path: root/drivers/net/xilinx_emaclite.c
2011-06-21drivers/net: Remove casts of void *Joe Perches
Unnecessary casts of void * clutter the code. These are the remainder casts after several specific patches to remove netdev_priv and dev_priv. Done via coccinelle script (and a little editing): $ cat cast_void_pointer.cocci @@ type T; T *pt; void *pv; @@ - pt = (T *)pv; + pt = pv; Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Acked-By: Chris Snook <chris.snook@gmail.com> Acked-by: Jon Mason <jdmason@kudzu.us> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: David Dillow <dave@thedillows.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-20emaclite: enable transmit and receive time stamping.Richard Cochran
This patch enables software (and phy device) time stamping. Since this MAC uses phylib, adding the hooks make hardware time stamping in the phy possible. Compile tested only. Cc: John Linn <john.linn@xilinx.com> Signed-off-by: Richard Cochran <richard.cochran@omicron.at> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-09net: emaclite: Add missing linux/interrupt.h headerMichal Simek
Log: drivers/net/xilinx_emaclite.c: In function 'xemaclite_open': drivers/net/xilinx_emaclite.c:961: error: implicit declaration of function 'request_irq' drivers/net/xilinx_emaclite.c: In function 'xemaclite_close': drivers/net/xilinx_emaclite.c:995: error: implicit declaration of function 'free_irq' make[2]: *** [drivers/net/xilinx_emaclite.o] Error 1 make[1]: *** [drivers/net] Error 2 make: *** [drivers] Error 2 Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-28dt/net: Eliminate users of of_platform_{,un}register_driverGrant Likely
Get rid of users of of_platform_driver in drivers/net. The of_platform_{,un}register_driver functions are going away, so the users need to be converted to using the platform_bus_type directly. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-01-10Merge branch 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6: (29 commits) of/flattree: forward declare struct device_node in of_fdt.h ipmi: explicitly include of_address.h and of_irq.h sparc: explicitly cast negative phandle checks to s32 powerpc/405: Fix missing #{address,size}-cells in i2c node powerpc/5200: dts: refactor dts files powerpc/5200: dts: Change combatible strings on localbus powerpc/5200: dts: remove unused properties powerpc/5200: dts: rename nodes to prepare for refactoring dts files of/flattree: Update dtc to current mainline. of/device: Don't register disabled devices powerpc/dts: fix syntax bugs in bluestone.dts of: Fixes for OF probing on little endian systems of: make drivers depend on CONFIG_OF instead of CONFIG_PPC_OF of/flattree: Add of_flat_dt_match() helper function of_serial: explicitly include of_irq.h of/flattree: Refactor unflatten_device_tree and add fdt_unflatten_tree of/flattree: Reorder unflatten_dt_node of/flattree: Refactor unflatten_dt_node of/flattree: Add non-boottime device tree functions of/flattree: Add Kconfig for EARLY_FLATTREE ... Fix up trivial conflict in arch/sparc/prom/tree_32.c as per Grant.
2010-12-06net: emaclite: Omit private ndo_get_stats functionTobias Klauser
xemaclite_get_stats() just returns dev->stats so we can leave it out alltogether and let dev_get_stats() do the job. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-17drivers/net: Remove unnecessary casts of netdev_privJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-01of/net: Move of_get_mac_address() to a common source file.David Daney
There are two identical implementations of of_get_mac_address(), one each in arch/powerpc/kernel/prom_parse.c and arch/microblaze/kernel/prom_parse.c. Move this function to a new common file of_net.{c,h} and adjust all the callers to include the new header. Signed-off-by: David Daney <ddaney@caviumnetworks.com> [grant.likely@secretlab.ca: protect header with #ifdef] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-10-25Merge branch 'next' of git://git.monstr.eu/linux-2.6-microblazeLinus Torvalds
* 'next' of git://git.monstr.eu/linux-2.6-microblaze: (42 commits) microblaze: Fix build with make 3.82 fbdev/xilinxfb: Microblaze driver support microblaze: Support C optimized lib functions for little-endian microblaze: Separate library optimized functions microblaze: Support timer on AXI lite microblaze: Add support for little-endian Microblaze microblaze: KGDB little endian support microblaze: Add PVR for endians plus detection net: emaclite: Add support for little-endian platforms microblaze: trivial: Add comment for AXI pvr microblaze: pci-common cleanup microblaze: Support early console on uart16550 microblaze: Do not compile early console support for uartlite if is disabled microblaze: Setup early console dynamically microblaze: Rename all uartlite early printk functions microblaze: remove early printk uarlite console dependency from header microblaze: Remove additional compatible properties microblaze: Remove hardcoded asm instraction for PVR loading microblaze: Use static const char * const where possible microblaze: Define VMALLOC_START/END ...
2010-10-21net: emaclite: Add support for little-endian platformsMichal Simek
Upcomming Microblaze is little endian that's why is necessary to fix protocol and length loading. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net> CC: Eric Dumazet <eric.dumazet@gmail.com> CC: netdev@vger.kernel.org CC: linux-kernel@vger.kernel.org CC: devicetree-discuss@lists.ozlabs.org
2010-09-02drivers/net: avoid some skb->ip_summed initializationsEric Dumazet
fresh skbs have ip_summed set to CHECKSUM_NONE (0) We can avoid setting again skb->ip_summed to CHECKSUM_NONE in drivers. Introduce skb_checksum_none_assert() helper so that we keep this assertion documented in driver sources. Change most occurrences of : skb->ip_summed = CHECKSUM_NONE; by : skb_checksum_none_assert(skb); Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-19xilinx_emaclite: netpoll supportMichal Simek
Netconsole requires poll support. Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-06of/device: Replace struct of_device with struct platform_deviceGrant Likely
of_device is just an alias for platform_device, so remove it entirely. Also replace to_of_device() with to_platform_device() and update comment blocks. This patch was initially generated from the following semantic patch, and then edited by hand to pick up the bits that coccinelle didn't catch. @@ @@ -struct of_device +struct platform_device Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: David S. Miller <davem@davemloft.net>
2010-08-01of/address: Clean up function declarationsGrant Likely
This patch moves the declaration of of_get_address(), of_get_pci_address(), and of_pci_address_to_resource() out of arch code and into the common linux/of_address header file. This patch also fixes some of the asm/prom.h ordering issues. It still includes some header files that it ideally shouldn't be, but at least the ordering is consistent now so that of_* overrides work. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-22Merge remote branch 'origin' into secretlab/next-devicetreeGrant Likely
Merging in current state of Linus' tree to deal with merge conflicts and build failures in vio.c after merge. Conflicts: drivers/i2c/busses/i2c-cpm.c drivers/i2c/busses/i2c-mpc.c drivers/net/gianfar.c Also fixed up one line in arch/powerpc/kernel/vio.c to use the correct node pointer. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-22of: Remove duplicate fields from of_platform_driverGrant Likely
.name, .match_table and .owner are duplicated in both of_platform_driver and device_driver. This patch is a removes the extra copies from struct of_platform_driver and converts all users to the device_driver members. This patch is a pretty mechanical change. The usage model doesn't change and if any drivers have been missed, or if anything has been fixed up incorrectly, then it will fail with a compile time error, and the fixup will be trivial. This patch looks big and scary because it touches so many files, but it should be pretty safe. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Sean MacLennan <smaclennan@pikatech.com>
2010-05-18of: Always use 'struct device.of_node' to get device node pointer.Grant Likely
The following structure elements duplicate the information in 'struct device.of_node' and so are being eliminated. This patch makes all readers of these elements use device.of_node instead. (struct of_device *)->node (struct dev_archdata *)->prom_node (sparc) (struct dev_archdata *)->of_node (powerpc & microblaze) Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-06net: emaclite: Use resource_sizeTobias Klauser
Use the resource_size function instead of manually calculating the resource size. This reduces the chance of introducing off-by-one errors. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-03-30net: remove redundant codeEric Dumazet
eth_type_trans(skb, netdev) does the "skb->dev = netdev;" initialization, we can remove it from various network drivers. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-15net: emaclite: adding MDIO and phy lib supportJohn Linn
These changes add MDIO and phy lib support to the driver as the IP core now supports the MDIO bus. The MDIO bus and phy are added as a child to the emaclite in the device tree as illustrated below. mdio { #address-cells = <1>; #size-cells = <0>; phy0: phy@7 { compatible = "marvell,88e1111"; reg = <7>; } ; } Signed-off-by: Sadanand Mutyala <Sadanand.Mutyala@xilinx.com> Signed-off-by: John Linn <john.linn@xilinx.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-29drivers/net/xilinx_emaclite.c: use %pM to shown MAC addressH Hartley Sweeten
Use the %pM kernel extension to display the MAC address. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18drivers/net: request_irq - Remove unnecessary leading & from second argJoe Perches
Not as fancy as coccinelle. Checkpatch errors ignored. Compile tested allyesconfig x86, not all files compiled. grep -rPl --include=*.[ch] "\brequest_irq\s*\([^,\)]+,\s*\&" drivers/net | while read file ; do \ perl -i -e 'local $/; while (<>) { s@(\brequest_irq\s*\([^,\)]+,\s*)\&@\1@g ; print ; }' $file ;\ done Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-22net: xilinx_emaclite: Fix problem with first incoming packetMichal Simek
You can't ping the board or connect to it unless you send any packet out from board. Tested-by: John Williams <john.williams@petalogix.com> Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: John Linn <john.linn@xilinx.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02drivers: Kill now superfluous ->last_rx storesEric Dumazet
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Neil Horman <nhorman@txudriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01xilinx_emaclite: Fix permissions on driver sources.David S. Miller
Noticed by Michal Simek. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-20net: add Xilinx emac lite device driverJohn Linn
This patch adds support for the Xilinx Ethernet Lite device. The soft logic core from Xilinx is typically used on Virtex and Spartan designs attached to either a PowerPC or a Microblaze processor. Signed-off-by: Sadanand M <sadanan@xilinx.com> Signed-off-by: John Linn <john.linn@xilinx.com> Signed-off-by: David S. Miller <davem@davemloft.net>
