path: root/drivers/net
2010-03-26ixgbe: cleanup maximum number of tx queuesJohn Fastabend
In the last patch I missed an unecessary min_t comparison. This patch removes it, the path allocates at most 72 tx queues for 82599 and 24 for 82598 there is no need for this check. Additionally this sets MAX_[TX|RX]_QUEUES to 72. Which is used as the size for the tx/rx_ring arrays. There is no reason to have more tx_rings/rx_rings then num_tx_queues. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-26ixgbe: Change where clear_to_send_flag is reset to zero.Greg Rose
The clear_to_send flag is being cleared before the call to ping all the VFs. It should be called after pinging all the VFs. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-26ixgbe: In SR-IOV mode insert delay before bring the adapter upGreg Rose
VFs running in guest VMs do not respond in as timely a manner to PF indication it is going down as they do when running in the host domain. If the adapter is in SR-IOV mode insert a two second delay to guarantee that all VFs have had time to respond to the PF reset. In any case resetting the PF while VFs are active should be discouraged but if it must be done then there will be a two second delay to help synchronize resets among the PF and all the VFs. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-26ixgbevf: Fix signed/unsigned int errorGreg Rose
In the Tx mapping function if a DMA error occurred then the unwind of previously mapped sections would improperly check an unsigned int if it was less than zero. Changed the index variable to signed to avoid the error. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-26netxen: update version to 4.0.73Amit Kumar Salecha
Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-26netxen: added sanity check for pci mapAmit Kumar Salecha
Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> Return value of ioremap is not checked, NULL check added. Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-26netxen: fix warning in ioaddr for NX3031 chipAmit Kumar Salecha
Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> crb_intr_mask/crb_sts_consumer is predefined for NX2031 not for NX3031. For NX3031, these values get defined in rx context creation. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-26netxen: fix bios version calculationAmit Kumar Salecha
Bios sub version from unified fw image is calculated incorrect. Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-26Revert "r8169: enable 64-bit DMA by default for PCI Express devices (v2)"David S. Miller
This reverts commit 353176888386d9025062a12dcec08d49af10cf2c. People are reporting problems due to this change and there is no anticipation that the cause will be tracked down any time soon. We can try next time to selectively re-enable this based upon chip type, or have a black list of some sort. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-25via-velocity: Fix FLOW_CNTL_TX_RX handling in set_mii_flow_control()David S. Miller
Clear, don't set, ANAR_ASMDIR in this case. Noticed by Roel Kluin. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-23igb: only use vlan_gro_receive if vlans are registeredAlexander Duyck
This change makes it so that vlan_gro_receive is only used if vlans have been registered to the adapter structure. Previously we were just sending all vlan tagged frames in via this function but this results in a null pointer dereference when vlans are not registered. [ This fixes bugzilla entry 15582 -Eric Dumazet] Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-23igb: do not modify tx_queue_len on link speed changeEmil Tantilov
Previously the driver tweaked txqueuelen to avoid false Tx hang reports seen at half duplex. This had the effect of overriding user set values on link change/reset. Testing shows that adjusting only the timeout factor is sufficient to prevent Tx hang reports at half duplex. Based on e1000e patch by Franco Fichtner <franco@lastsummer.de> Signed-off-by: Emil Tantilov <emil.s.tantilov@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-23igb: count Rx FIFO errors correctlyMitch Williams
Don't aggregate rx_no_buffer_count into rx_fifo_errors. RNBC counts packets that get queued temporarily in the adapter's FIFO. These packets are not dropped and are not errors. The correct counter is rx_missed_errors (MPC). Signed-off-by: Mitch Williams <mitch.a.williams@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-23bnx2: Use proper handler during netpoll.Michael Chan
Netpoll needs to call the proper handler depending on the IRQ mode and the vector. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-23bnx2: Fix netpoll crash.Benjamin Li
The bnx2 driver calls netif_napi_add() for all the NAPI structs during ->probe() time but not all of them will be used if we're not in MSI-X mode. This creates a problem for netpoll since it will poll all the NAPI structs in the dev_list whether or not they are scheduled, resulting in a crash when we access structure fields not initialized for that vector. We fix it by moving the netif_napi_add() call to ->open() after the number of IRQ vectors has been determined. Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-23ksz884x: fix return value of netdev_set_eepromJens Rottmann
ksz884x: fix return value of netdev_set_eeprom netdev_set_eeprom() confused ethtool by just returning 1 on error instead of a proper -EINVAL. Signed-off-by: Jens Rottmann <JRottmann@LiPPERTEmbedded.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-22netxen: The driver doesn't work on NX_P3_B1 so cause probe to fail.Eric W. Biederman
I haven't been able to get link up on a NX_P3_B1 since 2.6.31. The driver complains about a firmware hang instead. When I asked I was told rev 0x41 was a preproduction rev. So disable support in the driver so no one is surprised the code doesn't work. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-22can: bfin_can: switch to common Blackfin can headerMike Frysinger
The MMR bits are being moved to this header, so include it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (38 commits) ip_gre: include route header_len in max_headroom calculation if_tunnel.h: add missing ams/byteorder.h include ipv4: Don't drop redirected route cache entry unless PTMU actually expired net: suppress lockdep-RCU false positive in FIB trie. Bluetooth: Fix kernel crash on L2CAP stress tests Bluetooth: Convert debug files to actually use debugfs instead of sysfs Bluetooth: Fix potential bad memory access with sysfs files netfilter: ctnetlink: fix reliable event delivery if message building fails netlink: fix NETLINK_RECV_NO_ENOBUFS in netlink_set_err() NET_DMA: free skbs periodically netlink: fix unaligned access in nla_get_be64() tcp: Fix tcp_mark_head_lost() with packets == 0 net: ipmr/ip6mr: fix potential out-of-bounds vif_table access KS8695: update ksp->next_rx_desc_read at the end of rx loop igb: Add support for 82576 ET2 Quad Port Server Adapter ixgbevf: Message formatting cleanups ixgbevf: Shorten up delay timer for watchdog task ixgbevf: Fix VF Stats accounting after reset ixgbe: Set IXGBE_RSC_CB(skb)->DMA field to zero after unmapping the address ixgbe: fix for real_num_tx_queues update issue ...
2010-03-19KS8695: update ksp->next_rx_desc_read at the end of rx loopYegor Yefremov
There is no need to adjust the next rx descriptor after each packet, so do it only once at the end of the routine. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
2010-03-19igb: Add support for 82576 ET2 Quad Port Server AdapterCarolyn Wyborny
Signed-off-by: Carolyn Wyborny <carolyn.wyborny@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-19ixgbevf: Message formatting cleanupsGreg Rose
Clean up some text output formatting. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-19ixgbevf: Shorten up delay timer for watchdog taskGreg Rose
The recovery from PF reset works better when you shorten up the delay until the watchdog task executes. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-19ixgbevf: Fix VF Stats accounting after resetGreg Rose
The counters in the 82599 Virtual Function are not clear on read. They accumulate to the maximum value and then roll over. They are also not cleared when the VF executes a soft reset, so it is possible they are non-zero when the driver loads and starts. This has all been accounted for in the code that keeps the stats up to date but there is one case that is not. When the PF driver is reset the counters in the VF are all reset to zero. This adds an additional accounting overhead into the VF driver when the PF is reset under its feet. This patch adds additional counters that are used by the VF driver to accumulate and save stats after a PF reset has been detected. Prior to this patch displaying the stats in the VF after the PF has reset would show bogus data. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-19ixgbe: Set IXGBE_RSC_CB(skb)->DMA field to zero after unmapping the addressMallikarjuna R Chilakala
As per Simon Horman's feedback set IXGBE_RSC_CB(skb)->dma to zero after unmapping HWRSC DMA address to avoid double freeing. Signed-off-by: Mallikarjuna R Chilakala <mallikarjuna.chilakala@intel.com> Acked-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-19ixgbe: fix for real_num_tx_queues update issueVasu Dev
Currently netdev_features_change is called before fcoe tx queues setup is done, so this patch moves calling of netdev_features_change after tx queues setup is done in ixgbe_init_interrupt_scheme, so that real_num_tx_queues is updated correctly on each fcoe enable or disable. This allows additional fcoe queues updated correctly in vlan driver for their correct queue selection. Signed-off-by: Vasu Dev <vasu.dev@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: driver core: numa: fix BUILD_BUG_ON for node_read_distance driver-core: document ERR_PTR() return values kobject: documentation: Update to refer to kset-example.c. sysdev: the cpu probe/release attributes should be sysdev_class_attributes kobject: documentation: Fix erroneous example in kobject doc. driver-core: fix missing kernel-doc in firmware_class Driver core: Early platform kernel-doc update sysfs: fix sysfs lockdep warning in mlx4 code sysfs: fix sysfs lockdep warning in infiniband code sysfs: fix sysfs lockdep warning in ipmi code sysfs: Initialised pci bus legacy_mem field before use sysfs: use sysfs_bin_attr_init in firmware class driver
2010-03-19sysfs: fix sysfs lockdep warning in mlx4 codeGreg Kroah-Hartman
This fixes a sysfs lockdep warning in the mlx4 code. Cc: Yinghai Lu <yinghai@kernel.org> Cc: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-18smsc95xx: Fix tx checksum offload for small packetsSteve Glendinning
TX checksum offload does not work properly when transmitting UDP packets with 0, 1 or 2 bytes of data. This patch works around the problem by calculating checksums for these packets in the driver. Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-18ixgbe: Fix 82599 KX4 Wake on LAN issue after an improper system shutdownMallikarjuna R Chilakala
Advanced Power Management is disabled for 82599 KX4 connections by clearing GRC.APME bit, causing it to not wake the system from an improper system shutdown. By default GRC.APME is enabled and software is not supposed to clear these settings during adapter probe. Signed-off-by: Mallikarjuna R Chilakala <mallikarjuna.chilakala@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-18ixgbe: Fix 82599 multispeed fiber link issues due to Tx laser flappingMallikarjuna R Chilakala
Fix 82599 link issues during driver load and unload test using multi-speed 10G & 1G fiber modules. When connected back to back sometime 82599 multispeed fiber modules would link at 1G speed instead of 10G highest speed, due to a race condition in autotry process involving Tx laser flapping. Move autotry autoneg-37 tx laser flapping process from multispeed module init setup to driver unload. This will alert the link partner to restart its autotry process when it tries to establish the link with the link partner Signed-off-by: Mallikarjuna R Chilakala <mallikarjuna.chilakala@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-18Merge branch 'master' of ↵David S. Miller
2010-03-18jme: Advance driver version numberGuo-Fu Tseng
Advance driver version number after some bug fix. Signed-off-by: Guo-Fu Tseng <cooldavid@cooldavid.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-18jme: Protect vlgrp structure by pause RX actions.Guo-Fu Tseng
Temporary stop the RX IRQ, and disable (sync) tasklet or napi. And restore it after finished the vlgrp pointer assignment. Signed-off-by: Guo-Fu Tseng <cooldavid@cooldavid.org> Cc: stable@kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-18jme: Fix VLAN memory leakGuo-Fu Tseng
Fix memory leak while receiving 8021q tagged packet which is not registered by user. Signed-off-by: Guo-Fu Tseng <cooldavid@cooldavid.org> Cc: stable@kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-18KS8851: Avoid NULL pointer in set rx modeAbraham Arce
Kernel NULL pointer dereference when setting mode for IFF_MULTICAST. Tested on SDP OMAP4430 board. ks8851 spi1.0: message enable is 0 ks8851 spi1.0: revision 0, MAC f2:f4:2f:56:37:de, IRQ 194 Unable to handle kernel NULL pointer dereference at virtual address 00000000 pgd = c0004000 [00000000] *pgd=00000000 Internal error: Oops: 5 [#1] PREEMPT SMP last sysfs file: Modules linked in: CPU: 0 Not tainted (2.6.34-rc1-01039-g38d7ed1-dirty #3) PC is at ks8851_set_rx_mode+0x88/0x124 LR is at bitrev32+0x24/0x2c <snip> Backtrace: [<c01bfbd8>] ? (ks8851_set_rx_mode+0x0/0x124) [<c01d4164>] (__dev_set_rx_mode+0x0/0x90) [<c01dc460>] (dev_mc_add+0x0/0x78) [<c021f0bc>] (igmp_group_added+0x0/0x64) [<c021f174>] (ip_mc_inc_group+0x0/0x150) [<c021f3b8>] (ip_mc_up+0x0/0x64) [<c0219eb0>] (inetdev_event+0x0/0x3d4) [<c0066818>] (notifier_call_chain+0x0/0x78) [<c00668b8>] (__raw_notifier_call_chain+0x0/0x24) [<c00668dc>] (raw_notifier_call_chain+0x0/0x28) [<c01d7484>] (call_netdevice_notifiers+0x0/0x24) [<c01d7780>] (__dev_notify_flags+0x0/0x68) [<c01d77e8>] (dev_change_flags+0x0/0x4c) [<c001f0bc>] (ip_auto_config+0x0/0xf1c) [<c0028490>] (do_one_initcall+0x0/0x1bc) [<c00084dc>] (kernel_init+0x0/0x234) Code: e15130bc e1833012 e14130bc e5943000 (e5934000) ---[ end trace ed0fb00a94142792 ]--- Kernel panic - not syncing: Fatal exception in interrupt Signed-off-by: Abraham Arce <x0066660@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16l2tp: Fix UDP socket reference count bugs in the pppol2tp driverJames Chapman
This patch fixes UDP socket refcnt bugs in the pppol2tp driver. A bug can cause a kernel stack trace when a tunnel socket is closed. A way to reproduce the issue is to prepare the UDP socket for L2TP (by opening a tunnel pppol2tp socket) and then close it before any L2TP sessions are added to it. The sequence is Create UDP socket Create tunnel pppol2tp socket to prepare UDP socket for L2TP pppol2tp_connect: session_id=0, peer_session_id=0 L2TP SCCRP control frame received (tunnel_id==0) pppol2tp_recv_core: sock_hold() pppol2tp_recv_core: sock_put L2TP ZLB control frame received (tunnel_id=nnn) pppol2tp_recv_core: sock_hold() pppol2tp_recv_core: sock_put Close tunnel management socket pppol2tp_release: session_id=0, peer_session_id=0 Close UDP socket udp_lib_close: BUG The addition of sock_hold() in pppol2tp_connect() solves the problem. For data frames, two sock_put() calls were added to plug a refcnt leak per received data frame. The ref that is grabbed at the top of pppol2tp_recv_core() must always be released, but this wasn't done for accepted data frames or data frames discarded because of bad UDP checksums. This leak meant that any UDP socket that had passed L2TP data traffic (i.e. L2TP data frames, not just L2TP control frames) using pppol2tp would not be released by the kernel. WARNING: at include/net/sock.h:435 udp_lib_unhash+0x117/0x120() Pid: 1086, comm: openl2tpd Not tainted 2.6.33-rc1 #8 Call Trace: [<c119e9b7>] ? udp_lib_unhash+0x117/0x120 [<c101b871>] ? warn_slowpath_common+0x71/0xd0 [<c119e9b7>] ? udp_lib_unhash+0x117/0x120 [<c101b8e3>] ? warn_slowpath_null+0x13/0x20 [<c119e9b7>] ? udp_lib_unhash+0x117/0x120 [<c11598a7>] ? sk_common_release+0x17/0x90 [<c11a5e33>] ? inet_release+0x33/0x60 [<c11577b0>] ? sock_release+0x10/0x60 [<c115780f>] ? sock_close+0xf/0x30 [<c106e542>] ? __fput+0x52/0x150 [<c106b68e>] ? filp_close+0x3e/0x70 [<c101d2e2>] ? put_files_struct+0x62/0xb0 [<c101eaf7>] ? do_exit+0x5e7/0x650 [<c1081623>] ? mntput_no_expire+0x13/0x70 [<c106b68e>] ? filp_close+0x3e/0x70 [<c101eb8a>] ? do_group_exit+0x2a/0x70 [<c101ebe1>] ? sys_exit_group+0x11/0x20 [<c10029b0>] ? sysenter_do_call+0x12/0x26 Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16smsc95xx: wait for PHY to complete reset during initSteve Glendinning
This patch ensures the PHY correctly completes its reset before setting register values. Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16l2tp: Fix oops in pppol2tp_xmitJames Chapman
When transmitting L2TP frames, we derive the outgoing interface's UDP checksum hardware assist capabilities from the tunnel dst dev. This can sometimes be NULL, especially when routing protocols are used and routing changes occur. This patch just checks for NULL dst or dev pointers when checking for netdev hardware assist features. BUG: unable to handle kernel NULL pointer dereference at 0000000c IP: [<f89d074c>] pppol2tp_xmit+0x341/0x4da [pppol2tp] *pde = 00000000 Oops: 0000 [#1] SMP last sysfs file: /sys/class/net/lo/operstate Modules linked in: pppol2tp pppox ppp_generic slhc ipv6 dummy loop snd_hda_codec_atihdmi snd_hda_intel snd_hda_codec snd_pcm snd_timer snd soundcore snd_page_alloc evdev psmouse serio_raw processor button i2c_piix4 i2c_core ati_agp agpgart pcspkr ext3 jbd mbcache sd_mod ide_pci_generic atiixp ide_core ahci ata_generic floppy ehci_hcd ohci_hcd libata e1000e scsi_mod usbcore nls_base thermal fan thermal_sys [last unloaded: scsi_wait_scan] Pid: 0, comm: swapper Not tainted (2.6.32.8 #1) EIP: 0060:[<f89d074c>] EFLAGS: 00010297 CPU: 3 EIP is at pppol2tp_xmit+0x341/0x4da [pppol2tp] EAX: 00000000 EBX: f64d1680 ECX: 000005b9 EDX: 00000000 ESI: f6b91850 EDI: f64d16ac EBP: f6a0c4c0 ESP: f70a9cac DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068 Process swapper (pid: 0, ti=f70a8000 task=f70a31c0 task.ti=f70a8000) Stack: 000005a9 000005b9 f734c400 f66652c0 f7352e00 f67dc800 00000000 f6b91800 <0> 000005a3 f70ef6c4 f67dcda9 000005a3 f89b192e 00000246 000005a3 f64d1680 <0> f63633e0 f6363320 f64d1680 f65a7320 f65a7364 f65856c0 f64d1680 f679f02f Call Trace: [<f89b192e>] ? ppp_push+0x459/0x50e [ppp_generic] [<f89b217f>] ? ppp_xmit_process+0x3b6/0x430 [ppp_generic] [<f89b2306>] ? ppp_start_xmit+0x10d/0x120 [ppp_generic] [<c11c15cb>] ? dev_hard_start_xmit+0x21f/0x2b2 [<c11d0947>] ? sch_direct_xmit+0x48/0x10e [<c11c19a0>] ? dev_queue_xmit+0x263/0x3a6 [<c11e2a9f>] ? ip_finish_output+0x1f7/0x221 [<c11df682>] ? ip_forward_finish+0x2e/0x30 [<c11de645>] ? ip_rcv_finish+0x295/0x2a9 [<c11c0b19>] ? netif_receive_skb+0x3e9/0x404 [<f814b791>] ? e1000_clean_rx_irq+0x253/0x2fc [e1000e] [<f814cb7a>] ? e1000_clean+0x63/0x1fc [e1000e] [<c1047eff>] ? sched_clock_local+0x15/0x11b [<c11c1095>] ? net_rx_action+0x96/0x195 [<c1035750>] ? __do_softirq+0xaa/0x151 [<c1035828>] ? do_softirq+0x31/0x3c [<c10358fe>] ? irq_exit+0x26/0x58 [<c1004b21>] ? do_IRQ+0x78/0x89 [<c1003729>] ? common_interrupt+0x29/0x30 [<c101ac28>] ? native_safe_halt+0x2/0x3 [<c1008c54>] ? default_idle+0x55/0x75 [<c1009045>] ? c1e_idle+0xd2/0xd5 [<c100233c>] ? cpu_idle+0x46/0x62 Code: 8d 45 08 f0 ff 45 08 89 6b 08 c7 43 68 7e fb 9c f8 8a 45 24 83 e0 0c 3c 04 75 09 80 63 64 f3 e9 b4 00 00 00 8b 43 18 8b 4c 24 04 <8b> 40 0c 8d 79 11 f6 40 44 0e 8a 43 64 75 51 6a 00 8b 4c 24 08 EIP: [<f89d074c>] pppol2tp_xmit+0x341/0x4da [pppol2tp] SS:ESP 0068:f70a9cac CR2: 000000000000000c Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16smsc75xx: SMSC LAN75xx USB gigabit ethernet adapter driverSteve Glendinning
This patch adds a driver for SMSC's LAN7500 family of USB 2.0 to gigabit ethernet adapters. It's loosely based on the smsc95xx driver but the device registers for LAN7500 are completely different. Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16ne: Do not use slashes in irq name stringAtsushi Nemoto
This patch fixes following warning introduced by commit 12bac0d9f4dbf3445a0319beee848d15fa32775e ("proc: warn on non-existing proc entries"): WARNING: at /work/mips-linux/make/linux/fs/proc/generic.c:316 __xlate_proc_name+0xe0/0xe8() name 'RBHMA4X00/RTL8019' Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16NET: ksz884x, fix lock imbalanceJiri Slaby
Stanse found that one error path (when alloc_skb fails) in netdev_tx omits to unlock hw_priv->hwlock. Fix that. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Tristram Ha <Tristram.Ha@micrel.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16iwlwifi: Silence tfds_in_queue messageAdel Gadllah
Commit a239a8b47cc0e5e6d7416a89f340beac06d5edaa introduced a noisy message, that fills up the log very fast. The error seems not to be fatal (the connection is stable and performance is ok), so make it IWL_DEBUG_TX rather than IWL_ERR. Signed-off-by: Adel Gadllah <adel.gadllah@gmail.com> Cc: stable@kernel.org Acked-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-16ath9k: fix BUG_ON triggered by PAE framesFelix Fietkau
When I initially stumbled upon sequence number problems with PAE frames in ath9k, I submitted a patch to remove all special cases for PAE frames and let them go through the normal transmit path. Out of concern about crypto incompatibility issues, this change was merged instead: commit 6c8afef551fef87a3bf24f8a74c69a7f2f72fc82 Author: Sujith <Sujith.Manoharan@atheros.com> Date: Tue Feb 9 10:07:00 2010 +0530 ath9k: Fix sequence numbers for PAE frames After a lot of testing, I'm able to reliably trigger a driver crash on rekeying with current versions with this change in place. It seems that the driver does not support sending out regular MPDUs with the same TID while an A-MPDU session is active. This leads to duplicate entries in the TID Tx buffer, which hits the following BUG_ON in ath_tx_addto_baw(): index = ATH_BA_INDEX(tid->seq_start, bf->bf_seqno); cindex = (tid->baw_head + index) & (ATH_TID_MAX_BUFS - 1); BUG_ON(tid->tx_buf[cindex] != NULL); I believe until we actually have a reproducible case of an incompatibility with another AP using no PAE special cases, we should simply get rid of this mess. This patch completely fixes my crash issues in STA mode and makes it stay connected without throughput drops or connectivity issues even when the AP is configured to a very short group rekey interval. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Cc: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-16wl1251: fix potential crashGrazvydas Ignotas
In case debugfs does not init for some reason (or is disabled on older kernels) driver does not allocate stats.fw_stats structure, but tries to clear it later and trips on a NULL pointer: Unable to handle kernel NULL pointer dereference at virtual address 00000000 PC is at __memzero+0x24/0x80 Backtrace: [<bf0ddb88>] (wl1251_debugfs_reset+0x0/0x30 [wl1251]) [<bf0d6a2c>] (wl1251_op_stop+0x0/0x12c [wl1251]) [<bf0bc228>] (ieee80211_stop_device+0x0/0x74 [mac80211]) [<bf0b0d10>] (ieee80211_stop+0x0/0x4ac [mac80211]) [<c02deeac>] (dev_close+0x0/0xb4) [<c02deac0>] (dev_change_flags+0x0/0x184) [<c031f478>] (devinet_ioctl+0x0/0x704) [<c0320720>] (inet_ioctl+0x0/0x100) Add a NULL pointer check to fix this. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Acked-by: Kalle Valo <kalle.valo@iki.fi> Cc: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-15Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2010-03-15myri: remove dead codeDan Carpenter
We can never reach the return statement. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-15obsolete config in kernel source: HSO_AUTOPMChristoph Egger
CONFIG_HSO_AUTOPM is set by KConfig / set in the Kernel source, makefiles and won't be ever set this way, therefor simply removing the protected code. Signed-off-by: Christoph Egger <siccegge@stud.informatik.uni-erlangen.de> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-15obsolete config in kernel source: USE_INTERNAL_TIMERChristoph Egger
CONFIG_USE_INTERNAL_TIMER seems to be the remainings of some experiment. It is explicitely #undef-ed as not working, only referenced from one source file and rather aged. Hereby cleaning it from the kernel tree. Signed-off-by: Christoph Egger <siccegge@stud.informatik.uni-erlangen.de> Acked-by: Roel Kluin <roel.kluin@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-15drivers/net: drop redundant memsetJulia Lawall
The region set by the call to memset is immediately overwritten by the subsequent call to memcpy. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression e1,e2,e3,e4; @@ - memset(e1,e2,e3); memcpy(e1,e4,e3); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
