As I just discovered while doing WoWLAN, HW crypto
is done wrong for GTKs: they should be programmed
for the AP station ID (in the managed mode case)
and the HW can actually deal with multiple group
keys per station as well (which is useful in IBSS
RSN but that I've chosen not to use this).
To fix all this, modify the way keys are sent to
the device and key offsets are allocated. After
these changes, key offsets are stored into the
hw_key_idx which we can then track for the key
lifetime, not relying on our sta_cmd array. WEP
default keys get special treatment, of course.
Additionally, since I had the API for it, we can
now pre-fill TKIP phase 1 keys for RX now that we
can obtain the P1K from mac80211, a capability I
had added for WoWLAN initially.
Finally, some keys simply don't need to be added
into the device's key cache -- a key that won't
be used for RX is only needed in the TX header,
so "pretend" to have accepted any key without
adding it into the device -- no need to use up
key space there for it.
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
It seems that due to merge issues between different
trees or so this function prototype wasn't removed
when it should have been, do it now.
After driver split, extra _agn in priv structure is no needed, remove it.
iwlagn keeps a copy of key stuff internally but
never actually uses it, so remove it.
Move tm_fixed_rate inside CONFIG_IWLWIFI_DEVICE_SVTOOL and only
available when the option is enable.
WoWLAN may need the NIC even after suspend. One should not do anything to the
NIC in the bus level, since one cannot check whether WoWLAN is enabled or not.
Same for resume.
Add a simple comment to the code to warn about this.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
The price to pay is the access to the log system. Therefore logs from bus layer
are sent by dev_printk instead of IWL_XXXX.
Rename bus->priv to bus->drv_data to make the separation even clearer.
Call iwl_probe with a ready iwl_bus struct. This means that the bus layer
assigns the irq, dev and iwl_bus_ops pointers to iwl_bus before giving it to
iwl_probe.
The device specific struct is allocated together with the common iwl_bus struct
by the bus specific layer. The pointer to the aggregate struct is passed to the
upper layer that holds a pointer to iwl_bus instead of an embedded iw_bus.
The private data given to the PCI subsystem is now iwl_bus and not iwl_priv.
Provide bus_* inliners on the way in order to simplify the syntax.
Rename iwl-pci.h -> iwl-bus.h since it is bus agnostic and represent the
external of the bus layer.
It still holds a pointer to iwl_priv. But hopefully this will disappear at some point.
Also add the multiple inclusion protection to iwl-trans.h that was forgotten.
Move iwl-trans structures to iwl-trans.h
This function is really related to the transport layer - move it.
Basically all the nic_init flow should be in the transport layer.
iwl_prepare_card_hw will move to the transport too in a separate patch.
All the configurations of the HW for AMPDU are now in the transport layer.
For temperature offset calibration, send radio sensor offset in le16 format
Use the valid calibration mask for init calibration
IWL_PHY_CALIBRATE_DIFF_GAIN_CMD is for legacy device, remove it
Set calibration config flag for complete notification
Since iwlagn_setup_deferred_work is always called, fold it into
iwl_setup_deferred_work. BT related works are setup by the new
bt_setup_deferred_work lib_ops.
Signed-off-by: Wey-Yi Guy <wey-yi.guy@intel.com>
Since iwlagn_rx_handler_setup is always called, fold it into
iwl_rx_handler_setup. BT related handlers are setup by the new
bt_rx_handler_setup lib_ops.
kick_nic means to remove the RESET bit from the embedded CPU
Previously, the mesh was running whenever the appropriate hardware
and firmware was present.
Now we only run the mesh when the interface is running.
Also simplifies interface management a little.
Signed-off-by: Daniel Drake <dsd@laptop.org>
Acked-by: Dan Williams <dcbw@redhat.com>
Remove unused blindlist code.
Mark a few items const and static where possible. Involved some
code re-ordering, but no code changes.
Cc: Bing Zhao <bzhao@marvell.com>
Cc: "Luis R. Rodriguez" <lrodriguez@atheros.com>
Cc: ath9k-devel@lists.ath9k.org
Cc: Larry Finger <Larry.Finger@lwfinger.net>
Signed-off-by: Pavel Roskin <proski@gnu.org>
Acked-by: Christian Lamparter <chunkeey@googlemail.com>
Both ath5k_hw and ath5k_softc represent one instance of the hardware.
This duplication is historical and is not needed anymore.
Keep the name "ath5k_hw" for the merged structure and "ah" for the
variable pointing to it. "ath5k_hw" is shorter than "ath5k_softc", more
descriptive and more widely used.
Put the combined structure to ath5k.h where the old ath5k_softc used to
be. Move some code from base.h to ath5k.h as needed.
Remove memory allocation for struct ath5k_hw and the corresponding error
handling. Merge iobase and ah_iobase fields.
Acked-by: Nick Kossifidis <mickflemm@gmail.com>
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
Some of the newer Broadcom chipsets have longe names like BCM43224,
BCM43225, etc. However Broadcom decided to keep using u16 for storing
them. Use %X or %d depending on chip_id value to avoid BCMA8D8, etc.
Acked-by: Pavel Roskin <proski@gnu.org>
Old masks were causing ugly, delayed lock ups.
Following operation was incorrectly translated:
radio_read(0x0011) -> 0xffff
radio_write(0x0011) <- 0xfff7
Also change the default channel to 11. This is the first channel closed
driver switches to.
BCMA_IOCTL is register in agent (AKA wrapper) core, we need to use
special R/W ops for it.
drivers/net/wireless/ath/ath9k/hif_usb.c +135 hif_usb_mgmt_cb(6) warn:
variable dereferenced before check 'cmd'
drivers/net/wireless/ath/ath9k/btcoex.c +77 ath9k_hw_init_btcoex_hw(38)
error: buffer overflow 'ah->hw_gen_timers.gen_timer_index' 32 <=
2009813776
Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com>
drivers/net/wireless/ath/ath9k/init.c:199:21: warning: context imbalance
in 'ath9k_reg_rmw' - different lock contexts for basic block
drivers/net/wireless/ath/ath9k/xmit.c:1175:31: warning: context
imbalance in 'ath_drain_txq_list' - unexpected unlock
drivers/net/wireless/ath/ath9k/xmit.c:2047:23: warning: context
imbalance in 'ath_tx_process_buffer' - unexpected unlock
drivers/net/wireless/ath/ath9k/ar9003_eeprom.c:3041:24: warning: cast to
restricted __le32
We use all that functions by pointers only. This forces compiler to
create additional duplicated functions that are not inline.
Noticed by Michael in similar bcma code.
Harshal Chhaya discovered during network tests, that
several of his clients dropped-off the network. The
captured packets shows that the beacons sent by the
AP are at a much lower power than the other data
packets.
The reason for this mishap: The driver never updated
the beacon phy register, so all beacons were always
sent at the lowest power.
Reference: http://marc.info/?l=linux-wireless&m=131067225105801
Reported-by: Harshal Chhaya <harshal@gmail.com>
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
* reserves feature bit for CCA counters
* extends hardware register file definitions
tx start will start the tx queues: basically configure the SCD
Remove the IWLAGN prefix to SCD defines on the way.
Since the ICT is transport related, move all its functions to the transport
layer.
Since iwlagn_stop_device was the only caller to the rx_stop / tx_stop,
these two don't need to be API any more.
There are still a few functions here and there that should be
put in the transport layer. Mainly the functions that are related to the reclaim flow.
Also create a new file: iwl-trans-int-pcie.h which will include
the non static functions that are shared among the current pcie transport layer.
