For newer devices, uCode provide both "number of frames sent"
and "number of frames acked" information inside the compressed_ba
packet. So instead of figure the success/failure information through
the bitmap, use those information which is much betrer approach.
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
This patch replaces the handcrafted
sign extension cruft with a generic
bitop function.
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
This patch moves code out from wireless drivers where two different
functions are defined in three code locations for the same purpose and
provides a common function to sign extend a 32-bit value.
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com>
Make use the newly added method to pass platform data for wl1251 too.
This allows to eliminate some redundant code.
Cc: Ohad Ben-Cohen <ohad@wizery.com>
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
Acked-by: Kalle Valo <kvalo@adurom.com>
Acked-by: Luciano Coelho <luciano.coelho@nokia.com>
Add runtime PM support, similar to how it's done for wl1271.
This allows to power down the card when the driver is loaded but
network is not in use.
Call interface specific power callback before calling board specific
one. Also allow that callback to fail. This is how it's done for
wl1271 and will be used for runtime_pm support.
For 6000 series devices and up, enable automatic update MAC's register
for better power usage in PSP mode
Disconnected antenna algorithm is used to find out which antennas are
disconnected. It should be disabled for devices that support advanced
bluetooth coexist.
Signed-off-by: Shanyu Zhao <shanyu.zhao@intel.com>
Disconnected antenna algorithm is seperated into its own function from chain noise
calibration routine for better code management.
When the HT information is changed due to
BSS changes (like legacy stations joining)
we need to recalculate HT RXON parameters.
During the RXON rewrite, this code got lost.
When we've just associated, we need to enable
all calibrations and see if some were already
finished. Add back the missing code.
The RXON rework resulted in a massive loss of
throughput because we weren't programming the
device completely correctly -- the BSSID has
to be programmed into the device before the
AP station is uploaded. To fix this, simply
always send the unassoc RXON, i.e. even when
it was already unassoc so that the BSSID and
some other parameters are updated properly.
Garen noticed that this was wrong. Fix
the calibration -- default to multiple
chains and fall back to single where
possible.
"mac80211: Fix WMM driver queue configuration"
inadvertedly broke iwlwifi, because now mac80211
configures the QoS settings before assoc, and
therefore before HT. Thus, iwlwifi no longer told
the device about the HT setting, which it needs
to -- and thus throughput went down a lot. Fix
this by resending the QoS command to the device
not only when QoS/WMM settings change, but also
when HT changes.
In iwl_rx_queue_update_write_ptr function
replace iwl_write_direct32 with iwl_write32 when not in power save mode.
We don't have to go through grab nic access as the NIC is already awake.
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
Legacy (4965 and 3945) devices has different tx_cmd_protection routine.
Move to iwl-legacy.c
There were two type of isr supported by iwlwifi devices.
legacy isr - only used by legacy devices (3945 & 4965)
ict isr - used by all new generation of iwlwifi devices
Move all the isr related functions into ops, the ict type of isr
supports only needed for newer devices.
Move iwl_isr_legacy function to iwl_legacy.c since it only used
by legacy devices.
When building 4965 without 5000+ there were a
lot of build errors due to functions being used
that weren't even compiled in. To fix this move
some code around and only compile the HCMD code
for 5000+ series as it's not used for 4965.
Update the supported PCI ID list for 100 series devices
Update the supported PCI ID list for 6000g2a series devices
Update the supported PCI ID list for 6000g2b series devices
The debugfs code for ath5k was printing some unsigned int
stats with %d instead of %u. This meant that you could see
negative numbers instead of a clean wrap.
Signed-off-by: Ben Greear <greearb@candelatech.com>
Add watchdog functions for managing the Queues inside the hardware.
Normally the driver doesn't have much to do with these queues
directly, but the Ralink drivers did implement watchdog functions
for these. These watchdog functions are not triggered that often,
compared to the other watchdog functions, but I have at least
seen them trigger once or twice during a long stresstest run.
v2: Add extra documentation for register fields
Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com>
Acked-by: Gertjan van Wingerde <gwingerde@gmail.com>
As part of the queue refactoring, the rt2x00lib_toggle_rx
can be removed and replaced with the call directly to
the set_device_state callback function.
We can remove the STATE_RADIO_RX_ON_LINK and
STATE_RADIO_RX_OFF_LINK, as it was only used for
special behavior inside rt2x00lib rather then the
drivers.
The queue_entry argument to rt2x00queue_kick_tx_queue,
doesn't make sense due to the function name (it is called
kick QUEUE)... But neither do we need the queue_entry, since
we need the data_queue.
Acked-by: Helmut Schaa <helmut.schaa@googlemail.com>
The queue->lock is only used to protect the index
numbers. Rename the lock accordingly.
rt73usb.c:43: ERROR: do not initialise statics to 0 or NULL
Signed-off-by: Mark Einon <mark.einon@gmail.com>
rt2x00queue.c:804: ERROR: space prohibited after that open parenthesis '('
rt2x00queue.c:805: ERROR: space prohibited before that close parenthesis ')'
rt2x00link.c:70: ERROR: space prohibited before that close parenthesis ')'
rt2x00lib.h:60: ERROR: space prohibited after that open parenthesis '('
rt2x00lib.h:60: ERROR: space prohibited before that close parenthesis ')'
rt2x00dev.c:689: ERROR: spaces required around that '=' (ctx:WxV)
rt2x00config.c:136: ERROR: space required before the open parenthesis '('
rt2800usb.h:43: ERROR: space prohibited after that open parenthesis '('
rt2800usb.h:43: ERROR: space prohibited before that close parenthesis ')'
rt2800usb.h:44: ERROR: space prohibited after that open parenthesis '('
rt2800usb.h:44: ERROR: space prohibited before that close parenthesis ')'
rt2800usb.c:48: ERROR: do not initialise statics to 0 or NULL
rt2800pci.h:41: ERROR: Macros with complex values should be enclosed in parenthesis
rt2800pci.h:42: ERROR: Macros with complex values should be enclosed in parenthesis
rt2800pci.h:43: ERROR: Macros with complex values should be enclosed in parenthesis
rt2800pci.h:44: ERROR: Macros with complex values should be enclosed in parenthesis
rt2800pci.h:55: ERROR: space prohibited after that open parenthesis '('
rt2800pci.h:55: ERROR: space prohibited before that close parenthesis ')'
rt2800pci.h:56: ERROR: space prohibited after that open parenthesis '('
rt2800pci.h:56: ERROR: space prohibited before that close parenthesis ')'
rt2800lib.c:831: ERROR: inline keyword should sit between storage class and type
rt2800.h:1511: ERROR: space prohibited after that open parenthesis '('
rt2800.h:1511: ERROR: space prohibited before that close parenthesis ')'
rt2800.h:1513: ERROR: space prohibited after that open parenthesis '('
rt2800.h:1513: ERROR: space prohibited before that close parenthesis ')'
rt2800.h:1515: ERROR: space prohibited after that open parenthesis '('
rt2800.h:1515: ERROR: space prohibited before that close parenthesis ')'
rt2800.h:1517: ERROR: space prohibited after that open parenthesis '('
rt2800.h:1517: ERROR: space prohibited before that close parenthesis ')'
rt2800.h:1519: ERROR: space prohibited after that open parenthesis '('
rt2800.h:1519: ERROR: space prohibited before that close parenthesis ')'
rt2800.h:1521: ERROR: space prohibited after that open parenthesis '('
rt2800.h:1521: ERROR: space prohibited before that close parenthesis ')'
rt2800.h:1661: ERROR: space prohibited after that open parenthesis '('
rt2800.h:1661: ERROR: space prohibited before that close parenthesis ')'
rt2800.h:1662: ERROR: space prohibited after that open parenthesis '('
rt2800.h:1662: ERROR: space prohibited before that close parenthesis ')'
rt2800.h:1663: ERROR: space prohibited before that close parenthesis ')'
rt2800.h:2013: ERROR: space prohibited after that open parenthesis '('
rt2800.h:2013: ERROR: space prohibited before that close parenthesis ')'
rt2800.h:2014: ERROR: space prohibited after that open parenthesis '('
rt2800.h:2014: ERROR: space prohibited before that close parenthesis ')'
rt2500usb.c:42: ERROR: do not initialise statics to 0 or NULL
rt2500pci.h:1091: ERROR: space prohibited after that open parenthesis '('
rt2500pci.h:1091: ERROR: space prohibited before that close parenthesis ')'
rt2500pci.h:1092: ERROR: space prohibited after that open parenthesis '('
rt2500pci.h:1092: ERROR: space prohibited before that close parenthesis ')'
rt2400pci.h:812: ERROR: space prohibited after that open parenthesis '('
rt2400pci.h:812: ERROR: space prohibited before that close parenthesis ')'
rt2400pci.h:813: ERROR: space prohibited after that open parenthesis '('
rt2400pci.h:813: ERROR: space prohibited before that close parenthesis ')'
rt2400pci.h:950: ERROR: Macros with complex values should be enclosed in parenthesis
This patch fixes a few shortcomings in the tx path.
* move temp. ampdu_[ack]_len out of txinfo->pad.
* fix WARN_ON from tx.c:line 300 when tx_ampdu_queue
fails to queue the frame.
* In tx_prepare, we already have a local pointer
to the station's ieee80211_sta struct.
* remove a second !sta check, tx_prepare already takes
care of that.
This patch fixes a few comments in rt73usb.h and rt61pci.h.
Signed-off-by: Lalith Suresh <suresh.lalith@gmail.com>
The BSSID register shouldn't be set in AP mode on some older devices (like
rt73usb) as it breaks hw crypto on these. However, rt2800 devices explicitly
need the BSSID register set to the same value as our own MAC address (only
in AP mode).
Hence, don't set the BSSID from rt2x00lib but move it down into rt2800 to
avoid problems on older devices.
This fixes a regression (at least for rt73usb) and avoids a new regression
for rt2800 devices in 2.6.36.
Reported-by: Johannes Stezenbach <js@sig21.net>
Reported-by: Lee <lee-in-berlin@web.de>
Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com>
By not scheduling the TX/RX completion worker threads
when Radio is disabled, or hardware has been unplugged,
the queues cannot be completely cleaned.
This causes crashes when the hardware has been unplugged while
the radio is still enabled.
Legacy driver uses 0xff as the second argument for the MCU_SLEEP
command. It is still unknown what the values actually mean, but
this will at least keep the command in-sync with the original
driver.
Implement a basic flush callback function, which simply loops
over all TX queues and waits until all frames have been transmitted
and the status reports have been gathered.
At this moment we don't support dropping any frames during the
flush, but mac80211 will only send 'false' for this argument anyway,
so this is not important at this time.
When the TX status handler failed to clear the queue
in rt2x00usb_watchdog_tx_dma() we shouldn't use a failsave
to use the rt2x00usb txdone handler.
If a driver has overriden the txdone handler it must make
sure the txdone handler is capable of cleaning up the queue itself.
Rename rt2x00queue_timeout to rt2x00queue_status_timeout to
better describe what is actually timing out (note that
we already have a rt2x00queue_dma_timeout).
When rt2x00 is compiled with debugging but frame dumping is currently
not active we can avoid the call to do_gettimeofday. Furthermore,
frame dumping is not the default case, mark it as unlikely.
