Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com>
Reviewed-by: Jiri Pirko <jpirko@redhat.com>
This patch adds support for a new adapter in the 82599 family. Included
in that support is a new media_type ixgbe_media_type_fiber_lco.
Signed-of-by: Don Skidmore <donald.c.skidmore@intel.com>
error: bad constant expression
Signed-off-by: Emil Tantilov <emil.s.tantilov@intel.com>
Tested-by: Evan Swanson <evan.swanson@intel.com>
This patch cleans up two minor issues in ixgbe_down. Specifically it
addresses the fact that the VFs should not be pinged until after interrupts
are disabled otherwise they might still get a response. It also drops the
use of the txdctl temporary variable since the only bit we should be
writing to the TXDCTL registers during a shutdown is the flush bit.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
This change merges the over-temp task into the service task. As a result
all tasklets are finally combined into once single tasklet for easier
management.
This change merges the ATR table reinitialization into the service task.
This is yet another opportunity to avoid any race conditions as we don't
want to be attempting to reinitialize the table during a possible reset.
In addition this change adds a counter for table reinitialization so that
it can be tracked as part of the regular statistics.
This change is meant to further help to reduce possible configuration
collisions between the various tasklets. This change combines the device
reset with the service task. As a result it is now not possible to be
updating the link on the device while also resetting the part.
This patch is meant to merge the functionality of the ixgbe watchdog task
into the service task. By doing this all link state functionality will be
controlled by a single task. As a result the reliability of the interface
will be improved as the likelihood of any race conditions is further
reduced.
This change is meant to address several race conditions with multi-speed
fiber SFP+ modules in 82599 adapters. Specifically issues have been seen
in which both the SFP configuration and the multi-speed fiber configuration
are running simultaneously which will result in the device getting into an
erroneous link down state.
This change moves flags and state into the same cacheline. The reason for
this change is because both are frequently read around the same time and
infrequently written. By combining them into the same cacheline this
should help to reduce memory utilization.
The semaphore can be in locked state upon driver load, particularly
on 82598 if a machine is rebooted due to panic and the semaphore was
acquired just prior to the panic.
This patch unlocks the semaphore if it times out.
Add infrastructure in the PF driver to support macvlan in the VF driver.
Signed-off-by: Greg Rose <gregory.v.rose@intel.com>
Tested-by: Sibai Li <sibai.li@intel.com>
Implement setup of unicast address list in the VF driver's set_rx_mode
netdev op. Unicast addresses are sent to the PF via a mailbox message
and the PF will check if it has room in the RAR table and if so set the
filter for the VF.
Signed-off-by: Bruce Allan <bruce.w.allan@intel.com>
Tested-by: Aaron Brown <aaron.f.brown@intel.com>
->read_proc interface is going away, switch to seq_file.
This patch fixes a bug in the set_pauseparam
function that didn't well manage the ANE
field and returned broken values when use
ethtool -A|-a.
Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com>
The driver used to call phy's ethtool configuration routine to start
auto-negotiation. This change has it call directly phy's routine to
start auto-negotiation.
The initial version was hiding phy_start_aneg() return value,
this patch returns it (<0 upon error).
Tested: module compiles, tested on STM HDK7108 STB.
Signed-off-by: David Decotigny <decot@google.com>
Update driver version number
Signed-off-by: Anirban Chakraborty <anirban.chakraborty@qlogic.com>
Driver checks if the previous dump has been cleared before taking the dump.
It doesn't take the dump if it is not cleared.
Changes from v2:
Added lock to protect dump data structures from being mangled while
dumping or setting them via ethtool.
Added code to take FW dump.
o Driver queries FW at the init time and gets the dump template
o It takes FW dump as per the dump template
o Level of FW dump (and its size) is configured via dump flag
Signed-off-by: Sritej Velaga <sritej.velaga@qlogic.com>
Sending mbox cmds require multiple steps of writing to the DB register and polling
for an ack. Gettting interrupted in the middle by a signal breaks the mbox protocol.
Use msleep() to not get interrupted.
Signed-off-by: Sathya Perla <sathya.perla@emulex.com>
If waiting on POST returns prematurely (due to a signal), abort polling and return an error.
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-next-2.6
This should also fix updating of vlan_features and propagating changes to
VLAN devices on the bond.
Side effect: it allows user to force-disable some offloads on the bond
interface.
Note: NETIF_F_VLAN_CHALLENGED is managed by bond_fix_features() now.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
Changes:
- while making NTB, driver shall check if device dwNtbOutMaxSize is higher than
host value and shall add a short packet if this is the case
- previous temporary patch for this issue is replaced by this one
Signed-off-by: Alexey Orishko <alexey.orishko@stericsson.com>
This patch adds tg3_set_features() to handle loopback mode. Currently the
capability is added for the devices which support internal MAC loopback mode.
So when enabled, it enables internal-MAC loopback.
Signed-off-by: Mahesh Bandewar <maheshb@google.com>
Resending this patch with few changes.
Avoid multiple queues when MSI or MSI-X not available
Limit number of Tx queues to 1 if MSI/MSI-X support is not configured in
the kernel. This will make number of tx and rx queues equal when MSI/X
is not configured thus providing better performance.
Signed-off-by: Bhavesh Davda <bhavesh@vmware.com>
Signed-off-by: Shreyas N Bhatewara <sbhatewara@vmware.com>
Start/stop TX queue is controlled by TX queue "used" counter.
It is incremented while WRBs are posted to TX queue and
decremented when TX completions are received. This counter was
getting decremented before HW is informed about processing of TX
completions. As used counter is decremented, transmit function
posts new WRBs and creates completion queue full scenario in HW.
Signed-off-by: Padmanabh Ratnakar <padmanabh.ratnakar@emulex.com>
Use OPCODE_COMMON_NTWK_RX_FILTER command for promiscous mode as
OPCODE_ETH_PROMISCUOUS command is getting deprecated.
In case of UE, do not dump registers for Lancer as they are not
supported.
Disable coalesce water mark mode of CQ for Lancer
In Lancer if a frame is DMAed partially due to lack of RX buffers,
an error completion is sent with packet size as zero and num_recvd
indicating number of used buffers. These buffers need to be freed
and packet dropped.
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-3.6
drivers/net/benet/be_main.c
TTY layer expects 0 if the ldisc->open operation succeeded.
Reported-by: Matvejchikov Ilya <matvejchikov@gmail.com>
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
Like other mobile broadband device ethernet interfaces, mark the LG
VL600 with the 'wwan' devtype so userspace knows it needs additional
configuration via the AT port before the interface can be used.
Signed-off-by: Dan Williams <dcbw@redhat.com>
Use the current logging styles.
Convert logging messages to more current styles.
Added -DDEBUG to Makefile to maintain current message logging.
This could be converted to a specific CONFIG_TULIP_DEBUG option.
Use the current more descriptive logging styles.
Add pr_fmt and remove PFX where appropriate.
Use netif_<level>, netdev_<level>
Indent a few blocks in xircom_cb where appropriate.
Change the blocks that are guarded by #if DEBUG to
be #if defined DEBUG && DEBUG > 1 so that pr_debug
can be used later.
Remove enter/leave macros and uses.
git://git.kernel.org/pub/scm/linux/kernel/git/romieu/netdev-2.6
Support new device OKI SEMICONDUCTOR ML7223 IOH(Input/Output Hub).
The ML7223 IOH is for MP(Media Phone) use.
The ML7223 is companion chip for Intel Atom E6xx series.
The ML7223 is completely compatible for Intel EG20T PCH.
Signed-off-by: Tomoya MORINAGA <tomoya-linux@dsn.okisemi.com>
mac_pton() parses MAC address in form XX:XX:XX:XX:XX:XX and only in that form.
mac_pton() doesn't dirty result until it's sure string representation is valid.
mac_pton() doesn't care about characters _after_ last octet,
it's up to caller to deal with it.
mac_pton() diverges from 0/-E return value convention.
Target usage:
if (!mac_pton(str, whatever->mac))
return -EINVAL;
/* ->mac being u8 [ETH_ALEN] is filled at this point. */
/* optionally check str[3 * ETH_ALEN - 1] for termination */
Use mac_pton() in pktgen and netconsole for start.
Pull read_lock(&bond->lock) and BOND_IS_OK() to bond_start_xmit() from
mode-dependent xmit functions.
netif_running() is always true in hard_start_xmit.
Unknown 8168 chips did not have any PLL power method set as they
did not inherit a default family soon enough. Fix it.
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
Cc: Realtek linux nic maintainers <nic_swsd@realtek.com>
- RTL_GIGA_MAC_NONE is a fake index so put it at the end of the
enumeration and shift everybody.
- RTL_GIGA_MAC_VER_17 / RTL_GIGA_MAC_VER_16 ordering fixed. Though
not wrong it was confusing enough to wonder if things were right.
Renaming rtl_chip_info was not strictly necessary. It allows to
check the patch for the correct use of the indexes though.
There is no real firmware version yet but the manpage of ethtool
is rather terse about the driver information.
Former output:
$ ethtool -i eth1
driver: r8169
version: 2.3LK-NAPI
firmware-version:
bus-info: 0000:01:00.0
$ ethtool -i eth0
driver: r8169
version: 2.3LK-NAPI
firmware-version:
bus-info: 0000:03:00.0
Current output:
$ ethtool -i eth1
driver: r8169
version: 2.3LK-NAPI
firmware-version: N/A
$ ethtool -i eth0
driver: r8169
version: 2.3LK-NAPI
firmware-version: rtl_nic/rtl8168d-1.fw
Fixed-by Ciprian Docan <docan@eden.rutgers.edu>
Cc: Fejes József <fejes@joco.name>
Cc: Borislav Petkov <borislav.petkov@amd.com>
Invocation of rtl8169_rx_interrupt from rtl8169_reset_task was originally
intended to retrieve as much packets as possible from the rx ring when a
reset was needed. Nowadays rtl8169_reset_task is only scheduled, with
some delay
a. from the tx timeout watchdog
b. when resuming
c. from rtl8169_rx_interrupt itself
It's dubious that the loss of outdated packets will matter much for a)
and b). c) does not need to call itself again.
The implementation was a bit krusty.
The 10s rtl8169_phy_timer timer has been (was ?) required with older
8169 for adequate phy operation when full gigabit is advertised in
autonegotiated mode. The timer does nothing if the link is up.
Otherwise it keeps resetting the phy until things improve.
- the device private data field phy_1000_ctrl_reg was used to
schedule the timer. Avoid it and save a few bytes.
- rtl8169_set_settings
pending timer is disabled before changing the link settings as
rtl8169_phy_timer is not always needed (see the removed test in
rtl8169_phy_timer).
- rtl8169_set_speed
the requested link parameters may not match the chipset : bail out
early on failure.
- rtl8169_open
Calling rtl8169_request_timer is redundant with
-> rtl8169_open
-> rtl8169_init_phy
-> rtl8169_set_speed
-> mod_timer
The latter always enables the phy timer whereas the former did not
for RTL_GIGA_MAC_VER_01. It should not make things worse but only
time will tell if reality agrees.
- rtl8169_request_timer : unused yet. Removed.
- rtl8169_delete_timer : useless. Bloat. Removed.
Side effect : the timer may kick in if the TBI is enabled. I do not
know if the TBI has ever been used in real life.
Shorten chipset version test.
No functional change.
Careful readers will notice that the 'supports_gmii' flag is deduced
from the device PCI id. Though less specific than the chipset related
RTL_GIGA_MAC_VER_XY, it is good enough to detect a GMII deprieved 810x.
Some features push for a device specific configuration (improved jumbo
frame support for instance). 'supports_gmii' will follow this path
if / when the device PCI id test stops working.
