.
Signed-off-by: Arik Nemtsov <arik@wizery.com>
handle errors of nla_put() inside the if(nla_put...) {}
This makes the code simpler and clearer because:
we take advantage from the fact that we have only one nla_put
in our routines (so no real need for goto label).
this avoids ugly goto forward followed by goto backward.
Signed-off-by: Yair Shapira <yair.shapira@ti.com>
this completes the calibrator based fem detect logic in driver:
driver starts (by calibrator) in plt_mode PLT_FEM_DETECT
wlcore inits and starts plt on wl12xx
wl12xx fetches fem number from firmware and stores it in wl->fem_manuf
wl12xx immediatly returns (doesn't start radio, etc...)
wlcore returns the fem_manuf to calibrator using WL1271_TM_ATTR_DATA
plt_mode is stopped
bip calibration is not required in wl18xx. Therefore we
disable also auto fem (using calibrator fem detect) mode.
add wl->plt_mode that is used to indicate different plt
working modes: this will be used to implement calibrator side
auto fem detection where driver asks firmware to detect
the wlan fem radio type and returns it to calibrator.
this is not implemented yet and plt_modes: PLT_ON and
PLT_FEM_DETECT currently behave the same.
After the latest mac80211 changes, the sta has
the ap's sta pointer even before association.
This cause the auth and assoc frames to be sent
with the standard ap's rates, rather than the
basic rates.
Change the tx rate policy logic to use the regular
ap rates only for data packets (so control and mgmt
packets will be sent with basic rates)
Signed-off-by: Eliad Peller <eliad@wizery.com>
During interface removal, don't adjust sleep_auth if we are during
recovery. Since the FW is potentially dead we shouldn't talk to it.
Reported-by: Yossi Wortzel <yossiw@ti.com>
Initialize val to 0, to remove the following warning with
CONFIG_CC_OPTIMIZE_FOR_SIZE. The compiler used was gcc 4.4.1
(Sourcery G++ Lite 2010q1-202).
drivers/net/wireless/ti/wl18xx/io.c: In function 'wl18xx_top_reg_read':
drivers/net/wireless/ti/wl18xx/io.c:57: warning: 'val' may be used uninitialized in this function
Send EAPOLs using minimum basic rate for AP, STA, p2p GO and Client.
The patch fixes p2p connection issue with Realtek device in p2p
certification test 5.1.13 (DEVUT reinvokes Persistent Group).
Signed-off-by: Igal Chernobelsky <igalc@ti.com>
ht_mode added to wl18xx conf struct in order to support different modes
from the configuration file, as well as module params, and by default
(working without a conf file and/or no module params).
the hack regarding conf.phy.low_band_component_type for each board
is now explicitly handled after parsing module params.
missing default values to wl18xx config added.
fix string module params not to have defaults (so if empty, param
can be taken from conf file).
update conf version to 3.
Signed-off-by: Ido Reis <idor@ti.com>
suspend and resume callbacks configure wakeup conditions to the FW
which may be different between suspend and resume.
This feature is currently not utilized as both in suspend and resume
FW wakeup every 1 DTIM. Avoid waking up the chip and doing the FW command
unless there's an actual difference in the wakeup conditions.
Signed-off-by: Eyal Shapira <eyal@wizery.com>
We get DMA alignment trouble if the beginning of the conf.phy struct is
not aligned to 4 bytes. Use kmemdup to ensure alignment.
b43 with open firmware crashes mac80211 because
it changes the number of queues at runtime which,
while it was never really supported, now crashes
mac80211 due to the new hardware queue logic.
Fix this by detecting open vs. proprietary fw
earlier and registering with mac80211 with the
right number of queues.
Tested-by: Stefan Lippers-Hollmann <s.l-h@gmx.de>
Cc: stable@vger.kernel.org (depends on commit a6f38ac3)
Using work_pending() to defer certain operations when
a HW-reset work has been queued is racy since the check
would return false when the work item is actually in
execution. Use SC_OP_HW_RESET instead to fix this race.
Also, unify the reset debug statistics maintenance.
Signed-off-by: Sujith Manoharan <c_manoha@qca.qualcomm.com>
When an interface in AP or P2P-GO mode is removed,
check whether a station interface is already present and
reconfigure the beacon timers etc. properly if it's
associated.
Currently, there are problems with how ANI is handled in
multi-VIF scenarios. This patch addresses them by unifying
the start/stop logic.
Remove unused variables, use a helper function to choose
the slot and reset beaconing status at one place.
